PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 [93] 94 95 96 97 98 99 100 101 102
  1. Sig Kouger Mk.II
  2. 4 strokes for the Tracer?
  3. Perry Pump Question
  4. doubts about planes specs.
  5. Tail holder
  6. GP Shoestring and TH .75
  7. Plane for a OS 26?
  8. 80" Lanier Cap 232 wing flutter.
  9. super tiger .61, just wont stop, help
  10. camera on board, how to do it?
  11. Setup pull-pull with bellcrank
  12. JR Max 4 AM
  13. loading up and dying
  14. Midwest AT-6 Texan Flaps
  15. Sonic-tronic GAS Pump
  16. Cleaning .42 Engine
  17. Airplane flying question
  18. how do you make wing struts
  19. Wing Stuts
  20. gyros for planes?
  21. Spring air retracts bending
  22. Calculation of side thrust deg
  23. FMA Dual conversion reciever
  24. Prop Size on 50 Engine
  25. CAP 232 wing connection????
  26. CA glue sickness!
  27. styro-foam safe paint?
  28. How best to determine Height/Altitude
  29. Charlie Chamberts
  30. ? On hovering, engine mont
  31. Aresti 40 with .61
  32. stuck on ultrcoat
  33. Removing Monokote glue?
  34. Composite Propellers?
  35. Elevator Flutter
  36. Rv4
  37. Looking for flyers in Olney, Illinois area
  38. Turbo-jet In Cowl Mufflers
  39. Hanger9 30 minute epoxy question
  40. Help w/ Digital Picture posting
  41. gp at6 texan arf v/s ys 91 ac
  42. Ultrastick Radio Setup
  43. 6v for reciever
  44. Hinges?
  45. LT vs PT
  46. Need help to identify two rc models
  47. If your firebird/aerobird doesn't fly straight
  48. Are Eye Dropper applicators reusable?
  49. brushless motor for wattage cap 232
  50. prop question
  51. what are these things on the tips of a wing
  52. What is it?
  53. what oil to use for smoke??
  54. Best way to pin hinges
  55. ziroli AT-6 info needed
  56. what paint matches ultracote deep blue?
  57. 84 in Stinger!
  58. How Many Turns Should The Low End Neddle Be Out On A Webra Speed 61
  59. Getting warps out of ARF parts
  60. stearman
  61. Model shop in the Boston area
  62. Duralite battery/charger..new to me ...(((help
  63. good tachometer
  64. Blitz Gas Cans
  65. Ram vs. Glowire???
  66. 1/4 Scale Goldberg Piper Cub
  67. Help
  68. Float Planes
  69. Thinking of a Smaller ARF Trainer for Diesel ?
  70. making tail wheel assembly.
  71. How can I tint my canopy??
  72. Heat and Glue
  73. heli engine in a plane ???
  74. whats the best way to join metal
  75. field charger
  76. GP Extra 300S .60/ Engine
  77. Taube 40 control throws & CofG
  78. Sig Hog Bipe and 4* 40 balancing
  79. best everyday plane?
  80. Weight scale
  81. Remove fuel from Balsa.
  82. Thrust?
  83. *****belt It Out*****
  84. Top Flite LustreKote? Why don't this make sence
  85. I'm looking for carbon fiber Ultracote.
  86. help with picking the right size servos
  87. Wheels/Main Gear
  88. Dave Patrick 540T Edge
  89. Removing trim tape
  90. How can I find the C.G of Pitts?
  91. How can I find the C.G of Pitts?
  92. Carl Goldberg Extra
  93. question about "sealing hinges". . .
  94. fish eyes
  95. wing span or wing area
  96. 4*60 Fuselage Seperation
  97. Strange and sudden Rx problem
  98. Help ID purple&chartruse extra
  99. Electric fuel pumps
  100. CF Rod on Throttle ?
  101. Running in
  102. Clearcoat in aerosol cans??
  103. Carrying large planes on top of a pop-up camper....
  104. hing gap sealing
  105. Nor Cal Aero, Continental
  106. Logo Websites??
  107. definition of torque?
  108. Where can I buy Hallco landing gear on-line?
  109. I want the Fighterbird Sonic Gun to work on an Aerobird
  110. Finding a lost plane
  111. Brakes
  112. Canard Stabilizer Failure!
  113. Monokote Matching Paint
  114. Lazy Bee downthrust
  115. floats
  116. BEST PAINT NEED help
  117. painting foam
  118. futaba reciver
  119. cg extra 300 any dihedral?
  120. Diesel
  121. Floats for 1/4 scale Aeronca Champ
  122. Trying to locate Lee Taylor
  123. Must be a better way.
  124. 22-6 prop?
  125. From trike to tail dragger
  126. Robart retract problem
  127. Help Please!!
  128. monokote and wax?
  129. electronic mixer
  130. Primer for Perfect Paint
  131. Can this receiver antenna be fixed?
  132. Ramtec fan
  133. Exploding Covering...
  134. programming flaps on a 9C w/dual elev. servos
  135. airtronics reciever anteana
  136. What is the difference between a 14X6 pattern and 14X6 sport propeller?
  137. Pneumatic retract fill valve
  138. 46FX or 50SX for GP Tracer
  139. A couple of Smoke System install ??'s
  140. Futaba FF7 ?????
  141. F3b
  142. wm extra 300
  143. receiver
  144. looking for bolt size
  145. I want to hear from owners of seductions..
  146. Servos?????
  147. Tune Pipes
  148. Whiplash engine
  149. HP40 muffler???
  150. Best Price On Saito 56 Muffler?
  151. CG Sig 1/4 scale cub
  152. Canopy for a super chipmunk
  153. Stick 60 Landing Gear Issues
  154. Pusher and 3 point UC, good idea?:S
  155. Home-made Flying Wires?
  156. hanger rash
  157. Where i can find spark plugs with 1/4-32 tread?
  158. Sheeting Foam
  159. Goldberg Staudacher problems...
  160. Field Flight Box/Stand
  161. Aluminum Spinner Question
  162. tygon tubing and smoke system
  163. patching fabric?
  164. Need Help Selecting a Charger
  165. Flight Simulator for Mac
  166. Prop Size ?
  167. Center Mark Inc
  168. Fuel draw engine failure
  169. Ams oil 2000, and Klots
  170. what's in your collection??
  171. Tiger 2 Taildragger Conversion
  172. What is Negative and Possitive Shift?
  173. Landing Gear wire
  174. How much does Monokote weigh??
  175. Got an Airvista from a Friend <help>
  176. zenoah 38 exhaust
  177. Incidence Balance
  178. Swallow. C G Help
  179. minicraft hobby table saw are they any good?
  180. Moki 2.1 and Tru-Turn Spinner.
  181. Saito FA-100 Engine Run-in
  182. Paris boat club
  183. Dual tanks on H9 P51 w/Saito 100 & Robart pump
  184. Nylon Covering
  185. Rossi .53 engine
  186. Tires, rubber, foam, and others.
  187. Battery dies too easy?
  188. Polishing Aluminum Spinners?
  189. What is this thing on the wing for?
  190. Weight of Goldberg Super Chipmunk Wing?
  191. Drilling and Painting Carbon Fiber Landing Gear
  192. h-9 taylorcraft wing
  193. Lazy Bee throws
  194. Kyoso AP29L-V with fan unit
  195. solder flux =acid
  196. battery noise
  197. battery cyclers
  198. Transmitter Case
  199. radio interference, flying wires, wing rigging.
  200. Stainless steel
  201. mounting cowlings
  202. Brisson 3.2 question NEED HELP QUICK
  203. Non ripoff site?
  204. Engine Mount Thrust Plates
  205. Have you ever used Flaperons?
  206. scroll saw
  207. Anybody know if someone makes a rocket powered airplane?
  208. Geolon Woven Geotextile Runways
  209. need help
  210. Perry Pump
  211. Building Board
  212. f4u corsair
  213. Will it fit?????
  214. Ohio CAP 232 72" Wing CG Help
  215. Sport plane identification
  216. National Balsa Company
  217. Goldberg Ultimate Biplane CG location
  218. First Jet
  219. Electrical Help Please
  220. Can you NAME THIS PLANE?
  221. Incidence Problem/Suggestions
  222. How warped can a wing be?
  223. prop size question
  224. Best second plane
  225. FLat spins
  226. os .61 sf question
  227. HELP!-How Do I Cut Aluminum Spinners?
  228. HOB AT-6 Texan --- CG?
  229. How do you remove lock-tight???
  230. engine size?
  231. Strange or funny field repairs
  232. Plane weight to engine size
  233. Why do foamies cost so much!
  234. Remote glow driver help
  235. Shopping in Boston...
  236. What do you consider a fun fly plane
  237. Paint to match ultra coat
  238. weight of 1/4 scale pup
  239. zagi hesitates
  240. Need bulk kevlar thread, braided about 1mm diameter. Where?
  241. Engine Breakin: w or W/o stock muffler
  242. cap 232 problem
  243. Super Sportster
  244. Looking for second plane!
  245. Any Online R/C Shops that take PAYPAL??
  246. web site for carbon fiber landing gear
  247. cars and planes @ same site
  248. large engine starters
  249. H9 Titanium Pro Links???
  250. Mounting an engine inverted.
