PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 [99] 100 101 102
  1. SkyWays & WW1 Aero
  2. Longevity of foam for wings
  3. epoxy???
  4. 4 Bladed Props
  5. Velcro Man
  6. OS 46 FX Glow Plug Issue
  7. Carbon Fiber Spinners under 3" ?
  8. mounting engine horizontal or inverted vs. vertical/upright
  9. Source for 3 views
  10. teaching new pilots
  11. Robart retract help?
  12. Building Surface?
  13. fuel line tubing
  14. 60 size Dragon Lady
  15. Macs Products email address
  16. I am Getting tiered of waiting!
  17. Want my Cub to fly slower!
  18. Trimming problem
  19. Fuel Tank Position???
  20. Hitec 5945
  21. RC Shop in KL, Malaysia
  22. Dual-servo elevator linkage geometry
  23. Max Os Bx-1
  24. Flying Wing
  25. CG question
  26. runaway esc
  27. Tower Engines
  28. 1/3 scale Extra
  29. trike to tail dragger
  30. Attention fellow modelers..a little help please...
  31. Tower .46ABC?
  32. Hanger 9 78" 540 Edge
  33. Adding a smoke system???
  34. Looking for a switch
  35. Covering Hinge Gaps?
  36. motor size
  37. Twin Sync System(EMS/Jomar)
  38. Canopy Dye : your techniques
  39. Vacuum bagging system recommendations
  40. Adding oil to fuel
  41. looking for a club
  42. TF P-47 flaps
  43. Fuel Pump
  44. Aerotow!
  45. When You Say Nitro
  46. Multi-engines
  47. URI Balloon Festival?
  48. GP Big Stik arf setup advice needed
  49. Painting equipment suggestions
  50. Flying Machine
  51. Top Flight Paint
  52. Need help detailing a war bird (adding flying wires)
  53. How much time you spend a week in this hobby
  54. How do I re shape fuel tank?
  55. 60-size rotating retracts
  56. Stafford models
  57. Counter Rotating Propeller equipment
  58. Sullivan elevator splitter
  59. a picture/scheme of pepsi design
  60. Eye Wear
  61. Wife
  62. Maiden of Seduction Freestyle (need help)
  63. trailing edges - vacuum bagged fiberglass wing
  64. RC America Cap 232
  65. Finding the CG?
  66. Are big planes better than small plane
  67. D&L DESIGNS arf
  68. Removal of Covering from a Byron's Pitts
  69. Best companies for plane kits??
  70. Home page for Robarts?
  71. Physics formulas for CG weight placement..
  72. Brushless Speed Controls
  73. What Engine?Prop Combo
  74. Changing Engines On Existing Plane
  75. HELP Taube Balsa USA C.G.????????????????
  76. Seagull p-51. Good or bad?
  77. 3 Engine Twinstar Prop Recommendation
  78. 3 Engine Twinstar Prop Recommendation
  79. Help! I need a spinner!
  80. Tail Dragger
  81. handicapped user needs help
  82. looking for Dave Patrick video
  83. West System Epoxy over Polyester
  84. Covering Temperatures? (monokote & ultracote)
  85. Gyros ?
  86. bubbles in sheeted wings?
  87. moki 180
  88. Landing gear adjustment
  89. HELP...=( Epoxy Resin and Epoxy on a Coffe table
  90. what is copatable w/coverite black barron
  91. 4* 40 to a Spitfire????
  92. WWI Multi colored covering
  93. Using flaperons......need help
  94. First Float Plane?
  95. Experts, Hobby Shops, Clubs ... need a website ?
  96. That's not what I was looking for!
  97. picture in ama of T34
  98. Where to attatch landing gear
  99. Firewall fell off. How do you reglue?
  100. How to keep servo leads off of pull-pull cables?
  101. R/C Field in CT??
  102. trying to find website
  103. Epoxy strength differences ?
  104. ok here is one
  105. Need Help : Charging 12v field box battery
  106. rolls?
  107. Water Rudder Steering
  108. Control throws for Midwest Aerostar 40
  109. Great Planes Retracts Any Good??
  110. Looking for Rob Oliver NJ area Larry Kreisler?
  111. Pica 1/5 Scale P51D: Sliding Canopy
  112. Non Pneumatic Landing gears.
  113. Canopy For T34
  114. Frank Cummings
  115. Pratt or Bridi T-28
  116. Airplane Cleaner
  117. Any large scale aircraft builders out there?
  118. Anyone in Charlotte NC
  119. What prop for O.S.91 fx
  120. 33 inch Gee Bee floats
  121. Fiberglass Alternatives
  122. What to do when loosing perspective?
  123. How tight should pull-pull cables be?
  124. cg, for a simitar
  125. Help finding 3 1/4 spinner
  126. Balance
  127. Enya Parts
  128. SPINNER's WHAT SIZE?
  129. flying a warbird ?
  130. It's EASY!
  131. Can you tell me about Kromekote?
  132. Monokote over Ultracote?
  133. Fuel tank
  134. Fiberglass question
  135. How do I convert Avistar to bolt on wing?
  136. How to make a coiled tube
  137. os 40 la problem please help
  138. RADIO AGEING '''' HOW OLD IS TO OLD???
  139. any r/c clubs in Dothan Alabama
  140. 23cc on a modeltech joss stick
  141. Saito,magnum,os 4 Stroke Engines
  142. Looking for a Mantua Models importer
  143. Pizazz
  144. What is a good flying airplane
  145. I need help?
  146. Custom Cutters Variant II
  147. monokote smart stripe
  148. Ordering from Desert Aircraft?
  149. T-28 retracts`
  150. Incorporating a Local Club: Pros & Cons
  151. T-34 wing mount blind nut
  152. pusher prop manufacturers
  153. S/T 2500-Moki-180
  154. flap, elavator mixing
  155. Fuel line through firewalls
  156. Ready to paint Cowl for Sig Extra 300XS??
  157. Cub wheel confusion
  158. aeroglass info
  159. Alternate cleaning methods?
  160. World Models Mentor vs. VQ Models Texan
  161. Need Feedback on VQ Models
  162. OS .46FX prop choice for WM T-34
  163. How to get rid of CA stains????
  164. Which tuend pipe for a .53 Irvine
  165. Glue Expiration Dates?
  166. stinger 60
  167. Monocote?
  168. Fuel tank and Carb alignment
  169. Please HELP me figure out the NAME of this CAR/Buggy
  170. Pilot busts
  171. Where Do I Find Or Who Makes Plane Holders
  172. Tower Hobbies Towerkote
  173. Motor Mount Question??
  174. Which is better...the Robart or the Du Bro Balancer.
  175. Flying Fields in the Spirit Lake Iowa Area?
  176. VQ Models
  177. Shipping
  178. balance
  179. Robart retracts how much air?
  180. Pcm Vs Fm
  181. Center of gravity ???????
  182. Converting Tricycle to Taildragger - correct placement for main gear?
  183. What would be the best way to a glo-fuel-proof finish?
  184. Slow Printer
  185. Float mounting Systems
  186. Digital Air Pressure Gage
  187. Prop for O.S. 91 Fx
  188. Step by step instructions for 'glassing'?
  189. Instrument Panel Decals
  190. Carving Plastic Spinners to Fit Props
  191. 4-Star 40... roll coupling?
  192. Aircraft Price
  193. Does gasoline attach plastic covering?
  194. Rocket City Hardware
  195. What do I do with my Slowpoke?
  196. Gyro question
  197. help trimming laser ???
  198. Removing Castor Stains
  199. Hobby Services
  200. 3 bladed prop
  201. Dremel
  202. scale looking spinner for a cub?
  203. Litespan covering
  204. Zenoah 62 Mount
  205. O.S La engines
  206. Fuel Dots
  207. Aerial Photography - Pencam anyone?
  208. Hog-Bipe
  209. AMA Scholarships
  210. Plan for Field Tote
  211. "tacky" epoxy
  212. Enya 45X T.V
  213. Dinged LE
  214. Servo Torque
  215. Need to Unjoin wing halves
  216. Are there any Women out there?
  217. rc parachute
  218. "SG" What Brand is it?
  219. Securing Long Elevator Servo Wires in Fuse
  220. standard servos in lazy bee 40"
  221. flight characteristics
  222. Fuel containers...
  223. Power to weight Ratio??
  224. Servos
  225. center of gravity ????????????
  226. Jr 10X Transmitter
  227. Morrishobbies
  228. Smoke System ??
  229. Aero Sport 60 CG?
  230. Tme
  231. Smoke
  232. how many of you fly on ham band and why??
  233. Where's Epic RC
  234. Midwest parts
  235. shipping to england
  236. Great Planes - When is Balsarite coming back?
  237. Sealing seams in Monokote?
  238. about pull pull
  239. Lateral balance on a profile fun fly
  240. Substitute for K&B paint thinner
  241. Perry Pumps for four cycles?
  242. What's the difference between......
  243. K2R vs. the other stuff???
  244. Hitec
  245. Wanted: canopy for Ohio RC 43% extra 300S
  246. Wheels for 120 size Cloud Dancer
  247. Struts
  248. Just need a little help
  249. Storing planes in your trailers, Good or bad?
