PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 [53] 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Cheap 6m Conversion
  2. Transmitter Battery Question
  3. Servos not centering
  4. Reciever Connections
  5. What receiver for my Cuda?
  6. 9C TWIN ENGINE SYNCING
  7. JR,Futaba pos,neg shift question
  8. On-Line PCM9XII Manual
  9. Reset 9C model to Default settings...
  10. JR receiver crystals
  11. need help please
  12. replacing fuse in Tx?
  13. Eagle Tree pilot sets 4 world records
  14. 2/3AA for reciever battery
  15. Thinking about a 9CHP
  16. Multiplex Comander, any good?
  17. Airtronics DC crystals
  18. Futaba 8UHP worth 220USD?
  19. Charging HITEC radio gear with Futaba
  20. What Transmitter and brand ??
  21. Interference on adjacent frequencies
  22. Servo twitching... only 2 are, help.
  23. Futaba 6xas setting slave as channel 5
  24. Switching Channels ???
  25. torriod cores
  26. 8yr Old Futaba 6xa - Should I have it repaired?
  27. Futaba 7C TX
  28. Servo motor
  29. HELP! servos and monokote
  30. Question about recievers
  31. Help me decide??
  32. HOBBICO $60 BUCK PIEZO GYRO
  33. Hitec 5645 MG not centering
  34. Futaba┬┤s 9451 or 9351 servos for 3D?
  35. Futaba 9C books
  36. EMS Servos
  37. DS8411 or DS8411SA ?
  38. Can someone please answer this!!!!
  39. MicroPro-8000 going price
  40. Jr 8611 servo arm screw's?
  41. Savage Radio Freq. Change
  42. 14MZ and Comp-Arf antenna placement
  43. 6EXA with NiMH battery
  44. Servo connections
  45. Looking for Radio Accesories Storage Solutions
  46. 14z looking for wma file of Top Gun Song
  47. 14MZ Mode 2 to Mode 1 conversion info
  48. Proline Single Stick Radio wanted
  49. 14MZ all on one swich ??
  50. Airtronics RD8000
  51. Single stick Transmitters
  52. Proline Single Stick Radio wanted
  53. How do I choose a receiver? lo or hi?
  54. Supertec/GWS servos, Options please
  55. 14MZ backlight question
  56. Range Checking
  57. Retract and Flap
  58. Fp-TM2-AM Futaba module ??????
  59. Mixing twin rudders on a Futaba 7C?
  60. AIRTRONICS SERVOS OLD STYLE
  61. Looking for Synth 40 Mhz Radio ?? JR XS3 or Sanwa/AirTronics MX-3S? Or Suggestions?
  62. Hitec 5995/5955 issues
  63. 75MHz vs. 25MHz radio
  64. KO PROPO HELIOS EX-10
  65. Optic6 VS. 6102
  66. 10X users switching to 9303?
  67. 14MZ TX Pack - Part II
  68. Kraft Radios
  69. Datasafe Ultra
  70. Receiver help please.
  71. Hi/Low band receiver question
  72. futaba s9405 servo replacement gear set???
  73. 14MZ Batteries.
  74. electronics help needed
  75. Antenna Repair
  76. Need help--TX and RX not communicating properly?
  77. My first digi's- need help
  78. ,,selectable switching between 12v & 24v,,,
  79. 6v pros and cons
  80. Kraft Radio
  81. Futaba Service - Beyond the call
  82. Kraft Signature Series
  83. Eclipse 6 meter conversion
  84. Ailerons used as Flaps
  85. 14mz mode 1 Parameter
  86. JR XF622 Transmitter... Can U Help?
  87. Hitec Rx-Hi/Lo channels?
  88. 9303 Help!
  89. 14MZ flapperons myth or reality?
  90. 72 MHz GWS receiver R6N2 - How it work with JR and Futaba at the same time?
  91. hitec eclipse
  92. Gem 2000 Electronic Guardian
  93. Replacement for old style Airtronics receivers
  94. 14MZAP TX Battery Info
  95. 14mz servo monitor zero on sticks
  96. Royal Mini Servo
  97. JR 9303
  98. JR DS 8231 voltage
  99. Using two Elevator servos - best method?
  100. deans whip antenna
  101. Opinion on battery condition
  102. JR XS3 Pro and Hitec Receiver
  103. 9C and tite loops with ailerons/elevator..
  104. How to use my models from 9cap to 9 super????
  105. My new 9 cap super doesnt turn on????
  106. ,,,Anybody else "test fly" new radio's and equipment??,,
  107. which is better???
  108. Servo and long servo arm - Hitec
  109. Futaba 9CAPS or Evo12
  110. 14MZ
  111. New JR 9x Mk2
  112. Fail safe recommendations
  113. JR Tx and Hitec Rx?
  114. NES-4021 JR SERVO
  115. Brand New Hitec Servos 'leaking'?
  116. auto pilots
  117. JR Versus Futaba
  118. 72 Mhz radio used on the ground?
  119. Best servo Prices??????
  120. Glad I'm not the oly one who took the plunge!
  121. 14 MZ Question - Changing Frequencies
  122. Tiny receivers and range problems
  123. Are ball bearing servos worth it?
  124. Futaba 9CAPS or JR 8103.....Which should I buy ???
  125. Extra Channel on a Gemini II TX ????
  126. Robbe (Futaba) Terratop - DIY dual rate module?
  127. Free 14MZ soundfiles for your switches
  128. Can I use this RX?
  129. futaba servos and 6V
  130. Coreless not Coreless
  131. Throttle mix on 9C
  132. hitec vs jr
  133. Engine shut off
  134. PCM or dual conversion
  135. Will be realflight adapter cord work as a buddy cord?
  136. R/C freq in Germany?
  137. JR transmitter-Airtronics receiver?
  138. 10sx / 10x JR
  139. RC Transmitters and Pacemakers ?
  140. 9C super
  141. Servo centering and low/high rates
  142. Replacing RX antenna
  143. AILERONS WILL NOT COME BACK TO NEUTRAL
  144. multiplex profi mc 4000 vs futaba 9ch and JR 9ch
  145. Futaba cystal in Hitec receiver
  146. JR 9303 with Hitec shift selectable recievers
  147. PPM, PCM, Lockout & Failsafe
  148. My servos are dancing !!!
  149. Mixing servo brands
  150. New 14MZ user's your thoughts
  151. hi-speed servo's ?
  152. JR-TX compatible with Futaba and Hitec?
  153. hs-55
  154. GWS Single Conversion Receiver Question
  155. Same servos, one moving slower
  156. Futaba FX-40
  157. Disaster Waiting To Happen !!!!!!
  158. Disaster Waiting To Happen !!!!!!
  159. Disaster Waiting To Happen !!!!!!
  160. jr 622 book
  161. Reversing the servo direction...
  162. oops jr rx question
  163. Best Servos
  164. FUTABA FP-R127DF RECEIVER
  165. Beautiful Futaba 40 FX
  166. XP6102 Flap/Crow set-up
  167. Hitec servos good or not???
  168. low band cystal in hi band transmitter
  169. RCU Pimps for Advertisers
  170. Futaba 8UAP TX how good is it?
  171. Hitec Electron Receiver
  172. Eclipse 7- reinforcing the handle
  173. Receiver/Servo Issue
  174. Ace Battery Chargers
  175. Antenna routing
  176. Cirrus 5.4 gear diagram?
  177. digital airtronics mx3 question
  178. Airtronics RD8000
  179. Futaba's S3151 Digital Servo: a good choice?
  180. Futaba 3003 Vs hitec HS-55BB+
  181. IT U HAVENT NOTICED I NEED HELP!!!!!!!!!!!
  182. 14 MZ Heli Vrs Airplane version
  183. servos for edge 540 73" wing
  184. just purchesed a used kangeHS-475HB 1/4 scale question
  185. How do I set up my 8UAF for a flap switch?
  186. Retract Servo power set up....
  187. Cross Trim in MPX Profi4000, How?
  188. Servo size?
  189. JR Tx, Futaba RX. Will they work together?
  190. Seeking Futaba radio manual or instructions
  191. multiplex slim star digital servo
  192. When is Hitec's new AIRBORNE Spread Spectrum radio going to be available?
  193. Fut S9405 Servo - 'NiCd Only' ?
  194. New FUTABA FX 40
  195. Multiplex Royal Evo
  196. extensions????
  197. servo's for 1/4 scale Spacewalker
  198. Happy with Futaba 9ZaWc2 or Upgrade to 14MZ
  199. Retract Servo Question
  200. 9303 ZPCM MODIFICATION HORIZON HOBBY
  201. MPX Cockpit
  202. Next Radio?
  203. Looking for old time Deans connectors
  204. Potentiometers in Futaba 4NBF TX
  205. Hitec Eclipse 7 or Futaba 7C ?
  206. Question about tq3 internals
  207. Nice to have servo #s tell specs like radios
  208. Problem with receiver
  209. where to find Profi 4000 tutorial
  210. NEW 9 cap Super??????
  211. PPM and PCM RF sections in modular radios
  212. Optic 6 Programming Lockup
  213. Futaba PCM
  214. Transmitter Case at a Bargain Price
  215. Futaba Tx, Hitec Rx, Jr Servo's=Possible?
  216. JR radio questions
  217. Flew w/my new Optic 6
  218. Bare Bones Controller
  219. DC Components
  220. JR Rx & Hitec Tx
  221. How to fix side covers on futaba FG ??
  222. JR XP783 - Malfunction
  223. Buying new computer tx
  224. Radio Equipment & Setup questions for 69" Pitts & "rusty" R/C'er
  225. Receiver Crystal frequency.. 61.790 ???
  226. Radio South
  227. Sticky Tx Antenna
  228. 7c help
  229. Help me decide between 2 ebay radios>PLEASE<
  230. servo reversing in flight?
  231. Rx and Tx compatability?
  232. Which band, 50 or 72"
  233. Futaba receiver question
  234. Hitec servos
  235. Retracts with a 4 channel??
  236. dual conversion receiver?
  237. programming flaps on futaba
  238. Futaba R148DF Receiver, anyone using it?
  239. How to change servo gears?
  240. CamPac for FF9
  241. Difference in model #'s
  242. cox cobra 2ch radio
  243. Rx crystals
  244. What is Mixing Features of Comp. Radios
  245. Coreless servo for dual servo elevator
  246. Hitec receivers?
  247. Seeker with Hitec synth Tx?
  248. Airtronics and Hitec Flight Packs
  249. Futaba 3010 servos
  250. Airtronics Caliper 3ps info?
