PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 [37] 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. remote control for other purpose
  2. Batteries for DX7 receiver
  3. servo size help!!!
  4. Radio Crazy
  5. flaps
  6. Moved to JR forum Range check
  7. Transmitter switch covers
  8. Spektrum and Emcotec DPSI Twin
  9. Using Xmitter W/Simulator
  10. please delete
  11. Spektrum DX3 or Spektrum DSM Pro
  12. messed-up electronics
  13. JR DS821 sale
  14. 50mhz Berg anytime???
  15. Futaba 12FG "lite" anytime?????
  16. CIRRUS MRX-4 (Mk. II) FM 72MHz receiver
  17. 2.4 Satisfaction Poll
  18. Spektrum interference
  19. Futaba reciever questions...
  20. Futaba RX's and Hitec Crystals
  21. Where to buy Spektrum DX7 minus servos?
  22. Offset? what is it, how do you use it?
  23. How to program?
  24. 2.4 Receiver Antenna Types - Now I'm Confused ?
  25. .futaba controllers
  26. sim remote?
  27. comparing 2.4's
  28. Airtronics RD 8000
  29. GY601 problems! ik on a 601! its crazy
  30. OPTIC 6 COPILOT
  31. jr 3421 with 6v
  32. Can 4-stroke vibration cause RX interference?
  33. noob radio
  34. Reciever Crystals
  35. 2.4 GHZ system
  36. Futaba 6EXAP help
  37. JETI 012 connection question
  38. SPECTRUM DX7 HELP PLEASE.
  39. Missing post
  40. PCM-Servo problem
  41. Old Hitec Focus 6
  42. Futaba 2.4 Receiver Antennas - Length ? Positioning ?
  43. Throttle cut twinengines
  44. LiPo batteries use in a JR 10X?
  45. How about bringing back Single Stick Transmitters
  46. Can't believe this happened!!
  47. Magnetic Switch
  48. RECIEVER COMPATABILITY
  49. FAAST is not standard, products already not supported
  50. 2.4 GHz - A Broad Market Review
  51. Spektrum and Futaba
  52. Futaba 6exap just fried
  53. Freq. Shift
  54. Advance Models C130 & Futaba 7C
  55. servo glitch /onboard glow??
  56. DX6 or DX7???
  57. Electronic On\Off switch
  58. Futaba FASST Recievers - Case Design and plug socket layout
  59. best price on dx7
  60. antenna question
  61. DX6-AR6000 Range ?
  62. HELP!!!
  63. *HS-5645MG Digitals, To Much Slop In Gears*
  64. Deans 2-piece whip antenna, wire length?
  65. Radio newb need a guide.
  66. how do i take off my carburater?
  67. DX2 antenna repair
  68. HELP, whats servo is this???
  69. basic questions about dx7 and rx spektrum:
  70. In need of DX3 help
  71. Blue Bird servos
  72. Cheap flight pack!
  73. Kyosho Perfex Servos and Receiver
  74. "inverse time feed mode" question...
  75. DB connectors
  76. Futaba 9c radios and their color
  77. Help with my Kraft series seventy nine
  78. Sullivan Smoke Pump Not Pumping
  79. AM FM
  80. Radio interference?help...
  81. Help! radio newbie!
  82. Which radio?
  83. Airtronics RD6000
  84. is Futaba missing the boat?
  85. How do YOU set-up expo??
  86. 9C and 9CS - Who is using 2.4 GHz - Happy?
  87. Reflex XTR - Unresponsive support, exorbitant freight
  88. Tower Hobbies 7 Channel Radio
  89. Airtronics Rx-Old or new Z connector compatible?
  90. DX7, can secondary receiver be unplugged?
  91. MPI power switch with LED's..jumper question
  92. Would you still use Nicd for RX pack?
  93. Futaba Hi Band vs Lo Band
  94. DX7 / AR7000 problem (reproducible loss of signal)
  95. Gyro On Nose Wheel
  96. Futaba s3151 on 6Volts?
  97. Hitec HS-5955TG for steering?
  98. just got a bunch of neat RC stuff!
  99. 9303
  100. Digital Servos
  101. Cheap Smoke Pump
  102. buy used and rebuild?
  103. 2 week old Hitec programmer wont work!!
  104. what could have happened to my ailerons?
  105. GOING ABSOLUTELY APESH*T HERE! HELP!!!!
  106. Any 4-channel FM receivers for Futaba????
  107. Hitec Agressor SRX?
  108. Is this single or dual conv crystal
  109. RC radio instructions
  110. Capacitor vendors??
  111. Throttle cut off.
  112. JR XS3 help PLEASE!!!!
  113. i need dx6 setup for falcon 3d
  114. HITEC FLASH 5 CRYSTAL QUESTION
  115. Single/Dual RX Crystal
  116. Futaba R606FS 6 channel receiver
  117. problem with 7CAP trim!....help!
  118. Futaba 7C Transmitter Differences
  119. Airplane rudder gyro
  120. Spectrum DX7 vs Futaba 7c (2.4 fasst)???
  121. Futaba 7C question?
  122. TH Digital Servos and GP EXTRA 1.60
  123. JR -vs- Futaba -vs- Hitec quality
  124. advantage to the 7C vs T6EX 2.4 futaba?
  125. Can Spektrum DX-7 Slow Servos Down?
  126. RD8000 ANTENNA
  127. TX_RX question
  128. JR 7202
  129. SCANNER RC SSV-9766MG
  130. Noob Question: SR3000 Receiver
  131. li-po for reciever and trans???
  132. Surface radio receiver compatibility
  133. DX7 No Trainee
  134. Royal EVO V-Tail Mixer
  135. XPS and Giant Scale
  136. bluebird
  137. Anyone have any broken servos?
  138. What is completely "retarded trim" position on Futaba 9CHP
  139. Another Rx aerial length question
  140. Protech avenger 4ch?
  141. new transmitter
  142. Earth magnets and interference
  143. MX-3S servo problem
  144. Changing Crystal On TX
  145. 6 or 7 Channel Radio?
  146. Spektrum radio doesn't bind
  147. Spectrum Tx antenna direction?
  148. Which Aircraft Module System is Better, Spektrum or Xtremelink
  149. JR8103 no middle flap setting
  150. Throttle arming switch
  151. sullivan smoke pump and digital servos.....
  152. Is everybodies 40mhz FM hitech Zebra perfect?
  153. TF & RF crystals Does anybody know the Country of origin for this terminology please????
  154. Futaba transmitter charging jack protection bypass
  155. Lithium tx packs
  156. Running dual 2.4 RXs
  157. Better batteries=Better Range?
  158. DX7 Possible Concern
  159. GY401 problems with R50 Titan
  160. Mixer for tiltrotor / vectored thrust
  161. JRXS3 + reciever??
  162. Spektrum with analog and digital servo
  163. Antenna routing...
  164. Hobby People's Cirrus servos.....any good?
  165. Single VS Dual Conversion RX's & Interference
  166. 3003 / 3004 and 6V
  167. New X9303, Which version heli or airplane?
  168. New JR 9303 Single stick TRX
  169. stick gimbals better on the 7C than the 6EXA?
  170. Any downside to micro servos?
  171. JR 10X trim/ DR problem
  172. Digital servos shake uncontrollably when radio testing.
  173. 9C Synth module frequency problems
  174. A-123 2 cell pack and Servo compability
  175. Futaba 2PL FM radio or other?
  176. Hobbico VoltWatch
  177. Old Airtronics 94510 1/4 scale servos
  178. RADIANT !
  179. Spektrum DX-7 Problem ??
  180. any really "failsafe" ways to fight interference?
  181. 6EXA of 7C??
  182. PCM RX for Futaba 6EXAP
  183. Have you ever experienced total servo failure without warning?
  184. ACE HIGH TORQUE SERVO DS1213
  185. Hitec 645 or 625 for Planes?
  186. split elevators r127df / 9c
  187. Is my new DX-7 broke?
  188. power box problem
  189. Futaba 7C question?
  190. just to make sure...
  191. mixing sevo connectors..
  192. How much expo???
  193. Redundant on-board config
  194. Flight Network MaxStream 900MHz Question
  195. Flight package redundancy
  196. Anyone uses the new Hitec Supreme IIS RX?
  197. JR12x on 72mhz?
  198. 2.4Ghz antenna... the facts?
  199. Airtronics MX-3 Question
  200. 35 Mhz band color
  201. the twilight zone ?
  202. DX7: easiest way to program dual elevators and ailerons?
  203. Affordable 2.4 6 ch receiver, who will be the first to market it??
  204. Specktrum Binding?
  205. Berg 7 RX...ANY GOOD
  206. Micro FM Receivers on 50 MHz?
  207. Using Futaba 7CAP for a Heli
  208. JR X9303 2.4G stick modes
  209. HG Servos, anyone using those?
  210. Futaba 12Z and PCM1024 Channel 9
  211. Futaba 7c
  212. Futaba T8UAF, How long?
  213. Old Airtronic servo with new Airtronic radio.
  214. Conquest 6
  215. 4 Hitec HS645MG, and 3 Futaba S9151, would you use upgrade powerbox?
  216. Futaba 9c mix for ailerons.
  217. Metal covered DC-3 glitches.
  218. Any simple way to check a tach's accuracy.
  219. Just wanna be sure about this!
  220. TBM 8711 vs 5955 servo test...
  221. JR 10X zpcm Manual??
  222. JR's PCM12X for the Rest Of The World
  223. MAJOR problem with 2.4 system & Rain
  224. TX power loses!
  225. jameco electronics parts
  226. Electronics Choices
  227. DX-7 Won't Connect Problem
  228. Futaba 7C 2.4GHz Radio
  229. Futaba 9151 and 9301, good enough for DPM Extra on 45cc?
  230. Transmitter tuning
  231. jr servo replacement gears source
  232. battery size for hitech 5955tg
  233. Futaba R319DPS Receiver
  234. DX7 Trainer Switch On/Off
  235. Jr to JR Trainer Lead
  236. Speckturm module for JR
  237. Anybody using the new Futaba Spread Spectrum
  238. 6 Volts for speckturm systems?
  239. Controlling an ESC without a radio?
  240. What does Airtronics charge?
  241. Airtronics servo specs
  242. Where To Have My Radios Updated "Gold Sticker"
  243. Difference between Futaba 12FGA and 12ZAP
  244. I WANT YOUR 50MHZ RADIO GEAR
  245. Is a Hitec Servo Compatable with a Futaba Extension Lead?
  246. 6 EXA tx
  247. futaba 3001,3003 or 3004, please help
  248. PZ Stryker C radio= Delta or V-tail?
  249. Futaba neck straps, anyone have them?
  250. Spektrum TX packs... 1.2v or 1.5 x 8 = Enough ?
