PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Cirrus fm cr-217a receiver antenna wire length? how long
  2. smart fly eq10 question
  3. Futaba10C has no RF on low power
  4. DX8 RPM ON GAS
  5. I need your honest opinion.
  6. Radio suggestion
  7. Servo control voltages
  8. Radio brand compatibility question
  9. Which controller for Leopard 2A6
  10. Futaba R6014FS & JR Servos compatibility
  11. Twin aileron 5645's really slow
  12. Servo arm thread lock
  13. Should Hitec replace planes from lock outs
  14. Cloudy Display on Spektrum dx6i?
  15. Anyone using a J-Tec (JR with Hitec Module)?
  16. 2.4GHz - lost radio
  17. Lost radio
  18. Spektrum...Futaba..............
  19. JR 922 Receiver "Soft Switch"
  20. NoBS Batteries/Hang Time Hobbies Batteries
  21. reciever lites blink when turned on
  22. Radio interfearence
  23. Need right gimbal for Dx6i
  24. HELP with my old Futaba 3PJ radio controller and Futaba receiver
  25. Any experiences with the current range of Spektrum servos?
  26. Quick Change Aurora 9 and Optic 6 72Mhz and 2.4Ghz Antenna Mounting Mod
  27. transmitter battery
  28. Understanding Hitec Aurora 9 Updating, SmartScan and linking
  29. JR XG8 8ch 2.4GHz Radio System Built-In Telemetry Black
  30. Best 9C Conversion
  31. Spektrum Power Box 9 ch RX
  32. frsky quality
  33. Aurora date of manufacture
  34. Spektrum RX for DX6i
  35. Can Transmitters go out of calibration?
  36. HK-3000 3ch 2.4ghz FHSS RX compatible with Futaba 3PL?
  37. Futaba FP-T6NLK
  38. Radios in the UK
  39. Motor for wind turbine
  40. Program a landing mode
  41. Futaba 12z
  42. Spektrum receivers
  43. Buddy Box
  44. Spektrum prices ? ? ?
  45. Futaba R617fs and R6208SB with Hitec servos
  46. Turnigy 9X Trainer Port Fix/Hack
  47. FUTABA TELEMETRY
  48. Horizon Hobbies product support
  49. JR Transmitter
  50. JR R921 Receiver battery question
  51. Need major radio help before i blow it.
  52. Radio
  53. Brownouts....
  54. Still having electric problems with my spektrum controlled hobbyking Phoenix 2000, + Crashvideo
  55. Radio help.
  56. what reciever
  57. Can Servos Be Indexed for a Specific Arm?
  58. Switch settings for 12FG
  59. 12X Programing Help Needed for Fixed Wing
  60. Static Servo Setup using DX7
  61. Open Source Remote Control System (OSRC)
  62. Exponential on 12FG
  63. Need a new BEC
  64. hobbyking's HK-t6a for sim under window7 64bits
  65. R617FS vs. GWS elevator servo not centering
  66. Can't Link FUT 6008HS ?
  67. Do I need a larger capacity battery for my Rx.
  68. Spektrum DSM2 AIRMOD JR
  69. DX3S or Futaba 3PM-X
  70. Big servo for use in Elevator Trim Tab Ultralight Airplane
  71. Binding difrent brand TX RX Combos ?
  72. Futaba FASST Transmitter max voltage.
  73. Corona 2.4 for Futaba....concerns
  74. 12 FG triple rates on ONE switch
  75. Rhino 2620 3c 11.1 Transmitter battery
  76. Ignition Switch/Charge Port & 2.4GHz RX
  77. Futaba R617FS receiver
  78. Futaba 18MZ
  79. Hitec JR Module 2.4 AFHSS spectra
  80. Servo Programer/Tester?
  81. digital servos
  82. *SD-10G Idle Up Switch*
  83. DYMOND AERONCA CHAMP SERVO HELP
  84. Kudos to Futaba service
  85. $100 Servos Help!!!!
  86. HS5945MG
  87. Looking for TX balancer.
  88. Servo speed specs - what do they mean?
  89. JR DX11 crow set up.
  90. 2.4 glitching?
  91. Transmitter
  92. Why don't the volt watchers work w/2.4ghz
  93. Futaba 8FGA 2.4 Radio
  94. Transmitter / Reciever match
  95. Futaba 7c 2.4 Ghz Transmitter
  96. 12FG charge connector
  97. Dual elevator setup
  98. Hitec 5955 vs 7955 ???
  99. 14 MZ program fix
  100. Futaba 12FG edit button
  101. suggestions help for new surface tx
  102. Corrosion caused the crash
  103. 7c fasst
  104. ailvator
  105. Airtronics Servos to Futaba FASST Rx
  106. CopterX servo help.
  107. Anyone here using 466mhz UHF?
  108. Travel-size, compact, portable transmitter (TX)
  109. SPCM rx antenna question
  110. Question for Futaba 7C 2.4 owners
  111. RC Simuator for Mac
  112. Futaba 4YF Schematic?
  113. Throttle issue with FS-GT2 and Turnigy ESC
  114. Crystal Change
  115. Hitec Spectra Module teething problems
  116. twitching servo
  117. DX6i Range
  118. Spektrum binding issues
  119. DX6i With PCTx problems?
  120. 35% radio/servo/battery setup question
  121. Anyone using this Servo Power Board from Servo City?
  122. JR 50Mhz Rx. compatible W/ 53Mhz crystals ?
  123. Futaba FP-5NLP legal ?
  124. Ace RC Silver Seven SS Manual
  125. R617FS Fail Safe and Rx question.
  126. Spectrum DX7 Battery problem-My Fault
  127. DX6i-Slaving a servo without using mix (?)
  128. Kraft aerial
  129. Any place that has a sale on JR servos?
  130. Spektrum DX7 or JR XG7? give me suggestion plesae!hay all, I'm confused to choose a good radio for m
  131. Pos shift receiver ?
  132. *SD-10G Keep Losing Expo*
  133. Looking for a new Transmitter.
  134. FASST vs FHSS
  135. Dx10T delivery date?
  136. Are these analog or digital?
  137. 12Z Gear/Door sequencing question
  138. New Futaba Transmitters
  139. Futaba EXA 6 buddy box connector signal
  140. Futaba 7C 2.4 flaps set up
  141. Older Futaba r/c system, worth anything?
  142. Fast charging a Futaba 8FG?
  143. Spectrum slow link!
  144. US DAD SERVO
  145. US DAD SERVO
  146. Spektrum Question
  147. Hitec Aurora 9-Channel 2.4Ghz - yes or no?
  148. Futaba Transmitters Reverse
  149. Li-Po Batteries for Multiplex Transmitter
  150. Step by Step Hitec Aurora Throttle Cut Programming
  151. Battery noise ?
  152. FASST BNF compatibility?
  153. NS-05 servo problem
  154. 6DXi dualail travel adjust prob
  155. Futaba 8fg battery
  156. Spektrum DX7SE ds DX7S
  157. Need help with Futaba 8UAS TX
  158. hobby king equivalent of hitec 645 servo?
  159. Cortar cable antena Receptor Corona 2.4 (Receiver antenna wire cutting Corona 2.4)
  160. 10C Knife edge mix with two elevator servos
  161. Hitec 2.4 telemetry
  162. JR radio question
  163. Virtual caller
  164. Wiring help for separate retract batt for JR S791
  165. Retract cycling
  166. 2.4ghz metal on metal interference
  167. Need help with my first build
  168. Jato steering problems
  169. Redundant Receivers ??????????
  170. Smartfly Power Expander
  171. Eflite 3 in 1 and spektrum receiver in Venom Beacon
  172. tactic ttx240 2.4ghz DEFECTIVE ANTENNA BASE.
  173. How to tell a servo is dying?
  174. Hitec HS 5645-MG servo that's acking weird.
  175. Spektrem DX7
  176. can digital servos be repaired?
  177. HS-56 for throttle?
  178. hitec 2.4 module for JR 10X
  179. Hitec Aurora 9 Delta Wing Programming or Elevon Programming
  180. JR9303 advice
  181. Looking for a switch
  182. E-flite servo arms
  183. 12X new style charger??
  184. $53 for 9ch 2.4ghz tx?? any info?
  185. 11x Question
  186. Adding satalites to DX8 receiver
  187. DX8 Update question
  188. USB DSM2 Receiver?
  189. Futaba PCM failed-This never happened before
  190. Advice on Servo's BEC and runaway boat required.
  191. 2.4 module?
  192. DX 8 Help
  193. Am I trying to do the impossible?
  194. Futaba super 7 2.4 conversion??
  195. Receiver
  196. Power hd 1501mg - servo arms not Futaba!
  197. Eflite electronics in a Venom Beacon
  198. Futaba 6ex RX's
  199. Spektrum DM9 question
  200. Is this 2.4 module okay?
  201. ACE Radio's?
  202. 6V RX battery : is a BEC required ?
  203. Hitec servo with Futaba Fasst radio questions
  204. Bind and Fly? What is this?
  205. fubata 6 ex
  206. Help with HK-T6A V2 Mixing
  207. Radio problems
  208. Will Spectra Pro Come with antenna?
  209. Futaba 18 MZ
  210. equalizing aileron travel
  211. Record of your Aurora 9 Switches and Mixes
  212. deleted
  213. Hitec Aurora 9, Futaba 8FG Super, Spektrum DX8, Airtronics SD-10 - Fight!
  214. please help
  215. Hitec Customer Support
  216. Weird problem with EXI servos
  217. Orange RX
  218. HOBBY KING $5 ORANGES
  219. Forgot to turn off my XP9303...not good.
  220. Futaba 10CAG vs 8FG Super - pros and cons
  221. DSM2 and DSMX satellites
  222. I need a $200.00 Tx/RX
  223. Did I fry my Rx or what?
  224. ESC Location
  225. servos for 50cc geebee r 4
  226. SEARCH SERVO
  227. NEW DX7s at Horizon....
  228. New Spektrum Radio- Anybody Preordered yet?
  229. Orange Rx Binding Instructions
  230. Futaba 9caps- How do I assign a channel?
  231. reversing servo
  232. Futaba FASST versus Futaba FHSS
  233. mt-4
  234. No DX7. Now what?
  235. Futaba,Spektrum,JR,Hitec,or Airtronics,which is you favorite radio company?
  236. DX5e Switched from Mode 2 to Mode 1
  237. 1976 MRC Series 765 - 5-ch Digital Proportional
  238. DSX11 vs HITEC AURORA 9
  239. Futaba 8FG Super - Conditions Mode
  240. Futaba 6exa 72mhz Not Beeping?
  241. Receiver options
  242. Servo Cross Reference Guide?
  243. Customizing your Transmitter
  244. Fail Safes
  245. replacing old equipment
  246. Fair price for a 9zap?
  247. dx8 aileron differential setup
  248. HITEC AURORA 9 OPTIMA BODA CHECK
  249. Help: how to set DX7 heli mode for plane
  250. Question on Aurora 9 Curve point
