PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 [55] 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Reversed servo
  2. AM vs FM
  3. Radio Glitch????
  4. JR 6102 Air or Heli - difference?
  5. PCM Question
  6. Magnets and receivers? HELP
  7. hitec 605's
  8. When to use noise supression buffers or toroids ????
  9. servo ext. wire size
  10. Hitec Agressor Questions
  11. JR v.s. Hitec
  12. 9C help with multiple servos
  13. Antenna retracted on Futaba burn out the radio?
  14. 9C for $309 good deal?
  15. JR R700 help!
  16. Any1 know about the Ko Propo Helios EX10
  17. Synthesised radios
  18. JR XP6102 and which micro servos?
  19. Home-Made Transmitter Stand
  20. Cirrus cs62bbmg arms
  21. Multiplex Jumbo Speed Servo
  22. Tower Hobbies Servos?
  23. what size servos?
  24. switching rx and servos to new plane. Checklist ?
  25. Old Radio
  26. futuba transmitter
  27. Futaba S3004s or ???
  28. Are Base loaded Receiver Antennas OK for fixed Wing??
  29. How to reverse a servo???
  30. Tx Rx question
  31. remote bus for servos
  32. PC cable for servo extensions
  33. Hitec servo's
  34. New Hitec TX's for sale anywhere?
  35. New Futaba radio T14mz 14ch
  36. looking for an oldie
  37. replacement servo gear oil
  38. PCM9X Range
  39. Cap Head screws for Hitec?
  40. futaba 4ybf
  41. Using Futaba Tx with JR Rx
  42. How did you run your base loaded antenna (in plane) ?? Got Pic's ??
  43. Great Planes Switch Harness
  44. Hitec 535 RX - Positive and Negative
  45. Best 6 channel computer radio under $200
  46. Last year for JR Single Stick Transmitter ?
  47. radio questions
  48. servos spazing!
  49. Futaba 9Z WCII reciever compatability
  50. Hi/Tec 4000
  51. Problem with Futaba Conquest 6 (channel 4 and 5 conflict?)
  52. Big Problem: I'm a newbie.
  53. New Futaba 9Z Probs
  54. Ace Silver Seven TX (ch44 AM)
  55. Futaba Magnum 3PM-FS Question.
  56. Hitec HS 635HB servo, good value?
  57. Why is the 9Z better?
  58. Sanwa Servo compatibility
  59. TRANSMITTER CASE
  60. mpi mx6800
  61. RD 6000 Super message screen
  62. RD8000-heli mode for plane use?
  63. stock gyro
  64. R127DP PCM Receiver
  65. ultra stick 120 and 6XAS transmitter question
  66. U-Can-Do 3D .46 Servo question
  67. Radio Functions
  68. Futaba 6EXA radio
  69. how to replace a broken gimbal (pics)
  70. Excell 7 Pulse Proportional Transmitter (7) channel . Is this any good?
  71. Servo and Receiver advice
  72. Futaba 3PM -- thoughts from users?
  73. futaba s3151 digital servos????
  74. Elevator Flap mixing
  75. antenna wire
  76. reduce servo rotation for air retracts Fut 8UHP
  77. Servo question
  78. Using receivers after a crash?
  79. No Warranty on HiTec Servo Gears!
  80. RX/TX
  81. A second Radio?
  82. 1997 Futaba T6XA; still legal?
  83. Help, reversed charger polarity
  84. JR: X-378 vs. 6102???
  85. Really need help Jr 9303 with seeker II
  86. newbie needs radio advice, please help
  87. Futaba Buddy Box (Battery?)
  88. Help me fix bad gimbal on my Real FLight TX
  89. JR 8411 or 8611?
  90. Clitch from Hel%0&*. only on the right ?? HELP!
  91. Where to buy replacement TX battery?
  92. Good ~9 gram servo?
  93. Hitec 555 mini RX in .46 size spad
  94. Receiver help
  95. Is it ok to use a Futaba servo with a Tower Hobbies reciever?
  96. Strange crystalproblems with my Eclipse7
  97. Question about crystals and QPCM RXs
  98. matchbox
  99. AIRTRONICS VANGUARD 6 CHANNEL FM RADIO
  100. SUPER 8 programming ???
  101. TX Crystal in a Receiver
  102. Receiver service question
  103. Flaperons with JR 662 and Hitek 555 reciever?
  104. mixing and matching receivers
  105. dual elevator servos
  106. JR servo Question
  107. Tower Pricing = Insane!
  108. Jr 8411's w/ Futaba Receivers, Li-ions at 6V Regulated
  109. Need a large VERY FAST servo
  110. Standard/Mini Servo Mix (Futaba)
  111. how short to cut my antenna?
  112. Regular servo as retract servo??
  113. Futaba S3305MG Servo
  114. RF modules...
  115. Optic 6 or what?
  116. Using Lipos in Transmitter.
  117. JR Website
  118. 8103DT Programable Setups
  119. Plantraco DSP4-SC
  120. 9X help!!!
  121. servo wiringfutaba to airtonics
  122. jr x347 needing a reciever
  123. retract servos
  124. Futaba recievers
  125. Futaba 9Z wc2 Failsafe Question
  126. Hitec servos [225 bb]
  127. Futaba G plugs needed
  128. lacing tutorial, lock you connections
  129. Tank Expierament
  130. Beats me... two tx's, one rx, two crystal sets.. help!
  131. How do I power a Tx from an AC 110v wall outlet with a DC converter?
  132. Making my own extensions,,,,,ARGHHHH
  133. 9c vs 9c super
  134. Radio glitch question #2
  135. Futaba 3050
  136. A new KNOBBY box RC radio "recommendation"...
  137. Digital or Coreless...
  138. great pains Real Flight G2 updates?
  139. base loaded antenna qustion
  140. Hitec Optic 6
  141. Programming EXPERT GLOW DRIVER w/8103
  142. Hitec Eclipse 7 questions.
  143. Difference between FM and PCM
  144. multiplex royal evo 12
  145. Controller Setup, Dont know which stick does what.
  146. Secure channels for RC planes
  147. GWS R6N II 6 FM Micro Receiver question
  148. 8UHFS Mixing Question
  149. Hitec Flight Pack Compatible with Futaba Tx?
  150. JR reciver caution
  151. PLEASE HELP........ RX issues!
  152. Futaba 9Z dual rate problems
  153. JR 9X (9303) programing question
  154. Tower Retract Servo.
  155. Servo extensions too long - need help !
  156. Switching wires on a Cirrus servo?
  157. Any tricks for big fingers removing leads from RX?
  158. Berg Micro-Stamp w/ Hitec Crystal
  159. Hitec Optic 6 vs Futaba 6EXA vs Futaba 4YF
  160. JLine Quattro help!
  161. Hitec or Futaba. Best brand?
  162. Carbonfiber blocks radiosignals?
  163. Male-male extensions
  164. OLD TX BATTERY CONVERSION
  165. Polk no longer supporting RCU Forum?
  166. Futaba 9c or 9z
  167. JR 9303 Transmitter
  168. 8301 smoke mixed to spoiler in glider mode
  169. Servo extension wire?
  170. GWS Servos
  171. JR PCM9X radio
  172. Zhen Hua PCM
  173. type of reciver ???
  174. The Amazing Sky & Technology Receiver, What Happened?
  175. coreless servos
  176. FutabaT6XA discharging with dioade block
  177. Old cirrus servos
  178. too small a chanel for all those wires and airlines
  179. radio recommendation
  180. Beyond 6 channels
  181. PCM vs Fm Help selecting a transmitter
  182. Futaba – blue screen of death
  183. FUT 9CAP-HOW TO PROGRAM FLAPS???
  184. NEW JR 9303 Trouble
  185. NEW JR 9303 Trouble
  186. Futaba T6XAs and R149DP COMPATIBLE?
  187. which rudder servo?
  188. More flight time?
  189. History of R/C
  190. Is this any good for measuring servo current?
  191. when standard servos are not enough
  192. Where to find multiple servo connectors?
  193. Futaba 7c battery pack
  194. Question about PCM and FM
  195. FUTABA T4YF - CRYSTAL ? WHERE
  196. need advice concerning pcm
  197. is digital "tune up" needed?
  198. Radio Control recommendations?
  199. Futaba 3010 Servo With Gas
  200. READ ALL ABOUT IT!! Futaba's Newest Toy
  201. JR/Graupner MX-22 Availability?
  202. MX3S transmitter recharging
  203. FSx Co-Pilot PPM Receiver Questions
  204. Who fixes JR 652 ?
  205. NEED RADIO HELP..FUTABA SKYSPORT-T4YF
  206. Is $240 a good price for a Futaba 9CAP?
  207. S3001 vs S3004 servos?
  208. Digital Servos - PCM required??
  209. FMA FS-8 receiver with gas engine? Anybody?
  210. 14mz
  211. MPX 4000 - sequenced gear & doors
  212. I live too close to the field, what do I do?
  213. Is Airtronics MX-3S synthesized radio good?
  214. VG6000 vs Optic 6 vs Fut 6EXA
  215. JR 9303 Receivers
  216. Help me choose a Futaba Servo!
  217. Best place to buy JR 9303 Heli
  218. Karbonite servos for 50cc 3D
  219. Harry Higley 9C book-Good stuff
  220. servo reversing
  221. Radio South new Voltage monitor
  222. Servo Extension Length
  223. Can one 7 channel RX handle 8 Digital Servos???
  224. JR 9303 users: any bugs to report?
  225. Hitec Flash 5 flaperon setup
  226. what's the difference....?
  227. Futaba S3151 Digital Servos OK?
  228. 9C --Crow,full span ailerons ???
  229. airtronics rd6000
  230. Micro servos and receivers
  231. Schulze Alpha 8 FM Receivers
  232. Futaba Conquest AM radio..help
  233. 9C & 9Z & NOW 8U Service Menus revealed!
  234. JR R610UL Receiver
  235. Redundant Batteries
  236. JR radio Poll
  237. New Futaba site
  238. Need manual for JR century VII radio
  239. JR Servos Voltage Operation
  240. Please help!
  241. Well Futaba did it to me again
  242. Flight pack acting up. Busted reciever?
  243. Signal problems.
  244. JR Trainer cord
  245. Futaba MSA-10
  246. Low down on Digitals
  247. Eagle Tree Systems Wireless Dashboard review is now online in the RCU Magazine
  248. Servo failure mode?
  249. Futaba 9254 and 9252 servos question
  250. Donate Old Radio Gear
