PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Airtronics 10G porgraming issue
  2. How to test receivers ? 2 have had dead shorts ruining battery
  3. Pulse width question
  4. Futaba Receiver r7008sb extend antenna cables.
  5. Powerbox royal And I-Gyro Connections.
  6. Voltage drop and the dreaded "Brownout" , What's really at fault ?
  7. Multiplex HFMx M-LINK connection
  8. Jeti DS-14 / DS-16 Radios
  9. switching models from futaba 14mz to 18mz.
  10. Help needed with the alphabet soup associated with 2.4 gear
  11. Tower P51, DX6i recommended settings?
  12. Spektrum and Jeti RF Testing
  13. 72 Mhz Futaba RX retuning
  14. Spektrum DX7s or DX8??
  15. Spektrum AR 7350 and Failsafe
  16. AnyLink2 with FlySky TH9x
  17. Spectrum
  18. Tx/Rx Choice
  19. why can't you use flysky 2.4 module in jr 8103
  20. flysky
  21. Do old Radios have servo end point ?
  22. Futaba S3152 servos
  23. JR 9303 setup question for turbine Elan
  24. Seeking reciever and transmitter advice for older type servos
  25. DX7 vs DX7S
  26. 72 mhz transmitter ?
  27. fs gt3c
  28. metal gears servo
  29. Hitec HPP 22 3.5 mm cable interface pin out
  30. DX 9 Mystique PG program
  31. 12X Exponential
  32. Radio/ receiver
  33. Thinking of a Futaba 6K transmitter....your thoughts...
  34. Specktrum radios; why did you crash? Why did you have a "brown-out?"
  35. single sided 1" servo arm for mini/micro servo wanted
  36. Radio Shack rock runner car crusher
  37. Custom servo remote control system help please
  38. Futaba 14 channel rceiver
  39. Isolating Pafrallel Battery Circuits
  40. futaba t6xa radio
  41. flysky fs-gt3b
  42. Orange RX R720x telemetry - solved
  43. Placemenmt of a 2.4 antenna
  44. Exponential on Turnigy 9x radio question
  45. University Project
  46. S bus x bus when will Spektrum have one
  47. New to Rc and looking for advice
  48. Is twitching normal when the radio antenna is down?
  49. X9503 Multi Point Mix Question
  50. Control rc car with Raspberry Pi
  51. Help with Turnigy I 10
  52. Is checking a JR 600 FM receiver on the level ground from 100 yards a legit test?
  53. futuba 2.4 powers up,but no green light .
  54. HELP! No throttle on redcat rc
  55. Hobby King Turnigy 303 Headlock gyro setup
  56. HELP! Add Remote Trigger for Remote Start TQi 2.4ghz Tx
  57. Will Heng Long RC work in or with Mato Tanks?
  58. How to ID fake Spektrum receivers???
  59. Polk Hobby Tracker III...Need manual
  60. 2 Thumbs up Horizon Hobby
  61. analog vs digital
  62. Coreless servo jitters, 3-pole standard servo does not... why?
  63. Need help with Hobbyking gyro hk401b.
  64. Transmitter problems
  65. airtonics stylus tx battery change to lipo TIPS?
  66. Bec question
  67. RC Car Steering Issue
  68. receiver help
  69. Old futaba radio question
  70. Switching satilite on 2.4 receivers?
  71. futuba 2.4 won't power up.
  72. Solar Servo D772
  73. Hpi savage servo upgrade
  74. transmitter and receiver help
  75. Programming a mix on a DX18 v2 ???
  76. Servo mount
  77. Need a good tx/rx
  78. Detailed look at the 785HB Multi-rotation servo
  79. SD Card for JR XG8???
  80. which servos
  81. Powerbox Igyro 1e
  82. Reciever missing part?
  83. 27 mhz radio and receiver
  84. Review of Flite-Torque Servo
  85. RX/TX and FPV Beginner Question!?
  86. Redwing XQ Power servos
  87. Simonk ESC firmware questions.
  88. Converting JR transmitter to 2.4
  89. Best servo under $100???
  90. Best transmitter for a combat robot
  91. Crow settings for a DX8 and a Ar8000 receiver
  92. 88" Extreme Flight Yak 54 18 pounds 60cc
  93. servo problem
  94. Flysky?
  95. New to rc...need some help with Grasshopper.
  96. Battery dump/loss of control
  97. How much exponential
  98. Ecx ruckus
  99. Servo compatibility with older 72mhz rx
  100. Servo arm and clevis with single rotation axis
  101. THis might be the "Dumb" question everone is looking for!
  102. Futaba 14SG Programming Book
  103. Old Noob question about on/off switches ....
  104. 8 channel tactic transmitter compatible with tacti 6 channel receivers ?
  105. 8 channel tactic transmitter compatible with tacti 6 channel receivers ?
  106. No range with rc car
  107. 18MZ GPS is wildly inaccurate.
  108. Spectrum DSP60J programable digital servo with older radio ?
  109. Can RX signal loss/chatter occur by testing the TX too close?
  110. How does Voltage effect Tx range!
  111. Futaba 14MZ Backup error message
  112. Surface servo
  113. Control
  114. Need help with 2 Hitec 805 Servo's.
  115. Redwing RC XQ Power Servos
  116. Futaba 10J Programming
  117. Spektrum AR635 will not bind to transmitter
  118. Hitec Focus 4, questions
  119. Plane won't go into bind mode. Grrr.
  120. 8FG SUPER talking to several receivers at the same time
  121. Tactic TTX 650 and throttle
  122. Throttle and steering glitch
  123. Tactic TTX 650 multiple receiver binding
  124. Servo ?
  125. JR 9303 Radio Glitch?
  126. DX6 Spektrum Transmitter Shutting Off
  127. Help with several parts, please! I am new :)
  128. Help with several parts, please! I am new :)
  129. Dynam radios
  130. JR 28X Flight modes
  131. JR XG8 Transmitter Deal....
  132. Dx6 dx9 radio voice help!
  133. Sig somethin Xtra ARF receiver placement
  134. Looking to get back in to hobby? FrSky Taranis Plus X9D?
  135. Eagle A3-L Gain controls
  136. Stand alone stall indicater
  137. Tactic Tx and non Tactic Rx
  138. Which Tactic receiver?
  139. T8FG setting Question
  140. Traxxas T maxx 3.3 Front and rear Wheels spinning in opposite direction.
  141. spektrum 5030/5040 servos ok?
  142. Century Vll
  143. New to 2.4
  144. Wanting a Spectrum Radio... 7, 7s, 8, etc.....
  145. Tactic TTX650
  146. High Voltage Servo Throttle Question
  147. Turnigy 9XR Pro - compatibility, modules and questions...
  148. igyro srs +jr pcm9
  149. futaba 6ex
  150. Digital servos with analog
  151. Taranis with Spektrum SAFE
  152. FPV Equipment tips new build on Twinstar II?
  153. cause of blown servo's ?
  154. Is Jeti the only one?
  155. LVC Power Switch wiring question…
  156. Turnigy 9X throttle stick not responsive
  157. Elgae FASST receiver
  158. Hitec Aurora 9x problems
  159. FMA Piezio Gyro Pro G90
  160. Servo/Engine/Esc for balsa rubber conversion
  161. support during his return from Tommy John
  162. Aircraft Gyro Question
  163. Futaba 7c Flaperons move at different speeds
  164. Help with configuration FRSky TH9X
  165. RedwingRC Yellow power expander problem
  166. PowerHD Storm 4 HV Brushless servo from Redwing
  167. No response from receiver, Spektrum AR9020
  168. no reciver light
  169. programming aux channel on spektrum dx7
  170. Hobby Eagle A3 Super II gyro with DX7 need setup advice
  171. If you were to look at the four starts I think
  172. binding 9c super with Frsky TFR6 and TM-7 HELP ! these recvs. worked with my 7c and 8
  173. on the road as he tries to end the longest
  174. Spektrum DX6i replacement LCD
  175. Futaba 9Z battery cassette
  176. Receiver Antenna
  177. Long term radio for a newbie
  178. Need a gear set for a Futaba BLS-172
  179. flying g
  180. Trainer setup
  181. How good are Emax servos
  182. Futaba 8JN Transmitter RF Pin Out
  183. Hobby King RX3S Gyro
  184. Tx/Rx advice on a budget
  185. FrySky module receiver telemetry compatibility
  186. servo amp draw, how to?
  187. DX5E change mode 1 from mode 2, do the switches and trims also change?
  188. 14SG programming trick, offset center position
  189. voltage regulator for gy401
  190. voltage regulator for gy401
  191. Malicious attacks on 72mhz
  192. 9xr Pro
  193. Help with Futaba Telemetry Setup
  194. JR x9303 programming question???
  195. FlySky GT3C problem: Inherent issue, or is something wrong?
  196. Need Transmitter Binding Help!
  197. Can I bind to multiple RXs at the same time?
  198. Futaba T9CP with Spektrum DM8 module & Futaba Skysport 4 trainer cord possible?
  199. Looking for a airtronics 94510 servo
  200. importing a 35mhz RX from Hong Kong?
  201. goPro hero camera interferences with 35mhz equipment?
  202. 18 mz wav files
  203. How can I extend the range on a Spy Gear Spy Video Car?
  204. E Flite ESC disarm
  205. What do radio equipment do I need?
  206. DX7S + AR7000 Aileron
  207. Which 2.4 Ghz radio Spektrum DX9 or Hitec Auroa 9X
  208. Receiver antenna chaffing
  209. European radios (like DX18t) compatibility
  210. Throttle servo question
  211. 35mhz and 72mhz transmitter length antenna
  212. Turnigy 6 ch radio
  213. scratch made monster truck
  214. Futaba 8U
  215. How to slow down a continous servo?
  216. Spektrum DX9 question
  217. Multi-turn sail winch
  218. Spektrum AR63335 receiver connectors
  219. Servo question
  220. Tamco range issues
  221. DX18 Gear Door Question
  222. Help in setting Dual Rates with Futaba T14SG
  223. Neodymium magnets
  224. What The? Catastrophic failure under Spektrum DX9 Control
  225. Servo for AIRSOFT-GUN magazine, 360 deg, fast, high torque
  226. Help with CT6B transmitter
  227. Programming low voltage alarms with the FrSky FLD-02
  228. Question on removing gears on S-14 II type Kraft servos
  229. FrSky non-telemetry verses the telemetry systems?
  230. JR 28x software update wish list
  231. Compatible with a Futaba 4YBF 4 channel radio?
  232. Futaba 14mz....two Recievers
  233. Upgrade AM Radio Upgrade for Traxxas Rustler VXL
  234. Help me find a controller
  235. Dx8
  236. Futaba 9Z trainer cord
  237. Futaba T14SG Problem
  238. Futaba T14SG Problm
  239. Any Futaba 10JA 10-Channel 2.4G Air S-FHSS reviews
  240. Telemetry and Dx6
  241. Walkera Devo F7 with FBL KDS Helicopter
  242. FRSky Taranis Beginners Support Group
  243. Futaba FASST receiver antennas
  244. getting back into RC- Radio help needed please
  245. Sanwa (Airtronics) MT-4 Telemetry help
  246. Futaba 12z ailvater or normal tail type?
  247. Looking for new surface transmitter
  248. He averaged 162 points in 52 games
  249. make a mad push to get into the playoffs
  250. GRAUPNER MC-15 / 40MHz / channel 91
