PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 [35] 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. IS ANYONE COMPILING A JR X9303 FOR DUMMIES?????
  2. Cable for Futaba radio
  3. servo speed
  4. Hitec Spread Spectrum?
  5. spektrum 6200, use with out satellite ??
  6. Transmitter wtih Buddy Box- Help
  7. 9 CAPS & FM /PCM receivers
  8. To Spektrum or not to Spektrum
  9. Make my own "Y" connectors
  10. Long Servo Arms?
  11. Receiver Interference
  12. ESC/RX question
  13. Quest about My radio
  14. SPEKTRUM/JR REMOTE RECEIVER EXTENSIONS
  15. Traxxas TQ Glithchy?
  16. zombie slot?
  17. Digital/Analog servos
  18. 149DP an DSC
  19. Inexpensive dual-conversion FM Rx?
  20. Test flew my 9CAS 2.4 today
  21. Two Rx batteries into the Rx...
  22. Futaba 5114
  23. helppp!!!
  24. Blue bird micro servo gear replacement
  25. Binding spectrum reciever
  26. Is my DX7 broken?
  27. HDX Full range receivers
  28. to all 3D pilots, how much expo?
  29. quick Spectrum questions
  30. futaba 6exh 2.4ghz
  31. New Throttle Servo Needed
  32. Dymond receivers
  33. 6EX 2.4 Antenna In Heli Canopy
  34. Futaba 6EX modification
  35. Receiver wiring - need some help plz
  36. Spektrum users please help
  37. Jr 7202
  38. flight sim
  39. Extreme Link for 9Z
  40. Antenna Length - FM Rx
  41. Rebuilding JR DS821 servos. What to use for lube?
  42. Futaba T2er
  43. Futaba 9350 gear slop
  44. Futaba Programming Question
  45. battery life short lived
  46. voltage indicator problems - older futaba
  47. 3PKS
  48. Wet ReceiverMy
  49. 8UAP glitch problem
  50. Signal voltage
  51. 7C and Dual Elevators
  52. New Futaba 7 Channel Fasst VS DX 7
  53. Where can I find transmitter stick extensions
  54. Spektrum Receiver Location Question
  55. Need help converting radio from mode 2 to mode 1
  56. Bob Fiorenze Air Speed Indicator
  57. FMA offering Ham band radios again.
  58. So Mr Somenzini also had a 2.4 problem...
  59. Futaba T12FG JR X9303
  60. Berg, FMA, and other second party Receivers
  61. HS 645MG Servo Noise
  62. Industrial Supplier - Servo Connector Pins
  63. 9CAF failure
  64. Eclipse in PCM configuration?
  65. Help needed with radio unit on my new airplane.
  66. servo choices?
  67. Best place to buy 14MZ?
  68. reversing a servo (HS-625MG)
  69. Hs-645MG or S3305
  70. JR R921-ANY REASON THIS WOULDN'T WORK????
  71. AR6100e Range?
  72. 12FG
  73. Easily make fast charge cable for Futaba 12FG
  74. Nitroplanes/Raidentech servos: Anything you recommend for parkflyers?
  75. Help with Airtronics
  76. Flaperons with 4 channel?
  77. Need Instruction Manual - 6 Channel Radio
  78. cant figure out how to setup my esc
  79. High band or Low Band?
  80. Fried my receiver which is best replacement?
  81. whats up ?
  82. Futaba 9C Campac - Why Not an SD Card
  83. what does this mean???
  84. what does this mean???
  85. CCPM with a 8U non super
  86. RF CH25 Reciever or Transmitter
  87. Spectrum buddy box question
  88. Best Gyro for nose wheel steering
  89. New Spektrum DX6I and AR6200 full range
  90. round servo horn
  91. ???RETURN OF JR 8103 FOR SERVICE
  92. A or B Band?
  93. Glitching? Good tech tip on this on RCTV
  94. Spektrum DX-7 AR7000 Receiver Battery Advice Needed
  95. Battery for Futaba 9Z
  96. 2.4 connect during turn-on
  97. 2.4 FlipFlopper
  98. Customer Support Horizon Hobbies
  99. servo choices ???
  100. Futaba 4exa transmitter with Hitec micro 05s reciever
  101. what does this compare to?
  102. Help needed: TX Antenna
  103. X9303 programming help
  104. Battery tied to servo lead
  105. Which is the better 2.4 gHz system??
  106. spektrum modules in dx7
  107. 3 position flap
  108. antennae
  109. 6 channels
  110. DX6 aerial (antennae) position
  111. PCM?
  112. 7c vs dx7
  113. dx6i vs. 6ex
  114. trim question
  115. hard decision......
  116. blade cp transmitter adapter
  117. Spektrum Radio - servo problem
  118. 9C upgrade to 9C super qustions
  119. Can an S9252 lose neutral position?
  120. SPEKTRUM 3-CH CAPACITOR
  121. PCM and PPM on a field force 9 super tx question
  122. Typical range check distance
  123. Programming Help
  124. THREAD BULLY
  125. Airtronics MX-3FHSS 3-Channel 2.4GHz
  126. Airtronics RD6000
  127. Hacking a Futaba Conquest transmitter
  128. Spektrum AR6000 voltage
  129. CNC Servo Case tops?
  130. do hitec servo arms fit futaba servos?
  131. Heathkit manual
  132. Range of Spektrum's AR6100 Receiver (don't make the mistake I made)
  133. DX6 set-up?
  134. Best servo for the buck? 90 size.
  135. Question about the Futaba 7CAF Radio's Battery Life
  136. Whats a good high torque steering servo?
  137. Servos? Futaba 3010 vs Hitec 635 vs HS645?
  138. FLAPERON mode on DX6
  139. Futaba 8UAF timer buzzer not working
  140. DX7 users...
  141. Futaba 12 FGA VS. JR X9303
  142. Frequency question
  143. X9303 NEED AILERON SETUP HELP
  144. dual servos on aileron help
  145. I need to know....
  146. JR261
  147. RE: PowerBox Digi Switch & DSC??
  148. 2.4 GHz lots of questions
  149. flash 5 glitch
  150. servo power draw question
  151. Futaba 9zap or new 12fg
  152. Noise Traps/Ferrite Rings Needed with 2.4 ?
  153. Light Flite RC Rx's
  154. Hitec and 2.4GHz
  155. Traxxas TQ or Cen DSX
  156. JR X9303 2.4
  157. 129DP vs 149DP
  158. GY401 Problems with BCPP (updated with video)
  159. Futaba, Spektrum, Modules, oh my!
  160. With all of this talk of 2.4 ss... !!!!!!
  161. mx3 vs. xs3
  162. DX7 and DX6i, can they both support dual elevator servos?
  163. difference in an radios and recievers
  164. Mode change on Futaba 6EX 2.4Ghz
  165. Need help with Futaba 3pk
  166. Futaba 5014 or 5114?
  167. T6EX 2.4 GHz System
  168. Futaba 7C 2.4ghz, WHEN WILL IT COME?!!!!!!!
  169. another servo question
  170. Throttle kill switch on 9C
  171. 27mhz Vs. 75mhz Surface Frequencies
  172. Hyperion Servo's
  173. A CLARIFYING QUESTION JR/SPECKTRUM BINDING
  174. Hitec HFP-20
  175. Hanger 9 P-47 recomended retact servo problem
  176. Spread spectrum radio suggestions
  177. wireless reciever
  178. Dual elevator servos and dual Aileron servos with a 9C and 7ch reiever
  179. LOOSE CAPACITOR ISSUE--AR7000 OR R921????
  180. My horror Story DX7
  181. Futaba 127DF reciever and Hitec Digitals...A BAD combination
  182. Futaba 6EX or Spectrum DX6
  183. Color-coded servo extensions?
  184. Which servo should I buy?
  185. servo question
  186. Channel mixing my 9C
  187. Help Reseting an Airtronics Radiant 6/H
  188. Anybody "USED" any of the cheap Hong Kong servos
  189. Spektrum and JR RF Link Performance Telemetry from Eagle Tree!
  190. Advanced radio setup help
  191. Optic 6 and trainer cord
  192. 2.4GHz RC Car controller
  193. Futaba Tx, Late 1970s Vintage - Photos
  194. heli cannibalism???
  195. New 7C
  196. Kraft servo torque
  197. What do old timers think about 2.4Ghz?
  198. Radio, heli or airplane version
  199. Spektrum Receivers
  200. Rubber transmitter stick ends
  201. JR servo compatability with Hitec Rx
  202. RCD platinum for airtronics but using jr servos??
  203. Why buy Futaba?
  204. Voltage flickering on 6EX Futaba Radio
  205. Servos, servos, servos - - does it really matter for basic day-to-day flying?
  206. tryin to run 2 ele servos with a sx600 rad
  207. Spektrum DX7 Lockout
  208. TX adjustment?
  209. Should PCM be twitching like crazy?
  210. Metal geared servos and metal control arms
  211. voltage from ESC into receiver
  212. 7UAP elevon programming
  213. dx7 failsafe settings
  214. Expo on Throttle, Futaba 8U & 9C
  215. HELP" "Throttle Cut" Lockout on Fut 8UAP
  216. JR DS821 Servos
  217. Hitec Eclipse PCM module with arbitrary PCM receiver?
  218. conversion
  219. Futaba 6EXP Transmitter Setup
  220. Futaba 9C w/Spektrum wiring modification
  221. Airtronics M11
  222. servo linked to its own rx pack, any one know how to?
  223. What does the "B" mean on feigao 6ch RX?
  224. Lithium Battery for 9c Radio
  225. Why spektrum rx batt has 3 wires?
  226. Gyro Switch unit
  227. Who makes the Crystals?
  228. Futaba R5014 DPS Power Rating
  229. Lipos and Transmitters
  230. Futaba Skysport 6 model T6YG Mode change
  231. Need help choosing Radio's
  232. Mode 1 & Mode 2? 2.4 fasst
  233. Spontaneous aileron offset (discussion)
  234. Futaba 9Z and Fasst module
  235. Spektrum DX7 Neck Strap Warning
  236. Airtronics 94141Z servos..
  237. Servo size for 1/4 sclae (dynaflite super decathlon)
  238. HELP! futaba 4ex receiver discontinued
  239. Graupner MC-18 & MC-24 Spekrtum Module Installation Mod
  240. Graupner MC-18 & MC-24 Spekrtum Module Installation Mod
  241. 6 channel Futaba
  242. Time for a new radio...what to get?
  243. DX7 Does it again
  244. JR Nes 606
  245. Multiplex Royal Evo
  246. can I use my 4 cell rx nicad packs with the AR9000
  247. Matchbox - stepped controls with retract servos?
  248. Is 72 Mhz Dead???
  249. why the rediculous delivery times for 12FG
  250. Castle Creations Thunderbird 36
