PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 [49] 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Digital Servos
  2. Futaba Airtronics compatibility?
  3. 8611a vs 9152
  4. Digital servo costs
  5. Hitec HS-645MG Question?
  6. 9cap and trainer compatibility (teaching my 6 year old)
  7. Flight paks?
  8. Futaba 7-CAP Service Menu
  9. Question about R/C receiver output pulses
  10. BEST METHOD FOR 4 AILERON SERVOS ??
  11. Transmitter for surface and air
  12. Futaba receiver antenna issue Please Help!
  13. Futaba S131S servo
  14. Mode 1 Flyers, UNITE!!
  15. PC Joystick-To-R/C Trx Integration
  16. 8U Super Transmitter Use in Australia
  17. Servo Bounce Problem
  18. is my tx possitive or negative?
  19. Hitec PrismX PCM receiver
  20. Gyro Hunting what is it
  21. delete
  22. Interference range of transmitter
  23. Hitec Eclipse 7 QPCM eats batteries
  24. Hitec / Futaba Rx crystals - compatible ??
  25. 1024 or 0-120% endpoint adjustment?
  26. Does crystal manufacturer matter?
  27. JR X347 conversion mode1 to mode 2
  28. JR Retract Servos don't turn 180?
  29. Futaba servo horns. Hitec ???
  30. what rx will work with walkera tx?
  31. Futaba flyers club;Button to register?
  32. Multiplex has the same servo-arms as GWS ??
  33. JR 9011 Servos
  34. Airtronics MX3-S: horrible glitching! help!
  35. TX COMPATABILITY ??
  36. FUTABA 6CH RX W/ALIGN ESC
  37. Which radio to buy?
  38. Seperate power feed for heavy duty rudder servo?
  39. help
  40. Problems w/ using a 6V w/ no Regulator on Servos?
  41. Futaba 9Z WCII Programing Tips
  42. need a high TQ servo for my jato!?
  43. RD8000, good or bad.
  44. Jato servo problem!
  45. I like Sanwa/Airtronics but no one uses them
  46. At a crossroads JR vs Futaba
  47. 9C S w/ PCM RX battery question
  48. Hitec Electron6 receiver with Engine plane
  49. Broken Receiver Aerial
  50. Replacement battery for Futaba 8U Tx?
  51. radio interference
  52. 3004 Servo Keeps Flapping
  53. Model Avation/stickers
  54. JR 9303 spoilerons
  55. Need help On Optic 6 radio for 3d
  56. need help to choose nice tx
  57. Metal noise from tailwheel
  58. Futaba 8U switches
  59. pcm pcc
  60. Changing Hitec servo gears 5945MG
  61. MPI Switches with VOltage indicator
  62. Futaba 9 CHP/ 9 CAP controller question!
  63. Futaba S148 servo arm jitters
  64. ACE Servos?
  65. Futaba R146iP Question
  66. Accu-cycle Pro & NIMH batteries
  67. Right way to use ferrite beads or servo extensions
  68. Aileron to Rudder Mixing..
  69. Futaba 9153 servo
  70. radio questions
  71. Which Hitec Digitals for IMAC
  72. meaning of oz-in
  73. How about Multiplex Servo's
  74. Minimum receiver voltage under load
  75. manual for xf421
  76. Programing Ultra Stick with Futaba 7C?
  77. Diagnostic tools
  78. futaba 9206
  79. Help, getting back into hobby and need a new radio
  80. Field force 6 tx and futaba fy601 gyro
  81. Question: Heli Mode 2 throttle stick direction
  82. Futaba PCM, JR 8611's & Hitec 5955tg's compatibility
  83. JR 8103 and TF Contender Flap Question
  84. Using multimeter to check servo load
  85. Airplane gyro in heli
  86. Computer xmitter settings ?
  87. Ganging servos
  88. Question about trainer cord?
  89. Linear Servo Motors
  90. Transmitter/Receiver compatibility
  91. 2 questions
  92. JR 9303 Flaperon setup
  93. Where to order Futaba PCM?
  94. opinion
  95. Is this a good radio?
  96. New Guy Questions about radios
  97. 14MZ & Non-Futaba Receiver Compatablilty
  98. Is the AMA gold sticker program a hoax??
  99. Receiver Question
  100. swb control arms
  101. Need help setting up two engines
  102. Range testing methods
  103. radio interferance
  104. JR R700 FM Receiver
  105. JR 9303 LCD display question
  106. RCU Looking for writer capable of doing objective servo shootout article
  107. Old Timer Help!!
  108. Adding ATV to a existing radio?
  109. what causes radio glitching?
  110. reverse polarity?
  111. New Hitec Programming for older servos
  112. quick question about transmitter/receiver compatibilty
  113. Futaba Tx with JR Sport RS 600 Rx???
  114. Futaba 6EXA with Sanwa Receiver ??
  115. Double frecuency TX
  116. Battery Change to Futaba Transmitter
  117. Optic 6- more complaints than Futaba 7C?
  118. Has anyone had problems with HS5645MG
  119. jr or futaba?
  120. Futaba FP-R127DF RX
  121. Using both JR Servos and Futaba Servos on the Same Receiver
  122. reuse existing servos? (plugs)
  123. Need a good mini servo
  124. Multiplex
  125. Futaba 9cap stick spring problem
  126. Servo S-25X by expert
  127. Futaba 9C charger questions
  128. 14 mz freq change to fly abroad not posserble...
  129. servos mith or reality?
  130. 8611 centering problems
  131. Reversing a Servo
  132. EMI bead selection
  133. JR S600, what do you think??
  134. Multiplex Profi 4000 to Futaba Trainer Cord
  135. Radio interference issues
  136. radio twitching
  137. Key features to look for in radio?
  138. Where to buy Futaba 50 MHz TX crystals
  139. Futaba 6XAS Questions
  140. Hitec hs 225 mg refund
  141. Jrx347 Reciever Question???
  142. Changing frequency
  143. channel freq's
  144. Converted one time use camcorders on EBAY
  145. Tokyo Model Show
  146. Futaba or JR, give me your thoughts.
  147. 9Z WCII Battery Holder
  148. futaba
  149. Futaba 9C 3-position Switch Locations
  150. transmiter problem
  151. JR/Airtronics leads
  152. jr 10c info
  153. Good Basic FM Radio To Start With.
  154. replacing walkera radio.
  155. Antenna tubes-inside plane.....
  156. futaba r138 and r148
  157. Servo Causing Glitching
  158. Transmitter range
  159. ESVs and 4NFB Conquests
  160. Hitec Focus 4 as buddy box
  161. Multi Port Lipo Charger
  162. dual conversion? High/low band?
  163. charging larger receiver packs
  164. Avoid Mark George - Snyper68 Transmitter Scam
  165. Where to buy servo wire teminals?
  166. e Lithium battery
  167. change mode 1 to mode 2 on Futaba 6exa
  168. Good Radio that doesnt need chrystals?
  169. *JR ST125 Servos*
  170. Futaba 9C channel mixing problem.....
  171. 4 Channel/5 servos?
  172. Charge switch identification wanted?
  173. Cap 580 servo noise and centering
  174. JR xp652 mode change
  175. 7cap and 7chp
  176. Can you guys help me please?
  177. Servo stuck left...help!
  178. how u hook up 2 batteries?
  179. GWS receiver
  180. Problem with Futaba 7C and Hitec Electron 6 FM
  181. JR 10x or Futuba WC2
  182. jr/graupner c507
  183. Airtronics SR Transmitter
  184. 20% OFF Hitec Servos for a very limited time!
  185. QPCM range issue
  186. CAN I USE MY RADIO/RECEIVER FOR UNDERWATER PURPOSE?
  187. Help with Futaba 8U and mixing Elevator Servos
  188. pcm & ppm??
  189. JR Connectors??
  190. Part of my receiver antennea broke off, how much does it affect range? 55
  191. JR radios
  192. Set mixing % on new radio ???????
  193. Hitec Eclipse 7 or Futaba 7 ch.
  194. 9C vs. 9Z
  195. Synthesized Tx/Rx Question?
  196. compatable radio systems
  197. Hitec 225 MG
  198. M5 jitters
  199. 14MZ proportional channels
  200. JR 770 pcm reciever
  201. Problem with Radio
  202. Which radio is "more of a radio"?
  203. Servo Switch/Circuit
  204. ATTENTION: Erick Royer
  205. Futaba 14mz - Is it a good time to buy?
  206. Dual Elevator, Aileron and Flap servos with the 9C
  207. Futaba 9c Mix help
  208. 2nd/3rd Plane Electronics ?
  209. gyro???
  210. any help would be great
  211. Kyosho 7 Channel Radio
  212. JR Radio plugged into Futaba Charger.. HELP
  213. Hitec 635 Karbonite
  214. Futaba Repair, So Cal???
  215. *Airtronics "Z" Connectors*
  216. Flaperons... how do you set them up??
  217. ANY PLAC ETO GET SPECS ON STOCK REVO SERVOS?
  218. Hitec 5645MG centering
  219. older Futaba FP-T8SSH-P trying to resurrect
  220. Removing the flap switch - RD8000
  221. 6V 1400mAh & 4 S3050's = How many flights?
  222. Intermittent range problem with Airtronics Stylus / PCM / Flair Tiger Moth
  223. FUTABA 9CAP OR JR XP 9303
  224. GWS RX Problem
  225. Optic 6 display problem
  226. how to do a trainer cord to futaba 4yf?
  227. 6v or 4.8v receiver pack?
  228. 6v micro (?)
  229. Ranges of Futaba?
  230. FM and PCM. whats the difference?
  231. How adaptable are RC radios?
  232. Looking for receiver compatible with ParkZone TX
  233. parkzone P-51 transmitter batteries
  234. Where did my thread go ???? Censorship ???
  235. LHS or Tower Hobbies
  236. Is AM transmitter still legal?
  237. spectrum dx3
  238. $$$$Servo extensions$$$$
  239. Antenna
  240. Hitec HS635 servos in Excelleron 90 --Trust em ???
  241. Ground use radio systems
  242. servos disposition
  243. Best micro servo for a FAAAAST plane
  244. 9x2 Throttle Cut
  245. GWS NARO SERVO AS GOOD AS HITECH HS-55?
  246. Can I change Transmitter Freq on newer radios?
  247. MX-3 Airtronics transmitter???
  248. JR 10X Smoke Setup
  249. 7c or 9c for first computer radio
  250. Going to digital servos. Do I need a programmer?
