- Major unknown DX7 & DX6I Issue - Please Help
- Receiver and Transmitter problems
- looking for 2.4ghz radio...
- futaba haters rejoice
- SD10-G Programming Gurus, I need some help........
- Airtronics Feature Card
- Please identify this type/model of PCB plug.
- 8FG or Aurora 9
- how do I know when my TX is charged
- NO SELLING - JUST COMPARE FUTABA 8FG TO A9 HITEC
- SD 10-G VS T8FG
- Futaba 8UAFs 2.4 conversion
- Converting my JR 9303 to 2.4 with no wires
- Where to obtain Futaba type toggle switch nuts?
- Spektrum AR6200 UNBOUND! WHY? HELP!
- Servo Specification Database
- Servo and transmitter advice
- 2.4 Glitching with Futaba 10 C
- 2.4 GHz reciever placement
- Wire Source?
- servo compatibility with DX 7
- sim or program cable??
- draganflyer V Ti communications
- JR xf 622 placement of spring?
- safety: DX6i throttle lock
- reciever batt
- RDS8000 receiver antenna lead replacement?
- Airtronics use with Phoenix Sim??
- please recommend a transmitter
- problem with castle link.
- 14MZ Case Mod to accept TM 14 antenna
- Futaba R6014FS Reciever Channel Assignments
- 7C / DX7
- dx3s telemetry
- Futaba 12FGA
- Spektrum not binding
- Airtronics Tx w/ JR Rx???
- Futaba 3PG question
- Spektrum, FASST, Hitec - compatible?
- all my servos jitter when I turn on the radio
- DX-7
- servo size for spacewalker2
- ACE MIX MASTER
- Beginner needs help
- Corona DSSS 2.4 receivers
- Futaba 10CHP
- Servo for Futaba 4PK
- Totally Confused (SpektrumDX6i AR6200 etc...)
- Futaba 7c Rx Questions
- futaba t7c stick length
- Skysport 6 has no range.
- How do I adjust the 9ZAP throttle stick?
- Futaba 4PK or Airtronics M11X?
- Does anyone have a art-tech 6 channel
- multiplex power speed alloy servo horn?
- dx3s servo vibrates
- shortening wires on servo..
- AR6200 failure, Possible?
- Coming Back to Hobby... Which radio?
- Elementary question about FASST TX and RX
- Do I need separate power for my receiver?
- TB Power HD 1501 Servo's
- GYRO Clarification Needed
- 12FG Function menu prog question
- Gyro Gain Settings
- AILERON TRIMMING.
- Gyro Placement for Rudder Control in Fuselage?
- Channel Sharing with Battery
- Cirrus CS 601 std servo from Hobby People
- Servo mounting screws
- 14MZ AFR set up help needed.
- Radio control range
- Feedback wanted on hitec 2.4Ghz system
- Kinda a newbie question about jr rx's...
- DX6i Tutorial
- How can I fully program Futaba 9156 servos
- Switching from DX7 to X9303
- Spektrum DX7 Dual Elevator Setup Help
- Question about Spektrum AR7000
- new controller
- Are a JR 10X and Spectrum DX6i buddy cord-able?
- 9CAP PCM Battery Door
- 14mz issues(when switching different conditions )
- What is latest 12FG firmware version?
- will these work?
- Re-using r/c parts
- FUTABA 4PK ?
- Spektrum users BEWARE!
- newbie: batteries for transmitter?
- Lipo for 4PK?
- JM912 FASST
- Transmitter problem
- Mixing v tail on 3 ch glider to right stick
- anantana length
- Data pulses from DX5W amd 6EX
- Spektrum Dx6i, battery charge level
- servo voltage
- Stalled Servo?
- Fastest servos for .50 sized aerobatic airplanes
- Need LCD for DX7/ JR 7203
- JR sport servo help please
- flexible short aerial for futaba
- Spectrum Lock Loss problem
- is this installation ok for Spektrum ar500 receiver on a glider??
- Buying a new Futaba design first run
- Sound coming from DS821 servos?
- Spectrum AR 7000 dual battery hook-up
- 10c 2.4 problems (6014fs problems)
- What radio do you recomend me for this project R/C Roomba
- spektrum?
- adding 2 servoes for elevator and radio
- Gyro Help
- setup for Futaba 3PM effect
- Looking for a 2.4 Radio
- 10c questions (why did they make the 10cga)
- 14mz spektrum module setup
- converted dx2.0
- plug heat sink into rx question
- All new JR 11X
- JR 9303 Air Radio
- 3PK vs 4PK
- Backup Campac from 9C to 9CSuper?
- 2.4ghz module for hitec eclipse 7
- My DX2.0 super mods converted to DX3.0 and Telemetry
- need help finding module
- T4vf modified as trainer radio w/T10C
- SR-10 Dual Servo Reverser
- Reverse Throttle Response Needed
- v-tail connection
- Re: digital servos-what does HRS mean?
- Futaba 9CAP receivers question
- Hitec 1/4 scale servo pin out for futaba??? HELP
- Kraft Radio
- Futaba 10CAG & R6004FF P MIX Help!
- throttle servo issue
- Jr 9303 and Jet legend F15 help please.
- Corroded servo extension connectors.
- Spektrum DX2.0 to DX3.0 conversion step by step instructions inside
- Need Radio for drag racing & hi speed runs?
- Which radio
- looking for 3 inch metal full servo arm
- Eargle 2.4ghz surface radio
- N00b Radio Question
- Futaba 7C 2.4
- JR XP7202 Crow
- futaba
- Hitec Aurora 9 Manual now available.
- Manual for JR Max 6 Ch Radio
- 2.4 ghz rx and battery proximity ?
- Deffective Servo after forgotten failsafe
- Spectrum Radio Questions
- HELP, how to Program 12FG 3 pos switch
- Futaba 617 Radio
- Hitec A9 Maual Please
- Litco Systems #R101 xceiver. AM or FM ???
- ek products
- Walkera 2401 and external power
- comparing range checks, your thoughts please.
- Radio interference ?
- Has anybody used a JR XF421 as a buddy box for DX7?
- Multiplex Evo 9 programming question
- Fasst 2.4 module in FG series Tx?
- Tx charge = FAIL
- Reciever problems
- GTB Goes to WOT When Tx is Turned Off
- Mode 1 or 2 for US?
- Spektrum 6100e or 6110e
- Reversing a SERVOS direction
- Where to find transmitter for Radioshack truck.
- X9303 & Flight Modes
- Does anyone know the specs on a Futaba Receiver R136 F
- HS-7985 MG SERVOS
- futaba steering potentiometer
- need help with new futuba
- 42% Opto Kill Switch
- have you had a 14MZ stolen?
- HELP! Changing to stick mode 1, from 2
- Best bang for the buck trans and receiver.
- hitec servos & 2 cell lipos
- JR 791 & RT88 retract servo dimensions?
- servo help......
- Hitec 2.4Ghz Module/RX combo arrival
- Getting back into flying - what radio
- New JR DSX9. Heard anything about it?
- wanted to buy futaba 14mz
- SPEKTRUM BATTERY MELTING
- servos start with a delay- Futaba and FMA Direct
- Airtronics 6-channel flaperons
- Upgrade....help please
- 2.4 ghz Telemetry?
- Chidgey Single Stick Gimbal
- Flight Conditions VS Flight Modes
- Shipping to Mexico
- diff with ball bearings and teflon bearings
- Help with a receiver?
- Exceed RC 6-Ch 2.4Ghz Radio?
- The best Hitec or JR Throttle Servo for the buck?
- Futaba 10C and 4 Aileron Servos question
- Anyone Using Non Futaba CF card in the 12Z
- Q: WFLY 2.4GHz, it is hopping DSSS
- DX3S
- NEED HELP WITH NEW DX3S!!!!
- Car type TX with buddy box?
- More new Airtronics 2.4Ghz FHSS receivers, Cirrus - Airtronics radio
- Futaba 617
- 12X Flap system versus right eyebrow trim
- venom fm radio
- Servo Install
- Elevator Problem..
- Spektrum DX7 cut the controls to my airplane
- need from help how can bind and setup fail safe Airtronics mx3fg
- delete pls
- Will K Band Radar mess with Spektrum 2.4 signal???
- dsm2 module for futaba 10chp
- nimah or nicad in transmitter pack
- 149DP receiver Hi-Lo
- help for trimming retract servo
- chatter to all other servos when throttle used
- Futaba 2.4 ghz Reciever Offerings
- Anyone familiar w/Futaba 7FGK TX Radio ?
- Hobbico Standard Servos
- ppp servos
- 12FGA and 608FS question
- 2.4 and servo problem
- Is 2.4GHz susceptible to noise?
- Is my 9CAP going to be a dinosaur?
- How to tell what is bad, receiver or transmitter?
- Ever tried a Corona Synthesized receiver ?
- 149DP receiver-not responding-HELP
- JR X9303 Elevons??? Help with how to.
- JR R610M MICRO RECEIVER ,Q
- What tail servo for JR G500T? Hirobo Sceadu
- Going from Futaba to Airtronics Question?
- JR DS821's in a Speed plane?
- How much will a New 10C cost in 2 years?
- JR PCM9X II programming of aux4 channel
- Slop in HS 7955TG out of the box ???
- Futaba 12fg charging
- GeeWizz is the Futaba S3305 a dud?
- 9ZHP WC2 Heli convert to Throttled ratchet
- JR Z9100 ultra tourqe, and high speed servos???
- Futaba T7CAP Lcd panel display question
- 12fg issues
- Futaba 6EX Flaps + Elevator Trim
- DX7SE Spektrum
- airtronic's RD-8000 question
- HOW DO I USE MY RX?
- Price Increase for the Futaba 8FGA
- V-Tail and JR 12X
- Spektrum Rx antenna repair
