PDA
View Full Version : Questions and Answers
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. Down and Locked Retracts
  2. Falcon Propellers
  3. crank case for an os 61 fs
  4. Which models suit an O.S. 50 cc or Saito 50 cc twin cylinger engine
  5. SAFE Technology
  6. GMP 50cc GeeBeeR3 Owners
  7. Need help choosing carburetor
  8. Graupner HVS939BBMG with futaba - Help!
  9. 3w Engine!!
  10. Laser cutters for wing parts and leading and trailing edge shaped balsa
  11. Ball cup question
  12. Aeroworks 35cc Extra 260 ARF-QB
  13. Motors cutting out at about 70% throttle
  14. Cubic inches vs. Weight
  15. Gemini Models Super Champ
  16. Tiger Trainer MK II (GP 42 Engine)
  17. futaba s9202 servo
  18. Strange servo behaviour
  19. Carl Goldberg Anniversary Cub
  20. Saito Parts Needed
  21. Safe paint
  22. Painting Multiplex planes
  23. Nose gear
  24. Servo converter leads
  25. New: Pull-Pull System - Need Help!!!
  26. landing gear wire
  27. Tettra tanks?
  28. Make and model of my new plane
  29. Is my Goldberg Cub too heavy?
  30. saito 120r3 engine problems
  31. Great Planes Giles 202 1/4 Scale
  32. Kingtech telemetry
  33. Hobbico after-run oil
  34. Evolution .40 engine, what can i use it in?
  35. Heat resistant super glue?
  36. Long and Short Glow Plugs in Webra 120
  37. Futaba Radio conversion
  38. Successful Moving
  39. Looking for info/price on The Mignet “The Flying Flea”
  40. FS Racing Manual Needed
  41. Taurus kit price
  42. Jet hinges
  43. How to maximize flying distance
  44. Perry Pump
  45. Bellcrank -zenoah g38
  46. How to hinge thin wood?
  47. Need Cub plans
  48. Canopy mfg
  49. hot melt glue ?
  50. Extending Battery Leads
  51. Power requirements for a small Tiger Moth
  52. On plane video camera options?
  53. gas/glow plugs
  54. Spektrum DXe Transmitter
  55. FPV on 1.2m-1.4m planes
  56. YS 4-stroke fuel line routing diagram
  57. Getting Back in to it... Sort of...
  58. Covering a Cessna 182 Top Flite Kit
  59. Futaba R6208SB Receiver & JR ST47BB Servos (Ball Bearing)
  60. Cutting a staight LE with Monokote !!!
  61. Help Please - Phoenix Models Sukhoi SU 31
  62. Sport cub s not turning properly
  63. Sullivan glow drivers
  64. Twitching Servos
  65. JR XF421 EX Controller
  66. Tamiya Acrylic Paints
  67. prop help
  68. FMS P-51 motor, re use with an APC 2 blade. adapter problem.
  69. Cool Power MV 4-stroke question
  70. Smoke fluid- homemade
  71. Brush on Gasoline proff paint
  72. Great planes cub 60 replacement parts
  73. Atlantic Crossing Project
  74. Ryan STA ARF 70.8" I'm having trouble deciding where to put the receiver
  75. Mc cor rc 59 plugs
  76. Epoxy/Denatured Alcohol mixing question
  77. Car takes off when I plug in battery
  78. Recommended twin engine trainer???
  79. Evolution 33cc
  80. gas or glow and older radio
  81. What Airframe for a ROSSI 90RC FI with tubed pipe?
  82. selling all my rc
  83. Apprentice 15e and Apprentice S
  84. 80cc Plane Search
  85. How to cut covering straight
  86. retract tank fill
  87. 6 Channel Radio what to buy?
  88. What happened to all the Top Flite Kits at Tower Hobbies?
  89. O.S. 35AX Throttle Lever
  90. converting areo engine to marine engine
  91. What type of paint to use over Coverite 21st paint
  92. Multi Charger Anomaly
  93. looking for manual for a TOC53cc 3mm
  94. looking for manual for a TOC53cc 3mm
  95. Dave Patrick Models
  96. Re Covering
  97. What is the right criteria to choose the #C on an Lipo battery ?
  98. Rubik's Nitro
  99. Fuel Proof Paint
  100. GP escapade MX 30cc wing bolts
  101. Nylon wing dowel pins?
  102. Screws vibrating out
  103. O.S. FS-91 Surpass lifter problem...
  104. Slimline muffler
  105. O-ring
  106. Anybody ever witnessed an aluminum wing joiner tube fail?
  107. HELP! Nitro OS MAX .40 FSR not running properly
  108. GP Escapade 30cc question
  109. Balance for 1/3 Spacewalker
  110. Radian XL Beeping
  111. Funny Cub
  112. routers
  113. Back up battery
  114. GP Stearman to gas
  115. Nonsteerable music wire tail wheel mount?
  116. E-flite discontinued?
  117. Need advice/help with Triton EQ charger
  118. Kingcraft Pitts S2b
  119. RC A380: Recommended store and worth buying?
  120. Old Servo to new radio and receiver
  121. Advice on Kit Prices
  122. Pacer Hinge Glue
  123. Futaba T16SZ Battery
  124. fuel tank question
  125. Info on Bob Parkinson Balsa "Pusher Prop" F-18 Kit
  126. Removing mill rings from aluminum cowls
  127. Fail safe best practices
  128. "Best" after market item for RC airplanes
  129. New to RC Planes, help getting started
  130. Detailed sanding plastic styrene filler
  131. web site
  132. Website
  133. Sub micro servo
  134. Looking for tuned pipe for os 46ax ii
  135. Smoke 101
  136. Robart 630 - Cylinder Loose Nipple Issue: Help??
  137. What size spinner to use
  138. Look for a source for accurate FS code paint
  139. Need manual for OMP Hybrid Edge 540 92"
  140. High rate ,low rate
  141. Bvm retract valve new orings supply?
  142. Super Tigre GS45 conrod assembly
  143. ZigiRC
  144. Fueling options on Great Planes Skybolt 60
  145. Klasskote clear over Rustoleum
  146. How should I store my engines for the winter?
  147. Nelson Hobby Paints?
  148. nitro car electric start system on nitro plane engine?
  149. Ultracote Matching Paint
  150. Seagull Yak 54... Need airframe parts
  151. Soldering stationsq
  152. Iron Bay
  153. Latex Foam Rubber
  154. Three Blade
  155. Sullivan Flex tank issue
  156. best glues for bonding flexible plastic to styrene plastic
  157. best glues for bonding flexyrene plastic
  158. Hobbic superstar ep
  159. Byron A4 Skyhawk
  160. Covering material
  161. Help with my front nose cowling shaping
  162. Setting up dual batteries for Rx and Ignition
  163. Long Shot
  164. Sky Aviation’s P-51 Mustang
  165. Help on the AURORA LCU
  166. How to give a positive rating to a seller on RCU
  167. Need help...(very off topic)
  168. Landing Gear for 1/3 spacewalker
  169. King Kobra
  170. I don't have a car. What are my options on transporting my planes?
  171. Anyone Know If
  172. Need history on J3 Cub
  173. Lipo swelling?
  174. Monocoque
  175. asp 4 cycle break in
  176. Running a Gas Engine on a Plane without the wing
  177. Spektrum dx9 betrayal!
  178. light weight putty for styrene plastic
  179. plane repair service
  180. Rear engine but no push.
  181. RC Bearings
  182. Eagle Guardian gyro help
  183. 1970 Champion EK transmitter
  184. pica waco wheel pants
  185. Throttle linkage on gas engine
  186. Spektrum DX6i binding
  187. Forum look
  188. Slimline Boxer?SL 2000 replacement rollers
  189. SAFE and AS3X
  190. Problem with Retract Servo
  191. Super Sportster
  192. Question about Wren Turbo jet kit
  193. Aileron servo MYSTERY on E-FLITE APPRENTICE
  194. Aileron servo MYSTERY on E-FLITE APPRENTICE
  195. What kind of retracts ARE THESE?
  196. retract schematic
  197. hole cutting tools for styrene plastic
  198. hole cutting tools for thin plastic
  199. Radio Shack Sound Bat II Rc Car - Controller Missing
  200. ASM C130 Motors
  201. Super Cub conversion a brushed motor
  202. Glow engine fuel tank plumbing question
  203. Question about the Escapade .61
  204. Best way/Camera to video flying by myself?
  205. 89in. aj slick cg
  206. switch xb gold color
  207. Esc? Goes into low voltage cut off when batteries fully charged
  208. Flaps
  209. .91 glow vs. 20 cc gas
  210. Spoiler Vs Flaps, Calypso
  211. Best glue for spruce ?
  212. Exhaust Pressure.
  213. Fly RC Magazine
  214. R/C Parts - Buying in Bulk?
  215. Help need rossi 105 rebuild kits stat.......
  216. bvm fill valve for retracts
  217. sdshobbyusa.net
  218. Weeks Solution X Biplane
  219. Any intrest in a Building Service ?
  220. very cheap altimeter
  221. Where to get Missile red Monokote paint?
  222. Debonder characteristics
  223. Prop
  224. Wing loading
  225. De-anodizing aluminum and Re-anodizing
  226. dumb question
  227. Nelson plugs how do they do it. ??
  228. help with some words in the plans
  229. Motor upgrade
  230. help with meaning of some words in plans
  231. Bouncing Servo
  232. Need help on Zenoah 20cc engine timing
  233. Covering balsa clad foam wings
  234. Proper fuel tank set up for 4 stroker
  235. Sullivan Pushrod connector advice
  236. NiMH Batteries for glow starter?
  237. Need to cut holes in ribs of a wing that is already put together.
  238. who makes a Quality, Mechanical, Metal Retract
  239. Ys-61
  240. Paint compatibility
  241. Need help locating specific part
  242. How to install a safety aluminium spinner nut on a OS-95V
  243. Magnum 91 4 cyc (XL91RFS)
  244. MAC's muffler's
  245. OS 62 FS problem! Plz help!
  246. Motor Identification ?????
  247. Carl Goldberg Tiger 2
  248. Mixing rudder to aileron on a Futuba 9c
  249. Demon Cortex Glitching In G.P. .40 Sized Cap232 - Help!
  250. Throttle stick moves Thr servo....Pitch stick moves Throttle servo
