PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Buddy box on Airtronics VG-6000 radio help
  2. Futaba 14MZ discontinued ?
  3. Dymond Model Sport servos
  4. best place to buy Nicad battery packs
  5. Spektrum trainer cable.......
  6. Gyro & DX6i please help!
  7. 27MHz radio question
  8. Futaba 9C Total Usage Timer (Futaba Service Menu)
  9. 12FG,12Z&14MZ Futaba owner question
  10. Gyro installation on a rudder of a plane
  11. 8U 2.4 Conversion
  12. Are these ebay servos any good?
  13. Tower Pro MG995 Servos
  14. 2.4 and battery use
  15. Need to upgrade Radio
  16. Increasing ESC power
  17. 12FG and crow mode
  18. Truggy/buggy Servo spec comparison and where do we draw the line?
  19. Flaps set-up Futaba 7C
  20. Futaba 6ex pcm
  21. DX7 with broken stick ┬┐can I find a spare?
  22. Lithium TX Pack for Futaba 9C &10C
  23. Lipo Charging In Plane?
  24. Digital servo with non digital receiver?
  25. JR S400... Adding channels?
  26. Servo gears lubrication
  27. Return to flying-radio input: Airtronics RDS8000, Futaba 7C or Spektrum DX7
  28. RDS8000 2.4
  29. How bad will the Aurora hurt the 10C sales?
  30. e-flite tx \ e-sky rec
  31. Need crystals? Check out Performance Devices!
  32. SHORTAGE OF RANGE PLEASE HELP ME!!
  33. longer range with radio
  34. 2.4ghz rec. aerial. which way does it go?
  35. Turnigy/Eurgle 9 channel 2.4 radio
  36. one transmitter per model??
  37. JR transmitter with Hitec receivers?
  38. FD 2.4G?
  39. SPEKTRUM RECEIVERS shut down
  40. Task for servo or other?
  41. Can' decide on TX snd Plane
  42. Futaba radio AILERON stick is basically stuck! Help!
  43. How to make your RC Servo Water-Resistant (VIDEO)
  44. loss of channels
  45. servo positioning......!!!
  46. Quantum 8 from FMA DIRECT?
  47. has anyone tried the hobby king mini digital servo "HD-1581HB"
  48. Futaba 9cap super-twin elevator 5645MG
  49. 2.4 problems
  50. Weird servo chatter, need some help!!
  51. what do you think about this system ?
  52. Futaba PCM Receiver Question
  53. Which JR reciever 2.4 for 100CC plane ?
  54. Powerbox Competition - using extension cables.
  55. 7 ch spectrum RX
  56. NO MORE 2.4 to 72mhz module switching?
  57. Something for check my top speed
  58. How to manage 2 Servo Aileron and 2 Servo Flaps by 6EXAP?
  59. Which madern receive can i use for cirrus 900 xlc ??
  60. Good First Tx for a Beginner
  61. How to make servo rotate 180 degrees with this remote...
  62. Hyperion Atlas Programmable Servos DS20's
  63. Futaba Service Advisory
  64. why is 2.4ghz so good
  65. FUTABA TRADE-UP PROGRAM!!!
  66. TX/RV COMBO'S
  67. is a servo a generator?
  68. Futaba R127df
  69. Spectrum recievers and brown out
  70. JR Model Transfer
  71. Hitec HS 5955 TG in a Jet
  72. Futaba 10c replacement switches
  73. Graupner/JR MX-22
  74. RDS8000+1RX FOR 99.95 HOBBY PEOPLE
  75. Hobby King HK-T4A Transmitter
  76. Think My Airtronics RDS8000 is DEAD
  77. Flaporons
  78. Y Harness Troubles
  79. Telemetry
  80. 72 MHz systems
  81. 6EXA/Electron 6/E-Flite Eratix Range Question
  82. DX7 Programming - Full-House Wing
  83. Hitec's Mini 6s RX wire 'bobbin'
  84. 4ch receiver and transmitter help
  85. HD - 9150 MG SERVOS ?
  86. Hitec 645MG glitching
  87. Any "compatible" 2.4GHz Receivers available for Airtronics, or other?
  88. Airtronics 92824 Receiver antennas
  89. Motor turns
  90. RDS8000: Dual Aileron EPA?? Please Help!
  91. Placing RC equipment
  92. Futaba HS Receiver (HS High speed mode) with servo
  93. President Obama's Futaba FASST System
  94. 10cg-2.4 R6014 HS
  95. Bearings vs. Bushings
  96. I have a Spektrum DX6i and AR6200 Receiver. Is it possible to...
  97. looking for 2.4 ghz 2 ch stick radio. options?
  98. Radio for gas boat
  99. Motor Froward/Reverse problem
  100. JR NES791 servo voltage question
  101. Breaking in brushes
  102. TrackerIII @ 2.4GHz Assan X8-hack module?
  103. POWER HD-DS120M HV Anybody using them?
  104. Revo Servo programing
  105. armature Help
  106. JR 12X Data Transfer - Setting Curve Points
  107. Futaba 10C Throttle curve
  108. sensored motor with sensorless ESC, will it work?
  109. Motor Problem
  110. US volz servo distributors?
  111. JR receiver with high voltage servo
  112. Lipo's in transmitters ? ? ?
  113. Airtronics crystal in a Hitec Receiver
  114. Hitec servos jittering after soldering on exts
  115. Receiever Help
  116. crystal failer
  117. JR X388S
  118. spektrum pro module for m8 work with sr3000 rx?
  119. Futaba new 6ch parkflight reiceiver with HS mode
  120. JR 9303 problems
  121. Futaba HRS and ESC Hard question
  122. Servo Arms for HexTronic servos??
  123. Duralite Question
  124. Do any transmitters use optical absolute rotary encoders?
  125. twitchin` ailerons
  126. Futaba 2,4 ghz lost signal
  127. Gyro Preference
  128. Weatronics 2.4
  129. Looking for ideal pair for Hitec transmitter/receiver
  130. Futaba R6014fs Low Signal Voltage workarounds
  131. Futaba R0114fs Low signal voltage work arounds.
  132. Gas esc
  133. Compatibility between different 2.4 manufacturers??
  134. DX6i buddy box?
  135. My thoughts on the Spektrum incidents...
  136. Old Century vII 7 ch pcm
  137. Airtronics Vanguard doesn't transmit
  138. Dx7 range??
  139. Futaba 7C problem - Idle-Ups and D/R's
  140. JR JEEP 2 Radio System?
  141. Spectrum / JR Air Mod [ PERFECT ]
  142. futaba 9cap question
  143. No Control Over Speed
  144. JR 8101 Servo buz on Futaba r6014fs receiver
  145. twin elevator servos-can't get them equal
  146. DX6 vs DX6i
  147. Futaba FASST 2.4 modules?
  148. Futaba 72MHz Rcvr Antenna Length
  149. DX7 Dual Elevator
  150. RDS8000
  151. ACTUAL EXPERIENCE WITH TOWER PRO 995 SERVOS
  152. Old Airtronics sail winch?
  153. Stick tension adjustable on Spektrum DX5e?
  154. Compatability Servo's-receivers-transmitters
  155. DX7 Experts, need your help on a twin engine setup
  156. What style horn do bluebird servo's use?
  157. 27 & 75am Crystals the same?
  158. Surface radio adjustment ?
  159. Suggest a multi model car radio
  160. is it safe to run 4x 200oz non digital servos from 2 aileron channels on my spectrum dx7
  161. (2) 149DP receivers not working
  162. Twin elevator mixing,something's wrong!
  163. Model transfer from Futaba 9ZAP to 14MZ
  164. Spectrum / jr AIR MOD ?
  165. ESC problem or tx/dx problem (ESKY and Turborix)
  166. Beware of HS-225 Servos
  167. reducing bec voltage from 6v to 5v...
  168. Electric sailplane vs Jr12X setup?
  169. best servo-in 75-100 oz range
  170. Futaba 12 FGA Dual Rates switch problem
  171. Corona Conversion for JR
  172. Anything new from JR?
  173. JR 12X programming butterfly (inverse stick)
  174. did i ruin my ESC?
  175. ON-OFF timer for ESC
  176. DX7 Model Settings Spreadsheet
  177. Airtronics Championship series single stick tx manual
  178. Changing Crystals
  179. Transmitters configurable via PC?
  180. need help chooseing a radio
  181. Single stick?
  182. NOOB servo question???
  183. JR 12X Mode Change
  184. Range issues with Futaba 7C 72mhz
  185. steering servo glitch with throttle pinned
  186. 2.4 Interference can happen!!!
  187. DX5E
  188. Aitronics Tx Antenna
  189. Futaba R122JE AM Receiver Glitching - Need Cures!
  190. DX7 Battery Up Grade
  191. Replacing JR RS300 Antenna wire
  192. SIMULATOR CABLE OF AIRTRONICS
  193. Futaba 8u flap help
  194. Spectrum DX7 verses Futaba 7C
  195. Reciever installation
  196. Smart Fly Super Regulator and Servos
  197. P-mix for the 9CAP Super radio
  198. Cheapest 2.4Ghz
  199. Futaba 8U with Syn Module issues with Hitec receivers
  200. Futaba 3305 servos
  201. Positive vs. Negative shift
  202. 2 Power HD-9150MG on y-harness
  203. Power HD Servos
  204. What servo 1/10 elektro buggy
  205. Do all 2.4 Ghz systems require a 5 cell (6 volt) receiver pack?
  206. expediential adjustment
  207. MatchBox VS Equalizer??
  208. Which controller?
  209. Old servo specs
  210. Servo Arm Compatibility
  211. 2.4GHz: DSM2 vs FSST vs JETI vs XPS
  212. UBEC Question
  213. servos buzzing....
  214. Hyperion Digital Servo Fried
  215. Big Offroader 2.8Ghz dsm Tx and Rx
  216. 12FG and throttle curves in airplane mode
  217. radio/real flight intelink shock
  218. radio/real flight intelink shock
  219. Futaba 12FGA vs 12Z
  220. Powering Hitec HS-5745MG Giant Servos
  221. Futaba receiver question
  222. 12Z Battery
  223. WHY MAKE A 27T MOTOR WITH 36 DEGREE ADV TIMING AND WHAT WOULD IT BE USED FOR?
  224. 12X with 2.4 module
  225. Centering problem
  226. wild beginner questions
  227. FD 2.4GHz 8ch radio V1.2
  228. JR 8103 Reset...
  229. Kraft Spectrum 6 Transmitter Batteries
  230. JR- Futaba 2.4..Cant decide....
  231. Need help with (Futaba 7C) rudder to aileron mixing
  232. 2.4 Ghz FAAST Receiver Installation.
  233. Shortening Servo Leads
  234. Using existing servo for use with electric motor
  235. 12FG Service Menu
  236. JR 10X battery voltage readout fluctuating...
  237. Looking for advice on upgrade to PCM RC
  238. RD8000 Worth fixing
  239. M8 with spektrum Value?
  240. Hitec HS 6635HB Horrible Service and Support
  241. servo centering
  242. Servo wiring help
  243. Dual Servos for aeleron control - beginner question
  244. DX3S Broken Antenna
  245. program Futaba 3PM-2.4 G Fasst Transmitter for car
  246. Servicing an older Futaba radio in California?
  247. Servo Compatability
  248. How long does a radio last??
  249. Can you transfer Models from a DX7 to a JR 9303?
  250. compatable receivers?
