PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 [42] 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Question about my brand new Futaba 9CHP batteries.
  2. understanding the ATV on my FP-T7UAF 7 channel futaba radio
  3. JR 7202 w/ 2 Gyros
  4. Futaba FP-T7FG/k question
  5. MPX COCKPIT SOFT FAILED
  6. Hitec Eclipse 7 vs JR 7202
  7. JR 10S Manual
  8. Are they doing away with 72mhz rx's???
  9. Tower Reciever Crystal ina Futaba Reciever
  10. Another radio "hit" question
  11. Berg 7P rx ?
  12. Updating Older Futaba with G Series Connecters ???
  13. Multiple radio hits in club caused by a near-by construction site?
  14. Servo: speed, torque, and application
  15. sizing of servos
  16. posted in the wrong place
  17. , Futaba 12Z or JR 10x
  18. dual receiver redundancy
  19. Dynam FM 4 NE-KO 4 with Simulator
  20. Transmitter questions
  21. Berg 7P Frame Rate
  22. Xs3 Pro Spektrum
  23. TX frequency measuring/tuning ?
  24. flaps on xp8103 heli
  25. R/C Racer's Transmitter Suggestions Needed
  26. Shopping for a Transmitter
  27. Tx suggestion for Trex 450SE
  28. dual receiver redundancy
  29. Modulation in FM?
  30. Tower vs. futaba 6 channel radio
  31. rx antenna wire
  32. Fast Cash
  33. HS-605BB gone bad??
  34. 1991 all over again-only worse
  35. TowerPro MG945 wire configuration?
  36. Nylon gears for Futaba 9402
  37. Spektrum DX-7
  38. Anounced JR 12X
  39. Futaba FC28 users Yahoo Group
  40. Spectrum DX-7 ?
  41. Rx Tx Compatibility
  42. Futaba or JR ???
  43. Kyosho Servo Inferno ST vs Inferno ST US Sport
  44. Duralite 6v regulator
  45. Knobs for Futaba 6 Channel flap control
  46. multiplex ,futaba, JR
  47. transmitter, receiver?? where is the problem {Need Help}
  48. New Longer range Spektrum for air coming?
  49. graupner - futaba compatibility
  50. KoPropo servo on 5 cells
  51. Futaba FC-28 V2 help needed badly!!!
  52. recommended servos for a 26cc size plane ?
  53. mystery reciever
  54. How close can transmitters be
  55. Rudder and gyro problem
  56. Jitters with a cirrus reciever and Hitech Servo's
  57. servo flutter
  58. 3pm 3pk
  59. Problem free tx? do they exsist?
  60. Where to go for RX crystal xchange?
  61. KARBONITE GEARS FOR GASSER?
  62. Futaba's new Top End Radio $3K... WOW
  63. Strange Problem with my Futaba 9z??
  64. Park Zone Typhoon RX swap
  65. Min servo torque for .25 aircraft?
  66. Transmitter Stands
  67. Final word on E-flite S75 servos?
  68. "home-made" servo reverser?
  69. Redundant Battery Pack
  70. DX6 LiPo
  71. Noob question-- does the Hitec Micro 05S really have 5 channels?
  72. tx antenna
  73. Need to Reverse my JR-125 servo
  74. Servo Compatability
  75. Any Pro bono Futaba repair experts out there?
  76. FM - PCM I Don't Understand
  77. Futaba 7C CAP
  78. What happened to 8?
  79. pls remove
  80. DIGTAL VS ANALOG servos
  81. futaba 3110 servo breakage
  82. Multiplex EVO 12
  83. Futaba 9CAP Broken Switch
  84. DS821
  85. RX antennae shortened
  86. SANWA RD6000 super comunication problem with reciever choice
  87. Elevon Programming on a Futaba 7C
  88. benefits of synthesized vs FM radios
  89. Failsafe?
  90. Futaba Digitals
  91. Hitec Digital Servo (HS-6965)
  92. Help, glitches on right half servos when rudder is input !!
  93. Changing TX Crystals?
  94. JR 7202
  95. futaba 9c super question
  96. AM / FM Transmitter question
  97. Multiplex Cockpit SX Should I buy?
  98. digital servo and batteries
  99. 10 to 15 foot range problem
  100. Returning digital servos to default
  101. Fs8
  102. 5 cells unregulated
  103. Reversing Futaba 3305 Servo
  104. spektrum dx3 biding??
  105. Use JR Radio with Walkera Dragonfly
  106. SUCH BAD SERVOS OF JR Frustating
  107. dirty receiver with short range
  108. pcm10x jr
  109. duel mode setting z12
  110. Cirrus servo's....at the risk of causing a flame war...are they any good?
  111. Rx reco for Futaba Attack 4ch 35mhz AM Tx
  112. digital vs. analog servos??
  113. Hitec digital servos -- very unexpected test data
  114. 14MZ channel changing question.
  115. 12MZ versus 14MZ
  116. Request about Tower Pro 5010 Servo!
  117. 2 questions
  118. Futaba 9C programming question
  119. DX6 Cuts throttle at half stick
  120. 9cap 2 times stronger signal than 14z
  121. noiseless or quiet servos
  122. Servo question
  123. aluminum servo horns
  124. RD 8000 Heli Flight Modes for Airplane Use
  125. BRAND NAME VS. "GENERIC" SERVOS
  126. What new radio to buy
  127. radios and servos ??????
  128. RD6000 sport ERR2
  129. RD6000 ERR2
  130. Futaba radio w/JR matchbox & JR servos
  131. Campac
  132. HiTec Eclipse radio setup...HELP
  133. 7.4 v servo
  134. Help - Futaba 2PL Tx/Rx won't turn on with brand new Ni-MH batteries!
  135. brand of reseivers and servos.. please help
  136. Hitec HS645MG..or Futaba S3305 servos, whats your experience with each?
  137. Futaba 9C
  138. Crystals
  139. Are Futaba 3305s safe for 1/4 scale planes and helis?
  140. help with picking crystals and servos
  141. dual elevator servos
  142. JR DS537 Digital Servos
  143. Wiggling Futaba S3004
  144. Trainer Box Question - Futaba
  145. Hitec/Futaba
  146. Two Way RC pair?
  147. Hitec HS-125MG Wing Servo
  148. Frequency change on T6XAS?
  149. Metz Mecatron - Antique Radio
  150. Rudder servo -- standard or high-torque?
  151. C19 FM35S Aerial length??
  152. hitec optic 6/ hobby zone super cub
  153. does this radio can be use for plane and heli?
  154. CCPM Dumb question
  155. Hitec Eclipse 7 Elevon Mixing endpoints
  156. Blue Bird Servos- Erratic!
  157. FUTABA S3001s and S3004s
  158. Futaba 3pm opinions?
  159. Futaba sythisized RX, TX
  160. 8uaps futaba set up
  161. Loss of signal from three feet!
  162. 9c acro butterfly mix
  163. where is futaba factory?
  164. Robotics Resources
  165. Thunder Tiger gyro help
  166. Throttle trim $ Futaba 7C
  167. Servo Geartrain Lash
  168. Lithium-ion voltage (8v) into JR reciever
  169. Cirrus servo
  170. on board engine starter
  171. Futaba T6EXA
  172. trainer/simulator radio
  173. When is 24 kg not 24 kg whenits/a HSR-5995TG
  174. Integy servos, anyone use them?
  175. Spectrum DX6 Tx spring tension
  176. Transmitter range with antenna collapsed ?
  177. Futaba 9C or Multiplex Evo 7 ?
  178. Futaba 9CHP Super with GWS SS = no throttle
  179. Futaba 9Z 10th channel hack... potential 12Z extra 2 channel hack?
  180. HiTec servo problem
  181. High band or low band?
  182. 4Channle with 5 sevro !!! XD ~
  183. Futaba 9C Knife-Edge Mix
  184. Airtronics nicad battery, but no charger
  185. fromeco charger
  186. Crystals in Tx Module for Optic 6
  187. does the gauge matter on antenas?
  188. Narrow Band AM Modulation
  189. How Does a Servo Work?
  190. where to get 35mhz 9chps??
  191. 14MZ/THIS IS A GOOD ONE!!HOW THEY FORCE US TO BUT FROM THEM!
  192. Split Elevators with dual servos
  193. futaba tx antenna question
  194. Futaba transmitter/receiver compatability
  195. centering iqque with hitec5945
  196. CASTLE CREATIONS
  197. 3pk Synthisised Reciever?
  198. Futaba 9Z lithium battery, how to replace?
  199. Which New bolt for a whip antenna.
  200. Parkzone Focke Wulf receiver
  201. would you guys say this is a futaba transmitter?
  202. Servo question regarding compatibility
  203. Using rf filter rings
  204. old post please delete me
  205. What Mini's on DPM Ultimate Ailerons?
  206. ? on interference while range checking
  207. Airtronics MX3S
  208. HS81 equivalent with 3D arms?
  209. Servo question
  210. Someone Help!
  211. Futaba Synthesized Rx Question
  212. futaba 7chp, skysport 6a, trainer compatability
  213. Thottle Fail Safe (info please)
  214. Beginner needs help.
  215. Need gyro for airplane!!
  216. JR radio problem, Horizon's 'help'
  217. 14MZ reciever compatibility with a base loaded antenne?
  218. JR Racing XS3, M8, etc? Please help.
  219. Hitec to Futaba??
  220. Price on Hitecs
  221. XtremeLink™ - 2.4GHz for Futaba, JR, and Hitec radios
  222. what transmitters will do this?:
  223. Hitec-Futaba compatability
  224. Anyone ever have a servo reverse itself?
  225. Spektrum DX2 problems?
  226. A short story
  227. Nomadio V2 any good ?????
  228. 6c or 7c or 9c somebody enlighten me
  229. FMA Co-pilot
  230. Compatibility of JR Sport and JR Propo
  231. Servo question
  232. Align Head Lock Gyro RCE-500X
  233. M8 Battery Help
  234. Radio TX / RX Servo compatibility
  235. I was shot down today.....
  236. JR 537's with 6volt
  237. Wanted ultra light weight Y-Lead
  238. need help jr7202 vs 9c super
  239. Heli or Plane
  240. need help jr7202 vs 9c super
  241. Futaba vs. JR for my 2nd Tx
  242. Futaba Square Micro Plug
  243. New radio system
  244. 9CAP Elevator Problem
  245. JR Service- PRAISE!!!
  246. futaba servo
  247. Nomadio binding issues?
  248. Replacing antenna on hitec reciever, please help
  249. NEW 360° Proportional Servo!
  250. Buzzing servos
