PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Futaba Fasst Frequency Hopping
  2. 8711HV Amps?
  3. Tower Pro servo
  4. Futaba 7C question
  5. servo question
  6. Switch problems from He_l
  7. car steering servo toast?
  8. JR MPH83T, MP82T, or 8711HV??
  9. Receiver AUX pins
  10. servo wires around the RX
  11. Servos for my 4star 120 II
  12. Futaba Skysport is this right
  13. Which servos for my plane
  14. Blinking red light & throttle cuts on Futaba R2004GF
  15. Need help!!!! Transmitter for super cub
  16. Need help!!!! Transmitter for super cub
  17. Help, JR Century 7 Single stick
  18. servo
  19. Channels vs Crystals.
  20. General Electronic Help
  21. Help me do some receiver battery math?
  22. Hobbyking 4ch V1 short range!
  23. Unusual problem with Hitec HS-325
  24. alert new fs-t6 someone could get hert
  25. JR Transmitter choice
  26. Tactic TTX 650
  27. Tactic TTX 850
  28. aissie withservi reversing on airlerons
  29. DX6i
  30. 9C goes full throttle on shut off!
  31. Best transmitter to use with Sky Surfer
  32. Twin engine mix Futaba 9C
  33. JR 11X Fimrware Upgrade
  34. Radio help (newbie)
  35. HELP, got new fut.super8 fg .videos?
  36. Radio South Service
  37. Blown Fuse DX7
  38. Little antenna help
  39. 18MZ Telemetry
  40. High prices on Futaba 9C
  41. Dual axis gyro for jets
  42. Need radio advice
  43. dx-7
  44. DX7s vs Futaba 8j
  45. Radio for a beginner
  46. great job
  47. JR XG14 DMSS
  48. HS35HD servo... Good for DLG?
  49. Futaba FP-4NL AM Radio Still Useable???
  50. Failed Range Check 2.4 Spectrum
  51. DX7 - Flap Help
  52. Help my Futaba T7cp is dead
  53. DSM2 Receiver from Value Hobby
  54. broken radio
  55. how do I use the trainer function on spektrum dx8 and 6
  56. 7.4 Li-Ions w/ Futaba 6008 unregulated ???
  57. Radio Compatibility Questions
  58. Spektrum A7000 retract servo?
  59. Need a little help with a Hp6DSM
  60. Hitec HS-635HB can you convert to non-carbonite servo?
  61. Convert to Life battery packs for Rx?
  62. Soft Switch replacement on powersafe receiver AR12100
  63. JR 8103 Orange Module installation
  64. Futaba WTR-& Trainer
  65. Spektrum DX7s/DX8 Telemetry Programming?
  66. 72 radios
  67. What is a brownout??
  68. 8fg dual elevator servos, on 2 chan.
  69. digital servo quiver under load?
  70. Notes from the easily amused
  71. Servo trouble
  72. Resetting the DX6
  73. HORIZON HOBBY-HOW'S THIS FOR SUPPORT??
  74. Help finding prop adapter
  75. Hitec Eclipse 7 radio equipped with a Frsky 2.4ghz module
  76. Futaba fp-r112je Am75 would it work with this remote. - Futaba Magnum Junior FP-T2PKA 2 CH 75MHZ
  77. 3Gx performance
  78. AFHDS2 (FlySky) vs DSM
  79. Sd-10g. Airtronics
  80. JR XS3 Pro Replacement?
  81. SPEKTRUM SWITCH SELECT
  82. help! which radio to buy? 8fg or 8j.
  83. Spektrum DSMR Technology. Does it improve range?
  84. reciever installation location question
  85. OK, what's the deal with Rx switches?
  86. Ai Runner Reverse V2.0
  87. FRSKY D8R-2PLUS receiver A2 port for RPM reading
  88. shrink tubing on reciever antennas
  89. WrongWay RC 2500Mah A123 Rx Packs
  90. Flaps on a AR7010...9303
  91. Futaba 6J radio for a car?
  92. Voltage sensor compatibility with XG8 !!
  93. rc interferrence
  94. Warbird servo recommendation please
  95. Jr 821 Hv servos???
  96. On/Off switch failed resulting in crash
  97. Mix and match brands?
  98. H.K. Minima compatible 5ch micro rx won't bind
  99. What RC equipment do i need for...
  100. New convert to 2.4 JR 9303
  101. Any futaba s-fhss clone receivers available yet?
  102. what replacement radio,
  103. Transferring settings DX8 to JR
  104. Replacement 7CAP antennae
  105. need tech help Moki electronic ignition
  106. JR 9503 on LiFe
  107. Wanna Help a New Guy with a DX7
  108. JR9302 convert Spektrum 2.4
  109. New FS-T6 Transmitter
  110. 450 Heli Servo
  111. hobby king hk-bxv2 reciver
  112. Which one to program>??
  113. JR DMSS Users need a TX case?
  114. Looking for a Cheap Transmitter
  115. Cheap Transmitter with servo
  116. Spektrum S6020 VS A6020
  117. Fly Dream new transmitter with LCD
  118. 12X Data Exchange
  119. How about a dual antenna retrofit for a spektrum dx8???
  120. Futaba 9155's still have slop after new gears
  121. Lipo battery won't fit in my RDS8000 Tx
  122. Hitec HS-225MG and 6.6v A123
  123. New Radio Technology ????? HELP!
  124. Esc for spektrum Sr201 dsm receiver
  125. Spektrum transmitter..
  126. Futaba 4PL vs Spektrum DX3S
  127. best servo
  128. replace NiMh with a LiPo
  129. Cheap Radio & rx
  130. Spektrum Servos
  131. Futaba T8J, need rechargable battery
  132. 12FG discontinued
  133. XP8103 updating and binding to sub-micro V911.
  134. PLEASE HELP! Redcat Racing F-18C
  135. Fly Sky CT6,need help
  136. Flaperons using Futaba 7C radio
  137. What am I doing wrong, can't activate the DuaL Rates in my 8UAF
  138. RC Noob needs help
  139. RC Reciever for light switch
  140. Futaba 3PM vs FlySky FS-GT3B
  141. RC OMG servos
  142. Futaba 12Z - convert Mode 2 to Mode 1?
  143. Tactic Anylink: How do I reverse a direction?
  144. KST T810 Transmitter & Receiver
  145. FHSS-3 receiver, analog servos
  146. How Many 2.4GHZ Can You Run At Same Time
  147. Quandary...
  148. Hyperion Servo Commander Install Troubles
  149. Info help re JR and Futaba system costs
  150. Simulator transmitter for ClearView
  151. Wiring transmitter pots.
  152. PowerBox SRS / 18CH FASSt : channel assignments ?
  153. Futaba FASSTesttelemetry : RPM sensor
  154. DSM2 receiver and DSMX transmitter
  155. Aircraft Servos
  156. 8FG - triming mixes
  157. Need Help with Spektrum dx5e and binding !
  158. LiPo transmitter Battery
  159. Futaba RX output voltage ok with JR servos?
  160. DX7s new Firmware 1.03
  161. Futaba MG servo horn screws
  162. spektrum full range reciever question
  163. DX7s throttle reversed, trim wont work
  164. Used pricing for 8FGS and DX8
  165. Turnigy 9x - setup help
  166. 12Z Programming question
  167. Digital Servo Current
  168. Futaba 7c (72mhz) channel 1 inop
  169. My hobby back from the dead !
  170. Power HD servos
  171. Smart fly EQ10 question
  172. programing crow on a 9305 JR
  173. FCC RF test report for TX
  174. S Bus question
  175. Futaba T10CAP battery
  176. Is there a DX-7 throttle curve thingie ?
  177. Who Sells More Transmitters
  178. JR 9303 Duel Ailerons Duel Elevators
  179. dx61 programming
  180. Is this a good idea ??
  181. Designing RC products for Hobbyist
  182. 9303 JR Spread 2.4
  183. Dymond servos
  184. DX7 switch assign Gyro rate / T-Hold
  185. A9 switches and set up?
  186. Futaba 14MZ gone, 14SG coming
  187. DX7 Throttle Programming
  188. Servo Buzz
  189. Charging New NiMh 2000 Mah
  190. JR G370 Aircraft Gyro operation ?
  191. RAM Beacon causes servo glitching; Help
  192. rx/tx binding optic 6 help
  193. ORANGE RX - washer / dryer incident
  194. Nitro and electric transmitters
  195. Minimum safe fly voltage - T8FGsuper
  196. Whic remote and transmitter will work?
  197. what reciver do i need?
  198. CastleCreations BEC Pro and Digital servos - How Many and how much voltage?
  199. help with wiring my reciver
  200. Digital servos-long leads
  201. JR Receivers
  202. Transmitter Antenna, Which Way Up.
  203. JR XG8 8-channel DMSS Transmitter
  204. Lipo Low voltage alarm for spectrum receiver?
  205. JR 12X/DSM
  206. DX7 to PC
  207. Old Duralite powerbox and 2.4
  208. Kraft Series 74 Single Stick
  209. Severe Twitching - Esky Honey Bee King 2
  210. adding a vibrator to my TX
  211. Did I make a Good Buy ?
  212. Hobbyking RX3S Flight Stabilizer
  213. Two battery packs or not?
  214. servo as remote push button
  215. Q about FMA Servos with the old Airtronics plugs.
  216. Spektrum module compatibility.
  217. PCM10X Backup Battery
  218. Best HK digital high torque/speed servo?
  219. DX7 to USB ?
  220. R/C Airboat Electrical Help
  221. AIRTRONICS RDS8000 RECEIVER Re BINDING
  222. servos voltage question
  223. DX7S must stop the beeping
  224. Setting up Ailevators in Spektrum DX8 / DX7s
  225. Waterproofing
  226. Glitching RCS M4209 Coreless Digital Servos
  227. Dx8 to futaba?
  228. sidewinder sct
  229. Upgrade from DX7 to DX7s?
  230. Neckstrap for FX-30
  231. Parallel servos
  232. 8FG SUPER
  233. Quick Q about 2.4 Ghz
  234. Futaba 14SG, coming soon
  235. Caution Orange 7 ch DSM2 can short out battery
  236. FASST, FHSS Ranges
  237. Turnigy 9X Transmitter 2.4
  238. Hobby Eagle A3 Gyro
  239. Spektrum system getting hit when turning on another 2.4 GHZ transmitter
  240. Battle of the Brands
  241. Solar MG D772 servos output arm / spline size.
  242. Futaba R617FS Genuine or fake?
  243. Powerbox Royal failsafe mode with Futaba 14mz
  244. 12Z Flaps Question
  245. Gyro for Cub rudder
  246. LiFe battery + regulater in a Hitec A9
  247. Brand new Max 46AX motor
  248. R/C transmitters
  249. 8FG & Naza set-up concern
  250. FASST RX placement in ALUMINUM airplane
