PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 [58] 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. wanted tracker II
  2. DSC and Flight Battery
  3. Jr 8411 servos versus Futaba servos
  4. Futaba 9C Syn Module-Post Pulled from "Futaba Support" Forum
  5. v-tail and jr xp783
  6. Transmitter pack charging?
  7. PCM 9X Flaps ! PLease Help ...
  8. Futaba receiver model numbers?
  9. Need help!! My receiver was on smoke!!!
  10. R955 receiver
  11. Multiple batteries for lots of servo's
  12. opposite servos
  13. Flaperons for Futaba 6EXA radio
  14. Receiver needed for a Radio I bought
  15. Futaba R309DPS receiver discontinued?
  16. Hitec Optic 6
  17. Crystal swap questions
  18. Mixing elevator halves w/ JR Tx
  19. JR XP642 Hi/Low Rates Different Servo Center
  20. Second radio for plain
  21. Can this radio be upgraded?
  22. Cystals
  23. Airtronics/Sanwa RD8000 Programming question
  24. MANUAL FUTABA FP-9ZAP
  25. Futaba 7CAP Sub Trim
  26. HELP - Crash Landing in a Pool!!!
  27. Delete, sorry
  28. Hitec Karbonite
  29. Benefits of a 7th channel
  30. Please Help me with this...
  31. 3-pole Digital -vs- Analog Coreless
  32. 9Z Set-up for Crow...
  33. where to buy female pins
  34. Multiplex cable
  35. antenna
  36. RE Synth NO problems at all!!
  37. flight packs
  38. Futaba S3010 servo
  39. 4721 JR servo failyer
  40. DAD Interceptor 2000 & Relay Servos
  41. 9C Mixing Question- Double Vision Biplane
  42. 9C, slight confusion, help...
  43. Question of Law - HELP!
  44. OLD JR 10X password
  45. Multiplex servos
  46. Servo arm screws
  47. EX-10 Helios Manual Needed
  48. Just switched from Futaba to JR 10x....help!
  49. multiplex evo 9
  50. JR Buddy Box
  51. Servo Arms/ Tiller? Where?
  52. Changing TX crystal
  53. looking for TX stand/support, not H9
  54. Programmer for Digital Servos
  55. Futaba 9C losing trim memory? WTH(eck)?
  56. Really Stupid Idea
  57. Receivers, Receivers.....???
  58. Metal arms for Futaba s9153
  59. wierd stuff happening to my radio/electrics
  60. Does anyone have Hitec HS6635 servos yet?
  61. Question about dual elevator servos - slight problem...
  62. radio compatibility
  63. Investing in the RC community
  64. Info. needed on old tower hobbies system 500-gold series
  65. Charging question on Futaba 7UAF
  66. 8103 heli related question
  67. 3 amp fuse for jr Radio
  68. Airtronics crystal in Hitec Rx - will it work?
  69. futaba 9c airbrake mix
  70. New Futaba 3151 Digital Sport Servo...
  71. Futaba 9C (tx&rx Only) Cheapest place to buy
  72. Futaba Throttle Channel Not Working
  73. Glitching!
  74. Futaba Sticks, made by the devil?
  75. Airtronics/Futaba
  76. help setting up a ultra stick with futaba 7ca
  77. Changing TX battery in my Futaba T6XAS
  78. Glitching Hitec Feather Rx
  79. Can it be done?
  80. futaba 9ca or 9ch?
  81. Radio endorsements - Are they fair?
  82. Change from 4.8v to 6v
  83. can I use a JR xp6102 with my nexstar that has futaba rx
  84. Difference between Futaba 7CAP & 7CAF ?
  85. non ballbearing servos
  86. Hitec HS225MG -- any good?
  87. Radio Retailer's ( which one will seperate)?
  88. Electrodynamics UltraSwitch II...
  89. 5945 for 5925
  90. Shorts antenas for indoor flying ???
  91. JR XP783A Manual
  92. Royal Evo Mix help please.
  93. 8103 throttle curve setup
  94. Futaba TX and Hitec RX in PCM?
  95. Programming the Futaba CAP7
  96. Futaba or JR Equivelent Servos
  97. Question on JR-Futaba buddy cord
  98. stripped hs 81mg need stronger
  99. JR 9011 SERVO - ACTUAL PHYSICAL SIZE ??
  100. airtronics vg6dr
  101. I need help with this EVO programming challenge
  102. What recivers can be used with a JR X-3810?
  103. Hitec RX with JR TX
  104. jitters
  105. Servo lag
  106. Hitec price increase?
  107. Module for Futaba FP-T5UAF
  108. Module for Futaba FP-T5UAF?
  109. What Servos Are U Using in GP Christen Eagle II
  110. HS-5475 Servo Gears Stripping in Normal Flight
  111. Futaba 9c program question
  112. J R Data save
  113. Interior installation of antenna in an Astro Hog???
  114. Servo Extensions
  115. Radio Range Problems?
  116. Rx antenna + carbon = bad things?
  117. Airtonics RD6000? Any other suggestions!?
  118. Digital Servo Burn In?
  119. XM Satalite Radio and Pcm
  120. 9c Tranmitter module
  121. Futaba 9C
  122. GWS Servos causing major problems
  123. Which Servo ismost reliable
  124. Antenna inside foam plane ok ?
  125. locking servo position (?)
  126. Shopping for a JR XP6102...is this a good deal?
  127. Servo question
  128. Where Can I buy A JR TX Module?
  129. Bench running Servos
  130. futaba 8 channel
  131. 6axe futaba settings for trainer
  132. Receiver matching
  133. Servo Reverser
  134. Servo Tray for Hitec DS5xxx servos?
  135. Waterproof servo ?
  136. Futaba 6EXA
  137. GY401 Gyro 5 cell pack
  138. Need help with Receiver measurements! Please READ
  139. Old Newbee with radio question
  140. Digital Servos?
  141. Fast servos
  142. PCM 9X user's guide
  143. crystal swapping
  144. S148 METAL GEARS?
  145. rc transmitter/reciver
  146. Can I Y-harness rudder/steering servo into Rx?
  147. ERRATIC CONTROL
  148. SRX-M8 Receivers?
  149. Looking for some good 3-channel radios
  150. Confused, need advice
  151. JR receiver question
  152. Servo Question??
  153. 10X Module swap from XP8103 Posibile?
  154. crystals question
  155. JR 10X and Trace Rate?
  156. New Futaba won't work
  157. New Futaba won't work
  158. Servo info??????
  159. Frequency table.
  160. PCM 9X = MX 22 ??
  161. Fut 7CAP another dual elev ?
  162. Problem with charging the Futaba T6XA Transmitter
  163. servo extension wiring
  164. Multiplex fimrware update
  165. A dual Rate Question
  166. 10X Heli to fly airplanes!! Is it posibile???
  167. How to activate Flaperons on the Futaba 9Z
  168. Berg 5 DSP-II receiver and sticky antenna problem
  169. Expo?
  170. Extra Channels in Radios
  171. GWS/Mini Servos
  172. Icom IC-R5 Frequency Scanner Help!
  173. JR Travel Adjust Problem
  174. Futaba trainer cord compatibility?
  175. Throttle Elevator Mixing
  176. What fool designed these servos?
  177. Y connector wiring
  178. Seeking info about futaba's 7C
  179. JR XF421
  180. 9cap question
  181. Newb R/C question
  182. FUTABA 8U question
  183. 9C top switch closeness
  184. Are Hitec Feather RX's reliable???
  185. Any news on Multiplex Royal Evo software?
  186. Channel 9 on the 9C and 9Z
  187. Servo Jitter
  188. Upgrade or Replacement for Aitronics Stylus?
  189. matching servo's
  190. Airtronics Buddy Box
  191. Radio gear (tiny stuff)
  192. Need info on KRAFT RX
  193. RD6000 Not Transmitting
  194. SO3T
  195. New RD8000 - Have questions
  196. Centered servo current drain
  197. Futaba Manuals
  198. ANYONE STILL FLYING SINGLE STICK
  199. HitecĀ“s plug fits to Futaba?
  200. HiTec Spectra Module getting hot
  201. Futaba 9z mix problem
  202. upgrading my 4ch radio?
  203. Question on mounting FMA Co-Pilot
  204. dishing out 1000 $ + for a decent Tx?
  205. JR, XF622 question,,,
  206. Futaba BB upgrade Kit for S148 Servos?
  207. Backup TX for my 9CHP
  208. Cirrus contact info
  209. which Futaba 9 channel for me?
  210. ROBBE FC-18 Where Can I Buy One??
  211. Ofna fail safe question
  212. Low to High rate changes trim of elevator
  213. Multiplex Royal EVO Transmitter
  214. Negative shift Rx, JR Servos
  215. JR PCM Failsafe question
  216. Futaba 7C LCD craps out
  217. They All Failed At The Same Time????
  218. Where do I find a schematic for the Futaba 4 ch TX?
  219. Servo oscillates!!!!
  220. PCM
  221. Servo Torque Calculator
  222. 7C / TME Simple Smoke Pump
  223. Ferrite bead filters...when and where????
  224. Dual Conversion crystal PPM Rx
  225. Strange Reciever Problem
  226. crystals
  227. Expert SL571 Servo usage
  228. Help on radio system (newbie)
  229. Futaba 7CAP dual elevator servos
  230. GWS corless S19 Vs S3050 Vs HS5475HB
  231. Airtronics RADIENT RT6P
  232. battery connectors
  233. Olympic games and r/c flying
  234. 2 1:4 servos help?
  235. How to Mix Dual Elevator Servos with the 9X
  236. 9C craps out after 12 flights
  237. JR 8103 VS. Futaba 9C
  238. Is this single-conv rx safe to use in place of a dual?
  239. receivers
  240. When is it time to recharge?
  241. Servo wabble
  242. T6Exas Question
  243. GREAT price on a basic 4 channel system
  244. Best Mini servo, Best price
  245. does anyone work on ace radios anymore?
  246. 9C or RD8000
  247. Hitec HS-645MG
  248. JR Radio Question: PPM vs. PCM
  249. Trim after switching Servos
  250. How long can a servo survive.
