PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Kraft Radio
  2. 10CAG trainer switch not working
  3. Hitec HS-85BB behaving badly, signal too fast?
  4. DX7 retail box wanted
  5. Spektrum compatibility question
  6. I found it!!!
  7. jr 770r rx
  8. DyMond servos question
  9. JR 921 Power Question
  10. throttle cut switch with ESC
  11. Ace R/C Manuals
  12. Horizon Hobby's Service - A Record!
  13. MOVED: Airtionics Radiant radio programing
  14. hobbywing 150amp esc broke
  15. Help With Box Starter Please
  16. programing Flight modes on 12X
  17. Correct Wiring Sequence for Ignition Voltage Regulator
  18. Free Futaba Receivers!!
  19. T. PRO 5010 servos...any good?
  20. 10x Question
  21. futaba 9vap
  22. Futaba Fasst R606FS rec
  23. need help with BEC receiver
  24. JR Propo (JAPAN) 11x Zero and DSX11
  25. Corona RP4S1 Synthesized Receiver
  26. Hitech Crystals on ebay!
  27. 2 crystal radio control
  28. reciever range
  29. FUTABA Updates Available
  30. Is Kraft KP4K AM or FM?
  31. Hitec 645MG failure...lost the plane
  32. Associated/XP XP3-SS 2.4 Ghz issue
  33. FrSky 2.4gHz. Module/Receiver System - Any Luck??
  34. Rechargeable NiMh
  35. super noob needs help!
  36. rds8000 throttle hi problem
  37. Hitec hs-5085mg adapter / mount question
  38. Servo case
  39. Crystals for vintage radios
  40. Remote Wont Program!
  41. Hitec 7955 best price ?
  42. dx6 and 7 trainer mode help needed!!!
  43. 2.4ghz TX antenna replacment questions
  44. 2.4 module
  45. Alan's Hobby Shop
  46. servo voltage from esc?
  47. DX7 Servo End Points
  48. Futaba 3004 servo's and A123 battery packs
  49. Battery makers
  50. Futaba t4vf spare parts
  51. Bind Plug for AR6100E on eBay
  52. Aurora 9 Flap to Elevator Mixing - How To?
  53. Connector/servo compatibility with DSM2 clone RX
  54. Will this DSM2 or other Spektrum receiver work?!?!
  55. 2.4 conversion for hitec tx
  56. can i use one transmitter for two vehicles?
  57. Flysky GT-2 Lipo Conversion w/ Battery Indicator
  58. futaba pcm conversion
  59. JR X9503 et DSX9
  60. Turnigy. SkyFly, etc. X9 radio???
  61. EFLY-9D 2.4GHz - 9 channel radio???
  62. Hitec 2.4 module & futaba 12fg
  63. how do i assign a switch to a ch on futaba 8fg?
  64. MOVED: exponential settings on rudder airtronics RDS8000?
  65. Fm reciever with pcm crystal?
  66. question about servos
  67. Control Horns, Exponential and Dual Rates ???
  68. Can i use an airplane radio/reciever on a boat?
  69. Servo slave modul
  70. Radio Setup Troubleshooting
  71. Futaba vs Spektrum radio - buy both?
  72. HELP FIRE!!!
  73. Servo Choosing.... HELP
  74. Jr 549x receiver problem
  75. JR sport SX 600 question
  76. Futaba 3pmX for a boat?
  77. Futaba R6106HFC rx in a Nitro Trainer
  78. Aileron/Elevator mix
  79. DX6i Buddy Box Setup
  80. hitec mode 3
  81. new spektrum dx8
  82. Futaba 8FGA 8 Channel 2.4 radio
  83. 8FG
  84. DX3R Problem need help
  85. Kraft Seventy One Series System
  86. Fixed
  87. Open letter to Horizon Hobby and JR Radios
  88. Trainer Cord? Spektrum DX6i Compatible?
  89. Radio controlled servo?
  90. 7 Channel Radio upgrade advice
  91. radios
  92. Hitec HS-322HD Standard Deluxe Servo
  93. Buddy Box and Spektrum 6i
  94. Jumpy Throttle and half speed.
  95. New to PCM
  96. Futaba 12FG trainer cord - who has it in stock?
  97. DX6i problems
  98. AIRTRONICS receivers
  99. Futaba 6EXP transmitter battery upgrade
  100. Aurora 9 Battery Toast?
  101. Power HD std. analog servos
  102. Help for newb-receiver voltage range is 4.8-7.4?
  103. Futaba 9C
  104. Inexpensive 2.4gHz Radio To Purchase??
  105. EFLA 105 Mini ESC Question
  106. where to get lipo for transmitter?
  107. Aurora 9 Optima 7 receiver Install
  108. problem, Dx3s
  109. How much Sub Trim is too much?
  110. manual for pcm 1024
  111. Should I go to 2.4?
  112. Venom Radio Bag for Spektrum DX5/6/7
  113. Old Futaba tx pinout?
  114. Airtonics RD8000 "V" tail menue problem
  115. ar500 antenna positioning
  116. voltage question...
  117. Tactic ttx404 2.4 ghz radio
  118. i still flying without any problem on my funtana 125 (5* hitec 5645 and 1 635 with futaba 7c fast 2,
  119. TS-170/HS-7955TG Are they the same?
  120. Spectrum DS821 failed in flight!!
  121. Kraft KPS14 torque
  122. Which radio for me?
  123. Wireless Trainer
  124. 11X
  125. Range test comparison of Futaba and Spektrum 2.4ghz and FM radios
  126. How to access Aux1 on DX6i?
  127. BULLIT PROOF RADIOS YOU HAVE AND USE A LOT
  128. Spectrum analyzer
  129. anyone use Futaba S9602 servos?
  130. Have you had any problems with a JR9303 with a Spectrum conversion?
  131. parkzone servos
  132. Elevator servo for 50cc
  133. WTG Horizon
  134. New 7C 2.4 Programming question.....
  135. what was your first radio system?
  136. DX6i problem, help please
  137. JR X9303 problem
  138. Futaba 10C or Aurora 9 for the money?
  139. Why so many channels?
  140. Multiplex Royal Pro or Futaba FX-30?
  141. Duration Batt for Futaba 10CAG
  142. Installing 2.4 antennae adapter in Optic 6
  143. Semi-Dumb Question
  144. Question on Tower Pro SG5010 servos
  145. Two 2.4MH transmitters, same planes
  146. aileron failure
  147. battery for traxxas 2.4ghz
  148. water in my Transmitter
  149. Glitch is this natural
  150. Glitch is this natural
  151. DX7 BINDING QUESTIONS
  152. futaba 7c problem
  153. Do power capacitors work?
  154. Pictures on 14mz. HELP!
  155. Hangar 9 s-300 servos
  156. throttle over rx switch
  157. MPI receiver crystals
  158. Radio Suggestions
  159. Futaba 4channel skyport
  160. does the JR/Spectrum supp forum have a REP?
  161. JR 783 Transmitter Reading Low Voltage
  162. Min-X Astromite IV data wanted
  163. Spektrum AR500 and two ailerons servos
  164. Spektrum Futaba 2.4 module sucks
  165. Rebinding a Spektrun rx with a different radio
  166. JR 6102 2.4 CONVERSION
  167. Programing Expo on Radio
  168. reuse of reciever after crash
  169. Spektrum7 mixing
  170. Futaba T8UAP with Hitec 2.4 Module problems
  171. all dx6 i pros, need help
  172. S.Bus
  173. Skysport 4vf
  174. Replacement gears for S9304
  175. Setting trim with my 2.4
  176. problem with esc sidewinder 1:10
  177. What 2.4GHz brand have you HAD problems with?
  178. 2.4GHz Questions...
  179. FM53 Galaxy 9 ch receiver
  180. Why servos dont work y connection..on Futaba 2.4 10c
  181. No Throttle cut on DX5e Transmitter
  182. Aurora9 as slave with Optic6 as master FM?
  183. I need help choosing a new 2.4GHz radio system
  184. 2.4 Glitches - It Does Happen!
  185. power plus pro servos?
  186. Spektrum compatible RX - New and legal
  187. DIY RF. Simplest circuit for basic trigger?
  188. I need some help
  189. buddy box question
  190. throttle channel makes other channels move
  191. I have a few questions about digital servos
  192. Tighten throttle on Airtronics RDS8000
  193. Problem with Sanwa RD6000 trims
  194. Rates
  195. waterproofing esc and rx
  196. Servo Smoked
  197. lipo futaba 7c help
  198. Recievers and power lines
  199. Discontinued Hitec servos
  200. Which radio system can program servos?
  201. jr10x lcd replacement
  202. Switching batteries in flight.
  203. Percentage of Mode 1 flyers in YOUR country?
  204. Spektrum - Good or Bad?
  205. info about this site: www.b-p-p.com
  206. Airtronics Vision Radio
  207. Which 2.4 Spectrum dx3s or Futaba 3pm
  208. Airtronics 94819 Mini Digital FAST BB Servo
  209. Yet another question regarding caps and voltage ;)
  210. Spektrum receiver question.
  211. Spektrum rx firmware upgrade
  212. Airtronics 94509 IC Heavy Duty Servo
  213. Convert FM/PCM to 2.4 ghz
  214. JR PCM 10SX II or 8103???
  215. Where to get best offer on a Futaba 4PK?
  216. servo max travel
  217. radio diagnostic
  218. Another quick capacitor question...
  219. 2.4 ghz reciver antenna
  220. hobbyking HK-7 2.4
  221. Another 2.4 Servo issue..
  222. airtronics receiver switch
  223. Fly Dream V3 IS-8D
  224. Slide vs. rocker switch's
  225. Choosing servo/RX/etc for custom RC
  226. DX7, elevator split?
  227. Buddy box settings for Airtronics RDS8000
  228. Anyone Know anything about the new Spektrum Radio coming out?
  229. Craft Air Balancer
  230. Resistor watt question...
  231. Two Crashes this weekend !!!!!!!!!!!!!! 2.4?
  232. How should i set the radio to the receiver?
  233. Long & Skinny Hitec Servo arms
  234. Chrome Monokote and 2.4 ghz radios
  235. Anyone using futaba 8fg on a transmitter tray?
  236. Coach Cable Question!
  237. ANY NEWS ON RELEASE DATE ON THE AIRTRONICS SD-6G?
  238. 2.4Ghz and Overhead Power Lines ?
  239. Futaba Gold Box
  240. burned 2 micro mg servos
  241. using a dx7 as a buddy box for the dx6i...help please!!!
  242. Futaba 9CAP - What's a good upgrade
  243. 2.4ghz lockout/shootdown
  244. Duration battery for 9C Tx
  245. pcm mode
  246. telebee gryo
  247. Futaba Radio
  248. Failsafe positions
  249. SX-600 UNUSUAL FAILURE
  250. Hobby King GT-2 2.4Ghz 2Ch Tx & Rx
