PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. 40Mhz WFT 09 9-Channel PCM/PPM Radio System
  2. Questions about the Futaba Fasst.
  3. Dropped my AR 9000
  4. Linking receiver
  5. Real Speed of 8717
  6. Which 2.4 Radio to Buy - Futaba, JR, Spektrum?
  7. Flaperon DX7
  8. AR-7000 Glitching issue
  9. Which gyro is better?
  10. CF card for 12Z?
  11. Best way to Cycle Futaba 6EX Tx Batteries
  12. Stiff springs for the Futaba 14 MZ
  13. Spektrum DX6i settings for Typhoon2 3D
  14. Futaba FP127DF
  15. JR 8611A Servo Problem
  16. Futaba 3pm
  17. Cheap Flight Logger Fuselage Connection
  18. AR9100 & Single Battery Pack
  19. Dual FUT 6014FS Receiver/Antenna Orientation (w/PowerBox Royal)
  20. Update: Crappy Spektrum Service Ctr Policy
  21. What servos have been used with A123
  22. JR 8103 Question?
  23. Futaba FASST R603FF Antenna Length
  24. Who's Got cheap Futaba Connectors ?
  25. 9303 Programming Questions/Options
  26. What is the best 2.4 for a 9C
  27. Aileron differential for Monocoupe 110
  28. 10C. Why not 2.4 GHz only?
  29. Glitches in my new 4 *
  30. HD 9150MG servo
  31. changine my receiver quick question
  32. Spektrum vs. NES-791 retract servo
  33. safe transmitter voltage
  34. Tamiya Controller
  35. DX6i programming
  36. Inexpensive Transmitter/Receiver with steering rate adjust
  37. What switch is this?
  38. Futaba 12FG,12Z sound question
  39. crystal question
  40. JR verses Futaba
  41. Chattering servo's on a USL120
  42. Batt plug on receiver-Help
  43. DX7 setup - Travel adj, DR and Sub trim
  44. Spektrum DX6 radios/receivers
  45. DX6i dual aileron problem
  46. JR 921 2.4 SS Rcvr Placement Question
  47. JR PCM 10X Programming
  48. Mounting those 2.4GHz Receivers
  49. AR6200
  50. JR 9303 2.4ghz & Gear Problems
  51. Hitec servo programmer question: speed
  52. 2.4 receivers
  53. servo setup help
  54. Broken DX6i
  55. Futaba Fasst 6EX and Spektrum DX6
  56. JR R 921 '.4 is not working with regulated LİOn
  57. Spektrum Dx6i
  58. JR R 921 2.4 Receiver +regulator problem
  59. Spektrum Rx choices
  60. futaba 2.4 gig RX placement
  61. rc18t servo
  62. 10C is around the corner
  63. If you had to choose between...
  64. JR 8711 question
  65. Blade CX2 Not at full power?
  66. Changing balance point on 2.4 radios
  67. charging rx/tx packs
  68. Hitech (servos) - Here I Come!
  69. Futaba 6014 receiver heat issue
  70. JR 9303 - 33% Biplane Setup
  71. Dual battery dual switch question
  72. Receiver Compatibility
  73. Spectrum DX7 conversion from Mode 2 to Mode 1
  74. chargers
  75. walkl warts
  76. Airtronics Servo Grommets?
  77. DX7 programming max throws?
  78. futaba tm8 on my 9c
  79. jr 10X aileron spring
  80. JR X9303 vs. Futaba 10c
  81. I need Help! (Dual Receiver Set up)
  82. Futaba R607Fs vs. R617FS
  83. JR9303 Throttle ratchet
  84. DX7 Programming Guide Air word document ??
  85. Radio/servo setup help needed
  86. Futaba 7C 2.4 Question?
  87. Help! looking for a particular transmitter accessory.
  88. Futaba Fasst / Receiver Battery Switch??
  89. Glitchin' FMA Quantum 8
  90. DIY 2.4GHz RC project
  91. X9303 Glitch
  92. deadband question
  93. Deans Base loaded ant on Futaba R146iP RX?
  94. need radio
  95. Spektrum DX7 Switch Mixing HELP!!!!
  96. Range of 2.4Ghz
  97. Spektrum 6100 receivers problems? Binding?
  98. Awww... Nuts
  99. AM Crystals
  100. Hitec antenna bobbin
  101. 12Z - Servo Travel vs. Limit point ?
  102. Transmitter details
  103. which is better
  104. cheaper JRPS537 servo alternative ?
  105. JR DSM2 Decals
  106. Is a computer radio necessary for 3D?
  107. DX7 and using 9 channel receivers?
  108. Delta Mixing Question
  109. 2.4 binding issue. Need Help
  110. Former 14MZ owner got a big suprise!
  111. Spectrum DS-821 Servos
  112. Faast and JR servos compatibility
  113. Are You Happy With Your JR Conversion Too 2.4ghz?
  114. self-contained, flyable 2.4GHz spectrum analyzer
  115. is Futaba the only heat related problem?
  116. Question about Dionysus Designs Servo Slower
  117. JR921 Receiver
  118. power hd servos
  119. TROY NEWMAN, MIKE MAYBERRY OPEN JR SUPPORT FORUM?????
  120. DX7 binding
  121. X9303 What is "trim" in the wing type menu ?
  122. Connect ELEVONS (Delta Wing) without advanced radio
  123. Futaba 14mz 2.4 update
  124. Spektrum DX6
  125. CAN HITEC HS-645 BE USED IN A PLANE FOR FLAPS????
  126. JR DS9411 Servo equivalents??
  127. BEC wiring
  128. Futaba 8 and Flap Setup question
  129. JR 12X out this weekend?
  130. Broken "B" Switch on Futaba 9C? Dang!
  131. JR X9303 Exponential Graph
  132. Lipo Pack for Transmitter ?
  133. 12FG Question??
  134. Your help on this one please
  135. The Ins and Outs of a JR Throttle Curve
  136. Spektrum throttle curve
  137. Dumb Question - Spektrum RX UPC? - Never Mind...
  138. Crystal Interchange
  139. HI TEC SERVOS
  140. Buddy-lead with 2 DX7's - different modes
  141. European r608fs ce mark
  142. JR 10X channel assignment help needed
  143. Can I bind 2 Spectrum radios Tx on same plane Rx?
  144. One Spektrum Receiver - Multiple Planes
  145. is this servo good enough? (beginner) pls answer.
  146. Futaba 9Z questions
  147. Sanwa Receiver
  148. Make your own servo extentions ?
  149. JR 9303 got me confused...!
  150. 7C 7-Channel Futaba 2.4GHz Battery
  151. Can I use a 6-channel Receiver w/ a 2-channel Radio?
  152. E-Flite Blade CX2 Radio Compatibility w/ Spektrum
  153. Spektrum/JR Flight Log - head scratcher
  154. 2.4 Rx cloning?
  155. Servo Rate Reducer
  156. JR921 flashing remote RX
  157. DX7 power on Problem with msg DMC
  158. digital vs analogue servos ?
  159. JR 9303 Switch Assignability?????
  160. JR DSM GIVEAWAY EXTENSION
  161. Linear mix VS Curve mx on 9c
  162. WHAT IS THE DIFFERENCE?
  163. swapping a crystal in the reciver only can I
  164. How to connect DX3R and DX6i to PC?
  165. Question about programming "decelerons" on a 9303
  166. Futaba 2.4Ghz RX installation
  167. Fasst Failsafe==>deadstick landing
  168. Charging DX6i
  169. JR SPORT 600
  170. HF module programming for T12, T14 FX 40
  171. JR 9303 Heli or Air??
  172. TX 9C BALANCE WITH 2.4 MODULE
  173. 2.4 for Multiplex Evo series
  174. Is there a Software flaw in R921 DSM2 Receiver ???
  175. I need Spektrum DX6 help with battery pack..
  176. adapting servo for retract
  177. AR7000 POST BROWNOUT UPGRADE QUESTION???
  178. short range
  179. 72mghrtz interference??
  180. Futaba 10C 2.4 GHz resolution question
  181. how to slow down a retact servo?
  182. JR/Spektrum Channel Assignments
  183. Servo arm support
  184. DX3R problem
  185. Adding flaps to a 6EX 2.4 Ghz
  186. RX compatibility
  187. 6014 and carbon
  188. E-Flight CX2 ESC
  189. JR Radio, non JR (Futaba) Connectors
  190. Tower Ts 170 Question?
  191. Tower Ts 170 Question?
  192. XPS 2.4 or Futaba Faast 2.4
  193. 9303 2.4 Heli and Airplane the exact same transmitter?
  194. Running ESC w/BEC and 2nd BEC, Need help troubleshooting
  195. G7000T/8700 Gyro Servo Question
  196. JR X9303 aileron problem
  197. Lipo TX Pack good or bad to use
  198. Poll - Connectors for Fasst parkflyer reciever.
  199. 100% setting values?
  200. Futaba tm-8. how do you like yours? any problems?
  201. Saving Tx Files to PC Spreadsheet to modify
  202. Servo Sizer Program?
  203. DX6i tx
  204. JR 9303 or DX7???
  205. PowerBox Royal with Two (2) FASST Recievers ?
  206. When do you know its time to buy a new radio?
  207. DX6 channel 5&6 change to rotary knob
  208. Tower Digital Servos
  209. Futaba 10C..will Hitec Spectra module work?
  210. 2.4GHz Receiver Wire Routing
  211. Rules of 2.4ghz antennas?
  212. R168DF Ch.2 glitch problem
  213. ds821's in .50 size heli
  214. JR 2.4 9303..Right move??
  215. General Theory. Practical Application
  216. AR9000 vs. R921 Spektrum Receivers
  217. Top Gun
  218. 12Z Software Update for FASST - Help ?
  219. Question about AR6200 and servos
  220. 2.4 for surface use
  221. RDS8000 manual
  222. Help need with get full stering/gas with Spektrum 3.0
  223. Corona Rx, which Tx will fit.
  224. Meter question on older Futaba FG series...
  225. *Hitec 5645MG Problems*
  226. Tower servo arms?????
  227. Spektrum 6100e rx
  228. DX3R Spektrum help
  229. ACE MICROPRO 8000 Software
  230. Ace SErvos, Any comments about them?
  231. Your thoughts after reading JR 12X manual
  232. JR X9303 Dual Elev. Q
  233. DX6i Field Charging Question
  234. radio transmitter / reciever
  235. Problems with Hitec HS-625mg
  236. Trainer/Buddy Box Set by JR SPORT with DX7
  237. DX6i binding help!
  238. JR 12X Manual now on Horizon website
  239. X9303 JR/Spektrum 2.4 Model Copy
  240. Futaba 4VWD
  241. Retract servo is not taking ATV EPA nor SUBTRIM
  242. OLD JR MAX 7 Computer TX
  243. Upgrade Futaba 8UAFS to 2.4 vs New 10C 2.4
  244. Looking for in depth info on new JR 12X
  245. Futaba Inspection Sticker
  246. BIND question RE: DX6i/AR6200
  247. LED's dim/blink on JR9100 Power Rcvr w/ Hitec 5625/5645
  248. maximum rx voltage
  249. Futaba 3PM FASST 2.4
  250. Hitec rx won't work!!!
