PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 [94] 95 96 97 98 99 100 101 102
  1. Calculating CG
  2. Tx makes PC moniter buzz
  3. 40 size edge?
  4. edge 540t
  5. How small pieces do you save?
  6. Glassing with Water based urethane
  7. servo: oz/in to pounds
  8. World Models pt26
  9. Don't know what kind of plane this is huge wingspan
  10. Field box?
  11. repairing engine mount flanges
  12. Zen 30 Cg
  13. Forte Wooden Props?
  14. covering with coverall
  15. spray gun.
  16. Does ca glue go bad if old
  17. Super Coverite
  18. Which servos to use???
  19. World Models Super Chipmunk
  20. graphics
  21. Is This AM Radio Ok to Use Still?
  22. Chrome Ultracote or MonoCote
  23. Help with aileron differential
  24. Uproar 40 & 60 - Comparison?
  25. Dual tank, 1 engine - How to?
  26. incedence
  27. Alerons
  28. Can monokote fumes make you sick?
  29. Super Aeromaster .60 size biplane
  30. Hobbico Retracts Useless... Now what?
  31. Transparency of Ultracote Pearls
  32. Glow r/c airplane locations in the Bay Area?
  33. Canopy Painting / Tinting
  34. Starting a Hobby shop business?
  35. K&b .screemen .48
  36. MPI Miracle Switch?
  37. Which magazines do you read?
  38. *
  39. 3rd Nipple
  40. bi-plane question (Phaeton)
  41. Where can I find a YAK-3,7 or 9 mdel kit?
  42. Li-on charger
  43. Smart Fly company and the equalizer
  44. Control horn attachment
  45. Great Planes Dazzler 40 ARF Assembly Advice Required
  46. Addin weight
  47. 1/32 plywood
  48. TX & RX battery charging
  49. Need your suggestion for a small biplane
  50. Hitech Prizm 7 and Crow on a Ultra stick 60?
  51. Decals/Bubbles
  52. covering Great Planes Cap 232
  53. Need Goldberg Tiger 60 decals.
  54. Prop Size for a P-47
  55. Drop Box
  56. thanks to all RE: changing tx/rx xtals
  57. Muffler For Magnum -40 Pro
  58. GM Rainbow Runner .45?
  59. Lateral balancing
  60. How we are percieved by the public
  61. Servo Mounting
  62. r/c shops in the atlanta ga area
  63. Do Rhom Air's spring down?
  64. PROP's
  65. Asrto Hog Hinges HELLLLP!
  66. RX antenna replacement
  67. Changing tx/rx crystals
  68. soldering music wire
  69. Andy Clancey Video
  70. What bipe is this
  71. Rx battery power
  72. GP Extra Engine Selection Question?
  73. Can't read voltage on RX Battery
  74. CG on Dazzler
  75. J-Tec Pitts Muffler
  76. 2 batteries with one receiver
  77. Glueing Balsa to Foam
  78. Washout Tutorial Needed
  79. Removing paint from cloth covering
  80. routing foam
  81. What was that plane at Perry?
  82. Sig Hog Bipe balancing
  83. hobby-poxy equal?
  84. B&B Smoke pump / G-38 question
  85. Smoke System Help??
  86. Balancing a prop.
  87. Three Bladed Prop Question
  88. Sealing hinges
  89. Jen Pro Carb/Mutunuc 65
  90. Do you think CA shortens your lifespan ?
  91. Graupner Trainer 65
  92. Interactive control system
  93. Recovering an old plane
  94. painting with latex paint
  95. Crow
  96. Enforcer ?
  97. Hobbico Avistar C.G. Range...
  98. CG for Sig Cougar
  99. Balancing Low Wing
  100. Where to buy Decals for a Christien Eagle
  101. need help with applying graphics
  102. Cowl/Paint
  103. Piggyback......
  104. Byron prop reduction drive
  105. Plumbing for an inverted OS46FX
  106. After the snow melts...
  107. D&a 100
  108. acceptable hinge gap
  109. Completion Weight
  110. Unlimited Vertical
  111. Goldberg Super chipmunk dual servos
  112. airtronics servo question?
  113. Solartex Covering on 3 Sea Bees Plane
  114. Removing Monokote
  115. Life of nicad batteries
  116. Flap setting for royal stuka, about 40' full?
  117. landing strip woes
  118. Opening a RC Related Hobby store
  119. Remote Needle Valve, or Standard?
  120. Has anyone seen plans for this plane? RFB x-114
  121. In cowl muffler build problem?
  122. Hobby-Lobby Parachuter drop-box
  123. Battery packs
  124. Need field Table idea's
  125. Decals for Balsa USA Sopwith Pup
  126. Bill Fulmer
  127. Cutting screws
  128. 3-Bladed prop for 4.2 Brisson
  129. What fuel do you suggest?
  130. cAN u id THIS MODEL?
  131. Nitrate Dope thinner
  132. Kangke extra 300
  133. CG on a Goldberg 300
  134. Allen-head thingies!
  135. Flaparons on Sig Somthing Extra
  136. kadet senior question???
  137. DGA pilots
  138. vmar t-34 mentor
  139. Thanks
  140. Compressor, Spraygun Painting Question?
  141. Flaps and Spoilers -- Amount???
  142. OS 91 in a Tiger 60
  143. 4 * 40 taildragger problem
  144. Astro Flight 02
  145. Moving avatars?
  146. Glassing Foam
  147. Fiberglassing Balsa
  148. Another 4-stroke spinner/prop question
  149. Sig sky tiger
  150. Spinners
  151. Saito 91 3 blade prop
  152. 3 blade for Saito 91?
  153. Paint Compatability
  154. Pilot Chipmunk 40 size
  155. Clear coat over Monokote?
  156. Chrome plating engines
  157. Ultra Sport Plus 45? 53? 61?
  158. Name that engine
  159. os bgx1 pressure fitting
  160. Chrome Monokote Help!
  161. BAE Hawk Electric
  162. Are Four Micro Servos for Ailerons on Bipe Worth it?
  163. Let me know if I am insane
  164. need info on arobatics
  165. Can anyone tell me how to add a pic. under your name?
  166. Model/Hobby shops in Florida
  167. Sportsman Waco
  168. I have a question?
  169. Pushrods
  170. FAI Fuel
  171. Modification For Mac's Header Pipe
  172. CG question
  173. Purchasing a Jett .46 engine. What do I need to know about.....
  174. Any got the web address of Ming Yang Model Company?
  175. Kyosho finish
  176. Latex question(s)
  177. Need help with engine mounting!!
  178. aeromaster foam wings
  179. need a carb for a GP 42
  180. Monokote vs Towerkote
  181. 1/7 scale WWII pilot
  182. I need help
  183. covering fiberglass ?
  184. Great Planes 60 EXTRA...do you have your plans?
  185. Fuel pumps
  186. Os61fx
  187. Need a New Starter…Which One?
  188. MiniFan 480 with a gas engine?
  189. Radio Receiver Setup
  190. cleaning glow planes after flying?
  191. Propeller moves when tightning nut
  192. guillow spit
  193. Recommend an incidence meter for me.
  194. RC Super store
  195. Tuned Pipe
  196. Replacement batteries
  197. Trying To Choose A Paint...help Plz!
  198. MONOCOTE SEAMS & Krylon???
  199. Glassing over hatches??
  200. can wood glue be used on a balsa plane kit & what is C A
  201. Brass Tubing
  202. Removing epoxy!
  203. Vacuum forming answers
  204. Futaba vs. JR charger plug polarity
  205. Servo Connectors
  206. Hanger 9 Edge pull pull?
  207. Awesome 182 Cessna
  208. this is the radio
  209. need info on a Sig Kadet trainer
  210. Just the Dope
  211. scroll saw problems
  212. How much pressure?
  213. Airbrush Expert Needed
  214. engine test stand
  215. Fuel proof paint???
  216. Drill holes on engine mount made slightly unevenly. Now what? (read on)
  217. Where on Earth can I get 4.1mm and 5mm drill bits???
  218. Carbon Pushrods
  219. Flying site in St.Louis
  220. unique pilot
  221. 4 stroke
  222. Advantages/disadvantages of mounting engine sideways vs. upright.
  223. Vacuum forming
  224. Aluminum Spinner or Plastic
  225. Allergic to CA ?
  226. Gyro on a twin engine plane?
  227. How much flaps
  228. 20 years of aerodynamic education erased
  229. Please help, looking for an airtrax 40
  230. Strong odor from epoxy?
  231. Klett products
  232. Futaba 6xaps
  233. engine for protege
  234. Article in R/C Report
  235. #11 xacto blades?
  236. Thrust line
  237. Ready2 or Jupiter Info
  238. Piezo Gyro for Airplanes
  239. New four stroke engine
  240. Cooling air cowling baffle
  241. C&H ignition system
  242. Looking for a display prop
  243. How to clean CA glue vapours?
  244. Do you know the name of this planes??
  245. Saito 72
  246. Hots canary
  247. spring air retracts
  248. servo's
  249. Aileron servo for bell crank setup???
  250. is zagi wing hard to fly?
