PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 [59] 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. I have a killer question
  2. 6EXA / Expert Reciever problem
  3. JR Trainer Cord Polarity
  4. 2 for 1
  5. Robbe Promars TX
  6. hitec receiver not compatible with 9C?
  7. Old or broken Servo Modification
  8. Futaba 8UAPS or 8UAFS
  9. 8103 cut programming
  10. Please help me choose
  11. is this servo eny good?
  12. servo info???
  13. Futaba 7CAP
  14. Splicing servo wire via solder over pre-made extensions.
  15. resetting fut 9 cap
  16. GYRO info
  17. Fatuba 6XAs help
  18. Crystal switch?
  19. Sneak Peak at new Hitec servo
  20. JR
  21. newbie and need help
  22. How do I clean a coreless servo?
  23. Century VII FM Transmitter found
  24. Duralites. Need info.
  25. transmitters
  26. back in to RC and i need help
  27. Wondering if companys new bus radio system is causing my interference?
  28. Crystals
  29. FMA Co-Pilot
  30. Futaba 7CAF 7-Channel Computer Radio
  31. link for JR 9x manual
  32. Computer vs standard transmitter...
  33. smoke system setup with Futaba 9C
  34. Hitec HS-635HB High Torque Servo
  35. JR Radio Frequency Crystal Change
  36. compatability issues??
  37. webra nano 6
  38. 10x or 9z???
  39. JR 8103 programming
  40. Re: Sources of radio interference??
  41. how are the cheap microservos on auction sites?
  42. Mode change, old Airtronics
  43. 9 C Help
  44. HS635 gear set?
  45. Frequency to race cousin radio shack
  46. new JR radio?
  47. JR servos connectors?
  48. Proximity servo to CD iginition module; dual rudder servos humm?
  49. 10X touch screen issues
  50. Servo cord config
  51. HELP! Futaba 4 ch sport? going crazy...
  52. Has anybody ordered from ....
  53. Servo no voltage load
  54. Quatro?
  55. Gas Type Engine Radio Interference
  56. 6 meter receiver
  57. Antenna length
  58. Channels 12,13,14 ?
  59. Audio lost plane beacon - locator, finder
  60. digital trims
  61. Newbie Radio Questions
  62. Futaba 7CAP question
  63. Servo Horn Screws for Hitec 5475
  64. Need help on charging TX battery
  65. JR Metal Geared Servo Screw
  66. JR radio 3810
  67. Opinions on Supertec Servos?
  68. SANWA RD8000 SUPER SERVICE MODE
  69. HS 55 for throttle?
  70. Futaba Servo to JR reciever
  71. Futaba 6EXA Tx& Hitec RD3600 Rx
  72. Jr 8103 vs Jr 6102
  73. Futaba C7 computer radio
  74. I need pistol radio for mammoth
  75. Are Hitec and Futaba compatible when it come to crystal?
  76. JR 8611 users feedback
  77. Looking for a Futaba 3PM user manual link
  78. Older Futaba Radio
  79. radio help?
  80. GLITCHING!!!
  81. JR and Airtronics radio equipment campatibility
  82. Some newbi question about servos and recivers
  83. TS-35 same as HS-225?
  84. HiTec HS-56HD Feather Sub Micro Servo?
  85. Connecting the 4 ail servos of GP Pitts
  86. Battery port in older Futaba type receivers
  87. Futaba 7C Trainer function not working
  88. Do I need to reprogram my 5645
  89. Some GOOD news!!
  90. Changing Rx channel
  91. 4 to 5 channel?
  92. NEED HELP RECIVER ANTENNA
  93. Best Price on a 9C
  94. Odd radio glitch, please help...
  95. 9Z WC2 Book????
  96. JR XP783 - Using 'Crow' in Acro Mode
  97. ARRGGHHHH !!! Stripped servo screw on my Hitec-5945
  98. JR 783 quit working Which radio to replace it?
  99. Problem w/HFP-10 Programmer, Help!
  100. Driving me Nuts !!!!!
  101. Moving into PCM question concerning crystal's
  102. Range Test question
  103. RD8000 ?
  104. Futaba Computer 6AX
  105. Let me get this straight ! [8|]
  106. 9Zap Alarm Question
  107. Servos twitching, T9CHP / receiver compatablility?
  108. New Forums needed for end-user Support of Manufaturers' Radios/Products?
  109. Hitec Eclipse or Futaba 7C
  110. Servo flutter
  111. Futaba 9zap question
  112. Sanwa Tx and Rx questions ????
  113. GWS Receiver repair
  114. Sanwa Error
  115. JR 9X Coming to U.S.?
  116. Hi Tech receiver & other servo brands
  117. Newbie pulled newbie stunt, asking newbie question
  118. Getting Hit Alot!!!!!!!!!!!!
  119. JR 10X help
  120. wall power for tx w/ sim
  121. EVO 12 and Reflex XTR
  122. FEEDBACK ON JR911 SERVOS
  123. Channel Problems
  124. Which Servo?
  125. Help Crashed into the sea
  126. Mixing Servos
  127. Hitech radios?
  128. Buddy Box for Hitec Eclipse 7 w/ FM rx
  129. Ebay Auction, is it worth it?
  130. Airtronics Delta wing programming
  131. HITEC HS5245's - ANY GOOD ??
  132. Servo torque conversion?
  133. servo torque
  134. Hitec 5955 servo
  135. No power, any ideas?
  136. Where to buy a new Hitec Eclipse 7
  137. Hitec transmitter crystals
  138. 8u transmitter module in 9c?
  139. a reciver without servos?
  140. Servo Extensions
  141. DC-DC converter
  142. 9VAP Mixing
  143. Trim expo mixers a.s.o.: Understand visually
  144. 9c questions
  145. GWS pico rx help needed
  146. Futaba 9Z or JR PCM 10X?
  147. 6 channel transmitters
  148. interference help
  149. question about servo leads, buffers, interference
  150. Telephone Company Interference
  151. HELP! Old Skool Heli Radio Gear
  152. website JR propo
  153. Has anyone tried PCM and PA-2 Failsafe.
  154. twin throttle servo question
  155. Hitec Digitals
  156. Futaba 8 chan R/X- heads up
  157. HS 625MG a good servo?
  158. Lost my RX, then it came back.
  159. Worm Gear Drive Servo
  160. PowerBox Champion 24/40
  161. Graupner MC 24 English manual
  162. How REMOVE Futaba Conquest XMIT on/off switch
  163. 27.255 AM Freq
  164. I need suggestions
  165. Nextel interference?
  166. what transmitter has independent servo controls
  167. How can I enhance my signal?
  168. Futaba S3010
  169. 'Sound-check' for glitch causing power supply
  170. Torque requirement
  171. Photos of Sanwa RD8000
  172. JR Frequency Problems?????
  173. indecision on servo's...
  174. Caliber 3ps
  175. Servo question.
  176. 1024 Resolution
  177. Need to find a radio servo
  178. Broken Rx Antenna wire. How do I fix?
  179. GWS servos any problems??
  180. Is it possible for a defective servo to cause a receiver to go defective?
  181. Best price on 9CAP transmitter only????
  182. multiplex cockpit MM 2.3 upgrade... i need a manuel or osme help to do CP
  183. Mixing receiver and transmitter channels
  184. Changing a Radio FREQ
  185. Ultra Stick & JR 421fx
  186. 6 ch with micro flt pack?
  187. JR/Airtronics servo compatibility
  188. basic information about raido control
  189. Reveiver causing servos to twitch?
  190. 9C mixing question
  191. Multiplex Profi 4000 versus Royal Evo 12
  192. RD6000 throttle/rudder Question
  193. 6XA inverted heli setup
  194. Flaps [edited]
  195. gears for Fut 9302
  196. Check this deal out!
  197. ANYONE HAVE THE GWS RECEIVER 8CH?
  198. jr radio what wires do what?
  199. Making your own extensions question/need help
  200. Airtronics Throttle stick Ratchet
  201. Have you had this problem?
  202. Rubber Whip Antenna for 8UAFS
  203. JR 8411 to Futaba receiver??
  204. High-torque servo
  205. Where to get GOOD shrink tubing
  206. 9C Mixing question
  207. Screen contrast adjustment on 9C
  208. Electric HT wires interference with RC signal
  209. s3050 servo
  210. OK, I need a TRUE soldering expert here...
  211. help me price my Tx
  212. Still confused about flaperons
  213. Help me pick out a new radio....
  214. XP6102 troubles
  215. Frequency scanner
  216. Need help with TX6as
  217. feedback on MULTIPLEX ROYAL EVO transmitter!
  218. New Radio, need help (Hitec/Futaba/JR/Airtronics?)
  219. JR 783 and 8103 Modules
  220. Polk Seeker II
  221. Old Airtronics trainer cord?
  222. How to RAIN PROOF a transmitter unit!
  223. LOOKING FOR JR 10SX ANTENNA & MANUAL
  224. 401 gyros on 3D plane
  225. Airtronics/Futaba servos??help
  226. Using JR servos with Futaba/Hitech receivers
  227. 6XA lost channel?
  228. Futaba 7CAP Changing Frequency , Band , change 72MHZ 40MHZ
  229. Heli Servos?
  230. futaba T6xas
  231. Futaba 6xa setup
  232. Question about using Deans Connectors...
  233. jr DZ8450
  234. JR 9X battery question.
  235. Setting up Trainer on Futaba 7C
  236. FMA recievers Tracker II transmitter
  237. Micro18 FUTABA OEM BRAND servo
  238. Can you change trim without changing the end point on 9C?
  239. emergency help needed tonight 5375 top gear change
  240. Futaba GY - 240 Gyro ?
  241. Futaba 6EXA - Flap knob reversed direction
  242. Futabas' 7C Instructions Manual
  243. 4.8v receiver 6.0v servos
  244. Who has experience w/ this switch?
  245. Hi Tec servo jitters
  246. Futaba 3010 servos and ni-cads
  247. A few questions from a beginner
  248. Programming 9Z
  249. Will Futaba wake up?
  250. Futaba 6XA dual rate problem
