PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. JR Quatro radio
  2. Here today gone tomorrow
  3. charging4.8 transmitterbattary
  4. Futaba voltage requirements
  5. HELP ME PLS with the Airtronic rds8000 from TOWER HOBBIES
  6. JR 12X Radio
  7. Futaba 10C and 4 wheel steering setup
  8. I don’t like my 2.4 GHz radio.
  9. RDS8000 or DX7
  10. SUPER FALCON 25 ELCTRICAL SET UP HELP
  11. Any transmitters with durable plastic
  12. 1st radio
  13. JR 12x transmitter case question...
  14. Difference between JR 12X 72Mhz Tx modules
  15. Using an AR6000 receiver on a .46 profile
  16. Lockout on JR 12X receiver reasons???
  17. New 10 channel Airtronics?
  18. Range Video On Screen Display
  19. spektrum steering wheel
  20. Futaba 9CH FM vs. Futaba 9CH PCM
  21. inverted fuel tank
  22. Poisoned By The Internet
  23. JR R790 Receiver won't lock
  24. Reversal of Travel with 9CAS
  25. JR 12X 2.4Ghz receiver - R1221 or R1222 ?
  26. Angle of Attack Indicator
  27. Avionics for UAV: GPS telemetry and Video capture
  28. Strange Hitec Servo
  29. Recommend a 2.4 7ch radio
  30. Can you have two servos with 5 channel receiver without Y harness
  31. LiPo battery for 9C Transmitter
  32. Used Futaba R5114DPS G3 receivers
  33. 2.4 antenna position (9C/Spectrum direct mount)
  34. Mode 1, mode 2 buddy boxing ?
  35. does DSM2 module work in Futaba 12FG
  36. Futaba 12FG programming resources
  37. Futaba 12FG Butterfly differential
  38. Futaba 12FG channel grouping
  39. Graupner mx22-spektrum dm9 module hummm
  40. Single conversion and/or Dual Conversion
  41. AIRTRONICS RDS8000
  42. Glitching problems that I cannot solve
  43. 9303 problems?
  44. AR7000 reciever next to servo's
  45. Help getting acoms 4ch fm 40mhz receivers
  46. RDS 8000 How do I change from mode 1 to mode 2 the micro-computer ?
  47. DX3R ?
  48. Hitec crystal in Futaba Rx
  49. DX7 throttle curve for fixed wing?
  50. New Mid Range JR 2.4 Radio?
  51. Lipo reciver battery with ESC?
  52. VPX!! Possible new type of transmitter Battery
  53. will this LIPO work with a spectrum AR7000 RX
  54. Futaba 6exap trainer setup
  55. Charging Question
  56. TRANSMITTER MODIFICATION AND AMA ON 2.4 GHZ MOUDLES
  57. traxxas new 2.4 ghz spektrum technology 4 channel control!!!
  58. FUTABA 12FG OR FUTABA 10C FASST?
  59. toggle a dx3
  60. 10C MIX
  61. two batteries for redundancy
  62. receiver battery near the antena ?
  63. JR 9303 2.4 Rx light on but no connection
  64. Digital Servo's
  65. Airtronics 94780M
  66. Need help using key-tech gyro on fixed pitch heli
  67. Spektrum AR500 rx "ROCKS"
  68. Triton Charger not working
  69. 12FG 1MB SD Cards
  70. Spectrum AR7100R7 Advise
  71. Twin Aileron Channels on 8103DT?
  72. another spektrum bind problem
  73. Carrying case for Futaba 10C
  74. In or Out... switch question
  75. Looking for a servo...
  76. Futaba 12FG Programing Questions
  77. Strange problem with RC controller
  78. JR 12X Data Trans Program compatability
  79. DX6i Making an Elevator Switch
  80. JR R922 rx - digital only servos?
  81. servo for Piezo gyro
  82. Making the switch from JR PCM to Spectrum
  83. Spectrum DX7 +AR7000 2.4 GHz in Futaba FF-7 (T7CP) 2,4 GHz
  84. DX7 Dual Rates problem, need help please!
  85. JR 9 Tx.Battery Connector.
  86. JR 12x Balance Menu Question
  87. Servo Extensions or Extending the Servo Wires
  88. Receiver Rescue Required
  89. Futaba R608FS bought in US will it work in Asia?
  90. AR9100 led display
  91. flaps servos speed
  92. Futaba 6XAS Transmitter Antena
  93. Canadian trying to send in 7C 2.4 for recall
  94. I have just noticed on J
  95. JR DS 8417 Servo - gears seized up
  96. JR 12X stick extensions
  97. How About The Airtronics 8-Channel RDS8000 2.4GHz
  98. Ace DS1015 servo
  99. Futaba 9c and spektrum
  100. hovercraft mixing
  101. SX600 transmitter
  102. Interference or What???
  103. 11.1V LiPo for TX?
  104. Spektrum 7 flaps
  105. Jr receiver, Spektrum servos
  106. 3PK 2.4GHZ Higher MAH TX Battery...
  107. futaba servos with NiMH battery
  108. How many Futaba 10C?
  109. NiMH Batteries with futaba servos
  110. DX-7 Mixing ?
  111. Does anyone use ap2000i as a backup?
  112. 12FG 72MHZ module
  113. Corona 2.4g system
  114. Failsafe for car
  115. Ready to upgrade radio
  116. 7 cap set-up
  117. Are Futaba 2.4Ghz RX's region coded ?
  118. How do I change from mode 2 to mode 1 an Airtronics RDS8000?
  119. 12Z to JR 12X?? Actual Experience!!
  120. Tower Hobbies System 2000 TS-72 servo wiring
  121. Spring Air Transmitter Tray
  122. Auto Landing with a locked out Spectrum
  123. trainer switch without spring
  124. Servo arm for Hobbico 150 servo???
  125. servo choice
  126. 770s pcm receiver
  127. DX7 drops and breaks antenna..part number??
  128. Running spektrum receiver at 4 NiCD Cells ?
  129. JR 537 servo's
  130. How FASST are you?
  131. Futaba 10c aileron help
  132. JR 9303 2.4 and Crow
  133. Interference issues
  134. Do Specktrum recievers work with the OEM losi transmitters?
  135. 9303 trims again...
  136. jr x642
  137. connector for the DX7 battery is called?
  138. Max Range of Radio
  139. I TX for all.
  140. Futaba 7C FASST or JR DX7 Spektrum
  141. JR 12X Unsigned Driver on PC Data Install
  142. offer FD receiver
  143. Futaba 2.4G receiver pricing
  144. JR R790UL receiver
  145. JR XP6102 Fuse
  146. AS600 Spectrem reciever
  147. JR X9303 Trim Following
  148. Airtronics servo
  149. Spectrum module spares........
  150. Maybe One Reason For 2.4 ghz Failures
  151. JR 9303 72 Mhz receiver compatability
  152. Should I get a FASST 7 chan or 6 chan for my plane?
  153. WHO SELLS LOST AIRPLANE ALARMS???
  154. Ram sound unit
  155. 12 channel JR Module?????
  156. help wiht jr 12x
  157. 10C FASST transmitter receiver modules
  158. JR DSX9 side sliders
  159. Help Diagnose Why Lost Plane, H9 P-47 150
  160. Spektrum Pricing
  161. Faulty equipment not my fault.
  162. 2.4 ghz Jammers
  163. 7CAF and T6EXAP crystals?
  164. TX & Rx Alignment Fp-7Fg
  165. XS3 receiver question??
  166. Connecting the servos via long cables OK ?
  167. New radio investment
  168. Spektrum
  169. Duralite Li-Ion (11.1 V) OK for DX7 ?
  170. graupner mc 18
  171. darn, futaba 6 channel 2.4ghz parkflyer only fits mini plugs
  172. Alpex Hobby FM
  173. Futaba 10c
  174. JR R921 Receiver Voltage
  175. Losi with Spektrum DSM technology vs. Spektrum DSM
  176. 9303 Throttle Trim & 150 ATV
  177. WHAT THE #$! fried my berg4L rx
  178. JR 2.4 upgrade
  179. JR 12x 2.4 gHz: Remove Xmtr back?
  180. JR 10x New Datatransfer Software
  181. Transmitter error light for Losi Sport from Mini Baja..
  182. Light DIgital servos for Gee BEE
  183. FASST antennae placement, housing, tubing, orientation etc etc???
  184. channel Expanders, Syncronizers, etc
  185. How do you program dual rate on 12FG? and what is GROUP vs SINGLE?
  186. Kraft Radio
  187. Need help with setting throttle trims
  188. Why not a 12 FG, 12Z and 10C website?
  189. this receiver? the instructions say that it should work with either brand, but I hjr rs600 to futaba
  190. STANDARD SERVO FOR MECHANICAL RETRACT-GOOD OR BAD IDEA????????
  191. Does 2.4 have shorter range than traditional 72mhz?
  192. Programming
  193. Futaba charger to charge JR radio?
  194. Spektrum 6x 2.4 ....what receivers?
  195. JR buddy box cut out and I lost my model!!!
  196. AR9100 Spektrum powering with Lipolies ?
  197. 5 amp Fuse Servo Leads to Protect Against Dead Short Melt-downs
  198. 12x 10x questions
  199. Spektrum remote led?
  200. Binding without a place to plug binder
  201. JR 10X with LiPo pack
  202. Futaba 8U throttle not linier
  203. fly sky Tx and Rx setup???
  204. Reassign 2nd Aileron Channel on 9ZAP?
  205. R156F
  206. Looped back antenna.
  207. JR 9303 2.4 Mixing
  208. Radio selection help please
  209. receiver
  210. will this rx work with my tx?
  211. JR 8611's and 8711's gittering
  212. Airtronics MX-3FHSS/Hitec MG65
  213. Help me change my mind
  214. Price of DX6 when it was first released
  215. dx7 or x2720 stick mode
  216. Are all servos interchangeable
  217. DX6I programming issue
  218. Need Help finding Part for JR 10x
  219. Extra Reciever.
  220. Spektrum DX5E, DX6i or DX7 for surface use?
  221. INFO NEEDED GOOD SERVOS
  222. Any known problems using Hitec Servos with Futaba 6014 Rx?
  223. Hitec crystal in Futaba 127 receiver
  224. MKII Expanded Scale Voltmeter
  225. Programming 2Ail 2Flap with 7ch FASST RX
  226. Futaba 9c- rotating the sticks
  227. Help with X9303, aileron set-up.
  228. Can I mod a tx to transmit music?
  229. Airtronics RD-6000 compatabilities
  230. Voltwatch or Voltmeter
  231. Sun ip receiver dual conversion or single
  232. Aftermarket 72 mhz synthesized futaba 9z TX modules ?
  233. Spektrum Bind Plug Question
  234. Spektrum and Deans whip
  235. New JR 770 gyro not compatible with Futaba?
  236. Spektrum 6 DXi not binding
  237. Help with JR 12X
  238. newbie questions about servos and transmitters
  239. Spektrum systems "jerks" when turned on
  240. X9303 setup for multiple servos
  241. JR / Spektrum rx ext's w/ disconnects
  242. JR DS 821 vs Hitec HS-5475 which one
  243. Tired of waiting on Hitec/Multiplex for 2.4GHz Module
  244. JR 12X in Mode 3
  245. Whats The Deal With Nylon Gear Servos?
  246. RC EBay .surprise
  247. AR6200 and 27% extra
  248. HXT hextronic servo????
  249. reversed radio controls
  250. range of 27 mhz Am radio
