PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 [51] 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Sanwa/Airtronics RD8000 problems !
  2. Help for Sanwa/Airtronics RD8000
  3. recenter the 4 trim bars on the startup screen
  4. Pinout for Futaba 9CHP RF Module Connector
  5. Where to get transmitter case replacement
  6. 9CAP Servo test
  7. 4 servos 1 channel ?
  8. Futaba 9z WC2 question
  9. Optic 6 Throttle Setting Help!!!! Please!!!!
  10. 9C radio HELP
  11. Flaps on Futaba 6XAS
  12. Multiplex radio's 9 and 12 channel
  13. Receiver hit from defective ignition shield
  14. 6V servo @ 4.8V
  15. Is This True?
  16. Multiplex transmitter
  17. Length of the receiver antenna wire
  18. JR591 Servo Failures
  19. Futaba 6EXA
  20. Revo mixing on a X2610
  21. Futaba FF8 problems.
  22. typical range of servo motion?
  23. Futaba 14MZ trouble
  24. Futaba 6EXAS on 75 MHz?? please help
  25. 1st real radio question
  26. Futaba crystal in a Hitec receiver
  27. 2 Std. digital servos on 1 channel of Futaba R138DP?
  28. Hobbico Freq: Checker
  29. 42% Extra 260 (servos)
  30. Transmitter antenna patterns
  31. Compatibility issue with Hitec 56KB servos and FMA M5 receiver
  32. Balsa Products servos
  33. JR Radio buddied up with a GWS ?? Can it be done ??
  34. radio spazzing
  35. KRAFT KP7C TX schematics
  36. Good heli Tx?
  37. Ultra Stick 60 Radio
  38. Electronic Kill Switch for Gas
  39. pcm receiver
  40. Glitching between 9CHP and Cirrus MRX-4 Reciever
  41. Futaba 6 EXAS
  42. Having a Futaba 6XAS fixed?
  43. Having a Futaba TX Fixed
  44. how long can wires be?
  45. Servo/Control Rod Problem - Need Help
  46. In need of field force 6 50th ripmax special limitied adition manual
  47. throttle cut on JR 9303
  48. hitec 945 problem
  49. 9c Charge Leads
  50. Problem setting up my 9X!!
  51. Aftermarket neck strap
  52. best online shop to buy radio gear for giant scale planes
  53. Optic 6 question?
  54. problem
  55. Electronic Switch-design schematics
  56. Hitec 5645, use or not
  57. Futaba 3010 servos
  58. whats different between digital and non digital
  59. Need Help on Old Airtronics Servos
  60. JR DS811 won't stop chatter !
  61. Receiver antenna wire length
  62. trainer cord to a challenger 4000
  63. PCM FM DUAL CONVERSION QUESTION
  64. Futaba 3pm
  65. aileron y harness
  66. Blue Bird Servos? Too good to be true?
  67. Mixes for a SPAD DDust
  68. New Antenna, Whos gonna try it...
  69. Can I use my trans while charging?
  70. AIRTRONICS *TERRIBLE CUSTOMER SERVICE*
  71. Futaba 8U from 60Mhz to 35Mhz?
  72. Futaba Receiver and Jittery Servos
  73. 9CHFS
  74. About to make a purchase and need a little info.
  75. Poly fuse Tx diode jumper
  76. Pros and cons of using 53.4 mhz
  77. malfuction throttle servo
  78. R149DP Rx Question
  79. Futaba 6EXAS versus Hitec Eclipse 7
  80. JR rec. type R770s PCM troubles
  81. Gyros and Mciro-controller
  82. Hitec/Ace R/C Receiver Question
  83. Programming 2 elevator and aileron servos on a 8103H
  84. JrXP8103 Dual Elevator Radio Set up
  85. JrXP8103 Dual Elevator Radio Set up
  86. 9CAP Super - Run amok?
  87. JR 9411SA Gear train failure?
  88. Fc-18 expo on elevator problem
  89. tx question
  90. which futaba servos for world models extra 300s?
  91. pcm receiver
  92. Futaba 149DP w/ 9CAP no respond!
  93. Futaba or JR?
  94. Servo Connectors
  95. MG servo screws
  96. Put and end to dead Hitec Programmer Batteries !!!
  97. Hard crash cause crystal range problems?
  98. JR9303 and 2 rudder servos?
  99. Buddybox compatability. Help please
  100. Futaba R149DP info please
  101. Switches on my 9C
  102. 1 radio 2 reciever programming
  103. Recommended flight packs
  104. Need transmitter and Xtals for FP-R2GS receiver HELP
  105. JR XF631, Auto Shutdown?
  106. spectrum dx3
  107. changing TX battery in a futaba 8au
  108. How Long Do You Keep Your Radio Batteries?
  109. Changing from 72 Mz to 50 Mz
  110. Choosing Servos
  111. Futaba 6EXA and Black Wire
  112. receiver back to Horizon?
  113. JR 662 Charger
  114. 9z dual rudder servo problems
  115. Servo gear lube?
  116. 622 JR Help Needed
  117. Prism Transmitter
  118. 4 servos into 1 channel
  119. Noob needs new transmitter...
  120. Converting to JR questions...
  121. Which receiver?
  122. Question about Airtronics
  123. Procedure for replacing the S9202 pot
  124. 2 receivers for 2 aircraft
  125. Futaba 7ch Receiver broken ?
  126. ProLine literature/information
  127. Glitches....HELP!!!!
  128. Futaba 6EXA radio
  129. Crystal for Airtronics
  130. Futaba 9C Control Knobs--What do you use them for?
  131. How about the ESC?
  132. Pardon my ignorance, but....
  133. Getting Radio system checked out
  134. reciever; servors jitter!!!
  135. potentiometer question
  136. Servo Buzz/Linkages
  137. JR PCM 10 Question
  138. Bad crystal on one Channel?
  139. E-Maxx Radio Options
  140. E-Maxx Radio Ootions
  141. Airtronics Radiant .... NEED HELP !!
  142. first question?
  143. T14MZ and GV-1
  144. Cannot "Y" connect
  145. Shadow 3 receiver's
  146. help-jittering
  147. Questions about synthizied transmitter
  148. Linear ATV and Dual Rates
  149. Servo Compatability
  150. Futaba T6XA Tx Problems
  151. Why not Polk's Transmitters???
  152. a question about range.
  153. Old electronic elevon mixer
  154. Looking for a new servo for my T-maxx. Digital???
  155. Throttle cut, 14mz
  156. Hitec 605 servo arm screw's
  157. who bought all the berg rx's
  158. hitec servo into a JR receiver ?
  159. trouble with rd8000
  160. Which one ? FM or PCM
  161. receiver
  162. GWS CRYSTAL CHANGING QUESTION
  163. How many of you have had problems with your 7 cap radio system
  164. GWS DREAM STARTER RANGE
  165. HITEC 15MZ
  166. Will Rare Earth Magnents Interfear with my Rx
  167. Is the Align 6CH reciever compatible with a jr xp6102?
  168. airtronics servo 94102
  169. Futaba chp- cap- caf.. whats the difference?
  170. looking for servo arm screws
  171. Need help with this vintage radio system
  172. Drill Bit size for servo mounting screws?
  173. heading hold gyros
  174. Identify Single or Dual Conversion Crystals
  175. Synthesized receiver for my 3pk
  176. Is My Radio Legal Help please Channel 44
  177. JETI speed controller Need help
  178. Futaba Synthesized Transmitter Module
  179. Hitech 5645mg fails during installation
  180. Compatible Recievers for JR 6102 PCM ?
  181. Cut antenna wire....
  182. Glitching has me stumped need ideas!
  183. Need help on which servo's to combine
  184. Hitec 625mg (seems v. weak?)
  185. 2 servos and a 'Y'?
  186. RD8000 and SPOILERONS
  187. JR 8425 - 8411
  188. Servo Problem
  189. Futaba FP-4NBL & MCR-4A Question
  190. setup
  191. Hobbico CS 80 servo
  192. Align Tx for Futaba Rx
  193. Hitec Optic 6
  194. Does Any Retailer Have The 9CAF Super With Synthesized TX & RX In Stock?
  195. Transmitter Charging Problem
  196. FMA Copilot 8 and Reciever
  197. Tail Servo for Old Dubros Heli?
  198. buddy box trim correction
  199. Futaba radio charging question
  200. buddy box trim correction
  201. 8UHP programming
  202. HOW DO I KNOW VOLTAGE IS RIGHT
  203. Sharp stick ends for 8U and 9C
  204. no signal
  205. Futaba 9C battery
  206. R127DF and Hitec Digitals, save your plane and read
  207. Hitec Receiver + Futaba Transmitter???
  208. Anodized Gimbals/Stick ends for Futaba 9C ???
  209. Why cant air radios be used for ground vehicles?
  210. Easier Access to Futaba TX battery.
  211. Align 6CH Receiver for Futaba FP-T6NFK Transmitter?
  212. Reversed JR Servos
  213. Shadow III receiver
  214. [Futaba Field Force 6 (T6X)] How to set throttle range.
  215. adding channels
  216. JR to Futaba for Hitec Trainer Cord
  217. JR's new website
  218. Futaba 9C and 9Z
  219. Retrofitting 8611s to 8611A
  220. 2500mAH Li-Ion IN MY EVO!
  221. servos for Sig 4-star-60
  222. JR 8103
  223. hitec 605 servo
  224. Radio South TX Springs vs Futaba HD
  225. Futaba pcm receiver difference
  226. Hi/Lo Band on Tower Hobbies System 3000 Rx?
  227. Need GWS servo advise
  228. Battery Problems
  229. JR PCM 10X
  230. TX gimbal tuning
  231. XP652 replacement antenna
  232. Futaba 6EXAS\6EXH or Hitec Optic 6?
  233. Kraft servos
  234. RX current draw
  235. Futaba R149DP
  236. 14mz music playback help or opinions.
  237. Erratic Futaba Micro Radio set. Whats Wrong???
  238. WIMPY TX SPRINGS
  239. Servo connectors
  240. Royal Evo 12 channel selection problem!
  241. futaba 7c
  242. Futaba 9CAP Timer Question
  243. thinking about buying Futaba 6XAS...
  244. Servo mis-positioning
  245. can the Futaba 7CAP do expo on throttle
  246. "Servo Lock" Truth or Baloney?
  247. Have you fabricated your ownTransmitter Tray/neck strap?
  248. Fubaba 350 gyro set up
  249. futaba 7cap or JR6102?
  250. Channel list
