PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 [54] 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. What is Mixing Features of Comp. Radios
  2. Coreless servo for dual servo elevator
  3. Hitec receivers?
  4. Seeker with Hitec synth Tx?
  5. Airtronics and Hitec Flight Packs
  6. Futaba 3010 servos
  7. Airtronics Caliper 3ps info?
  8. Airtronics Radiant Case
  9. New Optic6! Aaahhhhh!
  10. Hitec HS475 Problems
  11. Blue Bird BMS630-MG Servos?
  12. Blue Bird BMS630-MG Servos
  13. servo gear replacement
  14. Synthesized TXs?
  15. futaba 9wcוו or jr 10 x
  16. Peak charge Tx batteries?
  17. HPI TX-2 radio controller
  18. jr 10x or jr 9303
  19. Adjustable endpoints on HS-75BB retract servo?
  20. Burg Receivers...Why Should I?????
  21. JR Radio help...any Techs out there?
  22. Seeker II and Futaba 9cap
  23. JR Receiver Chirps and Craps Out
  24. cold temperature no radio
  25. Hitec Optic 6 question
  26. throttle servo in reverse?
  27. Trouble w/new RD8000
  28. Best JR and HITEC servo prices?
  29. How do you convert a Buddy-box?
  30. MC3010 program
  31. JR Apex 7 Manual
  32. Help please
  33. FUTABA 9C Synthesized Module Help
  34. Shadow receiver, any one try it yet?
  35. VG600 & VG6DR(sanwa) buddy lead
  36. [Deleted]
  37. Futaba S9254 Digital Servo and 6V Battery
  38. Futaba's new synthesizer & receiver for 9C!
  39. Multiplex Evo 9 Programming Probs
  40. from 72 to 35mhz?
  41. Ready to Purchase Futaba 9 Super, which receiver?
  42. Futaba 2ER crystals?
  43. Need narrow band explaination
  44. Warning!
  45. How to verify transmitter frequency??
  46. Karbonite Gear Strength
  47. Pcm interference
  48. Is my radio to old?
  49. Aristocraft/Hitec Challanger 550
  50. Be Aware!!!
  51. JR X347 Won't turn on
  52. Tower TS 51 and Hobbico CS 51 Servo Qs
  53. neg/post shifts
  54. good reciever for a JR9303
  55. Dirt on the HITEC 5955....RC VERSION ANYONE???
  56. Multiplex Royal Evo 9 Programming Woes
  57. Which of these two receivers would you use?
  58. RC crystal type codes
  59. Optic 6 CROW Defect
  60. Old transmitters, need idea of value
  61. JR Module
  62. how to check transmitter with freq counter??
  63. Antenna Wire - Cut & Solder
  64. Airtronics high-end demise?
  65. 4.8 - 6.0 volt
  66. Who has the best prices on JR and HITEC
  67. Servo Jittering
  68. Airtronic (old style conn) servos to HiTec RX ?
  69. JR / Futaba plug compatibility question
  70. different brand radio and reciever
  71. Futaba 7c with crow?
  72. Optic 6 or Futaba 7C?
  73. Changing TX crystals...
  74. Futaba 9C Conversion to Single Stick.
  75. Futaba 9CHP lost memory!
  76. Need to buy Futaba TX Buddy Box
  77. buying a radio
  78. 9C - 9C Super FYI
  79. jaguar throttle trim messed up
  80. Multiplex space scooter help
  81. 1st radio advice
  82. Hitec Optic 6 vs. Eclipse 7
  83. Hitec 5945
  84. Help with jr-x378 radio fuse
  85. Mini PCM reciever
  86. Dead Transmitter?
  87. 8U Super + Flight modes
  88. Spektrum type DSM for air use?
  89. Matching Elevator Halves - The Easy Way!
  90. Charging Polarity: Futaba Vs. Airtronics
  91. Staying with one manufacturer for entire electrical system
  92. Why can't I use....?
  93. Add 2 channels
  94. burnt crystals?
  95. installing servo's
  96. Five cell pack / JR Receiver
  97. How to create a fully redundant RX RC system ?
  98. 9c helo programming
  99. 75mhz crystal in 27 mhz Transmitter??
  100. "Berg" RX's??
  101. HiTec - Red Servo Arms
  102. World Engines Expert
  103. servos for ultra stick 120
  104. How many of you use HAM Ban radios?
  105. How many of you use HAM Ban radios?
  106. Anyone tried blue bird servos
  107. Floppy antenna for Futaba Fieldforce 6 (T6X)?
  108. 20" Speedboat, 36" Antenna wire.. Problem?
  109. Convert PPM to PWM
  110. JR 9303 or JR 10X
  111. Futaba 9C sqeaks!
  112. 7CH Radio
  113. what goes where
  114. need a ? answered
  115. need a ? answered
  116. 645mg overkill
  117. Recommendation for single radio to run multiple airplanes?
  118. Standard size Blue Bird servos
  119. JR 6102 and Snap-Spoilerons?
  120. Help With JR 10X Aileron Travel Problem Please
  121. 27mhz range increase with CB stuff????
  122. 27mhz range increase with CB stuff????
  123. Ace noise trap
  124. Airtronic Super RD6000 Newbie Question
  125. Range of dual conversion receivers
  126. carbon body
  127. 9CHP can the throttle ratchet
  128. Airtronics receiver with Hitec/Futaba servos
  129. graupner mc24 gold
  130. PCM problem
  131. 9C Spoileron setup?
  132. HOW TO ASSIGN FLAPS TO A SWITCH ON A JR 10S
  133. Hitec 55's with FMA receiver?
  134. Transmitter---no crystal
  135. JR Servo Pulse Center Point ???????
  136. Questions about radios
  137. jr transmitter problem
  138. How many degrees of rotation available from average servos?
  139. Shielded cable for servo extentions?
  140. Centering the stick?
  141. Trainer cords.. for different brands of Transmitters?
  142. Buy 7C or 6EXA
  143. Need instructions for Hitech 720 Challenger, can anyone help?
  144. JR 9X/9XII/MX22/9303 Modifications
  145. Which channel to add battery to?
  146. Are there aluminum servo cases
  147. Futaba-- JR shifts
  148. Rd6000 Strange Problem
  149. With a 6ch Tx can I use a 3ch Rx?
  150. Question on Hitec electron 6 receiver
  151. Futaba 9 CAP frontplate paint trouble!
  152. Where to find base loaded/whip antenna
  153. Kraft Channel Master
  154. Expert Electronics
  155. interference?
  156. futaba 7c question
  157. is it ok to use a hitec flight pac with a JR radio?
  158. hitec and futaba
  159. Futaba PCM1024 Receiver on 6 volts - problem
  160. 9C Ch9 End Pt Adustment?
  161. Confused about Hitec 7 Eclipse models-HELP
  162. Help with Graupner/JR please
  163. Futaba Receivers
  164. Proline Single or Dual Stick Radios wanted
  165. Traxxas TQ3
  166. HiTec Optic 6 Tx Bug
  167. Throttle Channel Failure
  168. DPM 26% Edge 540T tail feather glitches
  169. will futaba and sanwa work?
  170. jr radios
  171. 14MZ news
  172. Futaba Memory Expansion
  173. Flpaeron/Spoileron separate switch on the 9C?
  174. Futaba 9CAPS Purchase
  175. ARE JR DS8511 (same as 8611) GEARSETS ANY BETTER THAN 8411's?
  176. Refurbishing servos
  177. Single Conversion RX
  178. JR PCM 9x Master PCB pictures
  179. JR 9X Software upgrade?
  180. 6102 question
  181. Ooops...antenna cut...
  182. Antenna deployment - impact on receiver range
  183. Servo jitter from Remote Glow Starter
  184. Hitec Laser 6 D/R problem
  185. Bouncing servos
  186. Transmitter Purchase
  187. Crow on 1 switch, 9C
  188. XP8103 Broke Elev. D/R Switch
  189. 9cap super
  190. Hitec HS-635HB, Tower TS-64, Hobbico CS-64 servos
  191. Optic 6 Backorder Problem
  192. Hitec Eclipse and coupling flaps to ailerons?
  193. Is a Gold sticker always good?
  194. Where to find an owners manual??
  195. TX question
  196. Help - Older FP-6NFK broken switches
  197. FMA S360 Servos
  198. free transmitter
  199. free transmitter
  200. 14 year old (new) AM futaba radio
  201. Futaba 9CAP or JR 9X ??
  202. hitec 81 vs. hitec81mg
  203. Questions about older JR receiver
  204. Do Certin Plane's Have Radio Problems ??
  205. Hitec Eclipse 7 ?
  206. Jr crystal question
  207. Spectrum Hobbies?
  208. 4 servo acro wing How to W/ Fut 9C?
  209. RD 8000 with Hitec Rec. Pack
  210. radio help! rf module? frequency? 40mhz to 72mhz some how?
  211. JR 2610 = ?
  212. JR 9303 TX Memory Backup
  213. oppisite sevros
  214. Radio Interference
  215. Futaba ratchet action
  216. Futaba Radio Manuals
  217. Unidentified Kraft Part
  218. HiTEC Optic 6 Problems
  219. JR 10X
  220. Universal Trainer Cord?
  221. Hitec Digital Servo Programmer vs Futab TX
  222. 2 airlerons, 2 servos
  223. Question about sevo reversing...
  224. Balsa Nova 120 What servos?
  225. Best 4 Channel Radio?
  226. IS THE FMA S301 A GOOD SERVO?
  227. Hitec Optic 6 QPCM
  228. I think I am ok but would like your input to be sure
  229. Berg 5 will JR Crystal work in it OK
  230. "NI-Cad Only" servos?
  231. Custom firmware for Multiplex Royal Evo ?
  232. JR ES579 servos
  233. single stick transmitter
  234. need gyro advice
  235. Futaba module retuning
  236. JR 783 Fuse
  237. Making Sanyo AA 2300 NiMH flight packs?
  238. The best radiosystem for around 500$
  239. 9C and flapperons, need a little help..
  240. Torque, confused!
  241. JR PCM 9X
  242. Signal boost
  243. RF receiver loses signal ?
  244. single conversion receivers
  245. KO PROPO digital programmable servo
  246. Radio problems Please Help!!!
  247. Futaba S3151 servos play in output shaft....
  248. New Base Load Antennas
  249. Futaba high-low band
  250. No range. Help.
