PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Programming butterfly on a sailplane with a JR12X. Help please..
  2. delete
  3. Number of servos per channel
  4. ANY COMENTS ON JETTY 2.4 GHZ MODULES AND RECIEVERS
  5. Futaba 12FG Stand???
  6. Ignition Kill switch wiring
  7. Handling fee from Futaba
  8. AR6100 CC 10 AMP BEC LOCKOUT
  9. Trainer cord: JR to Futaba systems
  10. 2.4 glitch with AR6250 and Dx-7??
  11. How many servos run thru RX
  12. Servos Buzzing
  13. servo selection
  14. JR servos and Futaba
  15. two RX's on one TX
  16. Airtronics Receivers... ?
  17. What difference btw car radio & heli radio?
  18. Futaba brushless servos and unregulated A123 2 cell RX batt
  19. Anybody use cheap battery on Spektrum dx6i?
  20. Is 5 cell Nimh OK for futaba 6014
  21. Looking for compatible Rx for futaba 2.4 GHz
  22. Elevon mixing on futaba 6EX
  23. DX6i with 3 ch. surface RX
  24. JR 8611A servo potentiometer
  25. Flat Channel knob
  26. JR XP8103 Hooking up 2 elevator servos, Question
  27. Trainer cords?!!!
  28. box and packing for Futaba 9C or 9CSuper
  29. Who sells Hyperion Atlas Programmable Servos?
  30. AR9000 Firmware or Hardware Bug?
  31. Radio for jet ???
  32. 4 DS821's OK on 6 volt (AR7000)
  33. Broke DX5e Antenna Cover
  34. xp9303 vs x9303
  35. Help with radio choice
  36. 7C 2.4 Settig up a Jet
  37. AR6200 wiring polarity
  38. JR 9303 2.4GHZ best price ?
  39. High Torque Servos or 6V receiver battery???
  40. JR 388X Radio / Spec. Mod.
  41. Servo ?
  42. 9C & rubber duckie antenae
  43. Better 9303 Setup Data Sheets?
  44. Hitec 5975 & HFP digital programmer?
  45. Hitec reciever question
  46. New 10C Questions
  47. Hitec 5965 MG servos
  48. Crystal....after market mfg..?
  49. Servo Power Expansion unit
  50. changing futaba recievers
  51. Servo shimmy
  52. Running LiPoly 11.1 Battries in Jr 9303
  53. Is this vtail mixer faulty???
  54. Throttle servo glitching
  55. 12FG or 10C? - Help me decide!!
  56. rx antenna routing
  57. Servo crosstalk problem
  58. Futaba Transmitter Problems?
  59. Fly Your R/C with an iPhone
  60. Buddy boxing a DX7 with Futaba 7C?
  61. best range
  62. Broken wires
  63. UNBELIEVABLE for JR module/rcvr combo
  64. Futaba 12Z, Technical support and Direct support forum
  65. speaking of 2.4ghz tx's and rx's = placement of rx in tight fuse ?
  66. help wanted Heathkit single stick
  67. DX6i help
  68. Why Don't the guys on 72 & 50 MHz get it ???
  69. HELP with SPEKTRUM AR6000 antenna placement.....
  70. Futaba ATV & AFR VS. ATV & AFR!
  71. Futaba Gimbals, 10C, 12FG, 12Z ?
  72. Hitec Supreme 8 IIS, antenna cut, resoldered, is it safe?
  73. RX ID code on R5014 wiped of.
  74. Futaba 4YF transmitter mhz
  75. conversions
  76. Spectrum DX5e Pros & Cons????
  77. Recommendations for 12-channel 2.4 GHz system
  78. Reason for not upgrading to 2.4
  79. Futaba 7ch 2.4ghz Channel 4 Problem.
  80. crystal question
  81. Futaba 6EX: Modify TX channel 6; Flaps
  82. programming be transfered from my 9c super to 10c or 12fga?
  83. How many chanels doyou need????
  84. New JR X9303 ???
  85. Ikarus MR-6 reciever question
  86. Anyone used the new Jeti 2.4ghz system?
  87. SPECTRUM AR7000 RECEIVER LOCATION CONCERNS W/PIC'S
  88. Futaba 10C and reflex
  89. water proof
  90. Signal strength
  91. Spektrum AR6200 & a Bipe setup problem?
  92. Futaba R6014FS and R608FS Discontinued
  93. Picked up a new futaba 3pm
  94. filter for long servo extensions?
  95. TX lipo Power level
  96. Replacement Metal Program Roller, DX6i & 9303
  97. Telemetry for RC cars
  98. Cleaning my Futaba servo extension connectors
  99. Polk's Hobby 2.4Ghz radio
  100. Polk's Tracker 2.4 Ghz
  101. Frequency Board During 2.4 Conversion
  102. Future antenna questions about 2.4 GHz systems
  103. How Reliable Are the 2.4gHz Systems Now?
  104. Dead Radio
  105. NEWBIE Question - Synching up TX/RX/Servos
  106. new 5645MG-twitching like crazy
  107. buddy box set up
  108. PLEASE POST IN SPECIFIC MFG SUPPORT FORUMS ABOVE ONLY!
  109. Spectrum ar9000 problem
  110. NO Longer "DONE" with the JR 9303
  111. Futaba R617FS replacement antenna?
  112. 10C Aerial question
  113. Disapointed with futaba charing me for screen replacement
  114. Tower 6XM TX
  115. JR 12X DSMJ or DSM2
  116. Flaperon settings on Spectrum DX-7
  117. Ace Micropro 8000 upgrade to 2.4ghz dual deck
  118. Used Tx buying tips and 9c as entry to 2.4GHz
  119. JR XP9303 convert to 2.4G
  120. Might order this Radio!
  121. can I charge a JR transmitter with a futaba charger?
  122. Not Able To Bind my AR9000's
  123. dsm dsm2 spectrum
  124. Problem w/ Futaba S3152 Dig. HI-Torq Servo after crash into the drink
  125. HELI RADIO FOR AIRPLANES??
  126. I'm disappointed with the new Airtronics repair service.
  127. Cheap 2.4 w/micro receiver
  128. Futaba Skysport T6YG Range check problems
  129. hitec servos
  130. Airtronics RDS8000 2.4GHz FHSS
  131. Futaba 7-C FAAST
  132. AR7000 w/o remote receiver
  133. URGERNT!! How do you reverse the controls on the E-flite LP5DSM 5 Channel Radio?
  134. URGERNT!! How do you reverse the controls on the E-flite LP5DSM 5 Channel Radio?
  135. ACE Retract Servo Diagram
  136. MC4000 throttle-cut mix?
  137. DX-7SE
  138. Futaba 9CAP
  139. Under The Title Of Do Not Do This...
  140. V-Tail on JR9303
  141. Futaba 2.4ghz receiver in a fuse with carbon wing tube
  142. 2.4 on the way!!!!
  143. Align-DS610 or the Hitec HS-7966HB servo for .60 Heli Rudder
  144. Smooth up the Pitch Stick Spektrum DX7
  145. futaba 14mz case
  146. JR 12X How do you program in crow??
  147. Can output voltage from a RX be regulated ?
  148. Futaba 10C - No Longer Modular?
  149. Spektrum/JR rc sim adapter
  150. spektrum dx3s displaying CAL in upper left corner
  151. RC LED
  152. Flash 5SX
  153. help finding esc
  154. Airtronics 97002 switch work with JR?
  155. Spektrum DX6i Radio recall
  156. Glitching! Need Help!
  157. t6exhp dual aileron servos
  158. Range loss?
  159. Cirrus 751 MG servo
  160. *Airtronics SD-10G 2.4 GHz*
  161. Spektrum DX6I Reciever??
  162. ace rc inc Christy Mixer
  163. Hitec 645MG vs Hitec 5645MG
  164. Newbie - Which Radio??
  165. Radios?
  166. Airtronics RD6000 or JR XP662?
  167. Analog retract servos in the 2.4GHz era
  168. on/off switch from esc
  169. The cutting edge of technology
  170. 2 servos on flaps, elev and ail_JR X9303
  171. How do I identify a servo...
  172. DX7 Throttle seems kinda sticky lately?
  173. JR radio Question
  174. Fasst system question
  175. Weattonics 72 MHz Rx - who sells them
  176. Esky Transmitter/Berg Reciever in wild hawk
  177. Robart Retract Servo???
  178. 12X MV 2.4GHz DSM2 Module
  179. servo testers
  180. R617FS rx - WHERE DOES CH7 GO??
  181. My Futaba 8UAF broke.
  182. Futaba R606FS batteries
  183. Anyone using Hitec HS-5485HB servo ? Would it be a good upgrade from 3004 ?
  184. Airtronics FHSS 2.4 question
  185. Voltwatch and JR Receivers
  186. DX6I ?
  187. using airtronics servos with futaba rx
  188. Losi 2.4ghz radios?
  189. Crystal Identification
  190. are spectum radios reliable now?
  191. adding a charging jack?
  192. Where can I buy for a 10x the battery Tx case cover and some switches????
  193. Futaba 3PM FASST Failsafe Problem
  194. Impact of trim on resting servo current drain
  195. Spectrum receivers in large modes
  196. Servo Connectors Don't Fit the RX
  197. Rx's at Donald's Hobby Center?
  198. JR 12x and sailplane program
  199. Crystal Replacement
  200. Using Hitech servos with Futaba 2.4 Ghz receiver.
  201. is it ok to have a servo with continous load?
  202. using a 6ch airplane radio for truck usage?
  203. New Futaba 10CG (dedicated 2.4 ghz)
  204. 9303 w XPS binding problems to AR7000
  205. Futaba 9C versus JR 9303
  206. Losi 8ight buggy Servo Issue
  207. JR to Futaba?
  208. JR Data Transfer and Printing
  209. turborix 2.4GHz 6 channel Tx
  210. JR And Spektrum 2.4Ghz
  211. Old servo
  212. Futaba GY502 Problem
  213. Spektrum DX3R VS DX3S
  214. Transmitter, Receiver compatability
  215. All servo's are fluttering. why?
  216. I got my Dx6i back
  217. Futaba 10CG dedicated 2.4 Ghz
  218. 10c and flaps
  219. Hyperion Coreless Servos
  220. Dual elevator lag with Futaba 10C noticeable?
  221. RX Instalation
  222. How many receivers can go under a spektrum module?
  223. Spektrum DX 6 Park Flyer binding
  224. Hitec 81hb anyone tried it????
  225. where to put them?
  226. Need 4 Channel 2.4ghz For Traxxas Summit
  227. Basic/Advanced, Airtronics RDS8000 TX
  228. where to find early three channel blade runner tx & rx
  229. Does anyone remember Aero Pack International's "G-pack" foam?
  230. programming a sailplane with JR12X
  231. Spektrum DX6i trim switch
  232. Converting on-off channel to proportional
  233. DX6i default programs
  234. Radio/servo compatability
  235. Futaba 7C. Dumb question
  236. E_SKY receivers
  237. JR 12X
  238. Are servos supposed to make nosie, at idel?
  239. Crystal for JR R600 Receiver
  240. Spektrum DSM2/AR7000 Airmod update ?
  241. Does anyone have the DOD video on how to program hitech servos??
  242. DX3R VS DX3S
  243. Matchbox won't work
  244. servo pulling power
  245. Safe range check distance for a gasser.
  246. Futaba
  247. AquaCraft's Reef Racer 2 transmitter/receiver
  248. JR Quattro to gitec focus link
  249. JR 9303 2.4 Won't turn on...2nd time this has happened
  250. Binding Spectrum DX7?
