PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Futaba 608FS-battery redundancy question
  2. Autonomous gyro help?
  3. Corona receivers
  4. specktrum dx7
  5. SPEKTRUM Misrepresentation?
  6. Assan modules and rececivers
  7. Used 14MZ thoughts?
  8. FS-TH9S or Turnegy 9x please help with this
  9. Servo voltage
  10. 1/3 scale Servo and power dist block help needed.
  11. Bind and Fly & TX-R (Anylink)
  12. 8fg updat Question
  13. JR Xp9303
  14. jr
  15. Futaba 6008HS vs 608 what's the difference
  16. Spektrum vs. Futaba?
  17. Anylink Tx-R and JR XF631 TX
  18. Spring RC servos
  19. new at rc and best starter redio
  20. Powerbox Cockpit SRS question
  21. Can someone explain to me how the rc transmitter/receiver works?
  22. INSIDE 8FG AND SD-10
  23. New 8FG Software V5.0!
  24. DSMX Tx Modude
  25. dx8 or HI-TEC AURORA 9CH
  26. Steering Problems.
  27. Futaba 9VAP - Service Menu & Mode Change Manual Available (incl. user password, calibration etc.)
  28. HK 2.4 rx antenna mount ok?
  29. Spektrum Makes Good!
  30. Futaba Region Code
  31. Henglong SuperSport Remote Issue
  32. How many servos?
  33. 2.4 Ghz technology question
  34. Dx7 ar7000 Failsafe
  35. Futaba 9Z - Unofficial Workshop Manual Available (Service, Repair, Reference & More)
  36. What would getting a better Servo actually do?
  37. 72 mhz super cub
  38. Sweet Hitec Special Deal Going Down!
  39. Orange rec. crash
  40. AnyLink on a JR 11X flying Sabre Jet!
  41. RECEIVER COMPATABILITY
  42. Is a module a receiver?
  43. 8FGS Switch Setting Problem
  44. Futaba 10CG
  45. Need HELP!! Spektrum 9100 Receiver
  46. Is my RX system faulty ?
  47. LED battery indicator for 8 cell NiMh transmitter battery pack?
  48. Walkera 22e receiver help
  49. What RXs work with JR PCM9 Single Stick?
  50. 8FG Super Impossible
  51. extreme conditions for flying system
  52. HS-5955TG burning issues
  53. Need help with radio system in Gs XUT Truggy
  54. Futaba has been busy lately.....
  55. 20 AWG servo extensions
  56. Another dual Rx question
  57. *** SERVO SUGGESTION? ***
  58. Futaba 18MZ Screen Protector Just Added...
  59. Moving Models from 9C to 8FG
  60. Very Strange servo problem
  61. JR ES579 servo problem
  62. JR ES579 servo problem
  63. NEED advice on servo for DEX410 V3
  64. Futaba 8FGS Airplane or Helo Versions?
  65. New to the Boards - RC reprogramming question
  66. dx7s and recivers
  67. Hellfire steering servo problem
  68. dx8 setup for Aerofly 5.5 on a mac
  69. Fut 14MZ &12Z in PPM mode
  70. 9C/TM8 with R6014 or other options
  71. Compatibility of jr rcvr and electrifly servos
  72. Binding R617FS to 8FGS problem
  73. R6008HS with 12Z
  74. 12X ENELOOP with 12X original Charger
  75. Double Jeopardy ?
  76. I'm a Newby Again
  77. receiver
  78. Hitec 5955 Question
  79. Carbonite gears OK for throttle on 4 stroke Radial?
  80. Servo recommendations for RC10B4.1
  81. SPEKTRUM DX10t
  82. hitec aggressor-lynx3d module compatibility
  83. One servo uncontrolled intermittently
  84. Warning Graupner USA HOTT SYSTEM
  85. Manual for Servo Driver
  86. Futaba SBus info needed
  87. Servo application question
  88. Stepdown from LiPo 2S to 6v
  89. 18 Mz 3-way switch operate flaperons-how?
  90. Transmitter
  91. Virtual Futaba 18MZ
  92. Hitec Electron 6 FM RX
  93. FUTABA R5014DPS
  94. 80's Era JR PCM9 w/RX Value
  95. DX6i ... is it sufficient?
  96. 8fgall dual rates on one switch
  97. Servo horn for Futaba S125 sail winch servo
  98. Quality cost effective RX compatible with Futaba 6EX 2.4GHz
  99. channel 5 and 6?
  100. RF output
  101. Constant Tone PZ Trojan Receiver
  102. New JR Radio
  103. anylink
  104. buying a used Futaba 6EX
  105. Question for Futaba pilots
  106. Help select Servo and Batteries. 1/8 Buggy.
  107. help -elevator servos
  108. running a dc motor from a servo
  109. Spektrum Evolution Rx
  110. 9C Super and FASST Module - any tips or advice?
  111. universal digital servo board?
  112. Spectrum DX7 BUZZZZING
  113. what lipo i can put in transmiter gt-2
  114. getting back into the hobby and i'm lost
  115. One Arm RC Flying
  116. Charging 14mz without 120v
  117. 12fgh programing help
  118. Dymond Radio
  119. The new DX8 vs the new 8FGAS
  120. HK Servos?
  121. Hitec A9 and BNF?
  122. What transmitter recomended me?
  123. Heli wont take off
  124. From NIMH to LIPO?
  125. Futaba T6EXAP with HiTEc Micro 05S?
  126. Tamiya Mdnight pumpkin Radio
  127. Rock crawler motor upgrade help
  128. 12Z FASST and MPDX-1
  129. Stuck in scan mode
  130. Burned out receivers
  131. 12X Transfer Blues
  132. Futaba 7C 2.4 vs 8FGA 2.4
  133. 2.4Ghz Compatibility
  134. What wil JR do to match the 18MZ?
  135. Karbonite with gasser?
  136. DX7 duel aielron servos
  137. binding receiver
  138. Corona R8FA 2.4Ghz Fasst Compatible Receiver
  139. Wfly 7 channel tx and rx?
  140. 12x charging fuse
  141. Kraft Radio
  142. How many servos on a stock reciever?
  143. January 2012, what is a good first radio today?
  144. Non Futaba FASST RXs
  145. Servos are twitching severely, Fut7C, R6106HFRX,DS410's
  146. Futaba crystal in a GWS radio
  147. TQ3 Radio 27Mhz Sporadic Throttle
  148. Removable transmitter switch plates
  149. PLS HELP. 1/12 scale Rock Crawler
  150. Spektrum Aircraft Telemetry RPM Sensor & Bracket - SPMA9569
  151. JR 10x Gimbals
  152. FrSky DHT Module on Futaba 7CAP
  153. Savox servos
  154. 8FG Upgraded To 14 Channels
  155. Turnigy 9x: is 7.4v Rx Pack OK?
  156. LiFe Rx Battery
  157. Lst 1 servo
  158. One Millisecond Stepping Servo Tester
  159. servo wireing
  160. What servo do u suggest? have a few Questions
  161. PLEASE HELP ME with my jr racing XS3 remote
  162. Using correct sized servos for .60-.90 size sport models
  163. Futaba 6J question
  164. Terrible service from Horizon Hobby
  165. The XQ-POWER Servos for Lastest News
  166. Futaba 7UAF Super and 8 UAF radios
  167. AnnMarie Cross Futaba 18mz manual
  168. PZ servo's (not parkzone)
  169. Futaba 10cag vs Aurora9 vs Airtronics sd10g
  170. DSMX Receiver not labeled as DSMX ?
  171. Hi-Tec servo
  172. Futaba 8FGS Switch question
  173. Graupner MX-22 horizontal line across screen after shutdown.
  174. Servo sizes?
  175. FUTABA 12FGA Questions
  176. Anyone did an Aurora 9 three position switch reversal.
  177. wrong thread do not know how to delete thread sorry
  178. servo help
  179. Hitec Programmer????
  180. rudder servo chatter with gyro installation
  181. European radio
  182. Regardig servo torque ratings
  183. Can I use 5 cell on airtronics 94102 servo
  184. li-op with regulator wiring help
  185. Futaba S3010 servos listed as 'Nicad use only'
  186. DX6i Reverses channels by itself
  187. Compatibility Between Radios & Hardware - Need Some Help Please.
  188. Futaba Futaba 3PMX Surface Radio Dual Rate Steering???
  189. Futaba T18MZ manual.
  190. Momentary toggle switch for 9303 tx? SOLVED!
  191. futaba Wireless trainer system WTR-7 with a 9ZAP
  192. Blast Fron the Past
  193. Hitec 7955tg servos junk
  194. Spektrum AR6200 replacement
  195. Range check problem with Jr11x zero
  196. DX7 VIBRATION & AUTOTIMER UPGARDE
  197. 2.4 range check fail!
  198. good inexpensive 6 ch airplane radio?
  199. rd6000 Airtronics
  200. what should I be looking for in a metal gear servo?
  201. Spektrum 10DXt
  202. Help with servo selection
  203. Is my Velineon VXL 3s garbage or warrantied?
  204. Amp draw from Futaba
  205. Hello Futaba forgotten 12fg user here
  206. Futaba 6J
  207. Futaba 10 C stolen
  208. Feedback ACOM 2.4
  209. Futaba FASST 6008HS
  210. Old Hitec ESC, question
  211. Counterfeit Spektums ??
  212. Savox servo potentiometers
  213. powerbox cockpit
  214. new to this stuff, receiver ?
  215. 2wd Losi 22 Servo
  216. Futaba 12Z transmitter update
  217. Problems with dual ailerons non response in ch 6..
  218. Help with Jr11x zero
  219. Futaba 7C transmitter Airplane or Heli?
  220. Computer Tx Resource?
  221. Hitex HS-5625MG Servo Arm Screw Size
  222. AR9200 PowerSafe Evolution Switch Hook-up
  223. Futaba BLS174 HV servos available when?
  224. Spektrum DSMX
  225. Futaba
  226. Transmitter Battery Choices
  227. 8FG Update 4.1 Question
  228. New giant scale rudder servo development
  229. Using a heli radio on a car...
  230. Parkzone Ember2 radio buddybox-able?
  231. Slowing Retract Servo
  232. selling antique radios on ebay, how much to ask?
  233. Futaba 9C Super Display Screen Replacement
  234. Did Hitec drop the ball??
  235. Slowing Retract Servo
  236. Dymond D 5000 MG BB M servo
  237. The Best After-Sales Service
  238. Spektrum DX7 failure
  239. Dual rcvrs
  240. Retract end point question
  241. DX7 + AUX1 + SMOKE
  242. homemade extensions for satellite antenna's ok?
  243. casing for dx7
  244. Second Plane Servos
  245. Question about running 2 brushless setups.
  246. Second Radio
  247. Resolution question with Hitec servos
  248. Hard lineing a TX to RX
  249. Futaba T4VF brand new, not working, glitch... what's the problem??
  250. E-flite servos
