PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 [96] 97 98 99 100 101 102
  1. warped wing
  2. PICA 1/5 P-51...is this a good kit??
  3. HELP finding Pictures of EASY 100
  4. Lanier Shrike C.G. Location
  5. Clunk Line Question
  6. Plans or kits
  7. 4 Stroke and 4 Star, Throttle linkage Help!
  8. Senior member?
  9. WIng Bolts and Cowl
  10. Do I need to put foam around my Rx/Rx batt?
  11. Covering with Sig Coverall
  12. Inside cowling exhaust
  13. Gassers and PPM radios
  14. quick gas tank question
  15. What tool is this?
  16. Operating Gear Doors for Byron Corsairs
  17. Vintage Style Landing Gear
  18. flying fields in Louisiana
  19. CAD - What are you using
  20. Gas tank/Receiver/battery location
  21. Gp Big Stik 40 & Tt 46
  22. Ski's for a Sig Senior Kadet.
  23. Saito 100 vs. 100GK
  24. antennae length
  25. saito 80, makin noise??
  26. Looking for info sheet on Flight Trimming.
  27. Expert ex-100 gyro instructions?
  28. Oracover
  29. Worn bearings
  30. Super Coverite Availability
  31. zlin forgotten
  32. 3D Freedom from AK Models
  33. Place to fly in Southern California...
  34. Hobbico CS-61 Servo's Question
  35. Wing Jigs
  36. RC Simulators--Which is the Best?
  37. Local Flyer
  38. Contol Line Question
  39. Global Kit Beaver
  40. Who makes 2 mm metal clevises
  41. Wing Failures
  42. Smoke
  43. Robart retracts for World Models GS Miss America
  44. Winter Cold Engine Starting!
  45. Rohm Air and Robarts compatible?
  46. Help, Spinner adapter for YS 90 FZ??
  47. Too much flex in my steering arm?
  48. grumman F-3
  49. Aerobatic suggestion for a G-38 Gas.
  50. general CG question
  51. Vertical flying or hovering ?
  52. Downloadable OV-10 Bronco plans?
  53. PILOT/OK Models Bucker Jungmeister
  54. Pull Pull alignment question
  55. Atomizer for Silkspan
  56. F4U Corsair
  57. polyurethane glue FYI
  58. how to you do my own nitro fuel?
  59. SATA minijet 3 HVLP and Nelson Paints
  60. Plane Plans
  61. Super Chipmunk power....
  62. GP 300s extra tips
  63. Question about ASP engines......
  64. Great Planes Pitt special
  65. Rom-Air Retracts
  66. Robart air valve 'O' rings
  67. Monokote over Ultrakote???
  68. Kyosho 40. spitfire
  69. What's the difference?
  70. Long lost TUCK thread
  71. shrouded propeller info ?
  72. Retract Basics
  73. Retract Help
  74. Aerobatic suggestion for 91 4 stroke
  75. Great Planes .20 J-3 Cub
  76. Monokote squares
  77. droping things from a powerd parashute
  78. hanger 9 cowl paint
  79. Sure Flite Models
  80. RC Designer software?
  81. fuel soaked fuelslage
  82. Flying Clubs
  83. HPI Dash RTR Opinions?
  84. Isoproply Alcohol *** Question Answered ***
  85. Bending 1/4 inch balsa
  86. whistling sound
  87. S**** covering?
  88. Planes subjected to heat?
  89. 049 black widow
  90. Plans
  91. Fiberglass Rosin vs Epoxy
  92. What is this?
  93. ? about pressure port on slimline pitts
  94. model tech magic 300
  95. Tru-turn spinner with Saito 91
  96. Help Request: OS Gemini FT120 Timing
  97. Is this a good price??
  98. Flying in snow
  99. Nose Gear Brake
  100. Source for a Cold Weather Transmitter Cover ???????
  101. RC Model Pilot
  102. Pull Pull Rudder Questions
  103. Using an incidence meter
  104. Sheeting wings
  105. Installing an OS91 fourstroke
  106. GP Pitts- Brison 3.2-What size 3 blade prop?
  107. AM or FM?
  108. Electronic Ignition
  109. Covering
  110. Which is easier to fly.
  111. CG on a tapered wing?
  112. Glassing a Giant Corsair
  113. weldbond for sheeting wings
  114. Onboard Temp Meter
  115. TME Deluxe Smoke Pump
  116. fiberglass clothing
  117. OS 50SX being discontinued?
  118. props-diameter/pitch?
  119. my sig 300xs will not loop!!!
  120. slimline STI smoke preheat system
  121. Silver Ultracote
  122. Gas Smell???
  123. Odorless CA
  124. accu dremmel - any good?
  125. which power plant ??
  126. Tiger Stick Wing Tips
  127. Tachometers
  128. Help with drum/air wheel brakes.
  129. aluminium landing gear
  130. 4-stokes in the cold
  131. Fuel Filler Routing
  132. Wing Jig
  133. You ARE the weakest link...
  134. Muffler mount deflection angle?
  135. Lightning holes in ailerons???
  136. Who makes this plane??
  137. Unsticking Pacer canopy glue
  138. How do you charge your flight box in your trailer?
  139. Hinge slotting for CA hinges
  140. GP Stik 40
  141. RC Propeller Question
  142. Sportster Bipe throws and CG?
  143. Question about Gas Engines
  144. 4" plastic spinner?
  145. Lol???
  146. Wanted / 2 Vectron Blackhawk Flying Sauser's
  147. Carbon Fiber Pushrods for Split Elevator
  148. I have a "few" Qs about the Zagi 400 and 400X
  149. David Combi-plane
  150. Sig wonder engine choice
  151. Maro propellers
  152. cg for a bi plane
  153. rossi 45 2000 with mini pipe questions ?
  154. Looking for someone to make a foam fuse.
  155. Covering
  156. What size starter for 25 cc gas
  157. Propeller pitch question
  158. Holderdowner Bolt
  159. Sig Kadet Senior ARF
  160. Great Planes Magnetic Building Board H J Lind
  161. TruTurn Spinner requires a 1/2" hole 3/8" deep
  162. GP Super Sportster ARF or kit???
  163. 60 degree bellcranks for Bronco
  164. On-board tachometer
  165. Co Pilot?
  166. CG Piper Cub Question
  167. Jr 8231
  168. What engine for a Vmar cap 232 60-90 size??? Help!
  169. 4stroke upside down in plane
  170. mini servos
  171. problem with CLUNK?
  172. How to balance 22"+ prop and 4"+ spinner??
  173. Covering Foam Floats with Tape
  174. Buddy Box Compatibility
  175. Ace 4-120
  176. Which is lighter ?
  177. Probably a STUPID question, but...
  178. balance
  179. Help needed for installing/securing wing tubes
  180. Source for Old Airplane Plans
  181. Set screw on OS 46FX
  182. Can you convert Airtronics Servo to work in Hitec RCD
  183. Edge 540 ARC
  184. long distance flight
  185. Use Butyrate Dope or Nitrate Dope?.. or does it matter?
  186. 2 stroke backfires?
  187. Fabric vs Fiberglass
  188. Dark exhaust oil
  189. Revolution Spinners
  190. Question for the U CAN DO 3D
  191. how to align wing tubes?
  192. Aileron servo installation
  193. Aerogloss Thinner
  194. Need info on building hot wire foam cutter
  195. Plank Stripper
  196. Cg Extra 300(special Offer Inside)???
  197. Balancing a plane Laterally
  198. Odorless CA/Accelerator recommendation ?
  199. Help On Stripping Paint!!!!!!!!!!
  200. O.S threads?
  201. Metric to imperial wing loading
  202. Help getting soldering tips.
  203. Gyros
  204. Dago Red
  205. Extensions for battery packs
  206. use glow fuel with tygon and dubro gas filler?
  207. COVERING with LOGO's???
  208. Digital camera hookup on airplane??
  209. New Plane in Tree
  210. Balance Gps Patty Wagstaff
  211. installing floats
  212. checker board pattern with monokote
  213. GP cessna help!!
  214. What wing design program do you like?
  215. What are the effects of no washout when it was intended?
  216. What's the difference between Denatured and regular Isopropyl alcohol?
  217. Cleaning transparent Oracover
  218. Colours that are seen well in sky
  219. Monokote sticking problems?
  220. Contact number for Richmond RC
  221. How to fix broken Aileron Hinge?
  222. prop source
  223. Painting monokote
  224. Tru-Turn Spinner?
  225. Lightest opaque covering?
  226. Futaba 9CAP/CAF
  227. 40 size trainer and floats
  228. Good RC Shop in Asia
  229. Gp Patriot.. Can Someone Talk Me Into Buying It :)
  230. Who is flying now a days?
  231. Flying a Canard
  232. Old OS max .40 SR
  233. Third line from fuel tank?
  234. Windshield for CG .40 Skylane
  235. Inverted 4-stroke Engine???
  236. jets...
  237. Pushrods and Control Linkages???
  238. Need input on a duration flight
  239. AMA alternative ?
  240. stinson reliant sr-9 howe is it
  241. Radios for Jets
  242. Futaba fp-t6va question
  243. Tips on checking Center of Gravity CG?
  244. Help!
  245. Read This
  246. From where I can get (buy) GOOD aircraft plans?
  247. Fiberglass Cowl For Dynaflite Decathlon
  248. saito 45 4 stroke
  249. supertiger 75 and 90 prop question?
