PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. AR 9100 power and swithching
  2. What is prefered volts for FASST RX?
  3. Replacement Reciever
  4. Question bout Flea Market FM Remote
  5. Futaba FP-R137GP 7Ch RX Antenna Legnth
  6. Jeti 2.4G System
  7. Mounting JR 921 rcvr on top of fuel tank
  8. Futaba 6014 heat failure (crash)
  9. Installing a Servo - Modifying the Horn? (Newbie)
  10. Spektrum modules
  11. Spektrum ar9000 vs. JR R921?
  12. Futaba 10CHP - Mode 1 & Mode 2-Differences, Switches, Mixes
  13. JR SX600 - Need help ASAP!
  14. Im looking for a DX7 with microlite servos and rcvr
  15. 14 mz setup smoke/ choke
  16. specktrum -walkera set-up
  17. futaba 7c ...can not get my throttle to work on my parkzone trojan
  18. My micro servo died yesterday, maybe the BEC was the killer?
  19. partial rudder to throttle mix
  20. Advise on Futaba 10C 2.4GHz Air needed!!!
  21. Spektrum Module Blows 9303 TX Fuse
  22. digital servos , 7 CAP
  23. HS-65 MG screw
  24. Futaba 12Z/14Z
  25. mx3 70/30 throtle question
  26. JR R921 RX Battery
  27. How much is the R5014 Fasst RX going for now in ebay or classified?
  28. 10c and HS-5645
  29. Hitec analogue and digital servo ok with FASST 6/7/8ch RX?
  30. Heads-up warning: Corona 2.4GHz
  31. Question about speed controllers?
  32. Futaba 12z charge jack pinout ?
  33. DX6i / AR6200 / 2servos - Some questions - Need help
  34. Wow, Why aren't all transmitters now like this?
  35. Futaba S3103 and S3108 Replacement Servos
  36. Is this reciever compatable with analog servos?
  37. WHICH ONE 10C or 12FG ??
  38. DX3R reciver options
  39. How many of you find this funny?
  40. Bind AR6100e to DX3R?
  41. Question about picking the right engine, transmitter & Servos.
  42. JR6103 Tx and dual elevators
  43. Duck on a DX7
  44. Dual elev and ails plus flaps - DX7
  45. Dual elevator set up
  46. Servos
  47. swashplate movement
  48. Training Cord for Futaba 6EX
  49. Switch enabled by radio/receiver?
  50. Servo Reverser Harness Initial movement?
  51. JR X9303 Auto Land Mix Problem
  52. Futaba 9CH radio any salvage parts??
  53. JR X9303 trim lever throw values
  54. Fytaba rx # R136HP with a 9C Tx?
  55. Jr MatchBox
  56. parkzone radio gear
  57. How do you set up flaperons an the JR X9303?
  58. Lipo in Tranmitter and Reciever
  59. Programming dual elevator servos on JR XP6102
  60. Spectrum dx6i
  61. Need JR XR-3 R133 3CH receiver
  62. DX-7 Tx very warm ?
  63. New flyer info for 2.4 DSM2 Spektrum
  64. DX7 dual elevator and flaperons - Elevator to flaps mix?
  65. spectrum DX6I
  66. Servo Accessories
  67. Thinking of getting new controllers
  68. JR X9303 throttle servo stops working when switched to normal mode...
  69. JR 2.4 ghz Module
  70. ACT S3D is DOUBLE 2.4 ghz system
  71. MOVED: fm or 2.4 GHz
  72. fm or 2.4 GHz
  73. JR Sport SX600 HELP!!!!!
  74. can this happen
  75. 645mg servos not centering well.
  76. Warning!! Do Not Buy Futaba 3114's
  77. Cellshield LVC Problem
  78. Kid size controls
  79. HS 5985 MG
  80. Silicone Adhesives
  81. Futaba 9CHP Super 9C Synthesized Radio
  82. Servo failure help please
  83. 4 channel TX came with a 6 channel RX: can I use 5 and 6?
  84. Use of Spektrum Mz module in Fut 12FG?
  85. GY 501 help!
  86. Servo reversing on Multiplex Evo 9
  87. Spektrum DSM2 module
  88. Got my 6ex back from Futaba today
  89. Spektrum DX6i binding problem
  90. JR 7202 Timer?
  91. Stickly Gimbal
  92. peace help me with my transmitter
  93. Suitability of X-Bee Modules for R/C
  94. Spektrum DSP75 Servo Chatter
  95. Two Different Servo's on One Y-harness?
  96. Hitec Neutron 6s
  97. The radio used the most at large events?
  98. FP5UAF-setup for flaps
  99. Power HD 2550A Servos
  100. Need to replace JR r700 rx antenna
  101. Futaba 6EXA Elevator Gimbal Spring Failure, Almost A Disaster
  102. Antenna routing tips
  103. 1/4 scale servo size
  104. 1/4 scale servo size
  105. Transmitter / Receiver Recommendations?
  106. Spektrum DX7 versions
  107. best dsm systems?
  108. JR R921 Receiver Current Capability? Is a Jumper Needed?
  109. Odd Futaba 2.4 7c issue
  110. Computer Radio GENERAL Setup Tips Wanted
  111. 10c throttle trim button
  112. Noob Questions
  113. Spektrum DX6i Problem?
  114. Dual Elevator
  115. Why so few 12FG posts?
  116. Spektrum probs with Zenoah G26ei
  117. Kraft KPT-7CS Mk IV Manual
  118. Spectrum 2.4 gig worries
  119. super vee 27 receiver
  120. wrong forum
  121. 3pm safe receiver voltage
  122. dx 3.0 dsm
  123. Spektrum DSM2 Airmod for Futaba
  124. Jittery steering servo on car
  125. AR9100 & Different Remote Receivers
  126. DX6i & DX5e
  127. Speed controller differences, car & boat?
  128. battery for a futaba 12fg
  129. crimpper
  130. Futaba 3152&168DF Rx=Nervous servos
  131. JR DS890G Gyro Servo
  132. WARNING-X9303 CHAFED AILERON GIMBAL WIRING
  133. JR 12X MV initial evaluation
  134. spektrum dx2.0, aux sr3000??
  135. surface vs air radios
  136. 4+ channel surface radios and a servo question
  137. ar7000 binds no servo control issue
  138. JR G500A gyro
  139. Expo went away on my 10X???
  140. Hitec's HS5083MG with other Gyros
  141. regarding spektrum flight log
  142. Airtronics 2.4 Receiver Placement in Electric Ducted Fan Jet
  143. voltage drop from battery to switch
  144. 9303 2.4 lockout......again?
  145. DX7 AR7000 loses bind
  146. SPEKTRUM DESENSITIZED ?
  147. mixing JR with airtronics
  148. DX-7 Aileron Centering
  149. Micro receivers for Futaba FASST
  150. Challenge #3
  151. Dual elevator servos on JR 9303
  152. I need a copy of circuit of my car :(
  153. WARNING!!! JR12X Owners
  154. The REAL reason for the Futaba Forum.
  155. DX7 spare battery..
  156. 9303 w/ 4 Ailerons setup
  157. JR Sport SX600 and training cord question
  158. Futaba Rx.....JR Servos?
  159. Any experiencie/review of the Hextronik 5010 servo?
  160. Futaba 2.4 major malfunction!!!!!
  161. JR G420T PIEZO pyro rate with a DX7?
  162. Need help programing dx6i with helipro black hawk 500 gp helicopter
  163. DX7 loosing Binding
  164. CAN'T POST IN SUB FORUMS WHY?
  165. DX7 RADIO QUESTION
  166. Spektrum dual rate question
  167. programming flaperons AND spoilerons with JR PCM 10X
  168. Is Spektrum 6ch enough?
  169. Xmtr antennas at right angle on Spektrum & JR 2.4Ghz
  170. DX7 MIxing Elevator halves
  171. Computer radios that come with decent manuals?
  172. Violent twitching of all servo's!
  173. digital servo movement
  174. Which is a better deal?
  175. transmitter/receiver compatibility question
  176. FYI: Spektrum
  177. 10C setup question
  178. servo matching
  179. radio and servo matching
  180. DG1_DG2_R6014FS
  181. Should I switch to Futaba?
  182. Why Airtronics?
  183. Jr 9303 Question
  184. E-flite S75 servos @6v
  185. Receiver x Ignition
  186. AR9000 and Flight Logger
  187. Berg 7P vs Multiplex RX-9 vs JR R790 on JR 7202 Radio
  188. Digital servo buzz
  189. Futaba receiver in EFlite T-34 Mentor
  190. Equipment help needed
  191. X9303 - possible wire chaffing leading to loss of control
  192. Futaba 3114's
  193. Brand New DX7 failing range check at 20ft!
  194. Help JR 12x
  195. Graupner MX22
  196. old RX and BEC
  197. crazy 3pk problem but not with a spectrum tx
  198. wk 1001 transmitter
  199. Jump diode to test TX Battery HELP
  200. Yet another delay in Futaba 10C stock
  201. 10X and spoilers - HELP!!
  202. synth Corona RX
  203. AM vs FM
  204. **Moved**
  205. wtb 49mhz toy grade controller
  206. Servo Recoil
  207. backup memory battery?
  208. RX power with Lipoly????
  209. Receiver to ESC connections
  210. Problem with throttle on Spektrum DX6i!!!
  211. Why do they STILL put 600mah batteries in new transmitters?
  212. Attatching a new receiver antenna wire
  213. Bulk servo wire?
  214. JR 12X in MODE 4
  215. JR9303 2.4 Ghz Programming question
  216. gws dual conversion crystal
  217. 10C Heli Notchy throttle stick
  218. Micro Servo/ESC Question for the Pro's
  219. 5955tg burnout
  220. Newbie Question about batteries to Rx
  221. Programing JR9303
  222. Hitec Focus 4 : Does it have elevon function?
  223. Reversing Flaperon mixed channel
  224. hitec servo centering
  225. Bad servo how often will they do this?
  226. Fastest servo EVER!!!!
  227. Using Airtronics servo with JR receiver??
  228. spektrum 7 and ar9000?
  229. Airtronics VG400 change fron 75 Mhz to 72 Mhz
  230. 10c ownere please answer
  231. JR 12X SNPT Option
  232. Spektrum Telemetry
  233. Digital vs analog Servo question
  234. Spektrum Digital Servo Programming
  235. Has anyone tried this servo Cirrus CDS751MG 13kg/cm Monster Digital Servo
  236. Futaba: Reversed throttle implies reversed failsafe?
  237. Quick Radio Question
  238. newbie needs help with rx
  239. Futaba 6EX 2.4 Full Throttle Problem
  240. Two receivers, separate functions...
  241. Servo Dimensions
  242. Updated Graupner IFS MC24 user manual ?
  243. Futaba Software Update Version 1.6
  244. transfering data/memory between two 10X's
  245. Futaba 9CAP RF turning off
  246. JR 12X USER'S REPORT
  247. DX7 Mixing
  248. Why is the dx6i so cheap?
  249. servo: radial to linear motion???
  250. JR xmitter battery connector
