- dx 18 JR 370A Gyro Setup
- Strange issue with Hitec 645MG servos on a dual pull-pull setup, Rudder and Elevator.
- Switches
- Flysky fs it4 telemetry and sensor placement HELP
- Futaba 8fg charging issue
- 2.4 JR 9303 Replacement Battery Concern
- Aloft Hobbies - A great company to buy from - FrSky - top knotch products
- Running tx off 12v wall charger.
- Proper gauge for RX battery charging
- High Torque Servo 23 NMs
- Carbon Z servo problems
- Trainer: Spektrum DX8 master with Futaba 7CAP slave
- TQ receiver to to TQ Radio?
- Servo "waving"
- Power HD 1214TH Servo Using alot of current
- Speed Controlls
- DX6i to DX6i "Buddy Box" ? How to please
- GT Power LED LIGHTS (Blinkers dont work)
- flybarless receiver
- interested in developing combination receiver/servo for rc application
- Park flyer receivers.
- Tactic 625 Receiver
- Where can I find A "GOOD" Screen Protector
- FrSky Taranus and companion software
- DX6i / Parkzone Radian Pro Motor Problem
- Is Airtronics pulling out of the RC market?
- servo voltage question
- Gear servo cycling
- orange tx
- Aileron and rudder trim is reversed on T8FG
- 18MZ Question for Futaba Gurus
- JR RG831B Receiver Weirdness
- We modify Hitec servos for you!
- DX-18 question
- WFLY TX module antenna
- Dual receivers in a 1/3 scale airplane
- servo with lots of torque cheap ????
- What type of battery setup is required?
- How to find an equivalent servo
- Why satellite receivers?
- Help! Need replacement remote for out of production r/c
- broken antenna help
- Data log
- Receiver,ESC, and servo problem
- Looking for advice on Auto pilots
- Jr XG14 transmitter programming pls help
- DX6i
- New Full Range"Anylink"
- FUTABA GYA430 -vs- JR G370A Gyro Comparisons
- Binding DX6i to Ares Gamma 370
- Servos operate off servo Tester But Only One Operates When Pluged into a Reciever
- need help , i can control my rc
- FS TH9X programing 3 way switch.
- Back in the hobby after 20 years, School me on the new radios please?
- Which replacement TX batteries?
- Need help with retract servo
- AVCS vs NORMAL Gyro Mode for Airplane Rudder Control on Take Offs
- hd servoes
- FrSky TFR6 question
- im back !
- Mini-HOWTO: Futaba Student-Trainer wireless setup
- Airtronics RDS8000 Parts Help
- Hobbyking tough electric servo reversimg
- Registering dx7
- Anyone use a JR 2.4GHz DMSS module (TG2.4XP)? Poor fitting on TXs.
- Tactic "Fuill Range Anylink" (pardon me....I guess!!!!!!)
- Radio brand
- Futaba GODS Futaba 7uaf super/pcm
- Jr 12 channel dsm rx
- Byron corsair flap servo set issues
- 2 servo Elevator does not stop at the same time?
- savox servos
- futaba 3003's and 3004's
- HobbyKing (Turnigy?) servos - RotorStar vs AeroStar
- Programming a Delta Vortex with a Futaba T14SG Need help with Elevons
- Jeti duplex ds16 / receiver r9
- DX18 can I use a PPM encoder? Connecting to Pixhawk flight control.
- 27 mhz synthesized tx?
- Help with Flysky FS-IT4
- What kind of radio problems can I expect with a steel tube fuselage plane?
- Endurance PCTx... NEVER ANSWERING EMAIL QUESTIONS!!!!
- Please identify old transmitter
- 72 mh Hitec cyrstals
- FS-T6 new
- Help Matching ESC to Motor, Battery, Manual Controls
- Receiver FS or HS mode - need help
- Futaba 9Z Transmitter Battery
- JR 8103 w/Spektrum ( mod ) ?
- Activating Eflite Retracts with Futaba 8FG
- Dx6i transmitter
- JR servo's VS. Spektrum servos
- hitec HS525BB servos-won't respond
- Old AM Transmitter to mate with my Airtronics 92123 receiver
- Help identify this ESC or Motor problem - Video included
- mato 8108r
- Can I assign a slider for throttle up on Futaba 10C?
- Power HD analog servos - pricing?
- Cleaning out elderly parent's house I found two 'digimite 4' boxes
- Fataba 8UAF setup Question
- Futaba
- fly sky gt3b binding issues
- New Spektrum DX6 with Telemetry
- Older Radios
- Jeti DS-16 transmitter charge jack polarity for field 12V charging
- DX7 Fail safe
- FX TH9X 9 Channel transmitter
- Need help don't know where to start
- Dymond R/C 01 D 1.5 Submicro Servo
- FS-TH9X Flysky, no throttle
- binding question
- Tower Pro SG90 Servo Centering Problem
- Single Stick Xmtr?
- Where do I start? I need your help!
- What receivers will work with a Futaba 3PM-2.4G?
- Futaba 8uaf to 2.4
- spektrum A6150
- Minima 6s won't bind
- Transmitter Question
- 645 MG with plastic spline?
- Anyone using a JR DS8900G tail servo?
- Window
- I got ahold of a hpi savage 21 and I dont know what transmitter I need to look for.
- DX7s Newbie: 4 Ch Rx Question
- Futaba 7C 2,4 Fasst ???
- Aurora 9 and Anylink
- DX7s: Extra Receivers
- Anyone have any experience with Endurance RC & Servo Commander?
- Spectrum DX7 and simulators
- Traxxas receiver board pin repair
- JR 28X / JR’s Flagship Radio!
- 12fg total reset??
- Need A 3 Channel Radio System And Servo
- Servo Problems?
- Futaba s9151 on 6v regulated?
- Window
- artronic servos be plugged into futaba recevier
- Fr Sky Taranis
- Will DX8 aircraft downloads be accepted by DX9
- RC 10 T looking motor swap
- Which receiver
- Upgraded Toys R Us "Baja Spider" motor to 12v motor, Need 12v Transmitter and Receive
- Servo gears...
- Can you guys figure out the problem with this R/C. *Pics included*
- JR 921 DSMX receiver dual battery hook up ?
- Are 8411 and 8611 gears interchangeable?
- Hitec Servos
- Problems with the Futaba "made in china" servo's, recievers, etc.?
- JR ST125MG servos
- tactic anylink
- savox SC-1233sg problem looking for some insight.
- Servo end point
- Jeti DC-16 mixer flaperons question
- Futaba 7c
- jr8411 servos whistling
- Graupner/SJ MC-20 Hott with OrangeRX DIY Module
- What is the current radio tech?
- 12FG Tx not communicating with PCMG3 RECEIVER
- Pin polarity
- Help needed for Annsmaan Virus 3.0
- Deans 3 Pin Connector Servo Adapters
- new futaba 8fg help ?
- Dual elevator servos
- Transmitter FS th9x
- ORX T-6 Range test.
- Taranis radios
- Hitec/FrSky receivers
- Transmitter unresponsive
- Ace micropro 8000 transmitter question
- blown receiver
- Anyone using Tactic radios for big planes?
- futaba 8fgh will it work for a plane
- JR Servos and slop
- Pro Line battery charger.
- Converting an old 72Mhz radio to 2.4Ghz
- airtronics mx-3
- JR DMSS Module and receivers
- Question about old FM radios vs new radios
- Tactic TTX 650
- Electric motors for sale cheap!
- IR pistol grip Tx?
- servo reversing question?
- Switching the Switch T12FG
- Need help programming jr 9303
- Replacement for Futaba 12fg
- T14SG Ailevator function
- Futaba 6014vwith smart fly
- Micro Servos For The Tactic TR424 Rx...........connectors ?????
- Airtronics Aquilla radio- Why?
- LHS servos
- Rebuilding my Rustler XL-5
- help, car wrong stop!
- Jeti-Duplex DC/DS-16
- ganging servo's
- Nomadio React Desktop software - help !
- Special servo plug
- 9503 Idle Up
- cgy750
- What servos for Seagull mxsr 91
- Question about high voltage power lines and 2.4 radios
- Wald Good-TTPW ground bassed tranmitter with control box no Receiver
- Tactic Servo info
- Receivers compatible with Futaba 6EX FASST
- Airtronics M12 thoughts?
- Futaba receiver prices
- Turnigy 9x dragonlink issues
- Problems with Value Hobby Servos and Batteries .... any suggestions?
- new switch?
- setting up a zyx gyro in a dx8
- Futaba 14SG on Flying Wing
- JR Z270 vs Futaba 3004
- What servos for Ripmax WOT4 Xtreme
- Specktrum DSM2 2.4 Air Module DM9
- Futaba T6J - Throttle hesitation
- FlySky GT3B - defeat reverse function?
- Tail Dragger RC Triple Servo Wing harness's (3 servo's, one plug)
- Hitec Optic 6 Sport 2.4
- New, Need help with TX, RX questions
- Dual MPI Switches
- Help Please!
- need help bad.. blade sr
- A little help..
- Feetech 28g/ 7kg/ .12 sec Digital Servo for Glider Wing
- Hobby King receiver
- Receiver advice
- Dont know what one to get
- Syren 10 - Sabertooth 2X25 Help needed
- counterfit servos?
- Futaba PCM compatibility
- reciever problems
- JR XP8103 update 2.4 or upgrade to new radio?
- Question about Futaba 12fg and Dji Phantom combination
- gas ignition TX/RX interference
- Is six Hitec HS 5955TG thru a JR 921RX to much
- Question about servo's and batteries.
- 14 mz programming advice needed
- The good (?) old reed systems days111
- Programming Spektrum DX 7, AR 7000 ?
- Dsm2??????
- Need tiny servos
- Affordable 2.4 receiver
- Blade 300x Receiver alternate?
- R770S 7channel 53mhz PCM Slimline receiver.
- Getting back in RC can any of my Transmitters be converted to 2.4
- Spectrum modules and receivers- 1st gen?
- Futaba 7c tx help
- HK 3axis stablizer V2 setup problem
- Jeti-duplex-ds-16-2.4-ghz
- Bms-620mg ??
- Why do Spectrum radios use Satellite Recievers and Futaba radios do not?
