PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. JR X9303 backlit screen
  2. Karbonite gears and small gassers
  3. Good service.
  4. 3-axis Gyro for Airplanes???
  5. Airtronic's digital servos
  6. Offroad Radio: 4pk or DX3R?
  7. Which Futaba 2.4 Receiver to Buy
  8. Resolution
  9. Little gimmick with JR DX7
  10. Standard Servos
  11. Kraft receiver
  12. New copterX cx-ct3a 3ch 2.4G radio
  13. Spectrum 9100 with dual a123 packs
  14. buddy box question
  15. 6EXAP Futaba transmitter acting screwy
  16. JR 9503 issues
  17. FHSS VS DSSS Technology.
  18. Old Futaba 7FGK FM-AM modual swap?
  19. Blown Traxxas receiver #2218
  20. Radio Programming
  21. JR DS 8301
  22. Fut 7c 2 aileron servo, eleavtor, rudder and steering
  23. Spektrum Servo Buzzing
  24. dual elevator
  25. Futaba 2.4 system question
  26. 3PB question:Loosing Fail safe with ESC..why?
  27. Dual rates
  28. Testing transmitter with an oscilloscope
  29. best radio to grow with?
  30. cold hands!
  31. Programming Throttle Curves on specific JR radios
  32. 10 cap 2.4
  33. Tower TS-53 with JR trans/receiver?
  34. Skyartec 702
  35. Futaba 12fg with hitec 2.4hz module
  36. lanxiang 2.4ghz tx/rx
  37. Futaba 12ZAP
  38. XMTTR Voltage reading adjustment?
  39. Futaba 12ZH Alarm
  40. 14MZ broken switch
  41. Futaba 12z Wing / Tail Types
  42. Hitec Servo Extension VS Aileron Extension
  43. Reversed
  44. Where can I buy a Weatronics and will it work with a 14MZ?
  45. TX Battery low warning with Lipos
  46. TRANSMITTER SIGNAL?
  47. JR Radio History & Pics
  48. JR Gyro / Futaba TX/RX Compatability
  49. Need some quality servo recommendations!
  50. Futaba tx-6
  51. Sullivan Glow Driver
  52. precision micro servo?
  53. Futaba 9C and Hitec Spectra 2.4 Module
  54. Faulty Futaba S3004
  55. Servo question. Enlightenment, please!
  56. Radio question
  57. SD-10G: New FHSS-3 Rx coming soon!
  58. changing gimble springs futaba 9C
  59. Futaba 12FG - is it worth it to upgrade to Li-po
  60. Something strange with Speck rec.
  61. CAD Drawings for Spektrum DS821 Servos?
  62. 12z - Simple Question
  63. JR 652 VS JR 6102
  64. Plastic tubing around 2.4GHz antennas
  65. Custom Transmitter Carrying Case-Help
  66. JR DS8411 Metal Servo Horn/Arm Hunt
  67. power hd servos
  68. MY HITEC HS-605 BB PROBLEMS CONTINUE
  69. need help on servo topic
  70. *What's Next For Airtronics*
  71. Futaba 8FGA vs Spektrum DX-8
  72. Change 27MHz Receiver Channel (no crystal)
  73. Futaba / Airtronics / Spektrum which one?
  74. Cheating
  75. Heli Gyro recommendation
  76. DX8 default framerate
  77. Switching RC transmitter chips from different RC toys
  78. 2.4 conversion confusion
  79. DX8 Bind Problem
  80. Tx up to 550$ for turbine jet
  81. Receiver sensitivity
  82. Are AM radios still allowed???
  83. # of radios used
  84. Looking for channel 35 JR reciever
  85. Looking for Airtronics ATX-style "Y" connectors
  86. Need Help for the exceed 2.4 6ch: (throttle)
  87. I got my new DX-8
  88. Futaba dropping all NiCads?
  89. Need Advice from the Pros...
  90. Spektrum DX8 as heli radio?
  91. Transmitter virus (?)
  92. FUTABA 10CG Servo-Slow Capability
  93. changing chnls
  94. Futaba 2.4G FHSS alternate receiver?
  95. Spectra 2.4GHz Transmitter Module in my Futaba 9CAP
  96. servo nosie
  97. T14Mz - Futaba Logo blinking Yellow
  98. Why Do I Need A PowerBox?
  99. Servo play
  100. JR Servos/Corsair Flaps
  101. y harness w'reverser problem?
  102. Corona Receiver and Futaba
  103. Using Futaba T7CHP for Clear View or other SIM
  104. Turnigy 620DMG+HS High Torque Digital Servo (MG
  105. Controller Help
  106. Futaba PCM receiver acting strangely
  107. help programing the 12FG futaba
  108. Which RAdio to use
  109. HobbyKing Orange DSM2 compatable receiver
  110. Goin Back to 72mhz PCM
  111. 72 mhz to 75 mhz Conversions?
  112. Futaba servo Oscillates
  113. using an RDS8000 as a buddy box to an RD8000
  114. FrSky 2.4Ghz for JR Tx
  115. BASIC: How to set up zaggi delta wing on my dx7?
  116. HS 7954
  117. Might buy Airtronics 2.4 8000 radio
  118. 12fg throttle cut
  119. Flying Wing - one servo not centered
  120. Range checking a 72 mhz FM system
  121. How to connect aileron servos top and bottom on bipe .
  122. Telemetry.
  123. Its time to upgrade to 2.4
  124. HobbyKing OrangeRx Futaba FASST Compatible 8Ch 2.4Ghz Receiver
  125. JR DS8411 vs Futaba S9155
  126. programing JR 11X transmitter
  127. Air Transmitter Modification Question
  128. spektrum or 2.4?
  129. traxxas help
  130. 2.4 GHz range check how?
  131. Best 6-8ch. Transmitter (Horror Welcome too)
  132. Switch failure
  133. crow programming with 7 ch recv
  134. Futaba 12FG Battery
  135. NEED HELP ON A GYRO
  136. Hitec Optima 7 died in-flight yesterday.
  137. JR 370 3D Gyro Installation
  138. 4PK Radio masks
  139. Help my tt-01 apparently does not accept traxxas 2.4 ghz reciver and radio
  140. magnets interfering with radios?
  141. unresolved rx problem
  142. Dynond 2.4 trans conversion from 72MH
  143. Futaba 9156 or Hitec 7955MG ???
  144. eurgle 9ch 2.4ghz
  145. throttle twiching
  146. Converting JR 10 SXll to FASST
  147. Futaba R6014HS Question?
  148. JR Z650M servo ?
  149. JR-Spektrum Frequency Hopping coming soon..??
  150. Can you convert old Airtronics to 2.4GHZ?
  151. Battery Life 2.4gig vs 72 mhz
  152. What exactly is a binding plug?
  153. Calibrate throttle-stick Futaba 14MZ and FX40
  154. 14MZ Fraud
  155. Futaba 9C Mixing question....
  156. JR 10X converted to 2.4 with spektrum
  157. Hobby King 72 to 2.4 module conversion
  158. Hobby King 2.4 conversion modules for Fytaba 8UAP
  159. Spektrum 7 Radio Battery Wiring Question:
  160. Aurora 9 Flap to elevator mix
  161. New Spektrum Telemetry, does it works for JR?
  162. Module compatibility for old JR PCM10?
  163. Restore old transmitter
  164. Two days of flying, two burned out servos...?
  165. Airtronics now in the Radio Manufacturer Direct Support
  166. Cheaper recievers compatible with JR TX
  167. 10C ailevator not working with pmix
  168. good standard size servo from HobbyKing and cheap?
  169. OrangeRC FASST compatable Rx's
  170. 72 nhz-How much longer???
  171. New Radio
  172. JR Receiver and Servos
  173. deans ultra to JR plug
  174. upcoming Spekrum DX8
  175. spektrum help!
  176. TRANSMITTER PROBLEMS
  177. Futaba 8FG Question
  178. Spektrum Module Cover
  179. What has gone wrong here ??
  180. Spectrum DX5 question
  181. Futaba T7CAP - Throttle Inoperable
  182. HobbyKing.com Swarm Sale - DS480 Digital Servos
  183. MOVED: Airtronics TX charger Help
  184. Futaba TP-FSM module in 9CAP super
  185. JR X347
  186. 8UAP UPGRADE TO 2.4
  187. Help Identify this receiver
  188. Hitec Eclipse 7 for RC car use?
  189. DX7 question
  190. JR 9303 throttle cut
  191. MOVED: Airtronics SD-10G Trainer Cord?????
  192. Futaba Reliability Chapter 2
  193. Receiver Battery Plugged in Wrong.
  194. Exceed-rc/Walkera FM transmitter negative shift?
  195. rx question please
  196. How good are the servos we use?
  197. RDS8000 twin motor question
  198. Setting up a failsafe with an ESC!
  199. DX7 unbinding
  200. Futaba 12FG Fasst - language selection?
  201. Receiver battery's not matched
  202. Futaba diode protection??
  203. MOVED: Aitronics Sanwa SD-10G combined/ separate trim save
  204. Hitec 805 1/4 scale servo
  205. OLD school airtronics servos
  206. Hitec Spectra Module Potential Problem?
  207. Anyone have any Futaba (FP-T3UCP) stick radio parts or want to sell one???? fp-3ucp pcm 1024
  208. hitec aurora 9 ?
  209. 12fg crashes?
  210. Non-Futaba FASST receivers.
  211. Longer Sticks For My Futaba 12Z
  212. SX600
  213. Power HD servos overall (Good or Bad)
  214. Legal Frequency?
  215. Need to make my own servo extensions, Do and Dont
  216. Futaba 10CAG Flaperon mixing question
  217. 8FG - Sailplane mode for an Airplane?
  218. DX7 was soaked in a downpour
  219. EF-MASH- transmitter...USB port?
  220. MOVED: Kraft servo adapter for Airtonics z
  221. optic sport 9.6V ??
  222. Pirouette PROBLEMS?
  223. Much help needed
  224. JR 370 Gyro with a Futaba Receiver?
  225. Futaba T8FG v 2.1
  226. MOVED: airtronics 92824 -2.4ghz rec. antennae
  227. Futaba 12fg 2.1 software is Futaba being naughty
  228. servo help
  229. Corona RS410 volts
  230. Servos for AIR PLANE, BOAT,CAR,Robot
  231. HELP im new to the rc Game
  232. My new Aurora 9 is here!!!
  233. DX7 Binding issues with eletric plane
  234. JR11x Inspiration for its design??
  235. 7C glitched and crashed my plane
  236. RDS8000 flaps-elevator programming
  237. need gyro help
  238. DX6i and old servos.
  239. HiTec Flash w/Li-Ions..RF in wiring
  240. E-FLITE BLADE mSR
  241. OK to store Lipo in Tx??
  242. Servos in wing acting as flaps
  243. New User Group for Custom Built Radio Control Systems
  244. JR X-378
  245. Hitech Aurora 9 optima
  246. Radio / Receiver questions
  247. Aurora 9 price too good to be true?
  248. WFLY9 radio from hobby shop warehouse
  249. What is BEC ??
  250. Hitec Digital Servo problem
