PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 [56] 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Kyosho advance PCM 5
  2. HELP! JR Radio
  3. Question for you guys on the ham band...
  4. Recycle Battery in Futaba Skysport.
  5. JR x347 radio operation
  6. Old Cirrus CR-217
  7. PCM; an aid for multi model owners?
  8. JR or Hitec servos
  9. Futaba 6EXA - Servo jitter and severely reduced range
  10. need JR 4131 reversed
  11. Where to get new antenna for Hitec receiver
  12. JR 8311 servo's
  13. 9202 at 6volt Q
  14. JR 9303 or Futaba 9CAP Super
  15. MZK micro 6 RX
  16. 8 channel Futaba recievers bad?
  17. Economical Place to Find HiTec servos?
  18. 7CHP vs. 9CAP
  19. Complex servos?
  20. 9C and DSC cord
  21. Need Radio Help!!??!!
  22. FUTABA 9VAP TRANSMITTER RESET
  23. Useing Expo. ??? Getting the rite fill !!!
  24. Locking servo Connectors
  25. JR radios convert 72 to 35
  26. Help selecting a transmitter
  27. Futaba parts- HELP!!
  28. Transmitter Output Wattage
  29. Trim Offset on JR 8103
  30. 9caf/cap
  31. SERVOS JUMP??????
  32. Who makes this servo
  33. Futaba High Band / Low Band
  34. TX question. PCM and FM receivers, Futaba
  35. Futaba Skysports 6A FP-T6VA Circuit required
  36. Burnt 9C circuit board causes crash !
  37. Blue Bird Servos
  38. What is a good tach.?
  39. Radio/Servo problems. Help please??
  40. Hitec 5475's
  41. Need help on new Radio
  42. Newb question. Mixing?
  43. Which 6 Channel
  44. MC4000 heli mixing question.
  45. T-Maxx 2.5. Just starting to race, what radio??
  46. Mini-servo limits?
  47. can't get the 2 elevator halves to move simultaniously
  48. Need to Borrow/Rent a Futaba 9Z
  49. Help fixing electric boat for youngster????
  50. urnedurnMini Digital Keeps Lockign Up, Need it fixed within 12 hrs
  51. Futaba 7UAF Super and Crow
  52. nacdanials onboarg glow driver?
  53. Rx for Synth TX
  54. CAP9 Programming
  55. bluebird servos
  56. Karbonite and Locktiteā„¢ is a no no...Please read
  57. oz/in vs. oz * in servo torque
  58. Free return shipping from Futaba in December Special
  59. Futaba 9ZAP programming
  60. Futaba 9CAPS Radio
  61. Add brake light to Traxxas Revo
  62. How much power does a servo use?
  63. servo horns for futaba 9152 or 9153
  64. Airtronics RD6000 programming
  65. Servos Kyosho Cap 232
  66. Futaba 3001 3004
  67. radio not able to conrol esc full
  68. Connectors
  69. Variable rate radio mod
  70. Servo "shelf life" ????
  71. Switching out Rx
  72. Older Futabas
  73. CAFS vs CAPS
  74. during last summerWouldn't turn left....
  75. Smallest recommended servo for throttle
  76. Choke servo for gas engine
  77. Hitec HS-5645 digital servo
  78. Transmitter and receiver compatibility
  79. DAD reciever crystals
  80. Futaba FP-T6NLK Conquest?
  81. DAD reciever crystals
  82. Can someone give me a basic explanation of 'exponential'
  83. Rverse polarity
  84. Futaba/JR cable adapters
  85. 9ZAP acting up
  86. airtronics 94732 servo
  87. Airtronics Vanguard Radio Reversing
  88. Newbie servo question
  89. JR8411 SERVO CREEP
  90. I'm getting interference!
  91. Flaps
  92. FMA M5 Receiver cuts out throttle on Zagi
  93. servo delay
  94. Setting up split elevator/aileron with 9c?
  95. Which Radio to buy?
  96. 7CAP vs 7CH
  97. 14 MZ Better protected from "shoot downs"?
  98. Servo power /torque /speed
  99. Futaba flaps
  100. JR 9X / 9303 heli / Air differences
  101. using my new fancy charger with transmitter
  102. Reversed Servos
  103. Futaba S9152 and S9153 Servos
  104. Rudder and Gyro
  105. Futaba 14MZ powered by Windoze
  106. Graupner MC 24 Manual (English version(
  107. FMA T80F72 radio
  108. Aileron Diff with a Futaba T6XAS? Is it possible?
  109. Jeti Receiver 27Mhz?
  110. Difference Between Futaba 138DP & 139DP Receivers
  111. Servo Pins and Connectors ???
  112. Anyone using the Hitec HPD-07RH Receiver?
  113. What Arms for Expert servo?
  114. New Tracker III
  115. Whats the difference(PMC)(FM)?
  116. Servo Extension Connector Holders
  117. Servo Recommendation (dynaflite decathlon)
  118. Luxor Rx?
  119. Problems with hitec eclipse
  120. Alternative to HS225MG servos
  121. antenna inside or out
  122. Eclipse Glitch
  123. Blown Rx
  124. Back up RX battery set up?
  125. Micro Receivers & Futaba 6exa
  126. airtronics vg6000
  127. Futaba 7U vs 8U
  128. futaba 6exa
  129. 7CAP Same as 9CAP mixing-wise for aeroplanes?
  130. Best price for JR 8611's
  131. How strong Rx battery to use in airplane equipped with 4 digital servos?
  132. micro servos
  133. replacing an rx antenna question
  134. New radio please advice!
  135. QUESTION ABOUT JR CRYSTALS
  136. Need for Boost/Buffers ????
  137. for automotive specialists
  138. 7CAP setup with flaps
  139. Airplane vs car servos
  140. Futaba T6EXA throttle gimbal pin
  141. HELP futaba 6XAS
  142. Sharing the R/C band
  143. PCM transmitter
  144. Looking for >>Futaba RX FP-R128DP
  145. Jr 4721 Servo question
  146. Best price on JR Servos?
  147. 9ZWC vs Royal EVO 12 Opinions
  148. 28% EDGE 540T 3 hours flight time
  149. Does the Futaba 9152 servo have a standard output shaft?
  150. Multiplex Royal Scanner!!!!
  151. JR 9303 Xmtr balance
  152. jr 8411 to 8411sa conversions
  153. Best Place to Shop forGraupner/JR Radios
  154. Futaba Radio programing
  155. 8103 throttle Curve?
  156. PCM?
  157. Radio glitch question
  158. Best price on Hitec 5945's
  159. receiver's antenna broken
  160. Loading a test meter for testing
  161. Futaba 4YF train cord linked to 9C - Advise needed
  162. Fut.9201 Specs
  163. Futaba charging question?
  164. Hooking up 2 ESC's
  165. Hitec Focus 4 Problem
  166. Sharing the R/C band
  167. Multiplex royal evo 9 should I?
  168. Spectra Module Question
  169. Need manual for JR X2i
  170. transmitter / reciever question
  171. Jr 9303 PCM not working help
  172. antenna in fiberglass fuselage
  173. Hi band Lo band on pcm
  174. JR homepage
  175. Multiplex EVO12 Range check??
  176. Futaba comparison
  177. servo classifications by Tower Hobbies
  178. Receiver Antenna
  179. Hitec 945MG Servos - Any Good?
  180. Stylus Display?
  181. 9ZwcII Battery died
  182. Transmitter Problems!!!
  183. Aftermarket Servo Arms for Futaba s9152
  184. Airtronics RD6000 Super switches
  185. Modify radio for new Freq in the Amateur band..
  186. Futaba S3010 Current Draw Concern
  187. tower pro micro receiver
  188. Airtronics RD8000 flaps issue
  189. receiver crystal
  190. Hitec 422 servo question
  191. Supplying Servos with 7.2V
  192. Volt watch troubles
  193. MPX4000 Tx & Protech servos
  194. futaba 3152 digital servo
  195. Fail Safe Throttle Idle T6xas but voltage > 4.8
  196. Remotes
  197. futaba 7c or hitec optic 6
  198. Availability of servo pots for Hitec5945 servo.
  199. MOUNTAIN MODELS Smooth E REPLYYY!!!!!!!!!
  200. I'm Stumped..Help!
  201. New to r/c planes. need tips on radio syetem
  202. Buddy Box ???
  203. Blue bird servos
  204. View your mixers thru the PC audio input
  205. Crystal confusion
  206. New transmitter needed ? Multiplex.
  207. Futaba 7 CAP vs Hitech 7 Eclipse
  208. J-Line Quattro Mode 1 to Mode 2, simple?
  209. JR 6102!!!
  210. Airtronics Stylus won't transmit.
  211. J.R. QUESTION
  212. Futaba 6 EXA used in Trainer mode
  213. Which receiver whould you choose?
  214. Simprop Radio
  215. Servo Recoils
  216. What mixes do you use to set-up your plane?
  217. Need a op manual for old KRAFT Tx
  218. MOVED: Battery Life Expectancy
  219. JR 10X opened diode on battery pack board??
  220. Airtronics RX problem!
  221. JR 10s 10sx 10sxII 10x
  222. 180 - 270 degree servo
  223. How many model memories is enough?
  224. throttle adjustment question? JR radio?
  225. Hitec HS50 wiring
  226. Coreless v's ferite servos
  227. Single stick transmitter to work with flight sim
  228. JR R700 rx question
  229. Replacement TX Antenna options
  230. How do I size my rec battery ( 7 servo's)?
  231. Need advice on TX battery
  232. Just joined club. Should I change my GWS receivers ?
  233. Rookie question about RX antennae???
  234. Dual Rate Question
  235. Bad Antenna????????
  236. What am i looking for
  237. Optic 6 for Sailplanes
  238. EXPO Question
  239. Interchanging crystal sets
  240. Radio differences
  241. Servo Crimping Tutorial
  242. Polks Seeker II Quick question
  243. New Hitec Servos, anybody playing with them
  244. flight modes in Futaba 9CAP?
  245. tx question 7C
  246. Pulling my hair out-trying to get dual ail. servos right w XF631
  247. Futaba 9252 will it work with 6V NIMHs batt
  248. Issue on 7C bug deleted..............
  249. Radio purchase advice
  250. Which Radio Manufacturer Has the Worst Customer Service...
