PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 [50] 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. 9x2 Throttle Cut
  2. GWS NARO SERVO AS GOOD AS HITECH HS-55?
  3. Can I change Transmitter Freq on newer radios?
  4. MX-3 Airtronics transmitter???
  5. JR 10X Smoke Setup
  6. 7c or 9c for first computer radio
  7. Going to digital servos. Do I need a programmer?
  8. two elevator servo help
  9. transmitter
  10. Subtrim versus Trim
  11. What kind of Radio is this?
  12. Which felt better to you? 9Z or Stylus?
  13. Hitec Optic 6 - How to charge batteries
  14. Buddy cord JR to a Futaba??
  15. Will a stock tmaxx servo go into my mt2?
  16. Need Specs for an older Airtronics serv.
  17. Hitech 625 MG or 645 MG
  18. Large Hitec servos - an anomoly?
  19. Question on Futaba Conquest and SkySport
  20. Hitech 635 karbonite
  21. Jr servo packageing
  22. Help me set up a mix please!
  23. Synthesized Tx’s what’s available how do they work?
  24. 10X Is this PCM lockout?
  25. GWS R-6N receiver
  26. Hitec Eclispe 7 Dual elevator servo's solution
  27. hitec servo slop...
  28. Futaba field force 7, memory upgrade.
  29. Which Radio? 9C or xp9303
  30. Synth Receivers
  31. JR 9303 w Synthesized Module
  32. Futaba T9CAP(Super) standard collocation
  33. How do you like your gimbal spring tension ?
  34. Futaba 2PH 2-Channel 75Mhz
  35. JR Recievers with Futaba Crystal question
  36. JR 8103 Timer
  37. 5745 delaying
  38. A lot to catch up on... HiTec servo questions.
  39. Having servo problem?
  40. which radio should i buy please help
  41. programming super
  42. Spektrum DX3
  43. Futaba 9Z questions
  44. berg receiver
  45. JR XR3i Radio HELP!!
  46. Radio and receiver 101 needed, thanks!
  47. FMA Direct SA-10 Servo Analyzer
  48. crystals
  49. Single flap, dual aileron - Setting up crow 7CAP
  50. I need a radio for a serpent 960 and a century predaor gasser....
  51. batteries and charger for JR SX3 ?
  52. 6.0V battery on JR charger
  53. HELP! Dual aileron servos and flap servos at the same time? Futaba 9C
  54. Better than 14 MZ : Futaba FX40 !!
  55. Synth Receivers - What's available?
  56. help! unknown servo
  57. Futaba and The new JR servos
  58. looking for micropro 8000 single stick
  59. Anybody tried any of the new JR "Sport" components yet?
  60. Spektrum.....good and bad
  61. Graupner MC24 dual RF
  62. 9152 vs 8611 and 5955TG
  63. Any problems with ELECTRON 6?
  64. Hitec HS-5995 robotics servo, Help!
  65. JR transmitter with Futaba receivers
  66. Trim setting changes when going to high rates
  67. servo reversing
  68. Ferrite rings/choke for smoke system RF?
  69. Something strange happened today.
  70. Radio range increase?
  71. Blue Bird Servo's
  72. FUTABA COLLECTIBLE?
  73. Polk Tracker III mini-review!
  74. Can I do this?
  75. Hitech and Futaba servo arms
  76. JR XF-631
  77. Airtronics Service
  78. FUTABA 9
  79. Transmitter question
  80. Hitec hs 225 mg lock up again
  81. Linkage setup Speed?
  82. isnt a crystal a crystal?
  83. Is this silly?
  84. Evaluating interference problems?
  85. Need HELP with Hitec Eclipse 7
  86. Futaba FM versus AM basic ?
  87. Using Futaba 4YF for a buddy box.
  88. Changing channel (from 56 to ?) on Futaba 9C Super.
  89. Transmitter pack capacity.
  90. Old Cox/Sanwa radio
  91. Using a Deans Antenna on RX
  92. Servo Tester
  93. Futaba 9Z Antenna Replacement - DIY??
  94. Need Manual for Hitec Flash 4 radio!
  95. Need a 75+oz in servo...Best buy?
  96. *Airtronics VG-6000*
  97. JR Economy servos
  98. Frequency
  99. Radio Survivability in High Temperatures
  100. 6 ch Computer Radio w/4 micro servos
  101. MS2K Newbie
  102. The 9C Flip/Flop
  103. JR / Futaba TX ??? (Not again)
  104. Futaba 7C, Dual Elev Question
  105. JR 9x2 tx mixing setup help please
  106. Interference
  107. Need Help! Jets Servo
  108. 6v battery voltage
  109. jr question!
  110. Futaba S3001 oscillating
  111. Eagle Tree Announces Flight Data Recorder V2 (FDRV2) Enhancements!
  112. Futaba FP-8SSAP
  113. JR PCM9 Receiver and 6volts
  114. Need Some help on TX/RX selection
  115. Digital Servos and Battery Requirements
  116. Tower Hobbies AM reciever question
  117. Enterprise FIX ??
  118. Futaba replacement Gimbles.
  119. New Radio AccessoryAvailable
  120. JR PLL-Synthesized module
  121. Looking for a Futaba 9C MAN for HEEEELLLLLP
  122. Giant U-Can-Do
  123. Range check questions?
  124. Receiver battery plug-in
  125. Beginner buying 6 ch radio
  126. JR 10X stick change
  127. Starship need help with radio
  128. JR Switch
  129. 30cc gas plane receiver switch type requirement
  130. R700 Antenna
  131. Wattflyer.com E-Power only website by the creators of RCU debuts
  132. RECIEVER BAD OR WHAT?
  133. Airtronics RD6000 programming
  134. Bad Reciever?
  135. FUTABA 7CAP PPM/PCM.....GOOD BUY?
  136. Tracker III I have one. Any questions?
  137. CamPac Reader
  138. "Tower Pro" high speed servo
  139. TX BATTERY LIFE TIME?
  140. lOW BAND HIGH BAND
  141. Gyros and accelerometers placing
  142. DIY servo Mixer??
  143. Hitec Laser 4
  144. SPF-5
  145. Futaba 9C programming
  146. PA-2 location
  147. Receiver fried from switch
  148. Setting up a R-309DPS - Power thru DSC OK?
  149. stupid mistake!! what to do????
  150. Hook-Up question
  151. Futaba 5UAF....Opinions?
  152. Help Futaba PCM Rx
  153. JR 8103 owners,I NEED INFO,,
  154. dual elv. matching w/o programmer
  155. Question about these servos?
  156. crystals universal?
  157. Older Airtronics Radio Systems
  158. Programming special functions on a 9C HELP
  159. 9303 vs Royal Evo
  160. Airtronics VG600 Hit?
  161. Futaba 14MZ internals
  162. airtronics stylus
  163. long range radios? (500-1000ft)
  164. radio receiver problems
  165. Buddy box on 50 MZ
  166. Dual Hitec 705MG to Multiplex Rhino
  167. pcm 1024 help fp-r129dp
  168. cmp quest gyro????
  169. JR9303 Timer and Throttle Stick
  170. Old Futaba equipment
  171. JR 6103
  172. JR 9303 motor timer
  173. 14mz best price?
  174. Single stick radio
  175. JR radio compatibility
  176. Question about Radio's
  177. alum servo arms for jr?
  178. Hitec 5645 and use of Y-Harness
  179. Newbie needs help to upgrade
  180. Receiver antenna
  181. RC Car Radio Frequency in South Korea?
  182. Which one to use?
  183. Aileron Servo connections to Receiver...
  184. Will this work?
  185. Futaba 14BZ- BSOD?
  186. reciver dead ?
  187. Sombra Interference
  188. Interference: replaced everything and still there??
  189. Can I use a proportional controller?
  190. 6V Receiver Bat Charge
  191. control feel
  192. Futaba and Hitec output shafts, same or not?
  193. Futaba Ch42 crystal for 72MHz Ch52 Receiver?
  194. old futaba fp-r4f dead ch1
  195. FM Receiver
  196. Radio systems and Nicads...
  197. JR 3121 Servos and Horizon Support
  198. # of glitches
  199. Airtronics RX with JR or Futaba TX
  200. Help with connectors
  201. Can I mix Hitec and Futaba Servos
  202. setting dead band on hitec servos
  203. dual Rx or power isolator?
  204. Servo tester
  205. Futaba 7C Super
  206. Futaba 3PK help
  207. How much for service
  208. How much for service
  209. Futaba T7cap
  210. COX/SANWA Rx identification
  211. 14MZ trim resets, anyone?
  212. No Airtronics in MAN Buyer's Guide,Aug '05
  213. Which Futaba 9CAPS should I get?
  214. Futaba servos used verses battery capacity used
  215. Futaba 9C and Li-ion
  216. Why TOWER dosen't sell JR Radio's ?
  217. Hitec Laser 4
  218. Switch harness with a charge jack
  219. Cheap RC Scanner
  220. My experience w/ a DSP4 from plantraco
  221. Need help from JR 6102 owners please.
  222. Smoke servo ???
  223. I need some equipment recommendations.
  224. trainer cords
  225. jr transmitter
  226. NEWBIE HELP w/receiver please!!
  227. Dual Elevators and Dual Ailerons in 7c ?
  228. New to the hobby and need radio help
  229. My Plantraco DSP4 Didn't come with Manual, HELP.
  230. What is the best type of reciever for a gas powered plane
  231. "Vinyl-Clad" Al Transmitter Box Touch-Up ??
  232. Futaba 6EXAS strange problem
  233. Multiplex Evo and IPD technology?
  234. FCC Response
  235. JR and Graupner Transmitters....
  236. JR's new R770 PCM Flight Pack w/ 5 Digital Servos for $160!?
  237. Ace silver seven single stick
  238. Tower Hobbies Servos
  239. What now with the new updated HFP-10????
  240. Futaba FP-S148 servo
  241. Radio to Suit
  242. Hitec HS5945MG servos
  243. Hitec servos´s ??
  244. Futaba Servos and Receiver and JR Radio
  245. Long range radio gear
  246. Spektrum - Spread Spectrum Tx/Rx
  247. 14mz trim reset
  248. Airtronics Infinity case crack
  249. fail safe on throttle for non pcm radio
  250. fp-r127df for electric aircraft
