PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 [41] 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Couple Q's reg. servo types and Rx compatibility, and exponential.
  2. Programming questions
  3. lipo in transmiter
  4. G3 and 9CAP
  5. New Radio
  6. JR X388S
  7. EK Logictrol Super Pro
  8. So - why do you put up with it?
  9. R5014 antenna cut to 4"?
  10. Throttle cut problems with Futaba T7CAP
  11. HS 55 Centering Problem
  12. Would you like a Spektrum manufacturer support forum?
  13. Hitec RX micro 05
  14. HFP-10 Programmer will not Reset 5645
  15. JR PCM 9X II
  16. XP8103 Headscratch
  17. Older TX and newer Rx
  18. Spektrum Binding Question
  19. duel conversion receiver question.
  20. Hitec Prism 7
  21. Get Rid of the Ratchet
  22. What is the advantage/difference???
  23. Datasafe software
  24. LCD screen protector
  25. Futaba 3305 Slop
  26. Controlling of Blue bird BMS RC servomotor BMS-660MG+HS urgent plz help
  27. metel servo arms for hitec mg servos
  28. Question for those with aeronatics knowledge
  29. DX7 Dual Aileron setup
  30. ask Danny at JR forum Post
  31. Converting Car Systems into Hovercraft Systems
  32. Spektrum DX7 Display Issues
  33. battery types?
  34. my big JR problem
  35. Hitec Buyer Beware
  36. Horizons take on programmable servos?
  37. jr 6102 issue
  38. spektrum servos
  39. Futaba MCR-4A RX W/Speed Control #Cells
  40. Which MINI servo for GP Reactor 46?
  41. Buddy box compatibility
  42. beginner servo problems
  43. Base Loaded Antenna
  44. Futaba Transmitter with a Hitech Reciever???
  45. Heavy stick springs for the Futaba 14MZ
  46. S-bec on JR reciever-v poor range
  47. JRSPORT RS6UL PROBLEMS
  48. number of High draw servos on regular reciever
  49. Futaba 9C guidance?!
  50. rx battery needs
  51. H E L P please
  52. Rx TX Servo and speed controller setup HEEELP lol
  53. DX7 and AR6100 interference with Stryker
  54. Robbe/Futaba FX-18 charging plug HELP please.....
  55. Crow with JR 7202-Still can't get it!
  56. MG995 Help
  57. Need help with aileron and flap settup
  58. programmer question
  59. Is it possible to invert the servo direction?
  60. Futaba r114f rec. song?
  61. heli antenna on plane?
  62. Servo Transplant
  63. Question about Digital Spread Spectrum
  64. Futaba 6exa setting up flaps
  65. Servo Overshoot
  66. Futaba receiver question.
  67. Multiplex and Aerofly
  68. DX7 Spektrum Issue!
  69. mixing analogue and digital servos
  70. Where to get 35mhz Crystals for Walkera PCM WK-701/RX-701?
  71. Futaba 9 channel TXs ... ???
  72. Tightwad wants digital coreless
  73. Digital servos
  74. potentiometer gone dead
  75. DX7 becomes a 9
  76. Changing a radio frequency
  77. Recorded Weeks flight
  78. what is the components inside a crystal?????
  79. Xmitter programming help needed....(please)
  80. x2610 range problem?
  81. Heli pilots please help
  82. Futaba servos with Spektrum DX7
  83. waypoint contact information ?
  84. Will this battery work with Hitec?
  85. need help with xf421ex tx
  86. TRICKLE CHARGE STATION
  87. RADIO FELL DOWN!!!! NOT WORKING PROPERLY AFTER THAT...
  88. Was I dreaming.....???
  89. Stripped servo gears...
  90. which trainer cord?
  91. Aluminum planes and radios?
  92. Thunder Power Lithium Polymer Receiver Packs
  93. futaba flight pack with airtornics transmitter?
  94. Graupner JR
  95. Whats wrong with these servos?
  96. 14MZ Battery info
  97. Transmiter that changes channels
  98. Futaba S9155 servos in the jet planes?
  99. Mix for onboard glow
  100. Converting 4ch tx to 6 chtx
  101. servo and esc amp draw?
  102. Spektrum DX7 or JR 7202
  103. Dx6 charger
  104. Broken Antenna
  105. Amplifier_Filter_Booster, I'm Confused
  106. *DX7* Free 2.4GHz DSM2 RXs
  107. How to install Rubber Duck on 9Z Tx ?
  108. servo for mini-t
  109. rc crystals
  110. dual elevator not synchronized
  111. Programming (c Super
  112. DX7 Aileron and Flap setup?
  113. Duel Elevator servo question.
  114. Telescopic Antenna of Futaba
  115. dx7 radio a good radio for the raptor 50 titan?
  116. 9c
  117. Spektrum DX-7 Won't Bind
  118. Do I Need a Power Box to Do this?
  119. Dual Receivers & Dual Batteries Instalation?
  120. [GEAR SET] Servo WAYPOINT W-068PB
  121. Is this 3IM
  122. JR ST125MG
  123. Futaba RF module powerup procedure
  124. PROGRAMMING ? 8103 for Twin Engines
  125. Which one do I use? The Isolator, Pow'r Bus Pro, or PowerExpander, or ???
  126. Is 6Volts rx bat'y OK on new Spektrum DX7??
  127. Heavy duty servos???
  128. 5955 centering and trim adjustment
  129. Metal Servo Arm Removal?
  130. UNABLE TO USE THE RADIO AS A JOYSTIC!! PLEASE HELP!!
  131. 1/4 scale servoes
  132. Best least expensive radio for electric 3D
  133. Hitec "Feather" RX...How Good Of Range Do You Get?
  134. Stepper controller interface to receiver?
  135. Cannon Tx Parts
  136. Advice on Servos 1.2/1.4 size plane
  137. I'm guessing about crystal swaping?
  138. XtremeLink Product Users
  139. Futaba 9zwc2
  140. Most distance?
  141. T-Rex450xl (HDE) with Dx6
  142. Spektrum DX3
  143. how many channels do i really need for a raptor 50
  144. question about futaba 7c and 9c
  145. Where are the BIG mfrs in the 2.4 GHZ market?
  146. NEED JR J229M OR 627X
  147. SR2000 help!!
  148. Cirrus Excell-7 PCM1024 modulation
  149. how high can I go ?
  150. 14MZ Battery Alarm
  151. First Computer Radio
  152. Twin Throttle help needed
  153. Buzzing digital servo
  154. 14MZ with Gyro problems
  155. The new Spektrum is now shipping!
  156. Hitec HFD-08RD V. supreme II s
  157. advice on radio choices
  158. rd8000
  159. Need a radio recommendation for my T-Rex at $200 budget
  160. Futaba vs. Airtronics vs. Hi Tec
  161. TP-FSM Futaba sync module
  162. Identify Futaba PCM encoder?
  163. Isolating Receivers and Batteries
  164. channel splitter
  165. ???Futaba TP-FSM Synthesized RF Module???
  166. Am i limited with the 8AUF?
  167. Glitching/interference with Futaba R168DF receiver
  168. Futaba DSM?
  169. NEED HELP PLEASE
  170. Difference between JR XS-3 & JR XS-6 ?
  171. 14MZ compatibility with JR Gyro-500A
  172. Request for Help with 9C & Gyro for Airplane
  173. Help w/ Futaba 9C and JR G500A Gyro
  174. e-flight s60 issues
  175. Hitec RCD 3500 S 8 channel Rx
  176. Futaba connectors and contacts and tooling source?
  177. HITEC HS 300 SERVOS
  178. XP2 HELP!!!
  179. How many channels
  180. Servos jittering/unable to center
  181. PCTx & Training Port for ground RC???
  182. Art-Tech and JR
  183. hitec optic 6 (are all bad?)
  184. CS-170 same as Hitec 5955 servo?
  185. Airtronics MX-3 2.4 GHz system
  186. Hitec 535 RX
  187. Spektrum TX blown fuses
  188. No TX Power indication
  189. Spektrum 2.4GHz 5-channel Transmitter from E-flite ( LP5DSM ): Any Details?
  190. Spektrum 2.4GHz DSM 5 channel radio sytem: $200 including Helicopter
  191. HPI SAVAGE TF-4 RADIO
  192. Radio Help Please
  193. FMA Quantum 6 channel receiver - Advice
  194. JR Servos Buzzing
  195. Attention JR 7202 owners!!!!!!!
  196. M11 newbie and need help PLEASE!
  197. Radio Protection
  198. Gas experience with Hitec
  199. Elevator Reverser Futaba EXA6S
  200. Radio Trouble - futaba 8u
  201. How to extend the range of motion of hs-55?
  202. Just won this on eBay, did I make a mistake?
  203. JR / Graupner transmitter crystals
  204. Need a picture of a 6EXA Right Gimbal please
  205. Futaba 3PM Tx - need rechargables
  206. USB Joystick as a controller?
  207. 9C - Anyone else seeing these problems?
  208. broken servo lugs
  209. 2 Spektrum lap timers to calculate acceleration
  210. Looking for the name of a company that made high-quality RC radios in the 80's
  211. Will a wireless camera effect my 72 mhz jr sport?
  212. Experiencing interference in 72 MHz in Nigeria; HELP
  213. Futaba 129 PCM recievers?
  214. which tx plase help
  215. I need help with my servo on my pro 2
  216. Servo load testing?
  217. Digital Servo Noise
  218. Mode 1 or mode 2...whats normal?
  219. Hitec HS 55 gear change
  220. Futaba 9ZH WC2 & HITEC spectra module
  221. Futaba T3PDF??
  222. Old AM radios
  223. 1.5 Volt AA Batteries in Tx???
  224. Searching for "Dynamco Magnetic Valves"
  225. Question about setting up the GY401/s9254 and the Futaba 9C.
  226. Dual expo on Futaba 8UAP?
  227. Futaba 6XAS trim tab lost its detents
  228. Futaba radio charger
  229. Fried Tx? HiTec Focus 3SS Reverse Battery Hookup
  230. 4EXA is haunted
  231. Older Futaba with Diode....
  232. elevator dual servo setup JR2610
  233. powerful servo & Y-harness set up on AM RX
  234. servo into 90degree opener?
  235. Futaba 12z
  236. Glitches with engine running - soft mounts?
  237. JR 8103 TX problem
  238. futaba skypoirt and batt?
  239. Walkera radios
  240. Servo recomendation
  241. fUTABA 9C MODE I TO 2 CHANGE
  242. Multiplex Evo 9 Battery
  243. Dual elevator on 10x HELP?
  244. HELP ! where do I connect the battery on RX
  245. Futaba 2.4Ghz Transmitter ETA
  246. Futaba 9C and Crow
  247. Servo problem-or what?
  248. Futaba T3PK & Receiver??
  249. Futaba 9ZHS WC2 -Dual Rate Exponential
  250. Transmitter PC interface
