PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 [30] 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. JR770 PCM Rx Problem?
  2. JR Expo question?
  3. Servo information
  4. AR6200 problems!
  5. Spektrum Receiver Wiring?
  6. Radio Service
  7. eFlight Servo Output Shaft Size
  8. servo lube
  9. "Futaba"/"Airtronics"
  10. Question fasst and dual aileron
  11. Twin electric motors
  12. Lookingfor servos
  13. please help me with receiver
  14. 10c and crow help
  15. New to 4 Channel transmitters, please help.
  16. Hitech 5955 with analog servo
  17. Ace micropro 8000
  18. Flapsdelay on the Futaba 7C Fasst.
  19. JR 10X Smoke Pump Mixing Question
  20. Remote 2.4GHz Receivers
  21. Airtronics 92185 PCM Z? polarity
  22. Help-JR10X program for Bonanza Vtail
  23. Tower Pro MG995 servos
  24. NEED ADVICE - RC CARS - ESC BATTERY BRUSHLESS
  25. GYA 352 GYRO QUESTION
  26. New DX7 oddity, back to the shop...
  27. Jr 9303 crow braking set up
  28. Does Spektrum offer a 2.4Ghz Module solution for a Futaba 9C?
  29. more models memory for Futaba 8U
  30. Futaba FASST lock outs?
  31. JR X9303 and Spektrum DX 6I buddy box?
  32. JR 10 X battery
  33. Joining three servos on a 6-pin connector, will that work?
  34. 12FG and Z.....vs...14Z
  35. 2.4GHz mistery glitch
  36. Will 2.4 fix engine caused glitches?
  37. Futaba 2.4ghz Rx Price/Channels Rant
  38. RS300 causing HS645MG steering problem
  39. 6" servo extension lead???
  40. switches
  41. is this normal 12Z behaviour?
  42. how to secure the airplane from electronic failure?
  43. JR 12X 2.4Ghz module
  44. Where to download a Graupner MX24 manual
  45. JR x9303 on 3S Lipo?
  46. 12Z Fasst Tx & Rx for Airplanes
  47. Trainer cord-JR to Futaba
  48. 10C flaps on 3 position switch
  49. Problem with digital servo
  50. Futaba receiver gone...or crystal ???
  51. futaba 9c super airplane version discontinued?
  52. Source for servo connectors
  53. New radio systems with 700 mAh batteries.
  54. US purchased FASST OK for Australia?
  55. y-harness with spectrum receiver
  56. Twin Battery packs
  57. Faast minimun voltage
  58. The RC Power Duck antenna
  59. Servo
  60. car rated servos in plane ?
  61. Mounting battery right next to RX?
  62. JR XF 622 transmitter battery
  63. DX-6i roller drum breakage.
  64. Spektrum Support Question
  65. Spectrum DX6i Question
  66. Servo gears for the following servos
  67. There is a catch with the DX-6i!
  68. DX7
  69. Airtronics RD6000.
  70. 12Z on 2.4GhZ as "Teacher" 9C as "student"Can I do it?
  71. DX6i, whats the catch?
  72. Just want to make sure
  73. DX7 bearing mod, greasing bearings?
  74. Graupner vs XPS module
  75. DX-6i and DX-7 in V-tail mode???
  76. Is Spektrum's Collision Avoidance Statements Questionable?
  77. Difference in stick feel between models?
  78. Servo Reversing problem and question
  79. 9C dual servo flap programming
  80. Help with ACE S.S.
  81. Battery wiring on JR radios
  82. JR 10SX
  83. Futaba 3PKS + FASST losing bind.
  84. Help with Jr 9303
  85. JR Max 4 Tx manual and charge question
  86. AR6200 - other spektrum receivers
  87. Dual Receivers
  88. AR6200 - other spektrum receivers
  89. 3 Rates on 10C?
  90. HS-82MG repair after saltwater bath
  91. Airtonics (Sanwa) Infinity660 convert to XPS 2.4Ghz
  92. Spektrum DX6 Questions/Concerns
  93. servos chattering
  94. 9CH synth problems
  95. FUTABA 12FG CONFIGURATION
  96. Radio Recomendation
  97. Rudder - Elev Mixing 9CAP
  98. spektrum DX3R question about disply!
  99. AR7000 FLASHING LEDS QUESTION
  100. 2.4 gig receivers set up.
  101. Vintage MRC radio
  102. PCM receiver with FM transmitter
  103. Servo Wont Trim / No aileron Movement
  104. Remote RX for JR 921?
  105. AR6100ML
  106. Extending LEDs to outside on Spektrum/JR 2.4Ghz receivers?
  107. which spektrum RX
  108. 12 FGA Charging Question
  109. DX-7 fuse blows ? ? ?
  110. How satisfied are YOU with your New Futaba 10C Tx??
  111. DX6i throttle clicks?
  112. How do you set up Hi/Lo rates on JR X9303?
  113. Anyone know how to swap sticks for 7C or DX7?
  114. JR NES-L501 Servos
  115. JR 12X....Charge time?
  116. Model memory chip for Futaba 9C
  117. 12Z won't transmit
  118. AMC 24 DS SCAN 35MHZ PROBLEM
  119. AR6200, duel elevators and ailerons possible
  120. What Spektrum reciever to work with DSM ?
  121. Futaba service center came through!
  122. chattering servos, PPM, 60 feet distance - normal?
  123. number of mixes in 9CAPS
  124. Antenna Position on JR XP9303
  125. Wich reciever?
  126. diff betweenn cypress wireless chip and 802.11
  127. 3PM install help..
  128. digital servo draw at neutral
  129. 9CAP Set Up Help
  130. JR R921 Receiver
  131. JR 9303 "Master" & JR 12X "Slave"
  132. Submicro FAAST receivers?
  133. fasst or spektrum
  134. Antena Measurement Help
  135. I need a crystaless transmitter.
  136. Futaba Module - FP-TP-FM
  137. Xmtr won't talk to Rcvr
  138. Futaba 608FS reciever locout/failure due to heat
  139. Spektrum plane locator?
  140. Beauty Contest
  141. Futaba 10C - Flight Report
  142. JR and Futaba compatibility
  143. Two idle speeds and engine kill ? X9303
  144. Xtreme Power Systems 2.4 Ghz
  145. D-Sub Servo Connectors
  146. electronics setup in plane
  147. Do I dare use my old Tactic TTX400 with my new sailplane?
  148. JR 10X model memory
  149. Futaba 10C is HERE!
  150. 2.4 radios and Gliders
  151. Spektrum/JR 2.4GHz Rcvr Reboot Times?
  152. reciever /transmitter range very short, twitching all over... HELP!
  153. JR Tx charger Heads Up!
  154. Protection of RC Electronic Equipment Against Humidity
  155. SERVO TWITCHING QUESTION
  156. Charging a DX7? With Ice...
  157. Setting timing AND BREAK for ESC
  158. JR 10X transmitter lights?
  159. 2.4GHZ and 72Mhz Hits
  160. AR9100 vs Ar922
  161. Singin the servo gear blues.
  162. Spektrum dual switch question
  163. 9C tx module ch53 FREE
  164. Onboard milliamp hour meter?
  165. Futaba 2.4ghz 6 channel fasst programming
  166. jr 9303 aileron dual rates?
  167. Servo Checking Setup
  168. Chattering SERVOS SG-50 Tower Pro's
  169. Separate receiver battery wiring
  170. Spektrum DX2 VS Futaba 3PM
  171. SUPER MICRO SERVO???
  172. Amateur radio R/C Band
  173. Futaba FASST 6 channel with a helimax axe cp
  174. Digital servo prices to come down
  175. Spektrum AR 9100 and A123 6,4V batteries
  176. Spektrum Dual Switch for 2 Batteries?
  177. Need help with Spectrum RX placement in Mini Ultra Stick
  178. Futaba SkySport T4YF - convert 4-ch to 5-ch???
  179. Faast 2.4ghz
  180. Futaba 3152 servo problem
  181. RF jammers
  182. DX3R
  183. JR 10X Question
  184. 12FGA Problem
  185. Best V-Tail mixer ?
  186. Futaba 9C conversion to 2.4
  187. 6000 RX with different TX's
  188. CAN QUICK LOCK BE DISABLED ON HOBBICO PRO HD SERVO EXTENSTIONS???
  189. 12FG battery alternative
  190. charging a Spektrum tranny
  191. TM7 and TM8 Same module?
  192. Spectrum DX6i as trainer box - Options?
  193. the 10C manual is now online
  194. Futaba 10C is on the way!
  195. Spektrum Glitches? - Crashed Models
  196. 9Z airplane help - aerobatic prog.- Ohio
  197. ASSOCIATED XP3D FM Digital 3Ch
  198. Would like to have a manual brushless esc
  199. JR-XP7202
  200. WiFi and Spektrum
  201. Servo Voltage
  202. Glitching detective work
  203. Radio Stand?
  204. Spektrum DX6i Batteries
  205. JR 9303 2.4GHz
  206. futaba radio skysport 6ch
  207. Lithium Polymer for Futaba Transmitters ?
  208. 14mz butterfly question
  209. New 14MZ/12Z/12FG update
  210. Sirius Charge Quad
  211. OK to use Spektrum extension in JR?
  212. Futaba 12FG
  213. How to reset a JR XS3
  214. Does Futaba and Airtronics Mix?
  215. 2.4 reciever 4.8 pack ok?
  216. Hitec tuning
  217. Possible Receiver/Transmitter Issues??
  218. DX6i - Rudder on Right Stick?
  219. JR 10 X servo revers
  220. DX7 LOSING SETTINGS WHY ?
  221. Why buy a Futaba 10C when you have a 9C?
  222. 12Z glitching in PPM mode?
  223. Spektrum antenna adapter
  224. Futaba 12z vs 12fg 2.4
  225. Why buy a Futaba 10C when u have a 9C Super?
  226. Futaba vs Spektrum
  227. Throttle Cut - JR Propo XP
  228. Futaba sticks: 7C vs 6EX
  229. Airtronics Radiant transmitter manuals
  230. DX7 rx won't blink when preparing to bind
  231. Futaba 12FG Tx battery pack
  232. any one till using a 8U futaba
  233. Futaba 7C 2.4G Battery compartment
  234. airitronics servos
  235. Futaba Field Force 8 Transmitter Module, Worth Selling?
  236. AM or FM Receiver and Transmitter, Make any difference to speed controller?
  237. futaba 9c conversion to 2.4
  238. JR 12X DEDICATED OR JR 12X 72/2.4 ?
  239. Updates for FUTABA transmitters NEW may 2008
  240. spektrum dx7 "CRASH"
  241. Is this Tx Appropriate
  242. Cannon R/C Systems
  243. Frame loss without fadres?
  244. JR PC data transfer system
  245. Binding plug for DX6i
  246. Futaba 3PM 2.4ghz
  247. Spektrum throttle shutoff
  248. 12Z 2.4 channel assignments?
  249. quick question
  250. Hobbico/Futaba large scale servos - can any handle 7.2v?
