PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 [33] 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. quartz and frequency change
  2. Loss of signal DX7/6100
  3. Hey Ralph?
  4. Super secret club info needed
  5. spektrum dx3
  6. Spektrum Rx's with "quick connect" already installed?
  7. Got my Airtronics RDS8000 2.4 Gig Radio!
  8. 14 mz receiver question
  9. Spectrum Quick Connect......Cool!!!
  10. New radio Futaba or Spektrum?
  11. How to Modify Traxxas TQ3 to linear 3rd ch?
  12. Is there a technological reason for no 72 SS?
  13. Calling All Kiwis - Importing RC Txs to NZ
  14. Photos of 2.4 install
  15. fasst module for jr?
  16. How did you fit your 9Z with the FASST module in to the original TX case?
  17. 2.4 ghz help
  18. Spektrum AR7000 receiver servo problem
  19. 6 ch rx and dual ailrons
  20. NEW SPEKTRUM AR7000 DATA AND BIND QUESTION
  21. servo jitter/glitching but this is different, vey strange !
  22. JR buddy cord question
  23. Kraft & JR Single-Stick Manual
  24. Flapron and aileron diff
  25. Futaba Conquest radio
  26. Spektrum DX3R DSM2 3CH good?
  27. Glitch when installing carbon fiber prop lost post
  28. ae servos any good?
  29. Futaba 3305 Gear Slop
  30. Futaba 9cap and Hitec Laser
  31. Futaba S3114 servo reviews?
  32. Radio and receiver Compatibilty ? ?
  33. Nomadio Sensor ?
  34. SPEKTRUM DX7 ....TRAINER OPTION?
  35. Updating the 12Z for 2.4
  36. Single channel glitching
  37. JR /SPEKTRUM R/X SPECIAL OFFER
  38. Need Radio Help Please
  39. Newbie question: Rx / Servo compatability
  40. Eclipse 7
  41. Deleted
  42. crystal ident. question
  43. jr to futaba buddy box cord problem
  44. E-flite Blade radio conversion
  45. Aircraft channel question
  46. DX7 HELP
  47. Dual receivers Spektrum
  48. A123 2300mah from sincity jets
  49. reciever antenna lenght?
  50. Hitec 40FM vs Acoms 27AM
  51. hitec jumper wire
  52. Transmitter antenna length
  53. channels
  54. Receiver Failed in flight - due to it's age?
  55. Cleaning TX
  56. Which Futaba to buy, non 2.4
  57. HAYES Whip Antenna Availability??
  58. 14mz variable rates
  59. Needed: r105ip
  60. 40 size flight pack
  61. Hitec HS-45hb clicking play
  62. FUTABA servo S3004 upper case from convertion kit C3003 -> C3004
  63. TIGHTEN UP YOUR 2.4 MODULE
  64. Futaba Cap 9 Aileron flap and air brakes
  65. Help/Servo
  66. What are you flying with the AR6100?
  67. Spektrum DX6I versus DX7
  68. DISCHARGING/CYCLING X9303 BATTERY IN TRANSMITTER
  69. Futaba Module for 9CAP
  70. No single-stick radios?
  71. Battery Lead...
  72. X9303 questions
  73. JR 921 2.4 Receiver Mounting
  74. Carbon fiber body and 2.4ghz
  75. Revolutionary RC Radio
  76. Old Radio systems worth
  77. Help Me Make A Homemade Bind Plug
  78. Hi Torque servo has very little torque
  79. FAAST 2.4ghz
  80. servo movement with less resistence then the rest, whats up?
  81. spektrum free upgrade
  82. Fascinating 2.4Ghz options from ACT in Germany
  83. Futaba R616FFM FASST Park Flyer Receiver
  84. Power Strip
  85. Why does my servo not return?
  86. How I power this receiver?
  87. Dual receiver install
  88. Spectrum Lockout Help
  89. Futaba R6014FS Recevier
  90. Lightest standard servos for a 40 size profile
  91. Vibration Problems Caused by Gas Power
  92. Futaba repair and service
  93. Electrical problems
  94. Connector's - Converters?
  95. Refurbished Hitec servo's??
  96. On Is Off And Off Is On ?
  97. JR X9303 VS Futaba 10C FASST
  98. Futaba Check Stations (Not)
  99. Hitec 5245
  100. Which battery pack for my Receiver?
  101. 7c 2.4ghz Question
  102. AR9000
  103. New AR7000 Spektrum Receiver
  104. Kraft Midwest Website
  105. JR 7202, Changing Mode2 to mode1
  106. New SPEKTRUM 9100 RX with dual batteries
  107. JR Receiver and Futaba Servos
  108. Tx and lipo 11.1
  109. Futaba 9CAFS advice please!!
  110. changing RX TX crystals
  111. New Micro Parkflyer FASST RX
  112. Futaba 75mhz Questions
  113. Inexpensive Servos from hong kong
  114. Spektrum DX6i
  115. glitching channel
  116. Castle's BEC, Reliable or Not?
  117. Futaba 12FG 2.4
  118. Best Tx & Rx combo for $100 and under?
  119. Foam for transmitter case?
  120. CIRRUS 900 FM
  121. Futaba 9Z WCII with Spektrum DM8 2.4 GHz RF module ?
  122. JR X9303 r921 Bind Problems
  123. question on spectrum dx6i
  124. Spektrum DX7 Issues?
  125. resistance of a standard JR/Hitec/Fut connector
  126. DO THESE JR R921 DATA LOGGER NUMBERS SEEM OK??????????
  127. 6 EXP?
  128. Tx Cases
  129. lost about 4" off of antennea wire
  130. Futaba 12FG FASST first impressions
  131. quick question about crystals
  132. New Futaba 10C 2.4
  133. Futaba 10C Official Thread: Press release inside!
  134. Can 2.4 Ghz mask glitches?
  135. 12Z rubber grip
  136. DX3r ajnd HS-65mg Servos
  137. Spektrum DX6
  138. JR servo amp draw? (8411, 8231 etc)
  139. Old servo arms
  140. 12x on horizons site!!!!
  141. Expected versus un-expected failures
  142. airtronics 94758z trouble
  143. Help- Confused between Hitech optic 6 and Futaba faast spektrum
  144. Futaba 10CAP!!!!!
  145. internal battery on mc4000
  146. internal battery on mc4000
  147. Futaba TM-14/617 failsafe problem
  148. Spektrum DX7 dropout problem
  149. JR XP642 (opening it up)
  150. 2010 RC tech wish
  151. Futaba 2.4 Ghz 6EX looses link midflight
  152. Dual Battery set up not working
  153. old pcm 10 jr question
  154. Newbie MC-24 question
  155. New T6XA in the box just opened !!!
  156. Driving three or four channels of motors
  157. 6EXP
  158. Hitec Prism 7X battery connector polarity
  159. Sell me a 12fg/12z/or 14mz
  160. older equipment
  161. Best Model Matching Radio
  162. How to test total amp draw under load?
  163. JR921 Receiver Upgrade
  164. Proper battery.wiring and switch setup questions
  165. JR Dual Conversion question
  166. most range
  167. anybody with a Wfly Radio? I need you're input.
  168. Futaba T7C 2.4GHz
  169. PPM and PCM
  170. Spectrum Dx6 with SR3 rx..
  171. Are you using Extremelink (XPS) and why
  172. Negative and Positive side
  173. RE: JR 9303 tx memory problems
  174. Looking at 2.4GHz
  175. Futaba 3305 servos
  176. ASSAN 2.4 GHz Transmitter module/receivers
  177. Spektrum Range
  178. Servos
  179. SPECKTRUM BROWNOUT-NEED IDEAS TO SOLVE??????
  180. How to change the area code in a Futaba T14MZ!
  181. Servo Freaks Out
  182. Duratrax Transmitter
  183. FASST FLIERS UNITE
  184. Spektrum DSP75 Oscillations
  185. HELP WILL PAY FOR ADVICE$$$$$$
  186. Need part # for JR Side Servo Mounts. Help...
  187. scanner servos?
  188. Futaba 12FG setup
  189. Futaba 12FG/TM14 buddy compatible with 2.4GHz 6EX?
  190. Hitec HS-475HB
  191. Discussion - Futaba 8UHFS channel swapping
  192. question on regulators and 2.4
  193. Futaba 9c: lost radio link to 148DP receiver
  194. dual elevator servos question
  195. 14MZ tech questions
  196. Modules and Receivers for 9c super
  197. Corona Receivers...
  198. Battery and receiver mounting in Airplanes
  199. 9303 2.4 Help
  200. IP Based RC ?
  201. need help Hitec Flash4 settings
  202. What kind of Tx/radio will work?
  203. Futaba S9202 servos
  204. Quick question about my Futaba Radio
  205. Airtronics,Quasar 6A No Throttle movement??
  206. DX6 Sticks
  207. Fut 7C vs Fut 6EX 2.4--Opinions?
  208. buzzing of jr servos with futaba system
  209. Glitch Futaba System
  210. Weird servo problem.. Help?
  211. Futaba Fasst TM8 LATE FEBRUARY
  212. HS77BB servo for retracts
  213. 2.4GHz DYNAMIC TESTING
  214. TM8 & R608FS
  215. dx7 or x9303
  216. Futaba FF3 Transmiter, Toast??
  217. FUTABA 2.4 ghz or JR 2.4GHZ?
  218. mode one and two
  219. Rx Antenna Routing - effective antenna length?
  220. Are Fut S9451 Digital Servos OK ?
  221. Futaba 7C & Ultra Stick W/ flaps
  222. buy Futaba 7C now or?
  223. Major loss of signal
  224. Buddy box cord adapter
  225. 14MZ Screens Failing??
  226. binding a dx7
  227. Help....9C
  228. spectrum dx3.0 receiver problems
  229. DSX9 4 aileron servo mixing?
  230. What servos do I need
  231. Spektrum DSX-7 high rate single switch
  232. 12FG and MPDX-1 controller
  233. 12FG, 12Z and 14MZ file transfer spread sheet
  234. JR 2.4gHz Tx module for Futaba
  235. Aerial problems (rx)
  236. Installing ESC with BEC to Airtronics receiver?
  237. HELP PLEASE!!!!!!!!! TRANSMITTER, RECIEVER RANGE PROBLEMS
  238. Self centering throttle
  239. How does the cold affect a rx
  240. acoms 2.4ghz steering wheel radio
  241. JRFX622
  242. JR 921 quick reconnect false failure indication
  243. How much carbon is too much???
  244. 14ch 2.4ghz Receiver question
  245. Where can I buy GEARS?!
  246. how ro use a heli radio with an airplane
  247. R149DP AND 5955'S
  248. Eclipse and PCM?
  249. DX6 Vs DX6i Difference
  250. receiver help please
