PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 [47] 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Spektrum DX6 Balancing Act
  2. SERVOCITY!!! Problem resolved
  3. Mode 2 to Mode 1
  4. Futaba G3 RX
  5. Hitec optic 6 run time.
  6. 3-Channel Mixing
  7. PCM radios?
  8. A LOT of Help Needed
  9. Need Help!!! JR XP9303 - PCM vs SPCM receivers
  10. radio ground check?
  11. Hitech Switch harness for JR reciver
  12. What do you think about this one?
  13. Can I use any open channel to power Hitec Supeme 8??
  14. Futaba servo screws???
  15. Hitec Eclipse 7 QPCM radio
  16. Lexors mr-6 receiver worth buying, range?
  17. a little help needed
  18. ART-TECH RC system
  19. Tower Hobbies 6FM conversion to 50MHz Ham band
  20. 14MZ software upgrade
  21. Spilled fuel on my Transmitter ...
  22. Should I expect the same quality?
  23. 9Z software upgrade
  24. airtronics RD 6-8000 opinions
  25. Futaba 9 channel rx R139
  26. gear slop in survos ,
  27. Need help w/ control..
  28. trying to mix a elevator
  29. Touring car radios
  30. cell phones shooting down certain TX's
  31. Receiver band - help
  32. Help Please!
  33. SHOT DOWN! 3 TIMES!!!
  34. Is it smart to fly with Hitec servors in My bigbird?
  35. Frequencies??
  36. Synthesized TX Module TP-FSM with 9Z
  37. Poor shock service, please help!
  38. FMA Servos
  39. Datasafe for 9303
  40. s3004 futaba servos
  41. Mounting Screw Sizes
  42. JR 649 & crystal falling out!
  43. JR 2610
  44. at
  45. HELP! What am I doing wrong? 9C and US 60 Question
  46. Equipment Repair
  47. Futaba 9Z discontinued production?
  48. Polk's Tracker III, Seeker II Receiver
  49. JR 8611a Chatter and control surface movement
  50. JR 8511's on regulator
  51. Range of GWS R-4PII Pico Type Narrow Band RX???
  52. Sorry. . .but another 7Ca dual elevator??
  53. WALKERA 1001 New 8ch transmitter
  54. Tower6XM
  55. Building custom twisted servo extentions
  56. Transmitter failure with new battery
  57. Did we do it wrong?
  58. GWS Servo splines- need heavy duty arms
  59. 14MZ / Model Airplane News
  60. 35mhz radio interference?
  61. AM/Fm, Synthesized, So many choices, HELP
  62. Futaba 14MZ just purchased! Any tips for voice/music/call out downloads?
  63. How to connect a USB CH Yoke to a transmiter
  64. Another 7C-CAP Futaba Question
  65. R700 receiver
  66. 35 mhz reciever with 36mhz crystal, Problems?
  67. Futaba 7C Question
  68. New Stylus Radio
  69. AMA says NO to Spektrum except on electrics
  70. Digital vs Standard servo
  71. need help setting up my electronics!!!
  72. Crystals the same?
  73. What's the Minimum Tx Voltage for Efficient & Reliable Operation?
  74. Use 2 cell lipoly with no regulator???
  75. Futaba 6EXA set charging
  76. throttle channel problem?
  77. FMA copilot effectiveness in low semi obstructed areas
  78. SPCM and ZPCM?
  79. optic 6
  80. Futaba Servo Info
  81. whats the differance between airtronics m8 and M11
  82. what is the difference between airtronics M8 and M11
  83. i am geting a new radio
  84. Wiring a four pin connector
  85. Seperate power to servos
  86. Do I need a new Servo?
  87. custom 1channel radio
  88. How Do You Guys Choose Servos?
  89. Bluebird servos?
  90. Looking to purchase JR 6102, but where?
  91. Radio choice ?
  92. crystal switching.
  93. Help me choose a good transmitter.
  94. BEST SERVO PRICES......WHERE???
  95. Help with Futaba Challenger
  96. Dual ESC's, and mixing = bad glitching
  97. advice on radio purchase.
  98. AIRWILD RADIO SYSTEM, DOES IT WORK GOOD?
  99. newbie suggestions needed please
  100. JR XF622 ccpm
  101. SERVOS FOR 40 SIDE PLANES NEED HELP
  102. Throttle PCM Failsafe
  103. Give the Matchbox it's own power supply?
  104. Haveing a problem with the throttle servo
  105. 14MZ/G3/5955TG/5995TG - Anybody?
  106. Multiplex IPD 9 ch - Synth vs Crystal?
  107. Need Help Programming JR8103
  108. What servo to use?
  109. Help with Radio glitch
  110. Convert Parkzone Radio into a simulator control?
  111. Futaba AM Transmitter and Receiver is ?
  112. New 2006 Servo Chart
  113. Help needed!
  114. New 2006 Servo Chart
  115. FUTABA 7C Overseas?
  116. Spektrum info ? range ?
  117. Custom Servo?
  118. JR9303 to JR6102 Trainer Cord Help!
  119. Need Wisdom Here!
  120. Tx Batteries
  121. Single vs. Dual Conversion
  122. HiTec Eclipse 7 PCM - Raptor 50 setup - HELP
  123. VG6000 question
  124. Buddy Box Mode1 and Mode 2?
  125. A receiver in every plane ? or no ?
  126. opinions on jr6102 vs futaba 6exas
  127. 10X Datasafe Question
  128. TreX CCPM setup on 5 ch Rx?
  129. HITEC 635HB SERVOS
  130. Deans back to stock
  131. New Cirrus Servo's
  132. 20ga servo wire?
  133. Suggestions please
  134. Trouble with JR Sport ST125MG servos
  135. Radio
  136. Servo reverse on FP-T8UP
  137. Futaba 14MZ T/X with JR R/C ?
  138. 9CAPS gear door sequencing
  139. SERVOS: FUTABA X JR
  140. Photo's of the RC car I got, Are these what I need?
  141. Airtronics 94362Z Rock Crusher Servo
  142. 7.5 Volt Switching Power Regulator?
  143. Futaba 7C 7 Channel
  144. Battery draw with Digital or analog servos
  145. ANALOG or DIGITAL?
  146. JR 8411 Shaft Gear Slop
  147. Futaba or JR for 6ch+ plane buddy box setup - Futaba Sucks
  148. Hitec servos
  149. What do I need to get this going?
  150. What is " DSC an abreviation for ??
  151. Berg Receiver Problem
  152. 9ZAP WC2 Changing modes in flight!!
  153. mx-a 75mhz???
  154. Can you convert a futaba am trans to fm
  155. Hobbico Servos? Is the saving worth it?
  156. Futaba FP-S134 Servo
  157. Basic Wiring and Signal types
  158. ? about Y harness
  159. JR 6102 or Futaba 7 CHP PCM
  160. Futaba aileron mixing question???
  161. Servo not turning left......
  162. airtronics 92372 receiver
  163. mpi miracle switch & fma quantum 8
  164. Channel 20
  165. Will a FP-R127DF RX work with a PCM/PPM switchable FP-T5UAP
  166. Need Specs on Older Futaba Mini Servos FP-833
  167. Old Heath kit radio complete
  168. DIY stick ends paint job !
  169. Is this wire suitable for servo extension use?
  170. How many millliamps?
  171. changing frequency crystal in radio
  172. Transmitter age JR 8103
  173. What is this called?
  174. No low end channels for JR???
  175. What's happening????
  176. futaba s3305 vs. hitec 645mg
  177. R114F broken
  178. Base Loaded vs regular Antenna where is the true!
  179. Power Management???Which one???
  180. A little help with a 9Z
  181. Spektrum car module in air radio?
  182. hitec laser 6 with a RCD 3500 understanding
  183. dx3 dsm
  184. New ACE Radio's!
  185. Challenger 720 rx question
  186. Will These Servos Work On This Plane?
  187. Sanwa M11, 27Mhz AM module ???
  188. Airtronics servos
  189. Need help on servo Reverser
  190. RD6000/8000 sticks failure?
  191. MC-24, no digital trims???
  192. Futaba Radio T6XA
  193. Hitec crystal with a Futaba Reciever, Can I?
  194. gas throttle servo
  195. jr quatro 4ch battery wrong polarity
  196. Futaba 9C question
  197. Cirrus servo's...
  198. Male-to-male cables...??
  199. futaba radios and jr receivers
  200. What type of transmitter?
  201. Servos and receiver for JR xp6102
  202. Wiring Airtronics to Futaba J?
  203. Sale price on HiTec servos
  204. Futaba 14 mz
  205. Large 8Ft RC Hanglider/Trike (Equipment?)
  206. Intermediate frequency, Question?
  207. HELP - Radio / Receiver Selection
  208. Jr XF622 (PPM) and FMS help please.
  209. RX Batteries Li-ion or Lipo's
  210. Elevator mixing on Futaba 9c
  211. HITEC 5745 Digital Giant Scale Metal Gear GOOD SERVO?
  212. servo selection
  213. High idle, low idle
  214. Help w/ Servo Selection GP Super Stearman 1.20
  215. Nicad batteries only?
  216. Servo centering question
  217. Question?
  218. Servo arm length?
  219. optic 6 battery life?
  220. Futaba RX. and Tx. questions.
  221. Nedd help making a powerfull servo
  222. Servo Hut - Anyone else having this problem?
  223. Hitec optic 6 Programming problems
  224. 10x??
  225. Throttle servos
  226. Old Futaba Rcvr FP-R128DP
  227. Gyro in an Airplane
  228. Which radio for someone new?
  229. HELP, NEEDED WITH JR and TAILESS Plane
  230. Flaps on a three position switch
  231. delete
  232. 14mz Software update problem
  233. PMXing
  234. Two steps to a better receiver range.
  235. Transmitter left on
  236. 9ZH WC, EVO 12 or Multiplex mc4000?
  237. differential on x-378
  238. WIll this receiver withstand 4standard servos and 1 micro.
  239. Radio suggustions
  240. Locking multiway servo connector
  241. Radio check rudder movement
  242. Mode 1 vs mode 2
  243. Micro Antenna ?
  244. spektrum telemetry system???
  245. GEM 2000 good or bad?
  246. JR & FUTABA
  247. Manual for Hi Tec Challenger 720
  248. Trasmitter issue
  249. Upgrading a 4ch radio, what to get?
  250. GWS R6NII receiver problems?
