PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 [44] 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Airtronics to JR trainer cord?
  2. Old Futaba AM - What is salvageable?
  3. Interference form Remote Glow Ignitor
  4. RX Amp Draw
  5. JR Propo 27 Mghz AM Crystal ??
  6. Tower Hobbies Receiver Repair
  7. Gyro mounting...
  8. Crystal compatibility
  9. throttle stick
  10. Car Rx for Futaba 9CAP..... which one?
  11. Help! Servos move by themselves!
  12. N/M fixed
  13. Are these crystals compatible?
  14. Jr max 66
  15. crow braking on 9cap
  16. .....
  17. SAFETY CONNECTORS FOR SERVO LEADS
  18. TowerPro MG995
  19. Thrtl Rate % on Spektrum
  20. Servos for Cap 232 35 %
  21. Please help me! I'm going crazy
  22. Comparing Digital Servos to Analog Servos
  23. Hitec Eclipse 7
  24. Are Venom Battery packs and good?
  25. Voltage regulator heat
  26. 9C Programing questions
  27. hitec hs 81 as retract servo???
  28. moew power (volts) to my servo
  29. TowerPro MG995
  30. 7CAP Trainer Function
  31. Glitching has me confused
  32. eclipse 7 terrible range
  33. SERVO TORQUE
  34. 9cap channel resolution
  35. Travel Adj and sub trim Problem
  36. Control problems - jitters
  37. extra receiver for an xr2i radio?
  38. How close is to close for tx's on the same channel
  39. Hitec Micro 05s vrs. FMS Direct M5v2 Sub Micro Receiver
  40. Channel 5 End Point Controller For Simpler Radios
  41. Single vs. Dual conversion receivers?
  42. AM R/C Aircraft gear...
  43. CIRRUS 850 XLC TX QUESTION
  44. Glitches?
  45. Revolution whip antenna anyone
  46. How much juice do I need??
  47. Digital Servos
  48. Rubber Ducky tx antennas okay?
  49. Keeping radio gear airworthy.
  50. Futaba and Graupner?
  51. Servo Malfunction
  52. Slow responding servoes
  53. Need HELP /// A.S.A.P.
  54. spektrum
  55. Airtronics VG6000 - Flaperons Reversed
  56. Shorty Rx Antenna?
  57. 8103 Flap Programming???
  58. Futaba 8uaps and split elevator
  59. 8 channel
  60. HS 225Mg
  61. hitec HPD-07RH QPCM reciever question
  62. Graupner/JR MX22 Tx buddy lead
  63. 4.8, 2700mAh . . . and i can charge it how?
  64. new tx not working with old rx
  65. basic tx/rx terminology?
  66. Airtronic transmiter
  67. RD8000: shifting transmit signal +/-
  68. Convert Inch Throw to Degrees Spreadsheet
  69. "jr sport" gear. . . ok to use or not?
  70. 3 Channel Radio in the 100 Dollar range
  71. Receiver with speed control
  72. Fut S9252 Servos with Powerbox ?
  73. Y Harness Fabrication/ Custom WIRING
  74. different versions of 10x ?
  75. stylus problem
  76. futaba 7cap
  77. Futaba Receiver Power
  78. Low Range
  79. In what order should dual rates and end points be set up?
  80. Radio Problems
  81. 9cap - 9cap super
  82. Digital servo resolution is horrible.
  83. Spektrum DX3 radio system need input please!
  84. Futaba 14mz
  85. A compatibility question.Need advice
  86. Futaba 9Z expert Question?
  87. Using Lipo For My Futaba 9C
  88. FMA Digital Servos
  89. Radio or Servos ??? Chicken or egg question
  90. JR servos
  91. New Radio
  92. high torque servo?
  93. hitec radio/reciever issues
  94. Anyone got a part number for an Airtronics to JR adapter?
  95. 9VAP followers
  96. 14MZ Mixing channels when I don't want it!
  97. throttle servo setup
  98. What do you think about the specktrum DX2
  99. JR 9303 and E-flight Blade CP
  100. JR 8611A In A Quarter Scale Plane = Voided Warranty?
  101. Spektrum issues
  102. 9c quick charge problem
  103. MORE THAN GLITCHING IS...
  104. Retract Servo Conversion
  105. Range issues
  106. Socket Head Servo Screws
  107. HAMS and FMA
  108. IPD vs PCM
  109. JR 8103/ Hitec programmer
  110. Upgraded servos for hpi mt2?
  111. Servos
  112. What is " stalled servo"?
  113. Multiplex Cockpit SX
  114. Replacing sticks on Futaba 9C
  115. More JR r700 glitching!
  116. using buddy/trainer lead
  117. Hitec Eclipse 7 Question
  118. Question
  119. Hitec HFS-05MS Good or Bad?
  120. Heli/Airplane Radios
  121. Ace Micro Pro 810 receiver
  122. 35 / 36 mHz Compatibility?
  123. time for a new remote control
  124. airtronics mx-3s problem
  125. eclipse 7 HELP
  126. FMA SERVO QUESTION!!
  127. servo power..
  128. Venom Smart Temp
  129. I'm looking for a proportional 180° servo
  130. Hitec Electron Receiver
  131. LOOKING FOR LONG TX STRAPS
  132. Please help me find the glitch Gremlin!
  133. Airtronics servo question
  134. Multiplex Cockpit Tx & Receiver Combo $100!
  135. Servo centering on 7C possible?
  136. 27 mhz question...
  137. Best non PCM receiver to use with gas plane
  138. Hitec servo fried my futaba Rx?
  139. Futaba 6EXA faulty stick !!
  140. need to reverse a channel ,need help
  141. In a Bind with Spektrum?
  142. How many transmiters?
  143. 5955Tgs and 7.4 volts
  144. Mid to high end controller, reciever for racing
  145. Radio Help
  146. Futaba 9CAPS super VS JR 9303 Air Synthesized Radio
  147. What does the upgrade in recievers buy me?
  148. new receiver technology!!!
  149. Flaps on Channels 6,7 in Futapa 8 UAPS?
  150. Airtronics MX3 in Australia?
  151. New 9-channel PCM radio from China
  152. 14MZ updates
  153. Who makes a better servo?
  154. JR XP 8103 - THROTTLE LOCK?
  155. ??Can you answer this one??
  156. 6XA battery level error
  157. Multiple servo problems
  158. Futaba Range Test
  159. Hitec Spectra Modules
  160. 14MZ and Schulze receivers
  161. My receiver wire got cut, what now?
  162. How do i setup a mix for knife edge?
  163. HiTec "Spectrum" Style Radio?
  164. Altering the throttle range on Spektrum MX6
  165. Channel 8 shares same channel as battery?
  166. Difference Between JR and Futaba Servo horn shaft
  167. Metal servo horns
  168. Extending Trim Range
  169. 14MZ or 12Z?
  170. S3101 Operation
  171. 9c and hyperion hp-dsp*6-fs compatability
  172. Are JR digi servos cross compatible with Futaba Rx's?
  173. MX 22 radio
  174. Individual Power for each servo?
  175. Kyosho Radio - Keep it or update it?
  176. The importance of setting sevos for max travel
  177. Receiver foa a old T6NHP Fuataba radio
  178. .
  179. Model Airplane News issue with article on vintage reed relay RC
  180. Smiley Antenna with 9CHS
  181. Need help w/ Airtronics info
  182. Futaba Recievers
  183. Pin out on Hitec buddy cable
  184. Carl Goldberg Models R/C for the military
  185. Battyer care guide
  186. Servos in Firebird XL
  187. Tech question about crystals
  188. Airtronics, JR, Futaba?
  189. General Questions about Hitec HPD-07 PCM Reciever
  190. SERIOUS problems with hitec optic 6
  191. Flaperons and Airtronics VG6000
  192. someone changed my Tx crystals
  193. JR 4721/2721 Question...
  194. reciever recieving some minor glitching
  195. HT625MG jitters with a Futaba 127DF reciever
  196. Metal gear servos for $24.99
  197. Smiley antenna range check
  198. Throttle/Brake Trigger Modification
  199. G3 rx antenna
  200. Need help finding the Web Address for KO-PROPO
  201. How do I mix the pitch coupling out of my twist.
  202. At what point HD wire & switches?
  203. 512 or 1024
  204. JR 9303 or 10X
  205. Graupner radios: negative or positive shift?
  206. connecter kits
  207. Airtronics VG6000 End Point Adjustment
  208. sanwa/airtronics RD 6000
  209. Reversing servos for flaps
  210. airtronics 94631 servo... torque?
  211. Futaba 9CHP Heli Q?
  212. 9ZAP PROGRAMING MADE SIMPLE????
  213. futaba radio i bought
  214. Controlling your model via computer
  215. CamPac transfer data
  216. Battery for 5475 digis
  217. FUTAB 7CAF
  218. .
  219. Futaba 8U Transmitter for Airplane
  220. Need Aristocraft/Hi-Tec servo connectors
  221. Escapement,escarpment???worth anything?pics
  222. Hacking the 14MZ MDL files
  223. optic 6 with no rudder
  224. Retract servo
  225. Radio Interference.
  226. Futaba 6EX Tx with Simulator
  227. 9303 vs 8103
  228. Need advice on mid-high end computer radio
  229. Need new Futaba TX only Vendors?
  230. Hitec Eclipse 7 Tx
  231. Help 9Z Throttle
  232. Silicon coated twisted servo wire
  233. Question about Berg instillation.
  234. How many amps do these servos use?
  235. how to check rx crystal
  236. Strange happenings with radio
  237. RD8000 not allowing charging?
  238. Selecting a 6 CH radio, Which one??
  239. Polk's Tracker3 vs Hitec Optic 6
  240. Boosting your transmitter's signal range
  241. Best 10X Battery
  242. Cirrus MRX-6 POS
  243. FP-6FG???
  244. What is the reasonable thing to do in this case?
  245. FX-40 Robbe Futaba User Guide
  246. Internet controlled motor?
  247. B-8 Micro Servo Question
  248. New Gimble for JR F400 Tx?!?!?
  249. BERG MICRO RECEIVER,If dont choose to program
  250. Interference of camera by motor
