PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 [57] 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. FUTABA SERVICE- unreal prices
  2. HITEC HS77's ------ ANY GOOD ??
  3. Futaba T14MZ price is posted at Tower
  4. TX/RX Interchangability?
  5. Aileron servos that see-saws
  6. damaging transmitter modules
  7. Radio hit or short ?
  8. Hi Voltage lines
  9. Which is your favorite Radio
  10. Anyone try the Dymond "Remove Before Flight" radio switch?
  11. Futaba R138DF Problems
  12. Futaba 9ZAP Questions
  13. low friction servos
  14. Futaba Reciever
  15. Rubber Ducky Antenna
  16. What low cost additional features would you like in a new Radio???
  17. Want to turn off Trainer switch
  18. TX LONG TERM BATTERY STORAGE
  19. Stiff Tx antenna
  20. A couple radio questions regarding JR Tx and GWS flight pack.
  21. Futaba S3305?
  22. Better digital transmissions?
  23. Inflight Glitching- Due to Antenna Routing
  24. Is there a way to activate expo on 6xa?
  25. Optic 6 in stock?
  26. Servo Power
  27. how to name a model in futaba 7chp
  28. Question for JR 10X radio owners
  29. Royal Evo throttle lock?
  30. Hitec Servos futaba control arms
  31. triple rates on futaba 9cap
  32. Hitec eclipse, how to change frequencies?
  33. Repairing 5925 servo wire
  34. Radio Choice
  35. JR X-378 Program Flaps for Dauntless
  36. Help me find a reciever.
  37. Graupner MX-22
  38. JR 8103
  39. Futaba 3305 & Battery question
  40. Airtronics Tx with Cirrus MRX-4 Rx
  41. Compatible radio with Chinese Dragonfly Helicopter
  42. Futaba "G" connectors, can I update them to "J" connectors?
  43. Did i just kill my servo??????
  44. Futaba FP-T7UAFS radio
  45. hitec optic 6
  46. Antenna Strain Relief - Do they work???
  47. Where to get plastic connectors to swap old Airtronics to Z?
  48. Buddy box mode 1
  49. Weird Radio Glitches?
  50. Hitec HS-805BB+ 1/4 Scale Servo
  51. Hitec 5925 (et al.) servo boot up time
  52. How long can a radio last?
  53. tower vs futaba
  54. Simple Antenna Routing
  55. Finally!! 8U/9C synthetic module due out..
  56. Futaba 6EXA problems with ailerons.
  57. HITEC Rx twitching
  58. Cleaning your TX? What is the best way?
  59. New Futaba 9CAPS Super!!!!
  60. 9 Cap Transmitter Modules
  61. Futaba 9C dimensions?
  62. Right hand throttle or left hand throttle?
  63. Multiplex V2 programmer
  64. Elevon Gyro
  65. Anyone has a Futaba 4vf circuit board chart?
  66. SERVO CONNECTOR DILEMMA
  67. Futaba and JR compatable?
  68. JR 10X radio problems (brand new!!!)
  69. Futaba 8 channel RX...only 8 slots.
  70. Futaba 9CAF or JR XP8103DT
  71. JR MAX 6
  72. Xmitter Repair
  73. futaba 7cap transmitter
  74. Longer Lasting TX Battery???
  75. Metal Spring at end of antenna???
  76. Reciver Antenna Cut
  77. Speculations on JR's answer to 14mz?
  78. Replacement M8 Wheel
  79. Servo Twitch
  80. Extensions with a choke.
  81. Servos for Funtana 40 & YS-63S?
  82. Buddy Link Between Futaba and JR
  83. Futaba T7CAP Timer: Doesn't seem to work???
  84. Futaba R149DP Problems
  85. 4.8 or 6.0 volts Rx packs
  86. NEW FUTABA T14MZ!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  87. PROGRAMING JR8103
  88. radio problems
  89. JR PCM9X Problem
  90. Futaba 3PK Crystal Question
  91. The one that doesn't exist...
  92. Servos for Super Cub
  93. Bad crystal or switch....help!!!
  94. JR 10X Transmitter Battery - Whoa!
  95. Crystal lifespan
  96. Evo 9 Multiplex radio
  97. Programming 9C to activate 2 retract servos
  98. Rubber Duck Antenna on a JR?
  99. Radio's on Ham Frequencies
  100. ParkZone Question
  101. Will the Futaba 7C Transmitter Work with a JR R700 Mini PPM 7Ch Rx?
  102. Royal evo flap programming!!!!! help :(
  103. Sullivan Genesys System
  104. Problem with Futaba 9ZAPWC transmiter
  105. single or dual conversion
  106. Problem with Futaba 9ZAP transmiter
  107. Crystal Compatibility
  108. hitec pcm to futaba pcm
  109. Radio set up for a 60 size ultra stick?
  110. JR Datasafe
  111. *Airtronics VG6000 flap trouble*
  112. JR 9303 - First Impressions.....
  113. Cirrus Radio change crystal from 27 to 72 Mhz
  114. Fm Crystal in AM Receiver
  115. PROBLEM WITH JR8411 SERVO SETUP
  116. Futaba Attack-4 with FP-R114H Receiver
  117. antenna length
  118. hitec dcx dual converation receiver what crystals?
  119. Old Cox/Sanwa radio safety??
  120. Are JR Match boxes reliable and consistant?
  121. JR 10x Kill Switch
  122. Can you mix digital servos with anolog servos and a digital receiver
  123. 8103 LCD display problem
  124. Can Futuba 9C be cycled
  125. JR XP9303 Radio
  126. Yaesu VX-5 is also a great RC scanner
  127. Setting Trim to a knob--anyway to do it?
  128. 10 SX Airplane Manual
  129. JR 9303 Data Transfer Question
  130. Rudder to elevator mix question
  131. JR XF622 Question
  132. Anyone with news about Radio South ?
  133. AM to FM conversion?
  134. No Mounting Hardware with Futabe Digital Servos?
  135. What's The Difference between PCM and PPM?
  136. the best price on servos?
  137. JR XP 642-special setting
  138. radio question
  139. Fuel Leak In Servos
  140. Help Xtal Swap Site/club
  141. RC Interface
  142. Good radio for scale planes???
  143. how far might a radio work
  144. Servo overshoots center and wags its way back back to center...
  145. Please enlighten me what is "failsafe"
  146. Looking for JR MAX-66 ADT user manual
  147. R138DP vs. R148DP Receiver
  148. Repairing antennas.
  149. radio glitching
  150. retract servo travel limit
  151. Airtronics Synthesized Transmitter Problem
  152. Where to find Hitec Plugs???
  153. 6 channel radio pick?
  154. Radio/receiver campatibility
  155. Futaba 7CAP Tx Frequency
  156. Standard Servo vs. Digital Servo
  157. I killed my 8103
  158. Hitec 5995?
  159. 72mhz AM tx with 75mhz crystal
  160. Futaba 5101 servo
  161. Range Check Problems
  162. JR 8103 AND NEGATIVE DIFFERENTIAL
  163. Another Newbie Question
  164. New JR Syn Pro Radio Issue????
  165. How many channels for flaps?
  166. Futaba 7cap problem
  167. 1st radio - JR F500 opinions?
  168. EMCOTEC DPSI TWIN
  169. FP-T7fgk Trainer Cord Question
  170. expo
  171. Recommendation for 1st Radio
  172. Problems with Ripmax service centre
  173. JR8103 PCM RF Module
  174. travel throws on UCD .46
  175. Futaba 8UAF Failsafe
  176. Radio Age
  177. 9CAP dual elevator setup?
  178. New JR XP9303 9-Channel Radio!!
  179. Hitec 5945 periodic twitch
  180. how much for a new reciever?
  181. Futaba S 3003 Servo Flutter???
  182. Returning to RC flying, radio questions.
  183. JR PROPO Century VII ????
  184. JR 9303 - Finally!!!
  185. Utilizing 3rd channel for own uses
  186. problem with servos
  187. Newbie
  188. Clicker on 7c
  189. TX Antenna Broken
  190. Futaba 6EXA / Shift
  191. Ace RC Mix Master
  192. JR XF421EX Flaperon
  193. Airtronics RD 6000 sport
  194. New technology Radio Group forming
  195. GWS Servos
  196. Futaba 3PM
  197. These new servo connectors with built in CLIPS ??
  198. *** need help jr racing xr3
  199. Training Mode on Futaba 8U Super
  200. older Airtronics servos and Fut PCM
  201. Hitec Flash 5 Memory Battery
  202. JR 9x (9303) is here!
  203. Aitronics Avenger, opinions needed
  204. flight times with 7C rx & digital servos
  205. 9C + hitec synthesized module
  206. Have you noticed an increase in RF INTERFERANCE (RFI) at your field lately?
  207. 9C Question
  208. Torque/Speed Recommendations for Plane...
  209. Replacing 9C battery ?
  210. Any Experience with GWS S03TXF High Torque Servos?
  211. ServoCity
  212. What Futaba rx to do dual elevators on separate channels?
  213. evo shift select now available
  214. what does the precision really mean on futaba servos?
  215. Dumb Transmitter Battery Question
  216. programming futaba 9c
  217. questionable Receiver
  218. Futaba 9 Channel radio's
  219. Universal Radio, from car to Heli
  220. Evo Programming Help please
  221. pcm reciever
  222. Reciever Antenna HELP!!!!!!!!!!!!!!
  223. Rx Channels
  224. Ann-Marie Cross and the Futaba 9Z**
  225. 9ZWCII Delete Model (Primary Condition)
  226. Futaba 9C Modules - Where to buy?
  227. 2 Receiver Batteries???
  228. Dropped radio
  229. futaba 7c
  230. GWS R6N Range
  231. Airtronics RD6000 reset
  232. HI-TEC channels different than FUTABA rx ?
  233. Expert 7 channel Transmiter
  234. Best place to purchase JR 10X Air
  235. mc-24 switches
  236. servo reverser
  237. HAM 6 Meter
  238. 9Z master reset
  239. frequencies & europe?
  240. If you had the choice, 10SXII or 9CAF ?
  241. Good TX for plane or heli?
  242. Coreless vs. Digital Analog ?
  243. anything wrong with buying a used transmitter?
  244. replace battery 9ZAP
  245. Airtronics Tx W/ Futaba Rx
  246. Haunted, chattering and going nuts HELP!!!!
  247. Servo Braking
  248. Arms for 8611
  249. what size pack do I need for rx
  250. Best $300 value?
