PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 [43] 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. 9CAP Elevator Problem
  2. JR Service- PRAISE!!!
  3. futaba servo
  4. Nomadio binding issues?
  5. Replacing antenna on hitec reciever, please help
  6. NEW 360° Proportional Servo!
  7. Buzzing servos
  8. New to 4ch r/c! Need help with my flight pack!!!
  9. When do I need to use a voltage regulator?
  10. Futaba 8U repair question
  11. 6EXH vs 7C (for heli)
  12. JR XP783 problem
  13. switches
  14. trim offset mode on JR 8103
  15. Frequency scanner?
  16. JR XP9303 field charging
  17. NEED futaba ESC HELP
  18. Strange futaba reciever
  19. Older Airtronics servo need specs
  20. Use of Flexable Transmitter Antenna
  21. E-flite S75 servos
  22. JR 125s skipping
  23. 9cap programing this ever happen to you?
  24. Can I use a Rx crystal on a Transmitter?
  25. transferring model information
  26. ailavator mixing using programmable mixes?
  27. servo twitch when turned on then nothing else
  28. mode 1 to mode 2 conversion
  29. What's the difference between the SPEKTRUM DX2 AND DX3???
  30. Hitec Fusion 9 receiver...
  31. GWS Receivers
  32. Futaba 6xea Battery?
  33. Swapping Rx in walkera 36
  34. Single servo glitch with engine running
  35. Transmitter Battery Question
  36. 14z/12z spare battery
  37. Life expectancy of receiver
  38. short rx chip or normal
  39. Tx and Rx compatibilty
  40. JR XR3i TX and RX different brands?
  41. JR PCM programming
  42. Variable Flap Positions
  43. Servos to use with Multiplex Radio
  44. GWS Nano Compatable Servo Arms
  45. TX Swap
  46. Spektrum DX6 problems
  47. JR 6102 question
  48. HELP... Need Transmitter Type (Airtronics)
  49. Sullivan smoke pump glitching - help
  50. servos twitching????/??
  51. micro receiver with a jr xs3?
  52. Charging Futaba 6EXA High Capacity Tx batteries
  53. Digital servos?
  54. low voltage in futaba flight pack?
  55. Futaba 9CAFS FM Super, good radio?
  56. New Spektrum 3PK HSR Module
  57. NiMh battery use
  58. Need M8 Help
  59. Servo Extensions
  60. ok, getting confused...which Radio??
  61. Buddy boxing different brands
  62. airtronics quantum 8p
  63. PCM rcvr versus FM x-ter
  64. futaba 5101 need spec info
  65. CONNECTING THE RADIO TO A PC. ANYONE HELP PLEASE!!
  66. Berg Micro RX + GWS Xtal -- Not a Marriage.
  67. Digital Servo Buzz
  68. heli vs. aircraft 7ch radio difference
  69. aitronics to airtronics Z, failed?
  70. Futaba FF9 Servo upgrades from S3001's
  71. VEX robotics controller and RC reciever?
  72. Trouble installing Radio on computer WInXP
  73. Hitec Synthesized receiver vs standard
  74. Problem with JR 790 PCM Receiver ??
  75. Synthesized Receivers available
  76. mid price level radio to purchase
  77. JR XP783 Manual
  78. T6XAS for heli?
  79. JR 9303 or Futaba 9CAPS... need some advice here!!
  80. JR reciever+futaba servos+speed controller
  81. JR9303 master 6102 Slave, Trainer Setup
  82. Tower Hobbies 6XM
  83. How to slow a servo on a 9cap super?
  84. Frequency Conflict Concerns
  85. Futaba FP-T8SSA-P antenna wire loose
  86. Spektrum Dx6 range
  87. Old Airtronics servos, need new Rx
  88. Li-Ion versus Li-Po on receviers and ignitions
  89. futaba
  90. Hitec module, Futaba radio, Airtronics receiver
  91. HELP!! need info for servo control
  92. *JR & Hitec Compatability*
  93. Universal servo plug - Best way to grip/unplug?
  94. 6EXAS Flaperon
  95. *RF Or EI Problems*
  96. Good starter Tx for Heli
  97. Synt module and hitec receiver?
  98. JR 8103 transmitter programming
  99. Spektrum cuts off at 30-40 ft
  100. I am shocked! Lost my 33% Edge because of the 9C receiver...
  101. R168DF glitch problem
  102. Airtronics VG6DR Vanguard
  103. What crystals for parkzone radios
  104. Scratched 12z display
  105. 9C Module Question - 3 hours left on
  106. Strange radio Interference on Giles Wildhare
  107. do i need a 75mhz transmitter for a 75mhz reciever?
  108. Multiplex help... really technical
  109. Changing to Futaba 9C super
  110. futaba 3305 servo, not with NiMH???
  111. Antenna Maintenance
  112. In what way is the Futaba S3151 better than the S3003?
  113. antenas
  114. Signal Interference
  115. Futaba 6XA TX antenna mount snapped off
  116. Spektrum
  117. how do i get my split elevators to move in the same direction?
  118. HELP! TX not responding
  119. Futaba Dual Conversion Crystal or not?
  120. 9CAPS Output
  121. How do you run 2 servos for elevator JR 6102?
  122. List of decent throttle servos?
  123. Some direction please?
  124. changing TX crystal
  125. t8UHF? Which Reciever?
  126. Receiver Channel Stops working
  127. Futaba 9CAP HELP
  128. Futaba 7CAP TX RX compatility
  129. JR synthesizer module, anyone using it?
  130. Dual Elevator servo setup
  131. antenna for my futaba
  132. JR821 servo's...anyone??
  133. Futaba radio frequences
  134. Sullivan SkyWriter smoke system set up on a 9CAPS
  135. Futaba FF7 or FF9?
  136. what does ATV do on a FOCUS4 transmitter
  137. Futaba 9z saving freq and ppm-pcm settings
  138. Tower Hobbies Radios
  139. futaba 7c
  140. Need help with a 4 aileron set-up
  141. futaba questions
  142. Batteries America - Heads up!
  143. Which Brand - Futaba,HiTech, or JR
  144. Hangar 9 Twist, digital servo upgrade
  145. Best Voltage Regulator ?
  146. PC to R/C Interface
  147. Rubber Ducky - range check
  148. 9g Micro Servo Suggestions
  149. Torque requirements for 1/4 Cap 232
  150. Is there such thing as a super slow servo?
  151. Radios
  152. y-harness problems?
  153. Biplane wires and radio problems
  154. New vs Old Airtronics wiring
  155. pcm
  156. 12Z internals?
  157. Adjacent Channel Interference
  158. JR XF631 = Spectrum DX6
  159. 10 X Programming Question
  160. 4.8 Volt or 6.0 Volt???
  161. JR 10 X screen blank OH nO ????
  162. Servo Selection
  163. Spektrum DX2 not for bashing?
  164. single vs. dual conversion receivers
  165. Rechargeable batts in rx?
  166. Severe Radio Hits
  167. Simple Reciever Question
  168. 12Z internals
  169. AUTOPILOT HAL2100 / PA1
  170. servo reverse
  171. Performance of Micro Receivers?
  172. Transmitter charging question
  173. zoom/telebee gyro mounting confusion
  174. Slow Servo?
  175. Futaba R168DF FM DC Receiver
  176. Did I hose myself?
  177. Futaba Receiver Servos
  178. Any difference in a Heli or Plane transmitter
  179. JR Radio vs 14MZ
  180. Servo e reciver for ZIROLI STUKA
  181. batteries
  182. jr 662 broken antenna tip
  183. Cooked my Futaba Transmitter Today
  184. JR R770 Reciever - Says 72Mhz on bag, 53Mhz on Receiver!! TWICE!
  185. Trying to get Hitec Fusion 9 Rx NO TOWER RANT
  186. New Futaba 14MZ and Hitec HS5955TG servos?
  187. Is it possible to reprogram HiTec-Servos for 180°-operation???
  188. Smiley Antenna for 35Mhz?
  189. Airtronics Vanguard with Tower Pro BMC
  190. Problem with new JR xf421ex transmitter
  191. signal booster?
  192. new radio
  193. Expert radio gear??
  194. how many channels for heli+ governor?
  195. Transmitter changes from PPM to PCM by itself
  196. Jr 8103 and DA100 trottle curve help
  197. Airtronics Servos
  198. HS 55 Servo for Gas Throttle
  199. JR radio -- setting up elevons XF421 or xp662
  200. Futaba 3305's and Nickle Metal Batteries
  201. Programing Hitec Eclispe with Sullivan Smoke Pump
  202. jr radio charge conversion?
  203. Basic Radio Question
  204. Newbie with Futaba 6Ch???
  205. Will this work? Nexstar?
  206. Profi-rom for Graupner MC24 - Where to get it?
  207. 9C super Tx only?
  208. 9CAP Super Not Transmitting
  209. Multiplex EVO 9 for Sport/Pattern?
  210. Mode 3 Radio?
  211. Hitec Electron 6 Receiver Antenna Cut
  212. Futaba MSA 10 Matchbox
  213. Spektrum DX6 - Can the Gear & AUX1/Flap switches be converted to pots?
  214. NER-910xz Circus Hobby ABC&W 10 channel JR?
  215. Optic 6 with Module question
  216. Help with a Dual Reciever Set Up
  217. Good beginner computer radio reference manual?
  218. Servo Wobble w/Extension Lead
  219. servo chatter with Evo 12
  220. diy esc for brushless
  221. Did I kill my Retract servos?
  222. Is my transmitter dead?
  223. FM in car transmitter for an MP3 player.
  224. Hitec RECEIVER crystal question
  225. Very strange problem
  226. 27MHZ Antennae Legnth
  227. need help installing the spektrum radio on my revo
  228. Servo Repair - positioner?
  229. Why is this reciever so cheap?
  230. Hitec Servo Programmer - the only one?
  231. PCM Crystals
  232. 9c Programming with 7 channel receiver
  233. Futaba 7C channel selection
  234. Where to buy connectors, pins, wiring for making servo extensions?
  235. *Good Radio For Gasser*
  236. Throw problem on dual flap servos
  237. JR DSC cable
  238. JR 8103 Programming
  239. antenna routing
  240. Cutoff Switch Question
  241. *RF Interferance*
  242. Anyone know about "3" EMI?
  243. Hitec Digital Servos
  244. Futaba Servo Leads into Powerbox ?
  245. Reversed Servo?
  246. Futaba 12Z only chat out there???
  247. RX/TX problems? JR Propo Python, HPI SR4.
  248. JR Sport
  249. Hitec support?
  250. JR transmitter / Hitec Receiver compatible?
