PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Duration battery for 9C Tx
  2. pcm mode
  3. telebee gryo
  4. Futaba Radio
  5. Failsafe positions
  6. SX-600 UNUSUAL FAILURE
  7. Hobby King GT-2 2.4Ghz 2Ch Tx & Rx
  8. Probably a Dumb Question
  9. Best option to convert my 72 MHz Futaba 8UAF to 2.4
  10. Graupner mx-22 service (secret) menu...
  11. Spektrum DX7 question
  12. radios
  13. Looking for Digitrio info
  14. RC controller base construction
  15. mono cables for trainer cords
  16. Can you identify this stick assembly?
  17. Schematic for a Futaba 4YF transmitter?
  18. 14MZ 7 channel mode. Where is it?
  19. Dumb Radio Question
  20. Using servo arm w/ bracket for ailerons
  21. Transmitter beep not loud enough
  22. No Rf led on Futaba 9c,Hitec Spectra 2.4 module.
  23. Throttle failsafe on a AR500 Receiver
  24. dx7 and dx5 buddy boxing
  25. JR PCM G series (512)
  26. manual wanted Heathkit
  27. Older DSM 2.4 Equipment-Is it Safe to Use?
  28. Best Sailplane Radio
  29. Anyone remember this radio?
  30. Odd radio characteristics
  31. new flyer with compatibility question..
  32. How can I adjust the RPM's of two motor individually with a DX7
  33. JR 9503 2.4 ghz interference with JR DS8411 Servo
  34. Corona 2,4 GHz Module Problem !!!!!
  35. Futaba 9c and Spektrum module
  36. Futaba T6XH D/R throttle?
  37. Choosing a 2.4 gig radio
  38. Futaba 6ex 2.4Gh Trim malfunction
  39. DX7 questions
  40. Futaba 2.4GHz Conversion For Older Radio's
  41. Does anyone who knows about Xcore digital servos
  42. Anyone else think they should bring back retro-radios?
  43. New information on JR's 11x
  44. Flap / Elevator Mixing
  45. *Airtronics SD-10G Upgrade*
  46. Hitec Flash 4 System X retract mod.
  47. One way to buddy box with a DX7
  48. Did I choose the right sevos for my plane?
  49. HELP...RC10GT...Electronics not working
  50. Question regarding placing capacitors in serial…
  51. Troybuilt Y-Harness
  52. esky radio for eflight heli
  53. What's a nice 9303 worth?
  54. 2.4mhz for air and boat
  55. deleted
  56. Multiplex MC3030 2.4 conversion
  57. Gws 2.4 tx and rx?
  58. BouncingFluttering Futaba 3004
  59. New Futaba System????
  60. esky honeybee cp3 HELP
  61. Using non-BEC receiver with ESC
  62. Futaba R6008HS 2.4GHz Receiver
  63. Spektrum module getting warm.
  64. trying to match crystals
  65. throttle/steering reversed
  66. JR 9303 vs. 9303
  67. Capacitor question...
  68. jr 3103 conversion to 2.4
  69. Airtronics/Sanwa VG6000 model memory
  70. Airtronics VG6000 help
  71. binding traxxas 2.4ghz
  72. Buddy Box for Hitec Aurora 9 - Conflicting info?
  73. futaba servo problem
  74. JR 8103 won't transmit
  75. Futaba Serial Bus!!
  76. Digital 2.4GHz RX : digital and/or analog servos???
  77. What is a t14z form Futaba?
  78. Futaba 2PL 2.4 Rx
  79. Futaba support
  80. AR 6200 firmware version?
  81. Li Po Storage Box
  82. Airtronics SD-10g mix question
  83. Hitec 5065MG servo x 2 quit working
  84. mixing servos, Futaba and JR and wiring
  85. 2.4 and WiFi interference
  86. RD8000 questions
  87. spektrum dx7 engine kill switch?
  88. need a receiver for a spektrum dx 3.0
  89. linkages/interference
  90. going to 2.4 need help
  91. hitec optic 6 2.4ghz
  92. Interference with video transmitter
  93. spektrum 2.4ghz radio system ????
  94. AR6100 in E-flite Pitts Model 12 15e ARF?
  95. Airtronics RDS8000 transmitter battery won't go into connection port
  96. Interference on 75MHz AM?
  97. How do I change Tx crystal?
  98. Servo ends for new receiver
  99. Optic 6 Programming assistance needed
  100. Speed control buggin out
  101. FlyDream 2.4Ghz Tx & Rx
  102. JR's new 11X- the lets not talk about the 3+1 digital trims edition.
  103. Futaba 6EX Flap "Knob" Modification
  104. Need a flight pack for a Spectrum 7ch system.
  105. Futba Radios
  106. Futaba's new 2.4ghz S-BUS...Outstanding!
  107. crystal help
  108. can i use blade cx2 radio for a plane?
  109. 12FG manual RANT
  110. Problems with Bluebird 620MG and Spectra 2.4
  111. how many channels??? Please help!
  112. TBM Power HD servos
  113. Is this Futaba 7C price TOO GOOD to be true?
  114. Spektrum Servo question
  115. Odd RX/TX binding issue
  116. HITec HS-965MG pausing/not working properly...
  117. 9303 aileron mixing
  118. Optima Receiver Power Consumption and a thanks to Mike Mayberry
  119. duel elevator servos?
  120. HiTec 7940 TH HV
  121. EXCEED RC 2.4GHz 6 CH Transmitter Cable
  122. any 1 no if this can be done
  123. HELP!: Making a circuit so that a 7.2v batt produces 6v
  124. Diode isolation w/dual 123 battery packs
  125. Receiver / Servo help
  126. Will the VG400 trainer box work with RDS8000
  127. Newbie question about programmable RC transmitters
  128. Futaba 2.4 Receiver Antenna Installation
  129. hitec eclipse 7
  130. Pro-Line Cadet Wiring Help
  131. New Hitec Aurora 9-Channel 2.4Ghz Radio System #2
  132. Throttle servo with AR7000
  133. Servo Flutter, E-flite SU-26M
  134. H9 Ultra Stick and RDS8000
  135. Antenna location Aurora 2.4
  136. Airtronics RDS 8000
  137. Spectrum Problems
  138. AM / FM best for boat???
  139. FMS simulator setup help wanted
  140. JR PCM9X11 - Screen Problem
  141. Futaba 10CG
  142. Spektrum AR7000 failure?
  143. JR 11X RADIO ON CHIEF
  144. Vantec esc
  145. Need help with setting Expo's
  146. radio glitching
  147. disintegrating radio
  148. DX6i Quad Flap programming.
  149. Any Kraft gurus? Need TX module pinout
  150. Hitec 7955TG servo issue???
  151. Graupner/Jr MX16S modification
  152. Futaba 14MZ battery
  153. JR 9303 2.4
  154. Spektrum Servo Application?
  155. Futaba 8FG radio only
  156. Need a radio!
  157. Crystals and my radio.
  158. Spektrum parts? Need a potentiometer.
  159. twitching servo help PLEASE
  160. Hangar 9 Transmitter Stand
  161. Aurora 9 question
  162. Can the DX5e do an air drop
  163. after market transmitter sticks
  164. Why is my RDS8000 beeping at me?
  165. Hi, I need some help with my RC car.
  166. Art-Tech and Futaba compatible?
  167. 6channel 2.4 Pistol Radio conversion
  168. JR Charger dead & JR FM XP6102 vs OEM 2.4ghz
  169. Airtronics Dealers?
  170. When will 4 Channel Park flyer Aurora 9 Receivers come out?
  171. Do I trade in my JR X9303 for an Aurora 9?
  172. HiTec Aurora 9 - Is it compatible with Micro 2.4's - e.g. Vapor, MCX, etc?
  173. Aurora 9 TX Charging Plug Type?
  174. Wanted, hitec 5945 & 5955
  175. Continued Battery Life Problems
  176. 2.4 upgrade question
  177. Whats The Right Servo?
  178. Are servo sizes standardized?
  179. Futaba reciever
  180. No more glitches on 72MHz
  181. plug in and go?
  182. 2.4Ghz Range Sucks
  183. AM/FM
  184. Airtronics RX Crystal Question
  185. Radio Check
  186. Sunlight and 14mz screen contrast
  187. 2.4 Module and recievers for Futaba and JR
  188. lost plane finder,very loud!
  189. Futaba Radio with JR servos
  190. Using a Spectrum ParkFlyer System for a custom car
  191. receiver antenna
  192. Can i use any 2.4G receiver with my airtronics?
  193. Servo Power
  194. Help with Receiver/transmitter...?
  195. Airtronics MX-Sport 2.4 - channel 3 ??
  196. antennas in a foil covered airframe
  197. Aurora 9 Suspicions
  198. Spectrum DXI6 controller for helicopter
  199. Airtronics/Sanwa compatibility?
  200. FUtaba FASST 2.4GHz question.
  201. What if it is the wrong band crystal?
  202. 9ZAP Programming
  203. Basics of transmitters
  204. Receiver Battery Pack Not Charging Right
  205. RX Futaba R168DF + DL50
  206. Increase steering deadzone?
  207. Smart Fly Eq6 and Rx Binding issue
  208. Assan in a jr xp2702 not binding
  209. futaba converson to 2.4
  210. Futaba 7ch 2.4 smoke system
  211. DSM2 Air Module
  212. JR 10 Screen
  213. Futaba T9CHP and Assan 2.4 module
  214. cost of screen replacement
  215. will my futaba 2.4 7c create interference when batteries are mounted together?
  216. JR XP8103 2.4 Conversion ???
  217. futaba 7c vs the spectrum dx6i
  218. Cox/Sanwa compatibility with Futaba systems
  219. Futaba S9254 Binding?
  220. Futaba T3PK 2.4 ghz radio and the traxxas optidrive
  221. Servos and transmitter
  222. which receiver
  223. Bought Used 3PK with Spektrum Module
  224. Another RCVR XMTR compatibility question.
  225. looking for a Radio & DX3E 3rd channel Question
  226. Can I use Airplanes with FUTABA t9CHP
  227. Futaba 8UA question
  228. JR x-378
  229. help, i want a tx/rx without an antenna and 2.4
  230. Futaba 2.4GHz FHSS vs. FASST?
  231. Throttle cut set up problem
  232. Futaba servo Spektrum reviver
  233. servo's compatable to airtronics
  234. A few quesitons
  235. Can't Bind AIRTRONICS 6CH 2.4 PARK FLYER RX
  236. help me
  237. Which radio to get...hmmmm
  238. AIRTRONICS 6CH 2.4 PARK FLYER RX
  239. Can a 9303 and a 9503 Data Transfer
  240. RX antenna repair?
  241. Which 2.4 System is REALLY the BEST?
  242. Futaba MZ14 advice
  243. Anyone used HK-7x 7ch radio
  244. WHERE DO I GOT MY RADIO STUFF?????????????
  245. DX7 and 4 Site Flaperons Setup
  246. Shared battery for ignition and radio
  247. Futaba FASST Receiver R6106HF
  248. 4ch with dual self-centering sticks
  249. Just How Many Channels Do You Need?
  250. lot of 4 futaba transmitters?
