PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 [34] 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. SPEKTRUM PROBLEM OR NOT?
  2. Spektrum 6XI Question
  3. X9303 Aileron Differential
  4. I have a Low Band Futaba FP-R148DP Rx that I need to make High Band
  5. Futaba Servo Horn Drawings
  6. FUTABA 8 CH.REC ON TOWER SITE
  7. Futaba12fg mz sd card backup
  8. DX600i
  9. Who prefers heli transmitters to fly airplanes and why.
  10. ULTIMATE BATTERY BACKER AND JR/SPEKTRUM 2.4gHZ?????
  11. Eclipse 7 or Futaba 7C?
  12. Some basic questions on new 2.4GHZ systems...
  13. Digital vs. Analog servo's need a tutorial
  14. Servo Adjustment
  15. Spektrum DX7 Question
  16. Video: XPS 900Mhz Announcement
  17. Regulator for lipo use on RX and servos
  18. Kraft Bicentennial Series AM/FM ?????
  19. Thinking of Switching to 2.4
  20. What's the difference?
  21. Reset main timer on 7c
  22. Don't you hate when stuff like this happens
  23. 12FG FASST
  24. Does Hitec Eclipse work with Futaba 2,4 Module?
  25. FUTABA SkySport radio system - connect to PC
  26. 149DP. Hot outer case?
  27. Futaba 12FGA: Programming for Multi-Engined Aircraft
  28. Radio Transmission Amplifiers
  29. Assan X8 2.4 Ghz problems
  30. Xtreme Professional 900mhz from Extreme Power Systems
  31. Futaba 9ZAP D/R problem
  32. Ultra Stick and 9c ( Mr. Cuda plz)
  33. 1000 mah>>> 6 servos
  34. Fat Dumb and Happy
  35. New 12z looks like refurb
  36. JR 10X internal fuse
  37. basic questions
  38. 2.4 GHZ Proportional Flaps
  39. Futaba 9C programming question.. High Rates?
  40. Ham Radio Article on R/C planes / radios
  41. Continuous rotation servo mods
  42. Dx6 Range Problem- need help
  43. Gyro Placement in Plane & Gyro for Tail Wheel, Rudder or both?
  44. Dx6 mode 1& mode2 switch
  45. Anybody looking for a Futaba 14MZ 2.4 module/Rec
  46. Servo Testers:
  47. Hypothetical Shoot Down
  48. Looking to upgrade my radio! Which one?
  49. need help setting up warbird with the 9C
  50. servo wire safety plugs
  51. Receivers going into failsafe when used with TM-14
  52. Matchbox & MSA-10
  53. JR DSX9 Any tests relating to its lower output?
  54. Airtonics with 2.4
  55. Can I use my air TX/RX in a surface craft?
  56. Need new radio, 9CAP or Dx7?
  57. servo torque requirements
  58. how many 9303 hum w/ spektrum module
  59. DX7 Throttle shut-off
  60. Small Problem with Futaba FASST
  61. dx7 + ar7000 lock out?
  62. Spectrum DSM
  63. Hitec 5955 Servos Y-harness 2.4GHz Rx
  64. Futaba 9c 2.4 modules
  65. Pro Line Tx conversion
  66. Servo Lead position on Servos
  67. Best source for great servo prices??
  68. Major Glitch in a Futaba SS system!!
  69. Futaba 7 channel 2.4Ghz receivers
  70. single channel supporting 3 servo's?
  71. Preliminary 14MZ-2.4GHz pre-flight and flying tests so far.
  72. $45 bucks on Energizer r/chargeable for nothing!
  73. Spektrum 2.4Ghz DSM2 VS Futaba 2.4Ghz FAST -- Different questions
  74. Single 5014 reciever on 100cc plane???
  75. DX7 Elevator trim problem?
  76. oh no not another 2.4ghz problem ??
  77. 12z update for 2.4
  78. 12FG SOFTWARE UPDATE
  79. Futaba Update for 14mz and 12Z
  80. Looking for some help - Potentiometer for Futaba
  81. 10X battery changes
  82. Need help understanding?
  83. 32MB Flash Card for 14MZ/12Z
  84. just getting back into the air
  85. 2.4 Rx copatibility
  86. Crystals for FMH P-2ch radio
  87. Problems with my new 9CHPS and syth mod with CP/CP+/Belt CP
  88. 14MZ with Futaba Module
  89. Mixing Airtronics and Hitec servos
  90. JR 12x Add MAN Feb issue
  91. DX7 Set Up for 1/4 Scale
  92. Newbie needs help
  93. JR DS8717 in 29% Sukhoi??
  94. R921 Reboot test
  95. Problems with the Schulze Alpha-5.35 receiver!
  96. Receiver/Battery/Servo wiring
  97. Running 2.4 Antenna
  98. Direct xmtr/rcvr connection
  99. 9303 2.4 Transmitter/Receiver Setup
  100. JR X9303 Receivers
  101. 6EXAS, 6EXP Difference?
  102. spektrum dx-7 receiver pack
  103. Duratrax & Futaba
  104. Differance between low and high band recievers
  105. Help With Controls On XP2...
  106. Will my nomadio sensor....
  107. Electron 6 receiver and dual elevator servos?
  108. optic 6 problem
  109. Futaba 12FGA FASST 2.4GHz systems: Now Available!
  110. OFFICIAL HEXTRONIK 12KG SERVO THREAD
  111. My Specktrum Story
  112. Mode 2 Flyers "UNITE"!
  113. Spektrum DX7 & AR6100 Shipping from Horizon
  114. FUTABA 14 CH. MODULES - IN STOCK
  115. Extra Radio Channels
  116. How do radios and remote controls work?
  117. Futaba 7C tx -- support dual elevators?
  118. Help with futaba 3pm 2.4g
  119. Contemplating switching from 9CAP to 12Z
  120. Rockenboks
  121. Will my Buddy box work w/ this radio?
  122. help! ground test failed....
  123. Why can't I duplicate this severe glitching???
  124. Scanner Servos -- has anyone tried them???
  125. 2 battery power setup
  126. Jr Servos
  127. E SKY Receiver ,xtl problem
  128. Futaba R136HP Receiver, any good?
  129. New all over again, Looking for Recevers with Integrated BEC
  130. Futaba 9C =Rudder
  131. AR 7000 humming noise
  132. HFP 20 New programmer
  133. dx6i 4.8 V battery pack
  134. 12FG pricing question
  135. lockouts on spektrum ar6200 2.4ghz
  136. Futaba 7c Fasst
  137. Mixed radio gear
  138. Futaba / JR Servo Comparison Chart
  139. What do I need to have flaps?
  140. Dual elevators on DX7
  141. Please help me get a radio/receiver for my mini
  142. futaba 6channel 2.4ghz rx compatible with 7ch 2.4ghz?
  143. Traxxas RX 2215 max volts to servos? 75mhz tx/rx compatibility
  144. Stock spektrum servos...
  145. Program or Match new Chinese Digital Servos???
  146. New Global service for Airtronics is crazy pricey
  147. Royal Evo/Cockpit 7.2 volt battery ?
  148. Futaba 7C P-Mix Problem
  149. Dual conversion and transmitters?
  150. DX7 switch question
  151. futaba FP-7UAF SUPER
  152. Tetra RX vs GWS
  153. Futaba 14mz with Spectrum/JR 2.4 Module
  154. Need a cheap 27mhz receiver for my mini-t
  155. BEST PRACTICES FOR INSTALLING SPEKTRUM/JR RECEIVERS
  156. Flysky Sim & JR Radio
  157. 607 vs 617 RX??
  158. 3PK Hole plug?
  159. is this a good radio
  160. Bad Rx or my fault?
  161. servo torqe
  162. please delete
  163. Futaba 7c rudder twin engine mixing??
  164. Spektrum Latency Spec?
  165. Need help with Expert radio
  166. DS 821 Problems
  167. Radio/Ignition Switch Placement For Max Separation
  168. Crystal change
  169. Crystal change
  170. COMPACT FLASH CARDS
  171. JR xr2i
  172. extra batterie 14mz
  173. 14MZ max compact flash capacity
  174. 2 battery setup
  175. Futaba 12Z or maybe a 14MZ PC interface
  176. 2.4 ghz signal operating distance?
  177. DX7 Flaperon and dual rates question
  178. Metric screw size for Hitec MG shaft?
  179. Help my Radio doesn't work anymore
  180. Futaba 7C 2.4 dial setup question
  181. Spektrum Radio Cuts out at 700ft, Crash video included. : )
  182. Newbie DX6 Charging Question?
  183. damaged rx antenna
  184. HYPERION RECEIVERS - How good are they?
  185. I want to make my own servo extensions where can I buy the wire, tools, and connectors
  186. 6 volts batteries & servos life
  187. glitching
  188. Rustler XL-5 Servo Help?
  189. 2.4 Ghz - Failure rate comparaison between manufacturers
  190. gears
  191. Castle creation Micro stamp RX question
  192. Two servos flap setup with mix... DX7/Raptor
  193. Spektrum 2.4Ghz DSM2 VS Futaba 2.4Ghz FAST
  194. Want to test a RP4S1-72 corona receiver to destruction Need ideas!
  195. Best battery for specktrum?
  196. Berg 7 w/ JR Buddy Box
  197. Where do you....
  198. 2.4 Ghz and 72Mhz - Rate of problems
  199. Spektrum DS821 Sevos Junk or good
  200. Airtronics receiver issue... WHERE TO BUY?
  201. Tower digital servos
  202. JR 3v battery repair/replacement
  203. I am impressed!
  204. Multiplex Cockpit MM
  205. JR 531 STD. Servo
  206. Servo repair and testing
  207. JR 12X Add Looks Just Great!!!
  208. Futaba 2.4ghz and fibreglass
  209. X9303 FUSE/WHERE IS IT???
  210. DX7 SPEKTRUM RADIO FOR A TANK?
  211. JR 783 Resale value?
  212. 9303 or dx 7
  213. AR7000 vs AR6200 size????
  214. JR SPORT 126 or Hitec 645
  215. Servos for 84" Flybaby With 1.20 FS?
  216. Question about CC's Berg receivers...
  217. 4.8 V "only" servo list?
  218. Futaba 14MZ with Futaba Module
  219. She DUMPED @ 4.5!
  220. i need a good radio system
  221. JR Spektrum radio SS channel selection?
  222. Travel Adjust
  223. Cheap micro servos
  224. FASST w/ Large Fuel Tanks ?
  225. Looking for TRIM manufactures
  226. X8 2.4 GHz module systems
  227. syncronizing Aux 2 and Aux 3-JR
  228. Optic 6 Just quit
  229. Fixing receiver
  230. Airtronics RD8000 and twin engine
  231. Spektrum Issue, DX6i/7 QUESTION
  232. Setup question for JR 9303 2.4 transmitter
  233. NEED HELP PROGRAMMING FLAPS ON DX-7
  234. Airtronics MX-3 FHSS vs Futaba 3PM 2.4Ghz
  235. Hitec Programmer and X9303
  236. Need new receiver for old Sanwa (Airtronics) Space 6P PCM
  237. Berg 7 connections
  238. Radar Guns & 2.4ghz spread spectrum ...
  239. NEW SERVOS FROM HITEC?
  240. Which radio is best for me?
  241. FUTABA 7C AVAILABLE
  242. Plug into any open receiver slot!
  243. Did the search For aluminum servo arms for the Hitec HS-65 MG..NADA..!
  244. IS ANYONE COMPILING A JR X9303 FOR DUMMIES?????
  245. Cable for Futaba radio
  246. servo speed
  247. Hitec Spread Spectrum?
  248. spektrum 6200, use with out satellite ??
  249. Transmitter wtih Buddy Box- Help
  250. 9 CAPS & FM /PCM receivers
