PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Recvr Batt & Servos
  2. which reciever for my spektrum dx 3.0
  3. futaba t3pdf digital radio
  4. Help - Aurora 9 or JR x9303?
  5. Used plane and a Hi-Tec system
  6. Hobbico FASST 2.4 Module for JR radios - Anyone tried this?
  7. HELP!!!
  8. duel conversion
  9. Problem with futaba 8fg sensor being to sensitive. But FIXED
  10. no motor function
  11. Transmitting on 2.4 and 35/72 from same TX
  12. 7.4 V servos - what receiver ??
  13. ar9000 and dual batteries
  14. How much current can a Futaba 608FS handle?
  15. Comaptiblity??
  16. I need someone to point me in the direction (newbie)
  17. Model Copy 9c to 8u
  18. XtremeLink v3
  19. JR 12 X Dual elevator missing 35 mhz
  20. Hobby King 2.4 Transmittor - Anyone Try These?
  21. strange radio problem
  22. NEWB to RC have a couple questions...
  23. delete double post
  24. Servo chatter.
  25. Issues with radio and controller?
  26. HAs ANYONE USED THIS RADIO BEFORE???
  27. Horizon Spektrum repair
  28. Futaba 8FG main body material ?
  29. Servo question/opinion
  30. delete
  31. *RDS8000 Setup*
  32. 2.4g DSX9 flap trim
  33. Pink GWS radio
  34. servo chatter
  35. fp-t6fg/k futaba radio
  36. futaba 14 MZ , need help
  37. WILL MY HB RX AND SERVO HANDEL POWER
  38. V-TAIL MIXING/DO I HAVE THE PROPER PLAN???
  39. New builder! Needs HELP!
  40. AIRTRONICS 5 AND 6 CHANNEL 2.4 RECIEVERS
  41. Need Help matching servos with my project????
  42. I HATE BINDING
  43. 2.4 Ghz Radio Comparison
  44. Newbie servo wiring question red or white wire?
  45. 2.4ghz compatability
  46. Ignition Battery Eliminator?
  47. Which One
  48. multiplex Tx
  49. Tower-Pro servos OH,NO!!
  50. Airtronics Mx Sport
  51. Futaba 12FG - How do I set Dual Rate for RUDDER2?
  52. Any opinion on 2.4 futaba 10c?
  53. Servo flutter when transmitter is off
  54. Carbon fiber and RF receivers.
  55. Jline Quattro hack
  56. RDS8000 help needed
  57. Spectrum Dual Aileron
  58. hobbico JR tx compatible FASST module
  59. JR 10X RAdio to 2.4
  60. looking at a new radio
  61. Anybody know this radio?
  62. will 2.4 work with old servos?
  63. Interference?
  64. Loose antenna Airtronics RDS8000
  65. Servo jitters
  66. adding buddy box feature
  67. Analog/Digital Servos in 1/5 - 1/4 Scale
  68. A123 Batteries & Futaba Receivers
  69. X9303 Shutdown in Flight, anyone else seen this?
  70. Radio Questions
  71. the Smallest (in size) programmable Tx
  72. KDS-8XTF 2.4GHZ futaba module
  73. Hobbico JM912 FASST JR Module
  74. Polarity Question?
  75. FD 2.4 GHz module
  76. Non working Tx Rx set
  77. Moving surface vs. servo torque.
  78. Analog Servos and 2.4 GHz
  79. Help! Like new Hitec 7950TH servo working intermittently!
  80. Airtronics 92664 RX60 micro receiver
  81. R617FS 2.4Ghz damage receiver
  82. 2.4ghz antenna orientation
  83. Futaba 3pk vs spektrum dx3r
  84. Litco Alpha 4 power supply
  85. Nomadio is Gone
  86. Futaba 2PL 2.4GHz Radio System: Has anybody had any experience?
  87. Futaba Conquest 6NLK question
  88. Futaba FM (Skysport) problem...any help!
  89. servo switch
  90. FUTABA 9 VHP
  91. 2,4 ghz cheap radio
  92. Need help using futaba 8fg on clearview or fms simulator
  93. Servo Reversing issue??
  94. Most powerful micro servo
  95. Servo glitch problem-need help
  96. first time electric build and no response from rx, esc, or servo
  97. Futaba 10CG 10CH. 2.4GHz with Simulator, need help, please!
  98. Who else sells the rx60?
  99. Heathkit test meter
  100. EXPO
  101. ttu-03 tx range
  102. JR 9303 2.4 Problem
  103. deleted
  104. Retract Battery
  105. Cheap wireless battery monitoring system?
  106. Servo Wire Question
  107. Similarities & Differences in FHSS systems
  108. Futaba S3801 servo
  109. Spektrum A6010 servos
  110. servo tester
  111. e-sky driver for computer
  112. Buddy box with futaba 6ex 2.4?
  113. Hi-Energy battery does not get the rated capacity
  114. Cox/Sanwa Radios
  115. Futaba Users please reply!!!!!!
  116. Futaba 6EX fault
  117. Hitec HS 7950TG HV
  118. JETI Duplex 2.4
  119. futaba 8fg and xmhobbies g401b are not compatible
  120. Programing FP-T7UAF
  121. 2.4ghz Module for Hitec Eclipse 7 radio
  122. Please recommend a ESC
  123. Futaba 8U question
  124. Futaba GY 351 Gyro - Where to get one??
  125. Hansen Hobbies Memory Card For Futaba 10CGA
  126. Any one useing Hobbyco fast for JR10
  127. Airtronics Tx and rx
  128. Spectra vs. fixed frequency radio
  129. Please Help!!
  130. Reciever Batteries - HELP
  131. Major unknown DX7 & DX6I Issue - Please Help
  132. Receiver and Transmitter problems
  133. looking for 2.4ghz radio...
  134. futaba haters rejoice
  135. SD10-G Programming Gurus, I need some help........
  136. Airtronics Feature Card
  137. Please identify this type/model of PCB plug.
  138. 8FG or Aurora 9
  139. how do I know when my TX is charged
  140. NO SELLING - JUST COMPARE FUTABA 8FG TO A9 HITEC
  141. SD 10-G VS T8FG
  142. Futaba 8UAFs 2.4 conversion
  143. Converting my JR 9303 to 2.4 with no wires
  144. Where to obtain Futaba type toggle switch nuts?
  145. Spektrum AR6200 UNBOUND! WHY? HELP!
  146. Servo Specification Database
  147. Servo and transmitter advice
  148. 2.4 Glitching with Futaba 10 C
  149. 2.4 GHz reciever placement
  150. Wire Source?
  151. servo compatibility with DX 7
  152. sim or program cable??
  153. draganflyer V Ti communications
  154. JR xf 622 placement of spring?
  155. safety: DX6i throttle lock
  156. reciever batt
  157. RDS8000 receiver antenna lead replacement?
  158. Airtronics use with Phoenix Sim??
  159. please recommend a transmitter
  160. problem with castle link.
  161. 14MZ Case Mod to accept TM 14 antenna
  162. Futaba R6014FS Reciever Channel Assignments
  163. 7C / DX7
  164. dx3s telemetry
  165. Futaba 12FGA
  166. Spektrum not binding
  167. Airtronics Tx w/ JR Rx???
  168. Futaba 3PG question
  169. Spektrum, FASST, Hitec - compatible?
  170. all my servos jitter when I turn on the radio
  171. DX-7
  172. servo size for spacewalker2
  173. ACE MIX MASTER
  174. Beginner needs help
  175. Corona DSSS 2.4 receivers
  176. Futaba 10CHP
  177. Servo for Futaba 4PK
  178. Totally Confused (SpektrumDX6i AR6200 etc...)
  179. Futaba 7c Rx Questions
  180. futaba t7c stick length
  181. Skysport 6 has no range.
  182. How do I adjust the 9ZAP throttle stick?
  183. Futaba 4PK or Airtronics M11X?
  184. Does anyone have a art-tech 6 channel
  185. multiplex power speed alloy servo horn?
  186. dx3s servo vibrates
  187. shortening wires on servo..
  188. AR6200 failure, Possible?
  189. Coming Back to Hobby... Which radio?
  190. Elementary question about FASST TX and RX
  191. Do I need separate power for my receiver?
  192. TB Power HD 1501 Servo's
  193. GYRO Clarification Needed
  194. 12FG Function menu prog question
  195. Gyro Gain Settings
  196. AILERON TRIMMING.
  197. Gyro Placement for Rudder Control in Fuselage?
  198. Channel Sharing with Battery
  199. Cirrus CS 601 std servo from Hobby People
  200. Servo mounting screws
  201. 14MZ AFR set up help needed.
  202. Radio control range
  203. Feedback wanted on hitec 2.4Ghz system
  204. Kinda a newbie question about jr rx's...
  205. DX6i Tutorial
  206. How can I fully program Futaba 9156 servos
  207. Switching from DX7 to X9303
  208. Spektrum DX7 Dual Elevator Setup Help
  209. Question about Spektrum AR7000
  210. new controller
  211. Are a JR 10X and Spectrum DX6i buddy cord-able?
  212. 9CAP PCM Battery Door
  213. 14mz issues(when switching different conditions )
  214. What is latest 12FG firmware version?
  215. will these work?
  216. Re-using r/c parts
  217. FUTABA 4PK ?
  218. Spektrum users BEWARE!
  219. newbie: batteries for transmitter?
  220. Lipo for 4PK?
  221. JM912 FASST
  222. Transmitter problem
  223. Mixing v tail on 3 ch glider to right stick
  224. anantana length
  225. Data pulses from DX5W amd 6EX
  226. Spektrum Dx6i, battery charge level
  227. servo voltage
  228. Stalled Servo?
  229. Fastest servos for .50 sized aerobatic airplanes
  230. Need LCD for DX7/ JR 7203
  231. JR sport servo help please
  232. flexible short aerial for futaba
  233. Spectrum Lock Loss problem
  234. is this installation ok for Spektrum ar500 receiver on a glider??
  235. Buying a new Futaba design first run
  236. Sound coming from DS821 servos?
  237. Spectrum AR 7000 dual battery hook-up
  238. 10c 2.4 problems (6014fs problems)
  239. What radio do you recomend me for this project R/C Roomba
  240. spektrum?
  241. adding 2 servoes for elevator and radio
  242. Gyro Help
  243. setup for Futaba 3PM effect
  244. Looking for a 2.4 Radio
  245. 10c questions (why did they make the 10cga)
  246. 14mz spektrum module setup
  247. converted dx2.0
  248. plug heat sink into rx question
  249. All new JR 11X
  250. JR 9303 Air Radio
