PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 [36] 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Expos on JR vs. Futaba
  2. JR 9303 - 2.4 GHZ Radio's on E-Bay
  3. ESC timing-mode setting.....
  4. S3003 / S3004
  5. X9303 Shipping Estimates
  6. -- reposted to JR forum, pls ignore -- JR/Spektrum 2.4GHz receivers and rx antennas
  7. Spektrum DX7 Ratings from flyers who have used it
  8. Futaba mc1128 help
  9. AM recievers - AM/FM conversions
  10. Castle Creations Berg 7p receiver question
  11. re-binding receiver to X mitter
  12. Airtronics M11 - 2, 3, or 4 channel?
  13. What is this ?
  14. 2.4GHZ RECEIVERS USED IN CRAMPED SPACES???
  15. HOBBICO CS170 ULTRA TORQUE SERVO??
  16. AX700 scanner use?
  17. Spektrum stuff
  18. Time for an Upgrade
  19. Profi mc4000 module available from XPS
  20. 4 functions from an Airtronics M8 3 channel?
  21. DX7 receivers 6000 vs 6100
  22. Negative or positive shift?
  23. Servo & Battery Wires
  24. Mapping AUX to elevator on DX7?
  25. Make your own servo extensions?
  26. RECIEVER WENT KABOOM!!!
  27. End point Adj.on retract servo
  28. Newbie here with a ?
  29. So would you trust a $10,000 plane to a DX7?
  30. Rcvr Jitters
  31. 60s gear
  32. Battery Charger/Discharger
  33. Horizon Support sucks
  34. Coiled Antenna
  35. JR and Spektrum
  36. Antennas breaking off the Spectrum small receivers
  37. Future Pricing on Futaba 2.4
  38. Compatability
  39. What kills my servos?
  40. Hitec HS55's with Airtronics Rx.?
  41. ALERT! Issue with "Air Alert"
  42. Why plane finders don't work with FASST R606FS?
  43. JR and Spektrum connectors?
  44. xtal falling out and causing crash
  45. Gyro question
  46. Dropped my Spektrum DX7
  47. controller advice
  48. Futaba T6EXAP NiCad voltage after 2 week storage
  49. How to extend Tower Hobby TS-80 servo?
  50. Jato controller
  51. Power output of JR 9303 2.4Ghz??
  52. ESKY receiver with 9CAP
  53. GWS Crystals
  54. JR 9303 available now?
  55. BD-5B and jr digital servo DS285
  56. Why don't manufacturers support 4 servo wings etc?
  57. xtremelink - smartfly
  58. Futaba 7C intermitten problem???
  59. Returning R/Cer Question
  60. Old Futaba Servos
  61. Has anyone ever mated a commercial joystick with an RC Transmitter?
  62. Spektrum install pics wanted
  63. POLYSWITCH ANYONE?
  64. FUTABA 12Z "Logic" HELP
  65. Futaba 9C + Spektrum AR9000 System
  66. XTREME LINK 2.4 MODULES FUTABA 9C
  67. Spektrum DX-7 help
  68. Can you use JR Rcvr with Airt TX 75 mhz?
  69. Difference between 4 5 6 and 7 channel heli radios?
  70. REDUNDANT POWER-SERVO ISOLATION
  71. Multiplex Royal Evo - Good News!
  72. Extreme Link 2.4Ghz System Question
  73. Hitec servos
  74. 14MZ Transmitter Pack - Cycle Results
  75. futaba 9c super synthesized transmitter
  76. High to Low freq receivers, FP-R127DF
  77. HAHA LOOK WHAT SERVO CITY SENT ME!!
  78. Servo Voltage
  79. 9303 flight mode ?
  80. dx7.. 1024 or 2048 resolution?
  81. glitching dx3.0
  82. Spektrum DX7 Transmitter case
  83. Berg 7p poor range check
  84. 2.4 9303 or 12FG 2.4 Going to 2.4 Soon
  85. Hitec Reciever, Battery/Switch into Channel 5?
  86. Futaba/JR Combination
  87. 9CAP Parts
  88. Torque on JR NES-L501 servos??
  89. Is there anyone use JR10X heli version with Reflex simulator?
  90. 8711 gears
  91. Flying wires causing glitches
  92. Do I have a faulty servo?
  93. Model Memory Vanished! Futaba 12Z
  94. good RX for Alfa mig15
  95. Glitch Busting Help
  96. Hitec programmer RC Mall Ebay
  97. 7c module Fasst system report
  98. Spektrum DX-7
  99. PCM Lockout?
  100. y
  101. What Work's Best?
  102. Loss of frequence on 14 mz
  103. Anybody own a Futaba FP-T2P
  104. what servo arms fit jr other than jr
  105. Futaba 2.4ghz compatability??
  106. general electronic q
  107. Kraft radio users
  108. Servo S3305 Futaba or ... ?
  109. need and want Radio, but which one?
  110. A question from a newbie
  111. Servos - Why or what makes them do this?
  112. XP9303 With Select Scan
  113. AR 9000 failures - service bulleting
  114. 2.4GHz Radios - enquiries.
  115. SOURCE FOR SERVO CONNECTORS AND CRIMPING TOOL
  116. APEX tranmitter
  117. HiTec Black Servo Arm Limits
  118. DX-7 Rx reset - possible cause
  119. Futaba 12Z or 12FG???
  120. Power System for a 28% Edge
  121. Futaba 6EX 2.4 Ghz lost ID Code
  122. Making my own PC data cable?
  123. Another Futaba 9CAPs/US40 Question
  124. 9303 2.4 Is out
  125. JR XP662 and aileron programming
  126. Futaba antenna for a JR Tx?
  127. help!Walkera 5G6 technical support
  128. Help!
  129. transmitter/reciever compatability
  130. Futaba 9CAP + Spektrum or FAAST
  131. Spektrum wheel change?
  132. SPEKTRUM FADES and FRAME LOSSES
  133. Futaba 7C vs Spektrum DX7
  134. Best 2.4ghz radio?
  135. Are the days of 2.4GHz systems already counted?
  136. New radio?
  137. Airtronics Radiant Memory Battery
  138. hitec 5955
  139. DX6 in Tunnel Hull Boat - Range?
  140. JR R649 receiver crystal question?
  141. Dual Ailerons / Flaps - Ch1 = R or L?
  142. JRx-3810 transmitter
  143. MX22 menu help
  144. Do I have a problem?
  145. OPTIC 6
  146. radio from Blade cx
  147. Digital servo question!!!!
  148. Twin Engine / DX7 Reciever Throttle Set up / NO Y HARNESS
  149. Adding a Toggle switch??
  150. Servo reversed!!!!!!!!
  151. Polk's Hobby Tracker III / is it any good
  152. DX7 and AR6000 for full size
  153. Delete this thread dont need the flame
  154. Hitec Aggressor 40mhz FM Transmitter work with 3.5gram 40MHZ 4Channel Receiver
  155. Your thoughts on this servo?
  156. JR 10X Transmitter Battery
  157. futaba 2.4ghz for plane and heli
  158. Futaba 6EXHP for airplanes.
  159. futaba 6exap failing
  160. R9000 FAILSAFE SETTING
  161. DX-7 / AR-7000 blocked signal ?
  162. 3PK Antenna plug? What should I use?
  163. Spektrum / Using one receiver in several planes / binding?
  164. broken antenna
  165. Futaba 9CHP + 2.4 GHz module, any Good?
  166. servo for gyro help?
  167. 4 or 6 channel ground radio?
  168. Spektrum DX 7 ROCKS !!
  169. JR radio charging polarity
  170. Y harness... how's it work?
  171. The new 2.4 GHz iVol 12 Channel Tx
  172. Gltich Question
  173. Futaba 12FG Special Conversion Software & Update Files
  174. Weatronic receivers
  175. rx battery question
  176. Tx-Rx compatability
  177. A Little Range Check Help.
  178. Cirrus Servo Arms?
  179. *JR 7202 Not Working*
  180. Receiver crystals
  181. Futaba 7CAP Fail Safe
  182. extension instead of switch?
  183. Am to fm interferance?
  184. AR 6000
  185. Cheap 2.4ghz receivers
  186. setup a gas plane Fut 7c and Hitec Fm Receiver
  187. How do you like your Futaba 6C FASST
  188. Sail Servo
  189. JR XP9303 PCM 72Mhz - Should I buy for $450?
  190. Control Motion
  191. left aileron travel problems with spektrum dx7
  192. DX7 What am I screwing up?
  193. Futaba 6EX-2.4 RX Without Regulators ??
  194. Radio Advice
  195. More than 9 channels? How would you use them?
  196. Traxxas TQ3
  197. servo reversing?
  198. Digital vs Analog??
  199. Linear electric motors as servos?
  200. Crow problems with 7CAP, please help!
  201. What is the diffrence from DX7 Heli and a DX7 air?
  202. DX3/HiTec-Futaba fail safe
  203. 14mz Poor Range
  204. Advice On DSM Options
  205. Range Problem
  206. 2.4Ghz in Europe
  207. Sanwa RD6000 conversion for ground use
  208. two forward stick transmitter?
  209. TX for Lama V3 Esky
  210. MSA-10 Servo Synchronizer / JR Matchbox
  211. Lipo for your Transmitter
  212. Single conv.Tx ???Possible?
  213. where can i get a new WC2
  214. Xtremelink
  215. new radio advice
  216. DX6 range?
  217. Giles 202 140 servos?
  218. Override the MG995 Servo
  219. *JR R790 Scan Select SPCM Receiver*
  220. Can you get softer gimbal sticks?? (Fut 7c)
  221. FUTABA 9 ZAP WC2
  222. servo question
  223. HiTec Optic 6 Case & handle Issues
  224. broken gear switch
  225. 9CAP forgets trainer settings
  226. Lazy erratic servo action.
  227. Killed 4 servos at once...
  228. 14MZ warning!
  229. question Futaba 2.4 GHZ in Peru
  230. servos , one or two?
  231. At a certain engine RPM my radio gear goes nuts ? Troubleshoot..
  232. Why can't you just get the radio!
  233. OLD Futaba conquest?????
  234. Can the Quality of battery affect the range in TX?
  235. Futaba fasst 2.4ghz signal loss
  236. Ace servo cycler
  237. Futaba T14MZ
  238. DX7 making quiet sound when on
  239. Futaba R5114dps receiver
  240. Di How do you wire up a TS-80 Giant Servo?
  241. Buddy box - how does it work
  242. How to set up flaperson with DX7?
  243. futaba 149DP with 6v
  244. remote control for other purpose
  245. Batteries for DX7 receiver
  246. servo size help!!!
  247. Radio Crazy
  248. flaps
  249. Moved to JR forum Range check
  250. Transmitter switch covers
