PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Looking for a 2.4 Radio
  2. 10c questions (why did they make the 10cga)
  3. 14mz spektrum module setup
  4. converted dx2.0
  5. plug heat sink into rx question
  6. All new JR 11X
  7. JR 9303 Air Radio
  8. 3PK vs 4PK
  9. Backup Campac from 9C to 9CSuper?
  10. 2.4ghz module for hitec eclipse 7
  11. My DX2.0 super mods converted to DX3.0 and Telemetry
  12. need help finding module
  13. T4vf modified as trainer radio w/T10C
  14. SR-10 Dual Servo Reverser
  15. Reverse Throttle Response Needed
  16. v-tail connection
  17. Re: digital servos-what does HRS mean?
  18. Futaba 9CAP receivers question
  19. Hitec 1/4 scale servo pin out for futaba??? HELP
  20. Kraft Radio
  21. Futaba 10CAG & R6004FF P MIX Help!
  22. throttle servo issue
  23. Jr 9303 and Jet legend F15 help please.
  24. Corroded servo extension connectors.
  25. Spektrum DX2.0 to DX3.0 conversion step by step instructions inside
  26. Need Radio for drag racing & hi speed runs?
  27. Which radio
  28. looking for 3 inch metal full servo arm
  29. Eargle 2.4ghz surface radio
  30. N00b Radio Question
  31. Futaba 7C 2.4
  32. JR XP7202 Crow
  33. futaba
  34. Hitec Aurora 9 Manual now available.
  35. Manual for JR Max 6 Ch Radio
  36. 2.4 ghz rx and battery proximity ?
  37. Deffective Servo after forgotten failsafe
  38. Spectrum Radio Questions
  39. HELP, how to Program 12FG 3 pos switch
  40. Futaba 617 Radio
  41. Hitec A9 Maual Please
  42. Litco Systems #R101 xceiver. AM or FM ???
  43. ek products
  44. Walkera 2401 and external power
  45. comparing range checks, your thoughts please.
  46. Radio interference ?
  47. Has anybody used a JR XF421 as a buddy box for DX7?
  48. Multiplex Evo 9 programming question
  49. Fasst 2.4 module in FG series Tx?
  50. Tx charge = FAIL
  51. Reciever problems
  52. GTB Goes to WOT When Tx is Turned Off
  53. Mode 1 or 2 for US?
  54. Spektrum 6100e or 6110e
  55. Reversing a SERVOS direction
  56. Where to find transmitter for Radioshack truck.
  57. X9303 & Flight Modes
  58. Does anyone know the specs on a Futaba Receiver R136 F
  59. HS-7985 MG SERVOS
  60. futaba steering potentiometer
  61. need help with new futuba
  62. 42% Opto Kill Switch
  63. have you had a 14MZ stolen?
  64. HELP! Changing to stick mode 1, from 2
  65. Best bang for the buck trans and receiver.
  66. hitec servos & 2 cell lipos
  67. JR 791 & RT88 retract servo dimensions?
  68. servo help......
  69. Hitec 2.4Ghz Module/RX combo arrival
  70. Getting back into flying - what radio
  71. New JR DSX9. Heard anything about it?
  72. wanted to buy futaba 14mz
  73. SPEKTRUM BATTERY MELTING
  74. servos start with a delay- Futaba and FMA Direct
  75. Airtronics 6-channel flaperons
  76. Upgrade....help please
  77. 2.4 ghz Telemetry?
  78. Chidgey Single Stick Gimbal
  79. Flight Conditions VS Flight Modes
  80. Shipping to Mexico
  81. diff with ball bearings and teflon bearings
  82. Help with a receiver?
  83. Exceed RC 6-Ch 2.4Ghz Radio?
  84. The best Hitec or JR Throttle Servo for the buck?
  85. Futaba 10C and 4 Aileron Servos question
  86. Anyone Using Non Futaba CF card in the 12Z
  87. Q: WFLY 2.4GHz, it is hopping DSSS
  88. DX3S
  89. NEED HELP WITH NEW DX3S!!!!
  90. Car type TX with buddy box?
  91. More new Airtronics 2.4Ghz FHSS receivers, Cirrus - Airtronics radio
  92. Futaba 617
  93. 12X Flap system versus right eyebrow trim
  94. venom fm radio
  95. Servo Install
  96. Elevator Problem..
  97. Spektrum DX7 cut the controls to my airplane
  98. need from help how can bind and setup fail safe Airtronics mx3fg
  99. delete pls
  100. Will K Band Radar mess with Spektrum 2.4 signal???
  101. dsm2 module for futaba 10chp
  102. nimah or nicad in transmitter pack
  103. 149DP receiver Hi-Lo
  104. help for trimming retract servo
  105. chatter to all other servos when throttle used
  106. Futaba 2.4 ghz Reciever Offerings
  107. Anyone familiar w/Futaba 7FGK TX Radio ?
  108. Hobbico Standard Servos
  109. ppp servos
  110. 12FGA and 608FS question
  111. 2.4 and servo problem
  112. Is 2.4GHz susceptible to noise?
  113. Is my 9CAP going to be a dinosaur?
  114. How to tell what is bad, receiver or transmitter?
  115. Ever tried a Corona Synthesized receiver ?
  116. 149DP receiver-not responding-HELP
  117. JR X9303 Elevons??? Help with how to.
  118. JR R610M MICRO RECEIVER ,Q
  119. What tail servo for JR G500T? Hirobo Sceadu
  120. Going from Futaba to Airtronics Question?
  121. JR DS821's in a Speed plane?
  122. How much will a New 10C cost in 2 years?
  123. JR PCM9X II programming of aux4 channel
  124. Slop in HS 7955TG out of the box ???
  125. Futaba 12fg charging
  126. GeeWizz is the Futaba S3305 a dud?
  127. 9ZHP WC2 Heli convert to Throttled ratchet
  128. JR Z9100 ultra tourqe, and high speed servos???
  129. Futaba T7CAP Lcd panel display question
  130. 12fg issues
  131. Futaba 6EX Flaps + Elevator Trim
  132. DX7SE Spektrum
  133. airtronic's RD-8000 question
  134. HOW DO I USE MY RX?
  135. Price Increase for the Futaba 8FGA
  136. V-Tail and JR 12X
  137. Spektrum Rx antenna repair
  138. Sailboat with Kraft radio
  139. Transmitter frequencies??
  140. On the spektrum dx6i, where is the endpoint setting?
  141. Futaba 6ex 2.4G Flap Switch
  142. Airtronics RD-8000 broken wire problem
  143. Best system Fut 12FG, ATX SD10G, Hitec A9
  144. Dx7 Heli Mode Only???
  145. Does anyone know anything about this radio/reciever package?
  146. Newbie looking for Reciever help
  147. Whats the cheapest on-line store to buy 5 x JR DS8411SA servos
  148. JR RX AILERON SET UP ?
  149. Spectrum DX5/ar500 questions
  150. Futaba 10 C reciever compatability
  151. Futaba balderdash
  152. 10c vs JR 9303
  153. Un Bound??
  154. Do JR digital servo's have a clutch ? ? ?
  155. 2.4 GHz Compatibility
  156. thanks spectrum service!
  157. Does anybody know if JR will be releasing any new radios soon?
  158. Airtronics rds8000 binding problem
  159. Programing Spektrum DX-7 Aux channels ?
  160. 2.4 requires digital servos?
  161. DX7 aircraft backup possible?
  162. what radio is best: KO Propo EX-5 UR or Airtronics MX-3FG FHSS-2
  163. Feedback for JR DS 811
  164. KO Propo EX-5 UR 2.4ghz
  165. Whats the difference between surface and air servos?
  166. infinity 660 airtronics NO Rudder TRIM
  167. JR 9X tranny / lipo ?
  168. To 10c or not to?
  169. Aileron travel
  170. Towerhobbies 2.4ghz radio
  171. vintage radio
  172. Turnigy receiver controlled on off switch
  173. Help choosing a radio!
  174. How do I put a gyro on ailerons?
  175. How do you think about FD 2.4G system
  176. Futaba 129dp
  177. Spektrum DX3R Framerate question!
  178. ESC interference with futaba 2.4 ghz
  179. Nitro Planes Digi servos
  180. Spektrum setup question (no throttle)
  181. Request for a review of several radio systems or best bang for my buck.
  182. New Futaba 8FGA & 8FGH 2.4Ghz Air Radios
  183. PCM Receiver Crystal Question
  184. HELP!!!! Which size servo do I need?
  185. Problem with Corona RP6D1 Synthesized RX
  186. questian about range
  187. Elevator - Flap Mixing????
  188. Airtronics sanwa vs spektrum
  189. Antenna question
  190. Question regarding compatibility
  191. hitec servo problem help!
  192. My Airtronics RDS8000 is Dead - AGAIN!
  193. will a hitec hfd-08rd reciever work with a futaba transmitter?
  194. Aircraft Mixing
  195. How much longer will 72mhz be around?
  196. Old Cox Sanwa 3-Channel
  197. Hitec Aurora 9ch TX - Buddy / Trainer / T.Pupil (Slave) set-up
  198. Futaba R6004FF Real World Range?
  199. Large UAV Controls
  200. Futaba 2.4ghz Receiver Problems!!!
  201. JR 12X LCD scratch removal?
  202. Tower hobbies 224 2 channel 2.4GHz Tx/Rx
  203. Fatuba 3PM 2.4ghz Problems
  204. Airtronics rd-8000 and vg-6000 question
  205. Airtronics RD8000
  206. Where to get replacement JR DS-285 servo arm?
  207. BnF and Spektrum Air Module
  208. Aurora TX Mode Change, Stick Tension, Sim set-up & Fast Charge.
  209. Airtronics 2.4Ghz 6-channel park flyer receiver
  210. Quick DX6i question
  211. Futaba 6EX throttel cut button HELP!
  212. How????
  213. can't install jr pc interface program into xp
  214. Servo glitching at half throttle - gas engine?
  215. Rudder elevator mix in Futaba 6EX
  216. Airtronics 92104 RX
  217. HK-6 Tx conversion from 12 to 6 volt
  218. Hitec 40 FM transmitter with a Graupner 40FM reciever???
  219. servos refuse to turn all the way around
  220. A123 balancing question
  221. Liu le used WFT09S 2.4G controlling yak54 50CC
  222. Airtronics micro receiver
  223. Blinking Spektrum AR500 Receiver is normal?
  224. BEC switch & Harness
  225. Radio for mini titan
  226. 72MHz Synthesized Transmitter Module For Futaba?
  227. WFT09S 2.4G radio, Another test made By Liu Le and Yang an
  228. Why No Choice of Receivers with 10cg???
  229. Anyone have experience with EXI servos?
  230. Video for WFT09S 2.4GHz 4096 resolution testing in Shenzhen Minsk Aircraft Carrier World
  231. 2.4 and RX
  232. frequency of non-digital servos
  233. Spektrum AR500 Save on gas plane?
  234. 72-75Mhz vs 2.4Ghz Transmitters
  235. Assan 2.4 module: any good?
  236. esky stuff any good?
  237. Is Duralite 11.1 V Li-Ion OK in DX-7 ?
  238. graupner 2.4
  239. Understand the difference betwen AM, FM, PCM, and Spectrum
  240. futaba t12z...where can I find the exchanges?
  241. Electron 6 rx - anyone else have one that will begin glitching?
  242. Tx/Rx Compatibility
  243. Sporadic behavior with weak signal, normal?
  244. Glitching like crazy with TX power off
  245. E-Flite Blade CP Tx Compatability
  246. what Tower Hobbies radios going 2.4 GHz
  247. Futaba steering servo
  248. Frequency Question
  249. 50 MHZ Mini or Micro Receivers????
  250. perfect regulator
