PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. 14MZ question
  2. Orange Satellite Rx compatible with Spektrum Rx?
  3. Radio for Rc Car
  4. Time Capsule!!
  5. Help with flysky gt2
  6. JR gyro ?
  7. RC for Dummies, Can you tell me what I need..
  8. hobby king recievers
  9. help with dx7 model match
  10. eFlite g110 use in airplanes
  11. TX li-po for Futaba 8FG
  12. Futaba GY-240 gyro in a plane ?
  13. Hitec A9 the only rx/tx that I can't get to work with GP780 gyro!
  14. Are all 2.4 GHz satelite recievers the same?
  15. Receiver for Spektrum DX6i
  16. Throttle trim problems with cheap radio?
  17. New and ready to modify!
  18. dx7 aileron control
  19. No joy- LOST in mail
  20. Planet T5 support for multiple models
  21. A new addition to my radio cabinet...
  22. engine life
  23. RDS8000 screen goes black in sunlight
  24. Futaba 617 Rx / Hitec 7955 servos - Compatible?
  25. Turnigy 2.4 9X Transmitter Manual.. Where?
  26. JR Trmtr. Snap Roll Switches & additions
  27. Possible Aurora 9 problems
  28. FS Tx Charge Plug
  29. Motor shuts down moments after throttling up.
  30. JR reciever
  31. Receiver with SMA connector?
  32. Best radio money can buy 2011 ?
  33. Tactic radio upgrade
  34. AR7000 will not hold bind ?
  35. Motor causing Rx interference?
  36. Servo AMP draw while in motion
  37. Ahrrgg! "R 149 DP"
  38. Frequency ?
  39. 12FG and gear doors
  40. TGY 9X very short range !!
  41. Futaba 8FG 2.106 Beta software released in Germany
  42. RPM sensor for DX8 radio
  43. JR X9303 Doesnt Turn On
  44. Don't Miss This ! Airtronics SD-10G with 10 Channel RX...for $ 379.99
  45. JR Gyro (NEJ-120A)
  46. "JR" new 2.4 is called DMSS????
  47. antique tx & rx
  48. Receiver wiring burining up
  49. gyro modification?
  50. R149 Dp Rx-Tx compatibility?
  51. Throttle cut for DX 7
  52. 2.4 - Why Are They Failing?
  53. Do I need a voltage regulator for reciever.
  54. ESC and UBEC
  55. 2 rx for planes
  56. I found an accurate RC receiver circuit diagram
  57. cheaper 2.4 full range with trainer
  58. 1 or 2 RX Antenna?
  59. Dual RX set up ?
  60. Upgrade Rustler VXL to 2.4ghz
  61. fly sky g2
  62. servos
  63. LIPO for Futaba WC2
  64. Transmitter programming questions
  65. corona 2.4ghz DIY help
  66. FS-GT3B 2.4G RADIO anyone got one???
  67. New Radio Arrived Today!!
  68. radio gear
  69. Hitec Aurora 9 + gadgets
  70. Transmitter Storage - Fuse Contact Corrosion
  71. Airplane Throttle Hold - Futaba 8UAFS
  72. FlySky FS-TH9X 2.4G 9CH System (TX + RX)
  73. A123's (unregulated) and (Spectrum) DS821 & (HITEC) HS85
  74. Frsky 2.4 Gig Question
  75. 10X and Quadwing Problem
  76. 2.4 ghz transmitters legal in US ?
  77. Vintage radio Conversion to 2.4
  78. HELP SERVO IDENTIFICATION PLEASE!
  79. Are the dirt cheap transmiters causing interference?
  80. delta wing mixing on a ct6b Tx
  81. Upgrades for Optic6 Sport and Optic6 Sport 2.4GHz now available
  82. flysky tc6b tx and rx
  83. battery discharge
  84. Need help with T7C
  85. Tower System 2000 TS-65 Equivalent
  86. Beeps from my T6EXAP
  87. Dumb question ...?
  88. Dual servo surface draw test
  89. Did I kill my futaba FP-T8VAP
  90. Futaba S-Bus?
  91. Merry Christmas
  92. Genie screw drive lube for servos
  93. Reciever size really matter??
  94. Servo issue
  95. gyros??????
  96. 2.4 Receiver Batteries
  97. Having Radios Serviced
  98. Futaba GYA 350 gyro
  99. How do you like your 8FG?
  100. High Voltage Servos
  101. Buddy box and mixes?
  102. RDS 8000
  103. rd 80000 conversion Help
  104. Transmitter battery door keeps falling off!
  105. How do you know if pcm radio?
  106. AR500 or HK Orange Rx
  107. Dx8 master to DX6i slave?? Cannot get to work!
  108. [Help] What RC Car should I buy?
  109. Compatibility between brands
  110. 2.4 Dilema (module or new radio)
  111. SwitchGlo Pro
  112. AR500 Receiver
  113. DX7 Service Bulletin
  114. Receiver for older type Futaba transmitter
  115. Optic 6 with trainer?
  116. Hitec program and transmitter center not the same
  117. How to set the DX7 for HB V2?
  118. Does the DX7 works just with a 7ch receiver? Like AR7000?
  119. Futaba magnum t3pdf
  120. Beginner, need advice and info.
  121. 12FG Logic Sw Question
  122. Airtronics MX-3 FG and Receiver
  123. Help, I'm a beginner at elect flight.
  124. Lipo and my 9Cap?
  125. Dual Elevator servos.
  126. Futaba 12FG dummies guide continued.
  127. additional info telemetry radio's
  128. Jr Fm to 2.4g? I know nothing!
  129. Six HS-5645mg Servos
  130. Futaba 12FG Flaperon solution that works!
  131. dual receivers
  132. Experience of JR DMSS
  133. Futaba 12 FG Dummies Guide
  134. JR NER-226X Receiver Replacement
  135. Replacing Futaba 8UHFS
  136. Aquacraft RX/ESC combo
  137. HD-3001HB standerd servo problem
  138. is a Mini servo drawing more amps?
  139. Multiplex RX12 DS IPD
  140. 8FG - Sticks On Different Channel By Switch?
  141. 12FGA or the 12Z?
  142. What is Hitec and Futaba waiting for?
  143. FUTABA 14MZ
  144. Sullivan Skywriter Amperage draw??
  145. dx6i spektrum mixing
  146. DX7 Crashed Two Planes
  147. Make Esc and Servo Work on the same Channel
  148. Turn and brake signals
  149. Corona CR4D New Version?
  150. hs 81 vs dymond d200
  151. Spoileron Programming for DX7
  152. Futaba RX's & Servos: NO Lithium Bats, 6v Max??
  153. remotely controlled multiple servos
  154. anybody with futaba 12fg and 8fg
  155. receiver mounting question.
  156. Futaba 4PL vs Airtronics M11
  157. Receivers and batteries
  158. DX7 vs Aurora 9
  159. Futaba 8FGA or Airtronics 10SD
  160. X9303 Dual rate set-up problem
  161. Hitec Optic 6
  162. 12FG Module pins
  163. DX7 vs. DX8
  164. Bad Jitter On 6V (Futaba R138DP)
  165. Digital servo affecting analog servo
  166. ko propo helios ex-10 wont pair up
  167. First timer looking for RTF plane
  168. HD POWER servos any good?
  169. Receivers for Futaba 2.4Ghz
  170. Modifying Futaba 6ex to Fly- Dream 2.4GHz
  171. Air Filter Maintenance
  172. PRO-LINE UPdate
  173. STICK ENDS
  174. Switches for a Futaba FP-T7UAP
  175. Help on servos
  176. Regular servo on retract channel?
  177. Servos
  178. Looking to upgrade my old futaba radio system.
  179. Do I need ESC for operating servos?
  180. Airtronics Digital Servos
  181. Hitec RX/TX comms problem
  182. Hitec 2.4 Binding, Changing Modes, and Range Checking - Cheat sheet help
  183. 2.4 diy conversion
  184. Futaba mz 14 Fully integrated 2.4???
  185. DX8
  186. Channel expander
  187. Spektrum DX2S questions
  188. Cold hands? You need a hot box.
  189. Adios, Hitec
  190. JR QUALITY CONTROL.9303 Tx.-SUCKS.
  191. Futaba 8 FG Programming Guide
  192. Futaba to JR Servo Adaptors
  193. Raptor 50 Super Combo Servos
  194. Changing shift on JR Transmitter
  195. HiTec Aurora 9... Optima Receiver 7 vs 9 ?
  196. Corona RP4S1 reciever operation voltage
  197. JR DMSS (JR's own 2.4)
  198. Tower TS-35 mini BB servo any good?
  199. PPM vs PCM
  200. Lower Airtronics Prices
  201. Futaba FAAST vs Spektrum/JR Spread Spectrum
  202. JR R700 Flutter on 4 different Rx's
  203. Converting Mini Cub to 2.4ghz?
  204. rx tx problems
  205. LiFe battery questions?
  206. Hitec Servos on a Y cable to a channel
  207. AR9100 lost signal - need help
  208. How Critical is the Rx antenna length?
  209. 2.4GHz receiver antenna and battery
  210. Optic 6 2.4
  211. McDaniels "Go Slow"
  212. A blast from the past
  213. Choosing new radio
  214. Why Futaba does not offer BNF?????
  215. Need some controller suggestions
  216. Great Service from Horizon
  217. 6volt receiver pack?
  218. Problem with HK servo extensions!!! READ
  219. Worth Converting my JR 347 to 2.4???
  220. Push button Micro Switches
  221. Radio for quadrotor - 4 mixing channel
  222. Futaba 6008hs high speed back to normal speed
  223. Changing the input/sticks
  224. rc radios
  225. Using Futaba S9452
  226. Fly-Dream
  227. What DON'T you like about your Tx?
  228. Programming Futaba 6EX for U-Can-Do 3d 60
  229. What to do with a dropped servo?
  230. HITEC Telemetry Test Flight
  231. VG400 to usb
  232. Futaba 12FG, which switch/dial for what?
  233. Trying to decide on a radio...
  234. Stripped Servo Horn Screw
  235. How do I read metric on torque on servo
  236. Futaba new T6J 2.4GHz
  237. FrSky HV receiver question
  238. Traxxas Slash stutter.....
  239. In The Market for New system
  240. Ofna Ultra MBX Comp + Futaba FASST 3PM issue
  241. Futaba transmitter data transfer help
  242. Antenna wire ?
  243. Antenna Length on 2.4GHz
  244. Spektrum stutter
  245. hitec aurora 9 german software?
  246. *mod plz delete*
  247. Spectrum DX7 system problem
  248. Any problems with Hitec 2.4?
  249. hitec aurora9 vs dx8?...please help
  250. Tower Hobbies 5 Ch Electrifly reciever question.
