PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 [40] 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Please help[ - Setting up a radio system with servo and Speed Controller
  2. FIELD FORCE 6(T6X)
  3. Matchboxes/Synchronizer
  4. Servo screw?
  5. When can we expect to see the Nomadio 16ch?
  6. Befuddled by Servo Choices
  7. 9z versions
  8. Comparative ranges of Tx Equipments
  9. A new 10 channel Spektrum radio!!!
  10. tower 6 channel
  11. Futaba Skysport 4exa question
  12. Controlling PCM servo with switch
  13. help with Kraft Sport Series equipment
  14. Mixing flaps & elevator with Futaba T6EXAPS HELP!
  15. Programmable mixing on pistol style
  16. Stall current
  17. Futaba R127DP Rx: PCM1024 *AND* PCM512?
  18. Is TH System 3000 TS-53 6v Safe?
  19. Good deals on DX7 receivers
  20. Buddy cable with different brands
  21. Spektrum dx 3.0 please help asap
  22. Weird problem with my new Futaba 7Cap
  23. Hobbico Accu-Cycle VS Triton
  24. JR transmitter/Airtronics Receiver
  25. Help! - Seperates..RD6000 nothing works!!! HELP!!
  26. Reason for erratic failsafe?
  27. New & Old
  28. Tweaking walkera radio system! plz help
  29. DX-7 related crash?
  30. Noob radio question
  31. futaba,,what else are they into?
  32. DX-7 and CSM 3in1 Simulator
  33. New Futaba 2.4ghz 6ch spektrum
  34. Suitable RC for Submarine?
  35. Standard Futaba Horn On A Hitec HS-81
  36. Killing the CCPM in a Blade CP radio?
  37. Spektrum DX-7
  38. Was your new radio too expensive?
  39. Some Questions about the Multiplex EVO12
  40. KO PROPO EX-10 Helios for the Mini-Z
  41. What battery and voltage for HS5955
  42. .
  43. question about tx
  44. Tx and RX range
  45. Futaba FP-S143 Servo Specs
  46. Servo jitters
  47. traxxas reciever connections
  48. Receiver for Vanguard Transmitter
  49. Futaba 6EXAS tx cycling
  50. DX7 Throttle cut feature?????
  51. JR xp662, buddy box lock out problem
  52. Digital Servo - How much more power?
  53. Futaba 127DF.RX
  54. How can I get FULL resolution on ALL channels of a Futaba 14MZ or 12Z
  55. Jr Reciever, Futaba Radio
  56. Airitronics reciever HELP!!!!
  57. Futaba SS listed at towerhobbies
  58. 9ZA WC2 Programming questions
  59. Do I lose my memory if I pull my tx battery?
  60. JR crystals
  61. Futaba reciever- What is the screw for?
  62. Powering a Seiko Servo
  63. 6EX-PCM Futaba question "Elevon Mixing"
  64. 2 receivers VS pwerbox,smartfly
  65. Dual G3 receivers
  66. HELP!!! GWS RECIEVER locked out!
  67. Dx3...
  68. DX 7 Back-up battery
  69. Futaba 2.4 Ghz
  70. New Futaba 12FG radio
  71. kraft KB FM CRYTALS
  72. Newbie Question about Freq.
  73. Looking for info on MultiPlex Profi radios...ie. compatibility.
  74. DX7 help please
  75. DX-7, gyro
  76. 72 mhz Frequency chart
  77. Futaba S-9351 Digital Servo
  78. Hit me up with some good buggy servo's!!
  79. DX-7 , Biplane set-up ??
  80. JR DATA SAFE VER.1
  81. Compatability of JR8611 servos and Futaba 149DF reciever.
  82. Spektrum Conversion For your Hitec Optic 6
  83. Xtremelink for the programming adverse?
  84. Futaba SS FASST Full Range system/Aircraft
  85. Could be dumbest radio question ever
  86. DX6/7 Transmitter mode
  87. Karbonite or nylon, which is better.
  88. DX-7 Elevator setup
  89. Futaba Battery connection?
  90. Supplying power to receiver through Y-harness
  91. Expo setting on a Hitec Eclispe 7 radio
  92. Picking Servos for Alerons
  93. Hitec HFS-05MS problem
  94. An odd duck question here
  95. Throttle Servo
  96. Servo's
  97. Spektrum - Aircraft vs Heli version
  98. Futaba anounces Spread Spectrum system in Europe
  99. nomadio react
  100. Eclipse 7...What is going on?
  101. Range of Spectrum DX7
  102. Voltage Checker
  103. my first of the year
  104. Receiver Antenna in the Wing??
  105. Becker Baseloaded Antenna
  106. Transmission of own data using a radio
  107. Hitec HFP-10 Update support
  108. Beginner needing to learn about servos
  109. 7CAPS or 9CAFS???
  110. What servo's for 8 ft. Lazy Ace?
  111. exponential buddy box?
  112. new radio recommendation
  113. Radio Controler
  114. Good first setup?
  115. Not impressed with the Rubber Ducky
  116. Worth revising servos??
  117. JR europe distributor??
  118. Spektrum Dx6 problems
  119. Dumb Receiver Question?
  120. Spectrum Heli version ques
  121. Hitec aggressor radio
  122. Spektrum receiver voltage
  123. Transmitter/receiver crystals
  124. Servo Steering Problems
  125. Security Connector Housings
  126. Setting the throws on a plane with a futaba 7 cap
  127. Spektrum receiver connectors
  128. Laptop RC car/truck
  129. 635HB OR DS821
  130. DS821
  131. Airtronics Spectra 7 PCM Manual
  132. Reducing size of servo arm holes
  133. Caomputer radio
  134. Diff between Airplane & Heli TX
  135. Futaba 319 DPS reciever??
  136. RD 8000 on PCM
  137. Tx Charging help please..
  138. SPECKTRUM AND GAS
  139. Airtronics 3-channel FM receiver question
  140. MX 22 programing throttle cut
  141. Most popular channel on 72 mhz????
  142. Right hand pistol grip Tx.
  143. changing an AM crystal in a dual conversion
  144. JR Matchbox Help Please
  145. Using Smiley Ducky for both 72 and 50 mhz?
  146. Transmitter compatibility
  147. Trim memory with Futaba T6XA
  148. Servos won't work w/ 24" extensions
  149. DX7 programming for Ultra Stick
  150. Proline single stick, interest?
  151. Servos, what works with what, Why, Why Not?
  152. Futaba 9255 servo problems ?
  153. Quick Q
  154. stuppid newb Q
  155. Quick simple Q?
  156. FM Tx work with AM RX
  157. Best replacement Battery for JR 9303
  158. Airtronics RD8000 and Negative Shift mode
  159. Winter flying with the 14MZ
  160. spektrum dx7 plane vs. heli
  161. Modding Futaba 9C Super Timer Volume
  162. 50MHz Micro Receivers
  163. Servo chart 2007
  164. 12Z Software for desktop or laptop
  165. TP-FSM Synth Module HK version!
  166. Problem with my a-tech xmb4 1/18 rc
  167. 4.8 VS 6 volts
  168. TX Q?
  169. DX7 switch harness?
  170. JR crystal swapping
  171. DX7 TO XTR CABLE ?
  172. SOLDERING BRAIDED CONTROLS
  173. Mixing and matching radios/servos etc
  174. Do I need to run PCM with DS821 digital servos?
  175. Repeated receiver troubles on same plane?
  176. Channel Question
  177. 14mz
  178. Futaba 9CAP and H9 Ultra Stick 60..
  179. Unknown crystal
  180. Trainer cord, Spektrum to futaba 9C ??
  181. hitec eclipse 7
  182. Need info on how to power up an RC crane
  183. WANTED
  184. Fair Price For RC Gear?
  185. JR Tx
  186. delete
  187. Servo Twitching
  188. JR XP8103 and flaps
  189. JR XP8103 And Airplanes
  190. Spektrum Radio or equivelent in price? (CHOOSE!)
  191. Setting up flaps on gas airplane
  192. Mini Pulse XT Servos's ?
  193. Anyone flying the DX7 in a composite airframe?
  194. DSM Technology in Future Radios? (Predictions?)
  195. radio
  196. servo gear lockup
  197. Helicopter Radio vs Standard Radio
  198. Need Help!
  199. DX7 Binding help
  200. Is anyone using a Berg 7P Receiver in their Gas/Petrol plane?
  201. Futaba Radio and Hitech Simulator Cord
  202. Use of cheap peak detecting charger with DX7
  203. New series Hobbico servos = Hitec ??
  204. Defective Futaba sold by Tower Hobbies
  205. Mode 1 Help!!!! Eclipse 7, Hitec
  206. JR XP 6102
  207. Standard Servos Ball bearings vs No Bearings
  208. Compare Digital Servos to Standard
  209. Spectrum - Programming Help With Flaps
  210. Speed controller help
  211. Need help with building a R/C project
  212. Another DX7 BLANK SCREEN OF DEATH
  213. posted wrong area
  214. 9Z mixing/conditions - Help
  215. TX programming terminology - what it means??
  216. Low priced NiM charger
  217. NEW JR 8711 Digital
  218. DX7 and Reflex XTR simulator
  219. Blue Bird High Torque Servos
  220. Futaba vs JR
  221. transmiter ????
  222. Help needed on Radio basics?
  223. How to adjust servo?? Help- New Flyer
  224. Servo Tester
  225. Servo Torque Once More
  226. Servo power and multi batteries
  227. 10X and Li
  228. Nomadio FULL Range 2.4Ghz aircraft radio
  229. Why do Futabu servos Humm?
  230. graupner e 8 ssm 27 info
  231. Changing Band
  232. Futaba Super7
  233. eclipse 7 transmitter radio
  234. Servo help
  235. R5014 Antenna - Cut it or not???
  236. AR6000 for .40 Trainer
  237. DX-6 Flight Packs?
  238. High Quality Servos and ESC
  239. Good Quality Servos
  240. Anyone still use AM?
  241. What WE Would Want In a "SUPER" Spektrum!!!
  242. failsafe ?
  243. RX Single Conversion Crystal
  244. Couple Q's reg. servo types and Rx compatibility, and exponential.
  245. Programming questions
  246. lipo in transmiter
  247. G3 and 9CAP
  248. New Radio
  249. JR X388S
  250. EK Logictrol Super Pro
