PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 [52] 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Multiplex 3030 signal test
  2. Futaba R319DPS receiver
  3. Radio question
  4. Pico reciever!
  5. Receiver antenna length
  6. dual rate offset?
  7. Aitronics 94358Z and 95359Z servos
  8. Are noise traps neccessary?
  9. CIRRUS CS-22BBMG
  10. Rudder servo pull-pull wheel
  11. Falcon Servo
  12. Old Radio's
  13. !4MZ--Help!! Exponential Set up
  14. mixing TX & RX brands
  15. which 6 channels transmitter to buy?
  16. which 6 channels transmitter to buy?
  17. post deleted
  18. Semi-proportional right and left steering
  19. FM or AM radio?
  20. Are HPI RF-2 Radio's compatible with Futaba Radios?
  21. Help needed - My TX gone crazy.
  22. -
  23. What connector for a speed control to connect with Neon SS radio system?
  24. Range for JR radio
  25. Best way to discharge a transmitter
  26. Old Airtronics SR2 and with a ESC?
  27. Manufacture Response to Your Posts -- One time only!!!!
  28. JR Channel selection
  29. 8UAF TX
  30. Done with futaba Servos hello JR
  31. Someone from Hobbico/Futaba please reply
  32. Transmitter neck strap/tray for Futaba 9C
  33. Futaba RX info?????????????
  34. Futaba 9c vs 9c super
  35. Kraft Pots and Futaba Pots: Technical Challenge
  36. Futaba 7 CAF
  37. 6V Rx Batt question...
  38. curious about JR 8611A
  39. Feedback on Hitec Optic 6
  40. OFNA micro-failsafe failing?
  41. Programming Differential & Spoilerons using 2 Rx on Ch 1 & 6???
  42. Gyro ?
  43. Do your own JR 8103 Lithium battery replace?
  44. How to Boost the Range of Cheap RC Cars???
  45. Positive Shift/Negative Shift
  46. Help on servo torque specs PLEASE
  47. Exponential-14mz
  48. JR servo repair
  49. Futaba 14MZ Price
  50. 6V Nimh peak question
  51. Receiver crystal
  52. Pro Line RC Repair
  53. 8611 JR
  54. WHAT DO I LOOK FOR IN A "USED" Tx & Rx
  55. Blue Bird Servos
  56. R900S / 9x2 problems
  57. Programing "dual" channel Elevators and Ail. for JR XP9393
  58. Linking 2 servos together?
  59. Setting up a new radio
  60. BERG Receivers....when???
  61. Eletrical system is dead how to test
  62. Futaba 149 DP short
  63. Rx Crystal for World Engines Expert
  64. Do I need a commercial load tester?
  65. GWS Pico RX!?
  66. adapters for servo plugs?
  67. 'Old' Hobbico CS-31 servo wiring?
  68. MacGregor Industries is recruiting
  69. Optic 6 Slave Trim??
  70. Airtronics servo numbers?
  71. Fut 9C, how to reduce end points on aux ch 9???
  72. Can anyone identify this receiver?
  73. Multiplex servos
  74. Question about 6V Rx packs
  75. JR XP6102
  76. Futaba PCM 7ch receiver problem after crash
  77. 9 channel radios.
  78. Futaba 9C sliders?
  79. where to buy Cirrus receivers?
  80. JR and Hitec servo pros and cons
  81. FUTABA FAIL SAFE UNIT?
  82. JR X2610 programing question
  83. Charging TX/RX - Best Practices
  84. Frequency checker from Hobbico
  85. Glitch on rudder
  86. Help!!! 9Z questions
  87. JR XP347 Problems
  88. Futaba PCM 1024
  89. Powerflite charger
  90. Futaba S3003 and S148 Why the price difference?
  91. Servo Connection Type
  92. 14MZ Conditions ? Help ?
  93. Looking for Futaba R128DP receiver
  94. Crystal Question, General
  95. Bullet Proof Dual RX Batts
  96. Channel 6 or 7? 9C question
  97. Webra RX
  98. HITEC HTP-10 Programmer Spreadsheet
  99. Overheated JR 8103 Tx battery???
  100. Transmitters and Antenna Types
  101. Aftermarket transmitter sticks
  102. Synthesized radios
  103. Well I Made the Big Leap!
  104. Servo not centering
  105. Ultra Stick and Eclipse 7
  106. Multiplex Profi 4000 Question
  107. Deans antenna
  108. Futaba 7C Programming Question
  109. reversed servo
  110. Park Flier Radio in a Glow plane
  111. Synthesised Transmitter
  112. radio interference problem, seeking advice
  113. looking for a good basic computer radio
  114. Mixing Transmitter and Recievers.
  115. JR 8103 Tranny Question!!!!
  116. Airtronics Rx Crystal
  117. servos gitter
  118. Transmitter search - HUMMMMM
  119. Futaba S3151 Digital compatible with analog servos?
  120. Receiver Help
  121. Suggestions for good radios to use?
  122. servo extension wires
  123. WTB....Hitec Eclipse 7 or Optic 6?
  124. 9303 & High maH Transmitter Battery
  125. 9303 & High maH Transmitter Battery
  126. Bought a Futaba 7uap...
  127. HITEC 5945's,,, I heard they are not compatible with Y Harness,,,
  128. Airtronics Rx w/ Hitec or Futaba Tx
  129. Servo wire extensions
  130. ganged servos and 14 mz
  131. Sanwa Cygnus 6 ch
  132. Jumpy Servo?
  133. KO Propo Volts
  134. Lynx radio system?
  135. Who has Futaba S9351 or JR DS 8611 For sale New in box? Dealer preffered.
  136. Water in Servo??
  137. FP-S136G Retreact Servo Problem
  138. failsafe
  139. Anyone have a bad hs 55 with good gears?
  140. hitech hs 55 servo stripped gear
  141. Slippery Antenna
  142. Futaba 7UAPS Charging Question
  143. Futaba T6XA - Any problems with this series?
  144. Antenas for Receivers
  145. Antenas for Receivers
  146. mixing hitech and airtronics servos
  147. Cascading Servo Extensions
  148. Failed Reciever
  149. Futaba 6EXA vs 6EXAS
  150. Operating rx/servos at lower voltages
  151. Glitch Counter?
  152. Problem transferring model to another Futaba 9C
  153. Transmitter Batt ?
  154. Micro Servos for throttle on small glow??
  155. Futaba 3152 Servo....any info?
  156. What are JT Charge Switches rated for?
  157. Deleted
  158. FMA Direct SA-10 Servo Lab
  159. RF Module Pinout for a 9ZAP
  160. R319DPS synth vs R309DPS synth recievers
  161. Futaba FP-7UAPS question
  162. 14MZ, Anyone own one?
  163. which wervos to use in a 1:8 scale buggy
  164. Tunning Crystals???
  165. Hitec whoopin' all up...
  166. Please help! Futaba 9z question on programming
  167. What's all that servo buzzing?
  168. Hitech servo output shaft stabilzer
  169. Graupner mc-16 manual
  170. Synthesize or not to synthesize
  171. Need radio help?
  172. Ultra Stick,and JR XP8103
  173. Futaba 6EAX replaced by "Super" Futaba?
  174. Futaba PCM rx
  175. Mode 1 and 2 selectable on Hitec
  176. PCM vs PPM
  177. Futaba 8UAS How to Question
  178. Will a JR Radio work a Sanwa Receiver
  179. Crazy Glitching, Suggestions needed
  180. ANY JR 8611 FAILURES
  181. trainer cord smoked my transmitter
  182. Futaba 8U PMIX 6 & 7
  183. Interference or not?
  184. Y harnesses- what's inside?
  185. JR 9303 questions
  186. EPA and dual rates: airplane beginner seeks help!
  187. JR single stick rudder knob slips
  188. RC Computer Switch
  189. Are base loaded antennas "accepted"?
  190. Information for a beginner on channels, please!
  191. Cirrus Y harness w/servo reverse
  192. Hitec HFP-10 info/ and single servo ??????
  193. Need Help--should be simple Elevon problem
  194. Futaba 4YF Skyport ?
  195. 9303 travel adj on Ailerons Question
  196. tx won't turn on
  197. New Multiplex Radios Mailing List
  198. Hitec Hitec HFS-05MS 5-Channel SC Micro Receiver
  199. I want to change channels.
  200. Connecting it all
  201. HPI SF-2 vs. JR Z590M for throttle/brake?
  202. Expert SL680 Servo Gear Set
  203. Servo Problem??
  204. hitec reciever + 6 volt nimh pack
  205. Hi-Tec servo splines vs airtronics splines
  206. VG-6000 question
  207. May two ESCs connected at the same time damage my Hitec rx?
  208. hitec spectra module
  209. Channel 1: Elevator or Aerilon?
  210. Futaba 9CAP flap setting question
  211. Opinions on Futaba 8U Super
  212. radio / gas engine interferance?
  213. Stopwatch Flight Timer for TX
  214. tx crystal needed
  215. I'm in the dark ages
  216. JR RADIO QUESTION
  217. Battery charger
  218. Help...digital servo question!!!!
  219. Are JR servos and recievers and radios compatible with Futaba?
  220. Battery fires
  221. How to diagnose a receiver problem?
  222. digital roll/pitch indicator
  223. DADS receivers
  224. Elevator servo mix question
  225. Yeah racing crystals...Will they work???
  226. radio matched to plane
  227. I used Lipos without regulator...No problems
  228. Hitec Flash5 questions and troubles. Hovercraft Video Inside!!!
  229. Seeker 6 Rx users...
  230. 14MZ and sound files, make anything you want.
  231. Can you do this? And How?
  232. 9Z wc2 programming question
  233. JR XF622/652 Does It Have EXPO?
  234. FMA FS 8 receiver, glitches???
  235. 7UAP Whats it Worth
  236. Need Some Advice About Glitching
  237. Feigao + Futaba = Compatible?
  238. Did I fry my receiver?
  239. Servo Recommendations- Metal? Nylon?
  240. Official BTA Autopilot Thread
  241. Whip antenna on 50Mhz Futaba 9 channel
  242. hitech synthesizer?????
  243. QUESTION ABOUT RECIEVERS
  244. JR 8103DT PCM Question work on FM
  245. AM RADIO
  246. Hitec crystel RX DC ?
  247. I got the 9C Super yesterday
  248. I'm gonna be buying a new radio for electrics... what do you recommend...?
  249. Need help identifying ESC/Receiver
  250. New Radio/channel matching w/crystals
