PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 [45] 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. JR NES 4005 servo torque
  2. Futaba R146iP Crystal
  3. FF9. chrome finish flaking off
  4. Help on schematic
  5. 9C Synth Module Compatibility
  6. Micro RX's and cell phone towers?
  7. HYDRO FOAM TRANSMITTER
  8. Hitec eclipse heli setup
  9. MOD2 vs MOD1
  10. Battery packs won't work..
  11. Futaba 6 EXA help
  12. Suppressor Filters on Ailerons...Why??
  13. Futaba Servo's work with a JR Transmitter??
  14. Hitech 7 channel HFD-08RD and JR 6102
  15. Servo Centering
  16. Interesting Old Radio
  17. Need a JR 537 or futaba servo??
  18. Looking for good/cheapish RX and a few other things
  19. Spektrum DX6 PROBLEM...
  20. Leaving An Extension Plugged In to Unused Channel
  21. Transmitter Crystal for Dummies: Question
  22. 14mz loading pictures help.
  23. Futaba Transmitter Battery Advice
  24. 8U "stop flying" Voltage?
  25. LI-Po for Transmitters
  26. Tower 6 XM, Something I'm missing here?
  27. Radio Advice
  28. Futaba Flyers Club
  29. Futaba 7C and Li-po battery
  30. Futaba 14Mz Upgrade file
  31. Nomadio Sensor
  32. Multiplex 9 ch Synth receiver problem
  33. Help replacing a switch on Futaba Skyport 6A
  34. Phil Kraft's passing
  35. 27Mhz versus 75Mhz. Which is better?
  36. single conversion rx
  37. Glitch Problem??? HELP PLEASE!!!
  38. Need help selecting a computer radio
  39. Futaba 9252 digital servo problem
  40. Did you like your JR PCM 10 "z" ????
  41. Futaba transmitter buying advice
  42. Futaba S38 Servo
  43. Futaba 9001 vs. 3152 Question
  44. Crystal question
  45. Radio Glitch??
  46. JR 9303 Radio Question
  47. raido self deprograming
  48. receiver sensitivity to gas engine ignition noise
  49. Transmitter controlled RX switch
  50. multiplex radio
  51. Mutiplex Digital servos
  52. PCM9X to 9XII Upgrade for UK Users
  53. Broken aerial
  54. Graupner MX22
  55. Hitec 635HB Question
  56. 14MZHelp with AFR
  57. NIMH and Futaba S3305
  58. Synth. rx required with synth. tx?
  59. Futaba Attack?
  60. 6EXA buddy box
  61. Special Rx needed??
  62. Servo wire Crimping tool and connetors
  63. Dual throttle control (part 2)
  64. CO PILOT GYRO
  65. HELP WANTED FOR A SERVO
  66. Any problems with Hitec hs 475hb servos?
  67. Futaba 7C vs. Hitec Optic 6
  68. Antenna mounting inside fuselage: safe?
  69. Rubber Duck Tx Antenna for 7Cap
  70. Epoxied Buttons
  71. 9303 Programing question
  72. Futaba should be ashamed...
  73. How to update your 14mz, official update.
  74. Any one using the new 12z G3 Rec
  75. Spektrum DX2 vs DX3
  76. Problems w/ low Freqs for micro reciever?
  77. Updated 14mz with shift select?
  78. servo Glitching
  79. PCM servos glitching
  80. Can you change tour transmitter channle
  81. Spektrum reciever antenna failure
  82. Info on Hitec Prism 7
  83. 14MZ Software release question
  84. compatibility
  85. Replacement for 10x coming??
  86. Servo jitters on PCM??
  87. how many amps do high torgue
  88. how many amps do hi-torque servos
  89. Futaba T6XA or Spektrum Dx6?
  90. GWS receiver on low channels
  91. DAD (Interceptor 2000) Reciever crystal?
  92. Servo Glitching
  93. Hobby Services vs Radio South
  94. Spektrum DX6 throttle question
  95. So 5 Cell Nicad Didn't Kill my 149DP?
  96. New CAMPac Editor Program
  97. receivers that have been in a wreck; opinions
  98. 9c flap aileron mix
  99. Transmitter trays
  100. Perplexing Servo Jitters !!!!!!
  101. Futaba 3PJ question.... Crystal/module help
  102. futaba 7c + ultra stick, asking too much?
  103. SCALECRAFT/POLK TRACKER III RADIO
  104. Manual for JR remote
  105. Futaba S3010 servos and battery compatibility
  106. Radio Compatibility
  107. Radio compatibility
  108. Digitals vs. Coreless Analogs
  109. Dual Throttle control
  110. remote start for nitro engins
  111. radio interfenece??????????
  112. do you think this is a good price for a spektrum reciever on ebay?
  113. JR-extortion
  114. ALL IN ONE RX - WOW!!!!!
  115. microcontroller-actuated servo, number of steps / precision?
  116. Missing buddy box lever: Futaba Skyport
  117. 75 mhz Futaba FM rx antenna
  118. Futaba 12 ZAP manual on line
  119. Crash protection for receiver & battery pack ?
  120. JR Controler---Airtronics receiver
  121. Hidden Servo Linkages
  122. Futaba TX where the best price to buy?
  123. Spektrum dx3 alternatives?
  124. Servo buy?
  125. Futaba R127DF receiver Discontinued
  126. ? on sero choice for my revo(race specs)
  127. JR servo Z connector
  128. Hobbico receiver compatibility: futaba
  129. 1/4 scale servo wire gauge?
  130. Measuring Servo Torque?
  131. 14mz stick calibration?
  132. confused by Futaba Reciever Choices.
  133. Transmitter tray
  134. Male/Female Pigtails
  135. my reciever doesnt work
  136. WHERE SHOULD MY 400$ GO?? ITS MY HARD EARNED MONEY AFTER ALL!!
  137. Servo Reverser Question. Please Help!
  138. What to switch?
  139. li to know if the 3010 servo is good for
  140. Which servo for giant Chipmunk?
  141. JR- R700 Diagram
  142. Glitching while ant points at receiver
  143. Dual servo lag in Futaba 9C
  144. New R/C Radios Using Cell Phone Technology
  145. RF/signal blocking
  146. futaba T8UAP radio user manual
  147. plug wire interchange
  148. MX-A AIRTRONICS NEED ADVICE !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  149. need help bout to make purchase tell me if its good one
  150. Y Connector and Battery/Servo connection for Channel 8
  151. CAP 232R with 3151???
  152. GH-1 Glow driver setup
  153. The Polk's Tracker III vs. Lanier Razor 3D - I lost!
  154. PC Board for Jr 10x Battery Case?
  155. .
  156. problems setting up hitec eclipse for heli
  157. Higec Eclipse Tx Range Check Blues - Cont.
  158. 1/4 scale Extra, servos
  159. Jr 2000 receiver
  160. Battery and setup questions (I'm a Rookie:)
  161. jr radio charging
  162. Walkera #4 TX Trainer connector pin-out
  163. base loaded install
  164. A more comprehensive JR 9303 manual found
  165. 50 MHz ?
  166. Amplified Y harnesses and exstenions
  167. Seeker II any new feedback?
  168. 5955s w/ Futaba on Y's
  169. What's the probability that this caused my crash?
  170. JR R700 receiver
  171. Bec or not Bec?!? Help desperatly needed!
  172. replacement gears for Expert servos
  173. Receiver Crystal Interchangability
  174. JR/Graupner mx-22 charging jack polarity ?
  175. Gyro on 1/5 scale Pica C-182
  176. 9C - VR Knobs and Sliders...
  177. Any Hansen Hobbies campac users?
  178. RADIO SET-UP FOR 4 AILERON SERVOS
  179. computer radio
  180. 9C Heli Setup Question
  181. Servo arm mechanical leverage
  182. EPA vs Dual Rate: Worst load on Servo?
  183. Looking for manual for JR Heli Remote
  184. Futaba 9-cap radio, receiver and Jr servo compatibilty
  185. next generation JR system - an honest discussion
  186. Newbie's best radio system choice
  187. Receiver Questions
  188. radios and receivers with reverse?
  189. servo mixing on futaba 7CAP?
  190. There's a scary lot of discontinued Futaba gyros !!
  191. Futaba 9C trim features with butterfly etc
  192. Hobbico vs Hitec Servo Replacement Parts
  193. Cannon Micro Rx Service
  194. high band and low recievers
  195. HELP!! Servo question
  196. 9C question on dual rates
  197. Robbe RX600 problem
  198. How to clean extension connectors?
  199. Old style Futuba to New
  200. Elevator helper Spring??
  201. Polk Hobbies Tracker III
  202. Which reciever is better?
  203. Ultimate micro rc gear
  204. JR Sport servo line
  205. info on the new Berg receivers
  206. T 12Z new pictures
  207. JR XR2I radio programing
  208. JR XP783 stick mode change
  209. Expert Radio / Transmitter
  210. 3PK throttle delay problem!!!
  211. glitching 2.4ghz dsm spektrum radio - is this even possible?
  212. Hitec electron rec in glow models?
  213. FP-7UAPS still worth using?????
  214. waterproofing receiver, mabye even servos too?
  215. UK Video Trasnmition laws??
  216. TX charger that will output 120 to 150ma
  217. Ko Propo
  218. JR RS6UL Reciever
  219. Hightech HS-635 servo
  220. Question about EVO battery managment.
  221. Radio switch mounting location?
  222. Futaba "Support" Forum?????
  223. Anyone have an AM 75mhz transmitter sittin around?
  224. leaking acid?
  225. where can i find these
  226. MX22 & synth module?? software upgrade??
  227. Futaba Mix ...Helllppppp...
  228. Quality purchases pay.
  229. Spektrum DX6 Range Testing
  230. GWS RX range
  231. Prism 7
  232. Futaba servos, what's the difference between these two
  233. Servo having trouble centering.
  234. Spektrum DX6 Trainer Function
  235. 14MZAP... 14MZHP what's the difference?
  236. Spektrum DX6 Training System
  237. 9CAPS vs EVO-9 vs MC-22
  238. 7CHP IDLE IDLE UP
  239. Vinyl Clad Transmitter Case
  240. Futaba S124 jiggle at centre.
  241. 10x or 9303?
  242. Question to determine new TX
  243. Servo arms
  244. New Futaba ad makes me laugh!
  245. Can a Futaba 9C do this?
  246. JR Compatible Batteries
  247. Looking for advise on a radio
  248. Berg or FMA ?
  249. 14mz users: screen quality
  250. overnight charging rate for nimh batt???
