PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Radio Question
  2. One handed flight?
  3. charging equipment
  4. FrSky G-RX8 issues
  5. Transmitter Recommendation
  6. Futaba S148 servos reliability
  7. Modifying Spektrum 2.4GHz Surface Transmitter
  8. FrSky X10S setup. How to?
  9. Horus x10s can't bind to G-RX8
  10. anyone ever heard of these guys? are they reputable?
  11. PowerHD Servos
  12. Need help programming FLAPPERONS on a Futaba 12z
  13. Re-binding, frsky rx??
  14. Transmitter/Receiver problem
  15. Futaba FP-7FG/K "Gold Box" TX - First year made?
  16. Cavelari Savox servo plug question
  17. Who hoarded all the 50mhz (HAM) gear?
  18. Vintage Push Button Radio Control
  19. Futaba device
  20. Spektrum dx6 help.
  21. Multiplex, are they still out there?
  22. Aurora 9X
  23. Receiver to ESC protocol
  24. New Tactic 660
  25. Binding Aurora 9X
  26. LiDAR
  27. Binding two FrSky's receiver at a time #X8R #RX8R #L9R #RB-10 Redundancy bus ?
  28. Serial number for the AR20310T receivers
  29. DX8 to DX9
  30. 14MZ - Keep or Sell??
  31. Rcvr near receiver switch
  32. DX6 4 channel receiver & dual ail servos
  33. Spektrum ar 7350
  34. Spektrum binding issues
  35. Looking at FrSky X12s...any comments
  36. Receiver and No ESC
  37. used T14SG. Worth it?
  38. Help radio installation
  39. Need info on a MRC Series 805
  40. AR7000 failsafe help please
  41. RC Transmitters
  42. JR Americas has received Notice of Bankruptcy!
  43. What is This?
  44. volcano 1/10 losing power, then dies
  45. Futaba 14SG
  46. Not sure what to do with 20+ Vintage RC Cars
  47. Respectable offer?
  48. hglrc xjb with spektrum receiver.
  49. Newbie to metal geared servos
  50. URGENT Spektrum DX 9 Firmware Update Problems
  51. I need help with my Spektrum DX6i
  52. Futaba 14SGA 14-Channel or the 10JA 10-Channel Air T-FHSS System
  53. futaba t7c battery replacement
  54. DX9 - are glitches possible?
  55. Cortex Gyro and Futaba SBus
  56. DX18 Gen 2
  57. urgent recomendation
  58. Can you still fly FM frequencies?
  59. Help with choosing a transmitter 2.4ghz
  60. Corona R14FA Receiver Lost Binding
  61. How to set up Model Select in Spektrum DX9?
  62. Futaba S148...should I use them.
  63. Futaba 8FG Super V -Tail help!!!!!
  64. Futaba T10J Telemetry data download
  65. Futaba 14SG
  66. Taranis QX7 & IRangeX 4 in 1 Module Help
  67. What is this crystal
  68. Compatibility Futaba Ko ProPo
  69. Spektrum S6180 Servo issue
  70. Servo recommendation
  71. Question about Receivers 12v
  72. Propellers can be classified in different ways
  73. flaperon with a 4 channel receiver
  74. Spektrum DX6 /E-flite Scimitar
  75. Tactic tax-47 servo arms
  76. Connecting the Spektrum AR9350 to the battery.
  77. What are these?
  78. Sc10 4x4 ESC and Motor reccomendations
  79. New Futaba user needs help with 18sz
  80. Spektrum ar8000 advice
  81. Transmitter recommendations (ideally with firm wheel / trigger, compact RXs)
  82. eagle guardian gyro
  83. Servo recommendation for special application
  84. Receiver help!
  85. JR 28X Trouble :(
  86. Like new HiTec Aurora 9
  87. Frysky radio and jets?
  88. Can my ESC handle this?
  89. spectrum receivers
  90. Sectrum DX4C not binding
  91. RC system not working - please help
  92. radio setup issues
  93. Finally Bought an FrSky Setup
  94. What radio should I get
  95. Wltoys a949 problem
  96. RC Car Remote Controller Missing
  97. Question on jr propo nes-8700g servos
  98. TaranisX7 Aurora68 binding issues
  99. Antena of Corona RP8D1 8ch 40MHz Dual Conversion Receiver
  100. mario kart 7 carrera rc
  101. TTX660 "forgets"ch5 set
  102. Throttle servo in reverse order help ?
  103. Futaba 6XA/6XH
  104. brass rod as actuator
  105. Tactic tr625 receiver with 6.6v lifepo4 battery
  106. Futaba 16SZA - Another delay
  107. Graupner MZ-18 Help
  108. Westport Variant
  109. Recommendation On A Futaba Receiver?
  110. Problem with LST Lever Potentiometer on Futaba 18MZ
  111. Rx-1 receiver replacement
  112. Futaba 3PM-2.4G MX esc reverse issues. Help!!!!!
  113. S Bus
  114. Help with using Transmitter/Receiver with motors
  115. AR8000 Rx compatible with DX7 Transmitter??
  116. FLYKIT - the first mobile RC ground control station for FPV
  117. Optical Kill Switch Causing Receiver to Cycle Off and On
  118. SD-6G buddy-box slave to a RDS-8000
  119. What do I really need in a transmitter?
  120. Servos make/brand?
  121. TGY-AEV01 Programming
  122. JR MP91WV gear set
  123. Bouncing Servo
  124. Hitec HS-M7990TH
  125. JR Quattro buddy box with another JR Quattro
  126. Futaba 14SG - 3 position switch (flaps) setup
  127. Binding Radio
  128. Digital servos chat when flaps up
  129. Aileron Servo Twitching While Mid Throttle
  130. spektrum dx 20 question
  131. Photon 2.1 ESC problems
  132. What's the difference between expensive and cheap transmitters?
  133. Futaba 14sg Tx
  134. Futaba 6J6
  135. radios with no reverse lock out and
  136. Absima cr3p
  137. Team Associated crystal set faulty?
  138. Receiver Capacitor- Glitch buster.
  139. Need help, my AR8010T Rx will not stay bound
  140. Futaba 18 sz lockout
  141. ESC won't Turn on!!!
  142. Binding spectrum dx6 to quadcopter
  143. Old servos TSS-50 TSS-51
  144. Are these worth anything?
  145. Antenna placement near cf wing tube
  146. Hero RC - Receiver
  147. Cheap "Blade" Tx doesn't push servos all the way.
  148. What to regulate 6v battery to?
  149. Futaba s3010 random slight jitter when centering sometimes
  150. radio and receiver issue
  151. Equipment for Westwings Swallow?
  152. Bound RX doesn't talk to radio
  153. Tactic receiver Question
  154. Universal servo
  155. Futaba Attack 2DR
  156. Bad Servo
  157. Lynx Proton receiver antenna?
  158. Battery interference?
  159. Wich brand?
  160. Which brand ?
  161. Product location
  162. Receiver for KingKong 90GT
  163. TX+RX combo recommendations please
  164. Fly Sky FS-I6 for R/C Air?
  165. Servo jitters when almost full travel help
  166. Turnigy receiver controlled on/off switch use
  167. WTB: Acoms AR-2/40 receiver
  168. Dynam 2.4 6 CH antenna wire
  169. T14SG loss of link?
  170. Futaba 7c
  171. FP-S48 Servos
  172. Futaba T4YF how to add knob for 3rd chanel
  173. New ESC and Receiver Which Order/ How to Bind & Calibrate
  174. max voltage a Rx and servos can take
  175. FrySky Taranis vs Futaba T16SZ
  176. Is DSSS for ground & air?
  177. Futaba 4 arm servo output numbers
  178. AKK Technologies K31P 600mw vtx
  179. DYI Servo leads
  180. 2.4GHz and aluminized film..!?
  181. Android phone ground station
  182. Newbie again
  183. DX8 DSMX 8-Ch Gen. 2 AR8000 Receiver
  184. Futaba 8J Flap elevator mix
  185. 42 DigiSwitch
  186. Spektrum DX20 - Recall problem
  187. Spektrum Radio stuck in "warnings NO SLAVE" window
  188. Servo lead length and interference
  189. New Futaba owner: Futaba 8J
  190. new charger battery c rating rating higher voltage
  191. very odd servo question
  192. Aloft Taranis Support is Awful!
  193. Plane setup ??
  194. Spektrum DX7S
  195. Jeti Transmitter/Hitec receiver
  196. LiFe receiver battery - telemetry - low voltage alarm - reliable?
  197. Spektrum DX9 Timer Button Change
  198. Orange RX DMSS receivers
  199. Futaba 3pks question
  200. Futaba R319DPS RX Question
  201. 12vdc ESC
  202. Futaba 14GA and Hobby King 8 Ch RX I'm Stumped!
  203. remote antenna binding question
  204. R617fs reciver-r606fs
  205. FrSky STK tool works for upgrade but not for config
  206. Are the FPV Transmitter and receiver same thing?
  207. Servo cable problem
  208. Blade 200 S pushrods adjustments after crash
  209. Flap cycle and Spektrum DX7S
  210. What is it with all the "made in China" Spektrum receiver's
  211. Spektrum AS3X receivers??
  212. How to attach Fly SKy Sensors to the i6B receiever
  213. Throttle EPA adjustable when racing
  214. hitec 8775mg servos
  215. Spektrum TM1000 Binding Question
  216. Spektrum DX20 - Recall issues
  217. 3pks module
  218. Connecting new brushless combo to old transmitter
  219. JR 3 AXIS aircraft gyro system airplane
  220. Motor Startup Issue - Help/Suggestions
  221. I managed to program proportional Flaperons / Spoilerons on the DX6i
  222. Drone remote not working
  223. between England and Sri Lanka at Headingley, live on Sky Sports 2 from
  224. Motor Startup Issue - Help/Suggestions
  225. Old guy, new tricks? Are there
  226. EURGLE 9ch 2.4GHZ Transmitter
  227. JR 9303 2.4 Help
  228. Maybe it is time to get away from Spektrum
  229. Any help with tower hobbies giant scale servo or other brands.
  230. Need a nano cps setup for dx6e
  231. FlySky/Turnigy i10 comments
  232. FlySky/Turnigy
  233. Spektrum powersafe rx
  234. DX7 Flaps Programming
  235. XP8103 programming vs XP7202 not happy with XP8103, feedback please
  236. Transmitter/Servo not made in China?
  237. Futaba 10J or Spektrum DX8?
  238. Who has the best 4-6 channel radio
  239. Graumpner 24 pro.
  240. RC Loses Signal
  241. OrangeRX Devo Module won't connect
  242. TTX300 help with light bar
  243. Anyone in the Saint Paul , Minnesota area to check these out?
  244. Hitec HFP-30
  245. Replace existing radio on old RC Truck
  246. Airtronics SD-10g Programing
  247. Traxxas E-maxx Esc
  248. Futaba Telemetry Radio Protocols . . ..
  249. Model matching
  250. DX7S Radio and As3x
