- need to reverse a channel ,need help
- In a Bind with Spektrum?
- How many transmiters?
- 5955Tgs and 7.4 volts
- Mid to high end controller, reciever for racing
- Radio Help
- Futaba 9CAPS super VS JR 9303 Air Synthesized Radio
- What does the upgrade in recievers buy me?
- new receiver technology!!!
- Flaps on Channels 6,7 in Futapa 8 UAPS?
- Airtronics MX3 in Australia?
- New 9-channel PCM radio from China
- 14MZ updates
- Who makes a better servo?
- JR XP 8103 - THROTTLE LOCK?
- ??Can you answer this one??
- 6XA battery level error
- Multiple servo problems
- Futaba Range Test
- Hitec Spectra Modules
- 14MZ and Schulze receivers
- My receiver wire got cut, what now?
- How do i setup a mix for knife edge?
- HiTec "Spectrum" Style Radio?
- Altering the throttle range on Spektrum MX6
- Channel 8 shares same channel as battery?
- Difference Between JR and Futaba Servo horn shaft
- Metal servo horns
- Extending Trim Range
- 14MZ or 12Z?
- S3101 Operation
- 9c and hyperion hp-dsp*6-fs compatability
- Are JR digi servos cross compatible with Futaba Rx's?
- MX 22 radio
- Individual Power for each servo?
- Kyosho Radio - Keep it or update it?
- The importance of setting sevos for max travel
- Receiver foa a old T6NHP Fuataba radio
- Model Airplane News issue with article on vintage reed relay RC
- Smiley Antenna with 9CHS
- Need help w/ Airtronics info
- Futaba Recievers
- Pin out on Hitec buddy cable
- Carl Goldberg Models R/C for the military
- Battyer care guide
- Servos in Firebird XL
- Tech question about crystals
- Airtronics, JR, Futaba?
- General Questions about Hitec HPD-07 PCM Reciever
- SERIOUS problems with hitec optic 6
- Flaperons and Airtronics VG6000
- someone changed my Tx crystals
- JR 4721/2721 Question...
- reciever recieving some minor glitching
- HT625MG jitters with a Futaba 127DF reciever
- Metal gear servos for $24.99
- Smiley antenna range check
- Throttle/Brake Trigger Modification
- G3 rx antenna
- Need help finding the Web Address for KO-PROPO
- How do I mix the pitch coupling out of my twist.
- At what point HD wire & switches?
- 512 or 1024
- JR 9303 or 10X
- Graupner radios: negative or positive shift?
- connecter kits
- Airtronics VG6000 End Point Adjustment
- sanwa/airtronics RD 6000
- Reversing servos for flaps
- airtronics 94631 servo... torque?
- Futaba 9CHP Heli Q?
- 9ZAP PROGRAMING MADE SIMPLE????
- futaba radio i bought
- Controlling your model via computer
- CamPac transfer data
- Battery for 5475 digis
- FUTAB 7CAF
- Futaba 8U Transmitter for Airplane
- Need Aristocraft/Hi-Tec servo connectors
- Escapement,escarpment???worth anything?pics
- Hacking the 14MZ MDL files
- optic 6 with no rudder
- Retract servo
- Radio Interference.
- Futaba 6EX Tx with Simulator
- 9303 vs 8103
- Need advice on mid-high end computer radio
- Need new Futaba TX only Vendors?
- Hitec Eclipse 7 Tx
- Help 9Z Throttle
- Silicon coated twisted servo wire
- Question about Berg instillation.
- How many amps do these servos use?
- how to check rx crystal
- Strange happenings with radio
- RD8000 not allowing charging?
- Selecting a 6 CH radio, Which one??
- Polk's Tracker3 vs Hitec Optic 6
- Boosting your transmitter's signal range
- Best 10X Battery
- Cirrus MRX-6 POS
- FP-6FG???
- What is the reasonable thing to do in this case?
- FX-40 Robbe Futaba User Guide
- Internet controlled motor?
- B-8 Micro Servo Question
- New Gimble for JR F400 Tx?!?!?
- BERG MICRO RECEIVER,If dont choose to program
- Interference of camera by motor
- JR NES 4005 servo torque
- Futaba R146iP Crystal
- FF9. chrome finish flaking off
- Help on schematic
- 9C Synth Module Compatibility
- Micro RX's and cell phone towers?
- HYDRO FOAM TRANSMITTER
- Hitec eclipse heli setup
- MOD2 vs MOD1
- Battery packs won't work..
- Futaba 6 EXA help
- Suppressor Filters on Ailerons...Why??
- Futaba Servo's work with a JR Transmitter??
- Hitech 7 channel HFD-08RD and JR 6102
- Servo Centering
- Interesting Old Radio
- Need a JR 537 or futaba servo??
- Looking for good/cheapish RX and a few other things
- Spektrum DX6 PROBLEM...
- Leaving An Extension Plugged In to Unused Channel
- Transmitter Crystal for Dummies: Question
- 14mz loading pictures help.
- Futaba Transmitter Battery Advice
- 8U "stop flying" Voltage?
- LI-Po for Transmitters
- Tower 6 XM, Something I'm missing here?
- Radio Advice
- Futaba Flyers Club
- Futaba 7C and Li-po battery
- Futaba 14Mz Upgrade file
- Nomadio Sensor
- Multiplex 9 ch Synth receiver problem
- Help replacing a switch on Futaba Skyport 6A
- Phil Kraft's passing
- 27Mhz versus 75Mhz. Which is better?
- single conversion rx
- Glitch Problem??? HELP PLEASE!!!
- Need help selecting a computer radio
- Futaba 9252 digital servo problem
- Did you like your JR PCM 10 "z" ????
- Futaba transmitter buying advice
- Futaba S38 Servo
- Futaba 9001 vs. 3152 Question
- Crystal question
- Radio Glitch??
- JR 9303 Radio Question
- raido self deprograming
- receiver sensitivity to gas engine ignition noise
- Transmitter controlled RX switch
- multiplex radio
- Mutiplex Digital servos
- PCM9X to 9XII Upgrade for UK Users
- Broken aerial
- Graupner MX22
- Hitec 635HB Question
- 14MZHelp with AFR
- NIMH and Futaba S3305
- Synth. rx required with synth. tx?
- Futaba Attack?
- 6EXA buddy box
- Special Rx needed??
- Servo wire Crimping tool and connetors
- Dual throttle control (part 2)
- CO PILOT GYRO
- HELP WANTED FOR A SERVO
- Any problems with Hitec hs 475hb servos?
- Futaba 7C vs. Hitec Optic 6
- Antenna mounting inside fuselage: safe?
- Rubber Duck Tx Antenna for 7Cap
- Epoxied Buttons
- 9303 Programing question
- Futaba should be ashamed...
- How to update your 14mz, official update.
- Any one using the new 12z G3 Rec
- Spektrum DX2 vs DX3
- Problems w/ low Freqs for micro reciever?
- Updated 14mz with shift select?
- servo Glitching
- PCM servos glitching
- Can you change tour transmitter channle
- Spektrum reciever antenna failure
- Info on Hitec Prism 7
- 14MZ Software release question
- compatibility
- Replacement for 10x coming??
- Servo jitters on PCM??
- how many amps do high torgue
- how many amps do hi-torque servos
- Futaba T6XA or Spektrum Dx6?
- GWS receiver on low channels
- DAD (Interceptor 2000) Reciever crystal?
- Servo Glitching
- Hobby Services vs Radio South
- Spektrum DX6 throttle question
- So 5 Cell Nicad Didn't Kill my 149DP?
- New CAMPac Editor Program
- receivers that have been in a wreck; opinions
- 9c flap aileron mix
- Transmitter trays
- Perplexing Servo Jitters !!!!!!
- Futaba 3PJ question.... Crystal/module help
- futaba 7c + ultra stick, asking too much?
- SCALECRAFT/POLK TRACKER III RADIO
- Manual for JR remote
- Futaba S3010 servos and battery compatibility
- Radio Compatibility
- Radio compatibility
- Digitals vs. Coreless Analogs
- Dual Throttle control
- remote start for nitro engins
- radio interfenece??????????
- do you think this is a good price for a spektrum reciever on ebay?
- JR-extortion
- ALL IN ONE RX - WOW!!!!!
- microcontroller-actuated servo, number of steps / precision?
- Missing buddy box lever: Futaba Skyport
- 75 mhz Futaba FM rx antenna
- Futaba 12 ZAP manual on line
- Crash protection for receiver & battery pack ?
- JR Controler---Airtronics receiver
- Hidden Servo Linkages
- Futaba TX where the best price to buy?
- Spektrum dx3 alternatives?
- Servo buy?
- Futaba R127DF receiver Discontinued
- ? on sero choice for my revo(race specs)
- JR servo Z connector
- Hobbico receiver compatibility: futaba
- 1/4 scale servo wire gauge?
- Measuring Servo Torque?
- 14mz stick calibration?
- confused by Futaba Reciever Choices.
- Transmitter tray
- Male/Female Pigtails
- my reciever doesnt work
- WHERE SHOULD MY 400$ GO?? ITS MY HARD EARNED MONEY AFTER ALL!!
- Servo Reverser Question. Please Help!
- What to switch?
- li to know if the 3010 servo is good for
