PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. new transmtter, best instruction manual?
  2. Reprogramming a Futaba display & 2.4ghz antenna?
  3. Can I convert hitec to 2.4 using a module like this?
  4. Are Fasst and DSM2 the same thing?
  5. 10c trainer switch problem
  6. blue bird servo plugs?
  7. Airtronics Rcvr, what is maximum allowable voltage?
  8. Futaba 6EX Problems
  9. Spektrum 9100/JR servos and unregulated A123
  10. Bench testing new servos.
  11. My DX3S died... Or something.
  12. Radio Data Sheets
  13. AIRTRONICS 2.4GHz A GOOD DEAL?
  14. Futaba 12FG compatible SD Cards
  15. It may be naive, but I still want to know....
  16. Futaba Receivers Question
  17. Futaba Heat issue? and you guys thought i was nutz
  18. Carbon Fiber causing radio glitches?
  19. Spektrum Futaba Never Ends
  20. How to fit a Futaba R617FS to a Walkera 60B
  21. difference between 9303 3 type and dedicated heli type?
  22. Display protector
  23. RX Antenna
  24. JR 2.4 radio Glitches
  25. Assan 2.4 Modules??
  26. Proper antenna wire length?
  27. 9303 Possible Lockout
  28. DX6i Binding
  29. Spektrum DX6I chargers
  30. Fail Safe Mode -You Guys Use It?
  31. Model Memory
  32. Here's one to pick your brain. Glitching issue...
  33. mode 1 mode 2 instruction books
  34. Dual Receiver Question
  35. Something interchangable with the MikroDesigns SPF5-ESC?
  36. Can I convert a 75 Mhz Futaba to a 27 Mhz?
  37. JR Cyclic Servo Selection EVO 50
  38. RES+motor on 4-channel radio, possible?
  39. tiny helicopters
  40. Futaba Rx install guidelines for the internetless?
  41. Factors afeccting RESOLUTION
  42. AR9100..Will I need power expander?
  43. Radio equipment for pulse xt?
  44. Futaba 6EX 2.4 Question
  45. 10c separate trims for each flight cond?
  46. Futaba 12FG and reciever compatibility
  47. 12FG Channel Order
  48. Tachometer help, PLEASE
  49. using airtronics m11 with 2 steering servos?
  50. Spectrum DX 7
  51. delete
  52. how do you attach flat aluminum servo arms
  53. This is probably a stupid question...
  54. JR 9303 2.4 aileron flicking at start up
  55. Down elevator MIX from the retract switch ?
  56. Futaba 7C 2.4 reset to Defaults.
  57. X9303 firmware update?
  58. Throttle hold in Acro on 10c
  59. JR 12x mix problems/questions
  60. LP5DSM radio (from CX2 heli)
  61. thottle cut\idle stuck on
  62. Spektrum AR500 application
  63. JR10x w/spectrum conversion
  64. rpm sensor
  65. 9303 2.4 problems, ?
  66. New JR921 Receiver
  67. HELP Setting up 3PKS with 3rd channel
  68. Radio Question
  69. Futaba Buddy Box Help Please
  70. DX7 Twin engine mixes . . .
  71. spektrum receiver antennas
  72. Spektrum DX6i
  73. Lost model alarms 2.4ghz
  74. Missing 14MZ in Puget Sound
  75. please help 12FG Gear sequencing
  76. twin engine trim quit working
  77. Switch nightmares
  78. RDS8000 - 6v?
  79. Polk Tracker III Radio WOW
  80. 208oz Digital Servo Free Shipping Money Back Guarantee
  81. RADIO FOR REDCAT SHOCKWAVE
  82. PCM or PPM mode for Aerobatic plane
  83. Aileron servos stuttering with Spektrum DX6 and AR6000
  84. Sero for E-MAXX
  85. EVX 2 not programing brake endpoint??
  86. Model File Editor/Converter 14mz/12z/9303/10x/12x
  87. AM to 2.4ghz
  88. Question about crystal compatibility
  89. Airtronics MX-3FHSS
  90. Futaba 12FGA/12FGH 2.4Ghz radio systems $629.97 at Tower Hobbies
  91. So who won the 2.4 race???
  92. Futaba 10C???
  93. china plane
  94. china plane
  95. Spektrum AR7000 and JR9303 2.4
  96. Quietest Servo??
  97. Change antenna on spektrum?
  98. Futaba TM-8 and R617FS - Lights
  99. futaba Campac compatibility
  100. Futaba 12
  101. 2.4ghz module in MX12
  102. Cycle a new 4.8v NIMH ????
  103. JR12X Mixing Question
  104. Futaba 9C...SPEKTRUM mod...Finally
  105. futaba fg-12
  106. Dual Aileron Servo On Futaba 6EX 2.4ghz
  107. DX7 Fail safe
  108. Voltage for RX
  109. What transmitter to use?
  110. WFly FT06-C and Phoenix RC sim
  111. Futaba Conquest PCM transmitter help
  112. AR6100 question
  113. Binding receiver in Spektrum radio
  114. FF9: Flaperon or Elevon for Canard aircraft?
  115. Flap-Trim in 9C-Super
  116. Corona 2,4 V2, in Futaba 9ZAP
  117. *removed post by RCFoozer until further info becomes avaliable*
  118. DX6i and eflight gyro-bld400
  119. JR data transfer
  120. Thank You for support
  121. JR12X Code Update
  122. Buying a new 72Mhz system ?
  123. Spektrum DX6i
  124. 70 oz. servos for Airtronics RDS 8000
  125. Need Stranded Servo Wire
  126. What regulator for a LiPo
  127. Radio number of channel questions
  128. MAN reports on Airtronics SD-10G 2.4Ghz radio system
  129. RDS8000 TX Battery
  130. Newbie Futaba 3PJ to 2.4?
  131. Futaba vs. JR for indoor
  132. X9303 help matching channels
  133. Does anyone collect vintage Futaba Radio Gear?
  134. HITEC BRAND VERSUS?
  135. 9303 2.4 screen adjust
  136. Futaba or Spectrum 7 Channel 2.4
  137. Flight Mode on JR X9303
  138. MPDX Pulse Values?
  139. Spektrum AR-6200 ?
  140. JR 9303 or JR 10X ??!!
  141. Programming DX6i for flaperons??
  142. MPX 4000 - which socket is for discharge resistance?
  143. HAS ANYONE USED BLUEBIRD SERVOS ON THEIR AIRPLANE???
  144. newbie DSM2 Bind procedure question?
  145. Questions about radios with more than 2 channels
  146. what servos should I use with a 50cc plane ???
  147. DX 7 Snap-roll ??
  148. Airtronics MX-3FHSS
  149. Mode 1 to Mode 2 in JR 10X
  150. JR positive shift??????
  151. Hitec hs55 reverse action
  152. JR Century 7 SS
  153. eneloop cells
  154. Are JR servo's programmable with a Hitec Programmer?
  155. 5945 question
  156. li-po's for TX use please respond only if YOU use them
  157. JRPCM10X 2.4Ghz issue
  158. DSM2 VS FAAST
  159. Can I get a JR Transmitter to work on a Hitec reciever
  160. DSM or DSM2 are there two kinds?
  161. Range issues!
  162. 9303 help please
  163. JR 10X Internal Fuse
  164. JR 921 & Power Expaner Pro
  165. 2.4 Module from Airtronics for Stylus??
  166. S3004 help
  167. DX7 setup 2servos ail,elev,flaps+1 retract?
  168. 3D Servos
  169. routing antenna
  170. Futaba 8UAP HELP!
  171. Radio glitches! This is a weird one.
  172. Transmitter Receiver compatibility
  173. Newbie needs TX and RX help Pls
  174. Battery Upgrade for a 10C
  175. Airtonics M11
  176. Twin throttle cut for JR XP6102
  177. x9303 dual servos on ail,elev,flaps
  178. binding 2 RX's?
  179. DX3s sensor question
  180. MX11
  181. 9C Ailevator issues
  182. spektrum dx2 & jr xs3, are they the same?
  183. How good are Hex Tronic servos
  184. Replace Radio System or Receiver
  185. DX6i and a buddy box
  186. Futaba 9CH -Dual elevator servo mixing
  187. Airtronics servos
  188. Servo compatibility question....
  189. SPEKTRUM RECEIVERS LOSE BINDING???
  190. jr 9CH RX SERVO LOCATIONS
  191. JR 9XII on super falcon 120 whit turbine.
  192. Futaba 7C FASST Throttle Cut Problem
  193. Jr 9303
  194. Jr 9303
  195. Eflite EFLR7130 to EFLRS75
  196. RDS8000 on flight sim
  197. TX under computer control
  198. Futaba 7C/FF7 2.4GHZ UK owners please
  199. Transmitter voltage?
  200. RDS8000 Has Me Confused!!
  201. old JR servo ???
  202. Digital / Analog Servo Jitters.....
  203. Not sure shot down or something else
  204. Walkera 4#3b & Airtronics RDS8000 2.4GHz
  205. travel adjust problem with JR radio
  206. Futaba 12 FGA Throttle setup
  207. Can Someone Explain The Advantages of a Digital Servo?
  208. Futaba 9C channel switching?
  209. Jr xp6102 HELP!!
  210. Fixing wiring on Hitec servo
  211. Blown fuse in Spektrum DX7 Transmitter
  212. 14mz Blade 400 CCPM issues.
  213. spektrums AR7100R heli receiver
  214. Question concerning ClonePac Memory Module for Futaba 9C?
  215. JR 9303 2.4 stick activated dual rates.
  216. Making spoilers/flaps out of ful span ailerons on Spektrum Dx7??
  217. Hitec servo gear sets for 5645
  218. Dual RX Batteries
  219. Futaba 3.5 gram RX!!
  220. Turborix 2.4 Ghz 6 Channel radio
  221. How do you mount your FASST antenna on CF fuse?
  222. Need HELP!!!
  223. Technical data of Hobbico CS-60
  224. replacement 2.4 FAAST antenie
  225. Buddy Box
  226. dual rate for the rudder on the RDS8000
  227. Help....Optic 6 and Spektrum
  228. Futaba 8U poor range test
  229. Spektrum DX6i
  230. Using Heli 4 channel Transmitter (FM) with 4 channel Airplanes
  231. Y-Harness /Dual Servo Extention
  232. 31 inch Tx Antenna on a RD8000
  233. Spektrum DX7 MIXING HELP PLEASE !!!!!!!
  234. Futaba Mixing
  235. Technical data for a JR servo
  236. What's up with Servocity.com?
  237. servos are buzzing
  238. JR 9303
  239. Not getting full throttle on Futaba buddy box?
  240. setting up dual elevator servos?
  241. Yak54 spe26 having aileron trouble glitching
  242. Spektrum AR9100 with 4 Cells...
  243. Futaba servo question
  244. hyperion titan 30a esc help needed!!
  245. What Are The Past 7 Channel Futaba Radios? Is the 9c that much better?
  246. Digital Servo Jitters
  247. Spektrum dx3 servo twitching.
  248. HonDaih HD-9660MG Servo?
  249. On-Board Tach/Airspeed Indicator
  250. JR R790UL Full Range or Park only?
