PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 [95] 96 97 98 99 100 101 102
  1. Differences in engines?
  2. Using Monocote on Fiberglass ????
  3. For Sale Information
  4. ? aeroworks edge540T 90
  5. giant ultimate anything available??
  6. Weight issue
  7. Carbonfiber control links?
  8. ugly stick
  9. space shuttle plans?????????
  10. Throttle Linkage 4 stroke
  11. Looking for flying spots in St. Louis
  12. Ultra sport question?
  13. engine for kadet senior
  14. reflex flight simulator
  15. New mod on 4*60 (Have Pics Now)
  16. racing wheels
  17. cap 232 ????????????
  18. Please recommand - Drill Press
  19. Any one from Montana.
  20. Elder 20?
  21. Which Fuel Mixture?
  22. need some help with rc skydiving
  23. Supporting my LHS...what's the point?
  24. Metric wing tubes??
  25. Gas conversion?
  26. 615 Rotating Retract troubles
  27. Great Sites????
  28. Balsa USA Phaeton 90
  29. Tower combo, Sig Kobra & OS 25LA...good combo??
  30. Covering Obechi
  31. How Do You set up the radio gear in a Great Planes Pitts
  32. painting plastic cowl
  33. My second glow plane?
  34. Tower Trainer 40 Wing Tips
  35. Suggestions On "repainting" ?
  36. Difference in prop size?
  37. Charge it, again & again ect.
  38. glow to electric rc
  39. K & B Ultrapoxy
  40. Building techniques
  41. frequency compatibility?
  42. Need Hi-Res Pix
  43. PT 40 Landing Gear
  44. Wierd Landings
  45. Flying Wing Information
  46. Laser 200 decals
  47. shirt
  48. Something every Pilot should have on his/her desktop!
  49. Hobbico Superstar EP
  50. welding cast alum case
  51. need to fix case on G62
  52. RC magazines & manufacturers info
  53. searching for K & B paint
  54. Anyone using a GPS for flight logging?
  55. Dutch Roll
  56. Is there something that will take the color out of monocoat?
  57. balsa help!!!
  58. Control horn goof
  59. servo mounted in wing...help
  60. Question about Rudder/aileron/ elev mix
  61. Full Body Pilot
  62. strange catalytic reaction with 30 minute epoxy
  63. Anyone have an actualy preflight checklist?
  64. Bungy for small models
  65. Aussie looking for contacts in Dallas
  66. A question of Paint
  67. Attaching Struts on a WM Cub 48
  68. Avitars?
  69. Preferred linkage for thottle?
  70. Lateral Balancing
  71. Starting an Enforcer or Force One
  72. CG for Clancy Aviations Speedy Bee ?
  73. US aircore
  74. Need Help with a Engine/Weight Issue
  75. 4*40 engine size
  76. Can you tint a canopy with coffee?
  77. Depends....
  78. paper tubes
  79. C.G. on Sig 4* 1.20
  80. Need Contact Info For Manufacturer Hi G
  81. carving aluminum spinners
  82. Moki tunning help
  83. What's up with Dubro spinners?
  84. onboard glow driver
  85. *
  86. Push/Pull Fuel System Plumbing Trouble?
  87. What Plane?????
  88. tune pipes
  89. thanks vB code
  90. Polybond glue
  91. flite metal
  92. learn funfly
  93. pull pull system
  94. Heres another plane Im not sure of ?
  95. Fuel proofing hard to reach ARF
  96. PULL PULL interference
  97. Powder Drop?
  98. mounting engine 0n sig 4*
  99. Du-Bro Skiis
  100. RX Battery Connector Question
  101. how much is too much?
  102. Magnum XL 91 Carb Settings
  103. hinges ca or plastic
  104. plans(how they work)flaps/ail.TF-p47???
  105. Robart hinge points and Elmers Probond
  106. YS-63 vs MVVS-77 pros + cons
  107. semi-scale .40 plane for aerobatics
  108. Ace Bingo 120
  109. Prop size for a Saito .65
  110. Removing oil from saturated balsa?
  111. How would you create a plane-saving parachute?
  112. Painting Monokote Which Paint to Use in My Airbrush?
  113. German mail order shop
  114. Glassing a Byron Christen Eagle
  115. Oxford,Miss.Flying Site?
  116. Coverite film
  117. Curious question about 4* LG
  118. I should know this..
  119. Painting equipment
  120. ACE RC 40 Size Staudacher S-300 Canopy
  121. Wing Area On A Biplane
  122. muffler
  123. A few questions from a newbie
  124. C/A hinge installation
  125. Anybody know what plane this is??
  126. Exhaust Residue on Servo?
  127. Custom Decals?
  128. Folding Prop ???
  129. Hi Guys, Anyone know what this is?
  130. :D
  131. Long leads
  132. Brian Felice's Pull-Pull Site
  133. Old gas tanks
  134. 60 size GP Aeromaster ??
  135. 60 size
  136. Help with pneumatic brake?
  137. Engine mounting
  138. Slimline Muffler Mfg. Email address
  139. Painted Pilot Figure
  140. rotating retracts
  141. really cold weather storage?
  142. 2C vs. 4C in 3D aerobatic planes
  143. Rc Plane Apparel?
  144. TX-Channel Question
  145. Run the antenna wire...where?
  146. Monokote technique question, HELP!
  147. Lanier Ultimate pitts
  148. Canopy Repair? Best idea?
  149. Aeroworks Edge 540
  150. leading edge shape ?
  151. need plans for Balsa Nova 1.20 cowl
  152. Vacuum Form Materials
  153. Famous People
  154. Engine breakin in fuselage
  155. Prince America-Have you Heard?
  156. Looking for Eastcraft Lectra-Starter information...
  157. cooking
  158. ABS Cowl Repair
  159. Fuselage needed
  160. sealing hinge gaps
  161. Questions and Answers: What batteries?
  162. Chain-link fencing for pilot stations - Your Thoughts?
  163. Os 52 Surpass Muffler
  164. Whats the Latitude Longitude of your field
  165. Any famous people involved in rc flying?
  166. Hots ???????
  167. Vac Bagging Supplies
  168. Radio --> ESC signal
  169. Automotive Paint for Cowls
  170. Full body pilot for pica spit 1/7
  171. what engine for ultra stick 40?
  172. Landing Gear Question....
  173. Where to buy pressure nipples
  174. Pro Bond and Vacuum Bagging
  175. Wright Bros. plane?
  176. Prop Size
  177. Hobby Shop Question!
  178. Engine size
  179. Os
  180. Hangar 9 DVT Voltmeter/Tach Problem
  181. Great Planes Building Board Modification
  182. help whith simetrical wing
  183. Robart retract torque
  184. Mono-coat Trimming
  185. World Record Altitude????
  186. Engine turning
  187. 300sx Or Xs Wheels And Pants?
  188. Hitec Servos, HS-5645MG Issues
  189. Why soooo many planes???
  190. Pete n' Poke
  191. How do I remove primer overspray????
  192. Kadet LT-25 wing size??
  193. How to take piston off?
  194. Balancing low wing models
  195. Sullivan remote glowplug connector>
  196. Sig Kadet Senior ARF
  197. Fiberglass cowls
  198. Flaps from Ailerons
  199. Pos/Neg Shift? Please Explain
  200. Spring Air Retract binding?!?!
  201. Airbrush On An Air Tank?
  202. Elevon Mixing
  203. Advice on Ball Links
  204. Top Flite DC-3 RTF Whats it worth?
  205. Engine Gurus, I need help
  206. Canopy Glue
  207. Stripping paint
  208. clean plexiglass of marker
  209. Sig Rascal 110
  210. Balsa USA Niewport
  211. Are there any 60 size EDGE kits?
  212. Shipping & Handling,why So Much On Handling?
  213. Canopy Tinting
  214. Just for fun, who has the SMALLEST AMA #?
  215. Removing dry epoxy from Ultrakote?
  216. Covering Advice?
  217. Pictures
  218. has anyone have problems with metcaf
  219. Slow Rolls
  220. How do I make retract doors work?
  221. Perfect Paint
  222. Servos - Decisions Decisions
  223. CG for a Midwest Sweet Stik 60
  224. GP Corsair problems
  225. Mono-Kote A Cowl ?
  226. Culver V
  227. Cox Sportavia Batteries?
  228. gyro's in airplanes
  229. Fill Valve Question
  230. Rounded wingtips on 4*60
  231. Model shop in Berlin, Germany
  232. Horizon Hobbies Support??????????
  233. Feedback on sprayed latex finish
  234. Info on your 60 size extra wanted!!!
  235. I need CG for ACE 4-60 bipe
  236. Help with Flaps
  237. GP ultimate bipe
  238. engine for Ace Upstart
  239. 3d what flying..what is it?
  240. prop size
  241. Top-Flight Contender
  242. Graphics
  243. Stability-gyro or autopilot?
  244. Steerable retract nose gear-help!
  245. Engine Weight vs. Performance
  246. Cessna 120
  247. pinking tape
  248. Smoke?
  249. Hovering
